Zaino Car Care Experiences
15152545657137
  • bluebeastbluebeast Member Posts: 258
    Tried the washing with Z and drying with the towel, although quite a bit was gone, I could still see the spots when I looked at it from the right angle. The water the golf course uses on the grass must be from a well or lake because I have never had this problem from rain or from washing my car. These spot were VERY white and almost had a little gritty feel to it.
  • pjyoungpjyoung Member Posts: 885
    But some of the golf courses in my neck of the woods are using treated wastewater for watering purposes. I shudder to think of what the "grit" could be ;>)
    Good thing I did not do a taste test......
  • fishxprtfishxprt Member Posts: 21
    I was wondering if claying after Z1 Z2 would remove the Zaino. I called Sal to be sure and he said that it does not remove the Zaino. Good news for those of us who want to keep the " glass like" surface. Where I live, L.A., I can feel the specks coming after about a month, especially on the hood, top, and trunk. It only takes seconds to clay a hood when it is not fully "specked" and the results are, as you all know, amazing.
  • mr_dmr_d Member Posts: 10
    Wet your towel/pad, then ring it out before you put the Zn on it. It makes a world of difference in getting that smooth, thin coat.
    Any comments from you "old timers"?
    Don
  • jocayabyabjocayabyab Member Posts: 8
    An suggestions for a good car duster?
  • hud116222hud116222 Member Posts: 46
    As I posted a while back, I noticed water spots becoming visible as I applied Z-2. These were not visible to the naked eye from any angle. I was very worried, but they magically disappeared after letting the Z-2 dry and wiping off. Maybe another coat of Z-2 bluebeast?
    I took the advice of many on here and got the California Duster. It is great!!! Works very well.
    Zainians, eh, bluebeast? Someone finally named this "cult." LOL
  • homer2000sseihomer2000ssei Member Posts: 159
    Water spots can be very trying. . . try a vinegar and water combo, and if that doesnt remove them all, you can go with almost straight vinegar. Then wash the car.
    Wetting the appicator - a common trick is to spray a little Z6 on the pad - couple of light shots from the spray bottle at the most. I have found that making it too wet works against you, until it starts to dry out a bit.
  • pblevinepblevine Member Posts: 858
    mr_d: home2000 has good advice. Most of us spray a moderate amount of Z6 on the applicator and work it in prior to using it to apply Z2 or Z5. I usually give it two shots on one side of the applicator, work it in a bit, and squeeze an "X" shape of Z2 on the pad.
    The vinegar and water combo also sounds good for water spot removal. It does sound like you've got super spots. Let us know what happens.
  • fastdriverfastdriver Member Posts: 2,273
    I wet my applicator pad with water, wring it out good and then spray some Z6 on it. Then I do the X thing with the Z2 or Z5 whatever I'm using at the time.
    fastdriver
  • mbdrivermbdriver Member Posts: 426
    Silver/light colored cars - I have brilliant silver paint, and my car definitely has that "wet look"! It's been Zaionoed regularly since new last year (not even clayed), and when I look down at the hood, with the garage light shining overhead, it's like looking into a silver pool of water! I really love the Zaino!
    mr_d -- follow the advice from homer2000 and pblevine about spraying a bit of Z-6 on your applicator before squeezing on the "X" of Z-2/Z-5. You'll use less Zaino, and it's application will be easier.
    Regarding the removal of dust, I agree that the California Duster does a great job. And for drying the car after a wash, use the "nozzle removed" trick or the Home Depot nozzle for the final rinse, followed by use of the California Water Blade. You'll find that one towel will be more than sufficient to complete the drying process.
    BTW, I can't understand why anyone would apply Z-6 BEFORE washing a car. Z-6 is a gloss enhancer, and though it chemically complements other Z products, I find it's more effective AFTER a wash or INSTEAD of a wash (assuming no dirt on the finish and all dust removed prior to Z-6ing).
  • squidd99squidd99 Member Posts: 288
    I agree. In my limited experience, but with a zeal to learn about Z and how to best use it, I understand that a car should not be "wiped" with anything, even with a Sal-approved white cotton USA towel, if there is any grit of any kind on the car.
    This includes spraying Z6 and wiping it off, per instructions.
    If a car needs washing, it is because it has visible dirt, and spraying that dirt with Z6 or any other liquid and then wiping it is asking for scratches.
    If in fact the Z6 is a "gloss enhancer," as noted above, a dirty car has no gloss to speak of, (although I have noticed the z finish to shine through a layer of road dust).
    I would think that the proper procedure to deal with a dirty car would be to wash first, dry, and then add a layer of Z6.
    This is what I do (including yesterday) and I think it works fine. I think that a freshly washed (black, new) car with several (5) coats of z5 and z2 looks even better after z6.
    But to put z6 on a dirty car is to ask for swirl and scratch marks from the grit. Z6 is not a quick wash; I don't think there is any such thing, because you really have to float the grit off the finish before you wipe it.
  • tonychrystonychrys Member Posts: 1,310
    Having had time to experiment and use a little logic, figured out the actual properties of Z6.
    I had gotten too much Z3 on my vehicle, and after it dried, was next to impossible to get off. I mean you REALLY had to rub and buff for certain "dried specks" to come off. Same properties as caked on wax.
    Well I thought, let me try some Z6... what the Z6 ended up doing after rubbing on the spots is "melting" the residue that was there and causing it to smear around.
    So Z6 is actually a product "leveller", meaning that when it is applied and wiped off it will "re-melt" the Z layer on the car and smooth it out. That's why a "waxed" car (I'm not talking Z) is so shiny, the abrasive wax knocks down the "peaks" on the paint finish. The more "level" the finish, the greater the light reflectivity.
    For another clue, read the instructions on Z6, it says that once you spray it on, do not let it dry on the car without wiping it off first. Why? Because by just spraying it on and letting it sit there, it'll re-melt the Z finish wherever the little droplets are. All you have to do is then spray on more product and wipe off to "re-level" that area.
    As I have said before, this stuff should be approached scientifically, not like black magic.
    My little attention getter, and No, I don't wash my Z6. Squidd99 and tony are both correct. I now carry a spray bottle with water and a little bit of Z7 Car Wash. First I dust a bit and then spray with Z'Water. After drying, I apply some Z6. The water spray is perfect for getting rid of all sorts of things like bugs, pollen, and assorted objects da'Dirt.
    Only when the car is clean do I then apply Z6. And it IS magic.
    pblevine-
    WHY do you even bother? The doubting Thomas' will never be convinced. Didn't we go through this with that OTHER topic- NO Zaino posts- which I just found again since they switched to this software? ;-))
    I say- let them use what they want. We'll be the ones driving around with our Zaino shine and wet look.
    Sometimes I swear some of these people are the same ones who drove Chris Parrish from this site.
    fastdriver
    I washed my wife's dark blue 98 Taurus and put a coat of Z1 and Z5 on after dinner tonite. It was ready to remove in under 2 hours. No smearing at all, and I was surprised that it took out as many of the "Swirl marks" as it did. I used Z6 afterwards. Definately more noticable on the dark car than a white one. Almost have that "wet look" with just one coat. My wife came out to look at it and said "It's like a mirror". I live in the same city as killakella. Could it be Honda paint or some sort of dealer applied finish that causes his smearing problem. ?
  • lex430lex430 Member Posts: 52
    Not sure why, but I have washed, dry, Z5 the car 3, 4 coats, and I am still seeing tons of swirl marks on my black car, espeically around the trunk, top of back bumper area.., maybe i shouldn't describe it as tons of swirl marks, but they are obvious under light!
    I make sure i wash my towels, and they are clean, and dust free, and same w/ my applicator! what am i missing?
  • ben54ben54 Member Posts: 5
    I'm ready to do serious work on my White SC430. Is there anything I should do, Zaino-wise, on a white car that I wouldn't do on a darker color? ie...product..applications, etc? Open to any suggestions. Thanks
    I just did the suggested steps on my white car. Be forewarned, it's harder than heck to see where you've been on a white car. I was surprised at how light the haze was on my wife's dark blue car. That may be the "hardest" part on white - it's so dog-gone hard to see where you've been. White cars may not obtain that "wet look" that a darker color car will, but it will still shimmer like a diamond, so wear your sunglasses!
  • wayn1wayn1 Member Posts: 69
    I have a golden pearl (white) 2000 Lexus RX300 and that baby shines like no other white vehicle shines in my 36 years of waxing my cars! Zaino IS the best product that i have EVER used. I do have that wet look on my white RX, and everyone comments on it. Oh, i have 5 coats on from last year and this year i now have 2 more and it looks just awesome!
    Hope this helps you when you do your own white vehicles.
  • killakella123killakella123 Member Posts: 52
    I'm glad that it is working so well for you! Perhaps you need to stop by and give me a lesson sometime. I am probably going to try another z-5 tomorrow. And I will attempt to put on the thinnest damn coat of all time to accelerate the drying and avoid the smearing. Anyone else who if having Zaino smearing problems with new Hondas please speak up!
    I have no knowledge of the situation with Honda paint. However, just to give people an idea of how thin to apply Zaino; I have five coats of Z-2 on my Solara. It has an unbelievable shine and gloss to it. My point is, after five coats, I still have OVER half a bottle of Z-2 left. The first coat with the Z-1 was a bit problematic, but after that it has been smooth sailing. Just wet that applicator a bit with Z-6, put a THIN line or an X on it, squeeze to spread it evenly, and just wipe on.
    I wonder if Sal might have had a bad lot of Z5? Stuff like that happens sometime. Maybe the question should be "Anybody buy Z5 around (the date you did) and are you having smearing problems". I've had this bottle of Z5 about 6 months. You might see if Sal would let you return the unused portion in exchange for a new bottle.
  • redsilveradoredsilverado Member Posts: 1,000
    thanks for posting your smearing dilema. not that i am happy to see that you had this problem, but i thought i had the problem as well due to improper application. i have a bottle of Z-5 that really ticked me off from day one. no matter how thin i applied it, same results, smear city. spent more time washing the truck than waxing. finally bought a new bottle of Z-5 to start the process on the wife's new rado, and you guessed it, no smearing.
    killakella123 -
    Just a thought- have you gone into the Honda topic area to ask about the smearing problem with Zaino?
    Like I said before, I have a 2001 Acura(made by Honda) and have had no smearing problems. Of course, I WARNED the dealer NOT to touch the car when it came in- NO wash, NO wax, NO removing the plastic sheets. I figured if there were going to be any swirls or scratches, it would be my fault. I did the clay procedure on the car before using the Zaino products.
    fastdriver
  • emaisonemaison Member Posts: 60
    I Z'd my car this weekend. I was trying to take some mental notes since we had the same smearing problems on our Accords. I washed the car with Z7, used an opened ended hose for the final rinse, and then used a fresh "Royal Velvet Big & Soft" towel to dry. I noticed that when I started to dry the car, no smears, but when I was getting towards the end of drying, I noticed the damp towel did cause some smearing. I let the car dry some more in the sun. I was just going to Z6 it but doing another Z2 was just to tempting. I did the Z2 and let it dry for 2 hours in the direct sun. When I took the Z2 off I did notice some smearing. I was getting pissed. I then applied Z6 (in the direct sun) a little more liberally than I had in the past and that solved 99% of my problems.
    A couple things I did differently than my first applications:
    -Made the Z7 wash a little more concentrated.
    -Gave my towels an extra rinse cycle.
    -Dried my towels in the dryer on 'very dry' setting.
    -Used a very little amount more of Z6.
    Why dont you try to just do a wash (or two) and Z6? See what happens then. I would think if you are still getting smears that means there is still excess Z on the car. The wash might help.
    Even though I have had the smearing problem as well, it has gotten better for me and each additional layer of Z2 I add really makes the car look better. Its looks like glass!
    P.S. I received my Z order (with Z5 of course) around the beginning of May.
  • gibbo01gibbo01 Member Posts: 5
    Fastdriver. i have sent you an email regarding zaino i would appreciate a response either via email or via edmunds. :-)
    Mike
    Lex430: I don't know the answer, but maybe the swirls are at the clear coat level. Take a look. Are the swirls below the Z5 layers? Again, even if the swirl marks are down deep, Z5 "should" help hide them.
    killakella: That Z5 layer still can't be smearing. Maybe pj has a point. See if you can exchange your bottle with a newer one. It can't be the Honda paint. I've got a '98 Honda Coupe, and although I think their paint is terrible, once paint is cured, its cured. Their will be not difference between Z'ing a Honda and Z'ing say a lexus.
    fastdriver: Why do I? I've got no great philisophical reason. Others like Chris Parrish helped me, and besides, its fun.
  • bh0001bh0001 Member Posts: 340
    I have the same problem with my Navy Blue 2001 Impala LS. I didn't let the dealer touch it when it came in and I started with Zaino right from day one. I've had the usual problems with smearing (used too much) but the real annoyance is swirls (not lots, but enough to make it noticeable)!
    I've switched towels (even though the first ones were 100% cotton made in Canada), carefully analyzed my washing pattern, stopped using my California Water Blade, etc, etc. I have 5 coats of Z5 on the car now and I still have swirls that seem to appear from nowhere. VERY annoying. Someone in the Impala group mentioned that they thought the paint on the Impala is the softest they've ever seen so this could be my problem.
    Overall the car looks AWESOME until you catch it in direct sunlight or under a streetlight at night and see the swirls.
    I'd be interested in hearing anyone's suggestions.
    B
    thanks for the tips emaison. I have been washing my towels hot with the extra rinse as well. Are you saying that because you think the zaino residue that is being wiped off with the towels might remain in the towels even after a wash? Sounds like a possibility.
    I didn't end up putting another coat of z-5 on this weekend. I just washed it and used z-6. In doing so, I did notice that all the smears from my previous 2 coats were gone. That made me feel good. If the next coat of z-5 I apply smears again, then I will try getting a new bottle. That z-6 stuff is pretty sweet. The paint doesn't feel all that smooth after a wash until that is used. I don't remember who tried to describe z-6 "melting" and redistributing the zaino coat.. but by what I can feel while I use it, they appear to be right.
    pblevine - you are probably right about it not being the honda paint. I don't see how honda paint could keep zaino from drying more than another paint. I know I had gotten any previous wax off the car with the 2 dawn washes I did before my initial application.
    emaison - I know this is off topic, but have you tinted the windows in your 2001 accord? Does it have those damn speckeled black dots at the top of the back window? If so, did the tint stick to it very well? I had mine done this weekend, and so far I am dissapointed with how it looks up there.
    Unclean towels is definitely a possibilty. I can still smell a slight scent of Z6 on my towels after they come out of the dryer.
    No I dont have tints on my windows. My interior is lighter in color so it doesn't get too hot. Are the speckled black dots that you are reffering to part of the antenna/rear defrost lines?
    No, I don't know what the speckled black dots are for, but lots of cars have them. I suppose they are for some sort of "look". The defrost/antenna lines are below the specks at the top of the window. All I know is that they suck and the tint doesn't look like it is going to stick to them to my liking. Sorry for the off topic post again!
  • cooldude1755cooldude1755 Member Posts: 22
    I've got my Z1,2,5,6,7,& 18 on order for two cars. One is a 2000 Solara the other is a 1990 Honda Accord. The question is, will clay on the Honda be enough to prepare for Z. I only used Nu-Finish on it and haven't polished it for about 2 years. It's garaged alot. My days of neglecting my cars are over! What process is necessary to prep an older car for Z?
  • joe166joe166 Member Posts: 401
    varies a great deal from car to car. Anything you do before you start with the full Z treatment requires you to wash carefully with Dawn to remove the other waxes or polishes and provide the proper base for the best Z finish possible. If the finish is fairly oxidized (dull, crazed, like the car in the nufinish ads in the junkyard), you have to use a POLISH to get the shine back before the polymer coating from Zaino will do any good at all. Use the lightest abrasive possible to avoid removing as much of the clear coat as possible. That would mean using one of several products on the market. See the "other" waxes forum for lots of suggestions. Even NuFinish has some abrasive in it. The heaviest I would go is polishing compound and that would require lots of care that you don't go too hard on it and remove the paint or thin it too much.
    On the other hand, if it is not oxidized, but just doesn't have that deep polish, a clay job and a full Z treatment might be all you need. Try it on a corner of a flat surface (flat surfaces seem to take the worst sun and elements beating of all). Do your clay, clean it and do your z1, etc. If you are satisfied with it, do the rest. If not, you haven't wasted a lot of time. The clay is easier than it sounds. Have fun.
  • daverosedaverose Member Posts: 233
    Polishing glaze would be the first thing to use on oxidized paint if Z1 doesn't take care of it before going to polish, polishing compound, or rubbing compbound. If a NuFinish car has been garaged, it might take isopropyl alcohol to remove the polymer component of NuFinish if Dawn doesn't get the car down to the paint/clearcoat.
    gibbo01-
    Sorry. Let me go check. I don't always use the same browser that my e-mail is attached to. Right now I'm in IE. My mail is with Netscape.
    fastdriver
  • silverbullitsilverbullit Member Posts: 11
    Hi there,
    I have used Zaino in the past and had great results on my other cars but just finished doing my new car and I have smears.
    I am sure it was dry when it was taken off. But even if it wasn't then it must be now, can it still dry after you have tried to remove it IF it wasn't dry to start off with?
    What can I do to get it off, I read something about a clean towel with water? Any suggestions...Thanks everybody?
    Personally, I'd just let it "cure" for another day. You could also (lightly) wash with Z7, dry, and put on another "very thin" layer of Z. BTW, what exactly were you applying: Z1/Z2, Z1/Z5, etc?
    And how much did you use?
  • armtdmarmtdm Member Posts: 2,057
    Do I live in a strange climate in Richmond, VA. My Z2 (these past few weeks) dries in less then 10 minutes, even less in direct sunlight. Doesn't streak,just comes off. If in direct sunlight it comes off much harder, splotchy areas that need more pressure to rub off but drying is not an issue here!
    It depends. Upon: temperature, humidity, altitude, condition of your towels, and wind.
    Some factors, however, can be discounted: position of the moon, odd vs even days, high tides, what you had for breakfast, the Fed Discount Rate, geological fault lines, and the local baseball scores.
    armtdm-
    LOL.... I have the same "luck" here in CT. Usually by the time I am done applying the Zaino- Z2 or Z5, it's dry where I started. If I had to wait HOURS or DAYS for this to dry, that would not work for me. I wish I knew why I don't have a problem. I do not use Zaino if the humidity is 90%. I have used Zaino in the winter, outside, when it's sunny, about 35-40 degrees with the same results.
    I have something new to try on my car, but the weather wasn't cooperating, work was real busy and when it wasn't raining, it was too hot! When I do it, I'll post some pics to see if there is a difference. In the meantime, enjoy these pics and look at the reflections.
    http://albums.photopoint.com/j/ViewPhoto?u=912729&a=13384233&p=50949354&f=0
    fastdriver
  • joebob6joebob6 Member Posts: 239
    I believe the problem is that people don't really understand what is meant by "thin". They apply it thin compared to the way they were used to applying waxes but still not thin enough.
    Another problem seems to be people are using older towels that they used for waxing and are not really clean enough or they use detergents with fabric softeners or fabric softeners when drying the towels. The residue will just smear all over the place. And of course, they believe it is the Zaino polish that is the "problem".
    Again great pics! Ah, the CL-S. Where in CT? My Honda Coupe ('98 EX V6 Emerald Green) also reflects like that. More important to me, the micro speckels in the green sort of glow and give the green a brillant shine with three coats of Z. Before I used Z2, my car simply looked black in direct sunlight.
    Unfortunately, I'm now a daily commuter, and its taking a toll on the car. 'Just came in from lunch, and examined the result of my passing a construction site at high speed this morning. A tiny rock got me right on the right side mirrow cover. Right through the Z, clear coat, and paint. Its only a tiny scratch about the size of a match head. But its there. 'Got out my trusty touch up paint and used a tooth pick to apply about a drop of touch up paint.
    (I am responding to your post as it appears to be directed towards someone like me who has had smearing issues.)
    I fully agree that "thin" is a relative term. I know how much Z I apply. I usually take a clean applicator pad, spray Z6 to dampen, then put a very small amount of Z2 or Z5 on the applicator. Usually two "thin spaghetti" sized lines making an "X". (I usually use even less than that.) All I am trying to accomplish is to see the Z as it goes on and then to apply it completely so that none of the surface gets missed.
    I think you are guessing what people are doing. Everyone here is intelligent and can read prior posts and/or Sal directions. We know that new white 100% cotton towels made in USA are required. We use them. We know that we should wash these towels by themselves, using a detergent like "All" or "Tide", without softeners either with the wash or with the drying cycles. We dont believe Zaino is the "problem" which is why we post here for suggestions and tips. I like my Zaino. I am very happy with it. My car looks beautiful. I just want to see if there is a way to solve my smearing issues.
    Zaino may not be the "problem" but then again there was mention of a defective batch of Z5 in prior posts. So anything is possible.
    Exactly. Well said.
    I too like the results of the products so far, and I'm developing my own techniques to work around some of the issues. But my observations are based on logic and science, so I won't bother posting them here ;-)
    And the mirror reflection of my black Lexus would put all the other photos to shame. Damn, I gotta get a digital camera.
    Also make sure that whatever detergent you use explicitly states: No dyes, No perfumes.
    Detergents with perfumes also can cause smearing problems.
    I am not trying to "attack" anyone with smearing problems. I was not referring to anyone in particular. I am just giving reasons why smearing occurs. The majority of users are not having smearing problems. I am trying to understand what is being done differently by the few that are having problems. The reasons I stated are just what I have seen people do. So yes, I am generalizing about smearing problems.
    Emaison: You state: "Usually two "thin spaghetti" sized lines making an "X"."
    How much surface area does this cover for you?
    The amount you describe would be enough to cover an entire hood of an average sized car...i.e. for cars with a large hood, like a camaro, you might need slightly more.
    When I am finished applying Zaino polish I cannot tell what is done and what was not done just by looking at it. After it has been applied it looks smeary, some areas you can see the smears more than in other areas. Many areas look like they were totally missed. I apply it in a consistent manner panel by panel in the same pattern so that I know I did not miss anything. It is totally unlike waxing where you can easily see what you missed.
    The thing I notice is that when you initially put the z on your applicator, work it in, and then start putting it on your car, it goes on thicker initially than it does once you start needing another squeeze onto the pad. That makes it really hard to not keep putting more and more into the pad to keep the layer even. I don't put more and more on, but I do notice that it goes on thicker when I first start rubbing it on after putting it on the pad. I do the trick of spraying it with z-6 and then working in the "lines" of Z on the pad.. I think next time I will try getting the whole pad wet and wringing it out. Apparently that is what someone posted earlier.
    I've had to apply Z in low light situations and have found a simple way to determine "where I'm At"...so to speak. When I stroke the applicator over the surface, I mentally note my starting point. Ok, I may be off by an inch or so. But my next stroke overlaps the first by more than an inch. The overlapping strokes seem to insure an even and thin spread.
    I too have had some smearing problems when I first started. The first time conditions were wet and cold. The second time, however, was wet and hot. Actually warm. It had been hot but the temperature was dropping quickly. Maybe that rate of change is a factor. I'm not really sure. But I left the car to dry overnight and that did the trick. That and my call to Shirley McClane. Anyway, the result was good and shiny too.
    After I initally put Z2 or Z5 on the applicator I (for lack of a better word) "dot" it on a few places...then as I am going back and forth the applicator will spread these "spots" or "dots" of polish and it will not really be much thicker at the beginning than in the end.
    I have noticed that when I initially put on Z1, I have to go over the first area several times to thin out the layer. For some reason, initially with Z1 there seems to be tiny water spots when it is first applied. I will go over the area a few times and "dot" other areas until it thins out, these water spots are gone, and it starts spreading evenly.
  • scottc8scottc8 Member Posts: 617
    from a new convert. I appreciate all the tips gathered while lurking here the last couple months. Gave my dark metallic green Lincoln LS the whole treatment this past weekend. Three coats of Z-5 and two of Z-2 (a good start, anyway). Followed directions to the letter, and was blessed with very hot, dry weather. Result is far beyond my expectation. Sunday afternoon in a hot garage, wiping off the last coat, I was thinking, "Yeah, looks good, but ANYTHING would look good with all this work put into it." Then I backed it out into the sunlight to take a look. Probably heat and dehydration getting to me but I think I heard a heavenly chorus or something as I gazed upon my glowing car.
    This is the stuff.
