Leak in power steering suction hose
I have a 2002 Camry LE 2.4L 4-Cyl with about 116,500 miles. I hear a growling noise when I turn the steering wheel to the right or left at very low speed. When the steering is turned, I see some yellowish-green liquid oozing from the "suction hose" that connects the power steering fluid reservoir to the pump.
Is this a kind of leak that can be fixed using Bar's Leaks 1600 High Mileage Power Steering Fluid Repair https://www.walmart.com/ip/seort/16794875 or Rislone High Mileage Steering Stop Whine with Leak Repair 4604 Power Steering Fluid https://www.walmart.com/ip/seort/2426102232.
Are such sealants known to damage to the power steering pump or other parts?
What are your thoughts on this hose set available at carparts.com: Power Steering Hose, Pressure Hose and Return Hose?
Anything to be concerned about?
