Problems with the new VW Beetle?
I can say I'm very satisfied with Volkswagen's after sale service. They stand by their product.
I just hope that replacing the airbag control unit will solve the problem for good, as I read that it's wiring is being replaced on another car. I will keep you posted.
As for the battery going down, my car would often require an extra turn of the ignition key to start up - and it's an easy 2.0L gas - until one day when it wouldn't start at all. This is when they found the original battery to be dead and replaced it (well under warranty). I haven't had any problems since and my worries the the car was leaking power turned out to be unfounded.
Please understand that since this is our Maintenance and Repair Conference, it is only natural that a topic here would be focused only on problems.
Have you visited our Hatchback conference? Check out this link to one of the topics there for a more balanced perspective:
New Beetle News (Topic #179)
Good luck!
Pat
Thanks much for shared real world experiences.
I would like the same answer as gozing2, is the TDI engine showing oil problems or is it just the gas engines?
As far as riding to low. I can't comment. I replaced a Ford Aerostar with the beetle. Everything seems too low.
However, a day later my son decided to see which would win a telephone pole or the beetle. Neigher one did too well. I don't think I am going to need to worry about the oil level in that car. Neither one of the passengers were hurt. That does say something about the VW BEETLE
I don't have any electrical problems, no problems with the sunroof(noise is to be expected when you open it all the way),the car has the power I want-it accelerates pretty fast,ummm tires are fine, ummm the paint looks good ahhhh I can't think of anything else.
The only complaint I have is have is having to get out of the car Oh and people stop me everyday and ask me about my car when I'm in a rush hehehe j/k I love that!!
Emersongs: I have that humming noise too when I accelerate! Someone told me it does that when it changes gears??! I don't know if thats true or not.
Sorry that you guys and gals are having problems with your bugs Take care all!
ChrisMar
2001 CyberGreen NB GLX 1.8T
1. Window came off track the first night.
2. Taillight was leaking, needed to be replaced.
3. Silver Emergency Brake button came off.
4. 5-Speed plate came off of gear shifter.(twice)
5. Oxygen sensor blew out, needed replacement.
6. Euro-Directional signal came off.
7. Window switch had to be replaced 2 times.
8. Passenger side door lock switch cracked.
9. Stereo wires shorted stereo.
10. Oil plug fell out. (This was probably the dealership's fault.)
11. Both low-beam headlamps blew at same time, costing me $85.00
That is all I can think of without my records in front of me. This has all been within 2 years. I have expired my warranty. I can honestly say, I will never own another New Beetle, or a VW ever again. I am too afraid of what the next problem will be, and how much it costs me.
If you have experienced any of the horrors that I have, I know your pain. Thanks for letting me vent, and proclaim my opinions of the car. I love the car, just not the many problems I have had.
11.
of course my old beetle , the first one was only $10 bucks, an old fixer-upper
Later, from North of the Lake. brucejan
1) Rear Defogger Broken
2) Driver's side external mirror control knob broken
3) Passenger window switch TWICE
4) Auxiliary power outlet inoperable
5) Tape player replaced
6) Both vanity mirror lights under sunvisors not working
7) Engine control module replaced
8) Replaced heated oxygen sensor TWICE
9) Replaced mass airflow sensor
10) Temperature control switch broken
11) Emergency brake button cover
12) Plate on gearshifter broken off
13) Both headlights needed replacing within one week of each other
14) Passenger window motor had to be replaced
15) Glove box door broken ($367.00 Repair)
16) This car has mysteriously stalled while cruising on the HIGHWAY
17) This car knocks like crazy, I use high octane gas
18) The oil is always low
P.S. I'm sure there are some other problems, however I am going by memory. Please if you ever thought of getting one of these cars, please just think again, I would not wish this on anyone except my mother in law.
Other than that my NB has been problem free since I bought it in April of 99'.
Well good luck in our decision
See Ya from North of the Lake.
brucejan
Let me list the ways . . .
1. Comfort control module on the circuit board was burned and melted which shorted the battery - this was the final straw for me leaving me stranded in a bad part of town on a Friday night.
2. Warped door panel
3. Drivers door was installed incorrectly causing a loud vibrating noise. Once this was fixed I was told due to the large door and the weight of it I would need to come in periodically to have it tightened.
4. Fuel system gauge was not properly calibrated
5. Right front turn signal replaced due to moisture build up
6. Vibration in car when window open/cracked
7. Window off track
8. Rear hatch would not open from the inside
9. Brake lights on all the time-they had to readjust the switch and replace if it happened again
10. Drivers side window switch replaced
11. Passenger seat lever would not not allow seat to tilt
12. Replacement of dashboard-I was told they are faulty.
13. When the nose of the car is parked down hill about a 6-7% grade or less it will not start. It has to be rolled to level ground then it will start. The dealer has never been able to duplicate this and therefore will not check anything out or replace anything. This happens quite often.
14. Sluggish going from reverse to drive and vise versa
15. When going from drive to reverse sometimes it will not go into reverse. You have to shift to park then reverse.
I have read almost all of everyones complaints and I see some definate similarities. A previous gentleman wrote that if everyone would please call VOA or write them then maybe they would start paying more attention to everyones problems. I will say that I have now gotten rid of this nightmarish car and got back into a Honda Civic and am much happier now. I sold my 1995 Civic with 44K miles and paid off to get this darn beetle - stupid me, but a mistake I will never make again! Also, due to the treatment we received at our dealer ship and VOA my boyfriend who is a 6 time VW owner will never buy VW again. I've never been treated such a lack of respect. The dealer is Roseville VW-never buy from them, never buy a VW!
If you call enough (like I did) and file a complaint with the BBB -they may listen. I finally got them to buy back my junky Jetta!!!
Pat
1) headlights burnt out
2)(both) windows broke and wouldnt go up 3 times
3) dashboard bubbled
4)inside door panels peeled
5) engine wouldnt start had to be towed
6) glove box NEVER shut and was taken to be repaired about 5 times
7) alarm constantly not working..going off..not going on..not letting my car start
8) automatic locks in cahoots with the alarm...not letting me in or out at times
9)brakes gringing together...fixed twice..one time soon after leaving dealership ..my tire went flat ...after both being "fixed" it made a rattling sound when i drove
10) its always been a jerky drive most of the time.
11)one time they said the air filter needed to be replaced ..didnt change it a bit
12) driver seat needed to be replaced..wouldnt move..said it was off the track..HOW!!??
13)power steering leak
14) rubber lining aroud doors peeled off
OH!!! and right now my alarm is going off!! gotta go...
over 1000$$ spent despite my warrenty on my 2 year old new beetle
~Starting to get "freaked out"!
