Trouble With Dodge Grand Caravan
after reading every ones problems I am nervous but at least I have an extended warantee.
Two points I would like to get across to everyone is;
The wiper malfunction was the switch. There is a service bulitin and mine was fixed for free. Go to a five star dealership!!! you should have better results.
The other thing is, Stay away from the 96's, It was the first year and had bugs to work out. 97's probably have some too but not as many. My father-in-law has a 99 and it has been flawless.
after reading this post, I think Im going to replace the transmission fluid in mine, for preventative maintainance.
My question is, are these problems indicative of a larger problem? How can all those parts just start leaking?
Also, the brakes grab/pulse when stopping - not every time, but often. The dealer service dept said it was just the ABS working. I suspect that it is more like the ABS not working as I am not slamming on the brakes or anything. Are they overly sensitive in the van due to it's light weight?
Any input on these things would be most helpful to me. Thanks in advance.
Now it seems that the engine is losing oil. No leaks this time. Only blue smoke at start up. My mechanic said the engine was burning about 1 qt per 3k miles or so, but now it appears that it's burning about 4 qts per 2k miles. That's a qt about 500 miles or every 3 weeks. Does anyone know what the tolerance is on burning oil? A qt every 500 miles seems excessive. I could live with a qt every 3k, but not this much. Any possible causes before I start shelling out cash to fix?
If that happens to be what it is, it is a major job, basically the same as a valve job. I did it myself the year both kids were in college because I couldn't afford the $900 the dealer wanted in 1996. Told my wife to shoot me if I did it again although I've put another 70,000 miles on it with no trouble at all from the seals.
Fix is to replace pump and plumbing. (Tends to make loud noise....).
thanks,
Bob D.
Incidentally, I have a 3.0L, not a 3.3. I typed when I last posted.
http://www.allpar.com/fix/trans.html
http://www.allpar.com/fix/trans-testimonials.html
I'm wonder if many of the owners that have experienced transmission problems are actually affected by someone using the wrong fluid type from the get-go. I'd be interested in finding out what the percentages are that this is the case, and in many of these failures, the initial cause of degradation of the unit itself.
Without competent and knowledgable service people in our auto stores, independant shops, quick change oil shops, and even certified dealerships... how do we really know that they used the correct transmission fluid when replacement or topping off is needed? How do we know they are recommending the correct transmission fluid at all? Many people don't stop to question the recommendation, thinking those individuals should know what they're taking about, heck, they work in an auto parts store...
After reading the posts of owners that finally scrutinized the shop or the mechanic that worked on their vehicles, I am now going to take a more active role in finding out was used to replace or add to my transmission. I know there are other things that can cause transmission failure, but this one simple factor seems to be a major player in the difference of a healthy unit or one that will cost big bucks in the longrun.
Just purchased our 1st minivan. 2001 DGC ES 3.8L. New to this forum. Wanted to share some of my finding with other owners. Regards!
As well I am also looking for a company that makes really large moonroofs.
Ian
New cap, rotor, plugs, wires, PCV, vacumn hoses, remove and clean throttle body, replace fuel filter, replace throttle position sensor, (fuel pump checked out and is putting out excellent pressure). Van runs great otherwise and uses very little oil between changes (2K) This problem is hard to fix because there are no codes and it only happens once a day. I plan on replacing the EGR valve this weekend.
Anyone have similar problems? It does not die out. It just hesitates from a stop and shutters on occasion.
Also dodge seems to still have problems with their tranny, Do any of you guys like your van enough to buy it again?
