Zaino Car Care Experiences
15758606263137
  • joe166joe166 Member Posts: 401
    I don't think it matters how humid it is in Miami at this time of year. Unless there is dew on the car there is no problem. I have been using Z products here for about two years and if the quantity applied is not too much the product is ALWAYS dry at the front of the car by the time you finish the back, even if you don't do the whole car. For example, if I am only going to do the hood, top and trunk, the hood is dry by the time I have finished applying it to the trunk and then it wipes off all the way back with no problem, no streaking, no delay. Even on smaller areas (I have sometimes done the top section of the sides--about 8 inches deep on my car without doing any other part of the car), the front is ready to be wiped by the time you have applied the back part without streaking. I have just not found any problem with the humidity, probably because of the heat. I always do it in the sun, though.
  • fastdriverfastdriver Member Posts: 2,273
    I have no problem with drying times either. By the time I have the whole car covered, the first part is dry. I also use Z2 in the sun. Z5 should be applied to a "cool" surface. It's the Z6 that I do in the shade. With FL humidity, it might take a little longer to dry, but not much.
    fastdriver
    pblevine-
    Tonight I was at a friend's house working on her PC. I went to my Acura/Zaino movie to show her.
    1. It took forever to download with her 56k modem.
    2. When it started, it FLEW by! Now I know what you were talking about. However, on her 533MHz speed PC, the pics were SMALLER and the words were too?? On my 250MHz PowerMac, the pics are bigger and the words are readable too. It doesn't fly by on my computer. I can understand the speed thing, but I'm puzzled by the smaller size. Can a PC monitor be adjusted for screen resolution too?
    fastdriver
  • darbhdarbh Member Posts: 51
    Pblevine: Thanks for the acknowledgment. Appreciated. Re: chamois. I know that the high-end wax crowd abandoned chamois a while ago. I think they believe that a chamois will remove some of the wax and/or that it will deposit oil on the paint surface. Sal believes that one should use cotton towels. But, clearly you are an experienced person, and observant, so I would assume you have not noticed any draw backs?
    Pjyoung: Yes, one of the benefits of the blower is getting all that hidden water flushed out. I hate doing a full wash and Z job, then two hours later I find water spots on the bumpers, below the door handles and below the gas filler door. Thankfully, they clean up more easily because of the Z. But, the blower prevents the problem from occurring in the first place.
    killakella123 brings up a matter of legitimate concern. How fast does the blower blow and will a high rate of air flow damage the car? Clearly, at a sufficiently high speed it would. Heck, some manufacturing facilities use water to cut solid materials, which it will under high enough pressure.
    Electric blowers produce air speeds of 100 to about 150 mph. Gas blows can get up to around 170 or higher.
    I have heard that someone drove my old LS 400 at top speed for a short while on the way to Las Vegas -- solely (yeah, right) to verify the manufacture's claim that the car would do a 152 mph (it can). [I repeat, I had nothing to do with this reckless exhibition of speed ;) .] The paint remained on the car (but bug impacts become much more dramatic at such speed and, over time, would be damaging, I am sure. However, you are likely to have been arrested before that occurs. I do not think bug impacts would be a problem with the blower, as any bug would have been quite pulverized before being shot out of the blower.
    Now, I think the blower is even safer that the conclusion that the above example would lead to. And, that is because the manufacturers want to be able to promote high blower speeds, so they measure the air speed immediately on exit from the blower nossle. The speed drops dramatically with every inch after exit, so I am not directing 140 mph air at the car.
    So, I think the long and the short of it is that killakella123 is right. The air is usually not going faster than what the front of the car experiences in normal freeway driving.
    Squidd posed some intelligent questions, also.
    "Don't you run the risk of blowing grit from the floor or driveway onto and across the car?"
    Good thinking. The answer is "yes?" And, you guessed the right solution, below.
    "Or do you just point it down and blow the water onto the ground?"
    Yes, you are right. Jeez, this group has some smart people in it. I have an electric blower, so it is light and does not care what angle I hold it at. So, I hold it high (over shoulder height and sometimes over my head), in two hands, with the hand on the back of the blower higher than the hand on the front (which is holding the air discharge nossle). In this way, the blower's air intake is high off the ground AND the air is being angled downward.
    The other reason I do not have a problem is that the driveway is clean and (probably more importantly) wet, because I just washed the car on it, so 1. there is not much dirt to tire up to begin with 2. what dirt, if any, remains is wet and 3., as discussed above, the air speed falls off really fast with distance, so the speed has dropped significantly by the time the air hits the ground. Now, if you put the blower nossle an inch from the ground, I am sure one would have a problem. But, there is no reason to do this.
    I do love to use the blower to get the water off the very lowest painted parts of the car body, which on mine go around and under the car (which is a [non-permissible content removed] to dry by hand). I still have no problem, because I lower the blower so it is not angling sharply downward -- it is, instead, roughly parallel to the ground (actually, slightly downwardly pointed).
    "Have you had any trouble with this?"
    None
    "and how long does it take to do the whole car after washing?"
    About two minutes, including blowing the water out of all those pesky places, which is one of the main reasons I use it. The other main reason is that I like anything that reduces the rubbing of the paint.
    "Right now, I use the Calif Water Blade, which I bought after reading comments here, and am, somewhat to my surprise, very pleased. This seems to get lots of water off quickly, leaves no scratches, and I can dry the rest quickly with one towel."
    I have a blade, too. Most people report good results with the blade. If I have to wash the car early in the morning, I use the blade so as to not disturb my neibors (and, it's against the law, to use a blower before 8:00 am in LA, where I live -- Use a Blower, Go to Jail -- actually, there's just a fine). A percentage of blade users on detailing sites report having scratched their cars with a blade, however, by picking up some bit of something and dragging it across the paint. Several of those still use the blade, but inspect it and run a towel over it frequently to pick up any dirt, particles, etc.
    There is one draw back to a blower if you live in a low humidity/high temperature area. You have to have a helper to follow immediately behind you with a towel, or you have to blow small sections yourself and then towel, if you wash the car in the heat and particularly in the heat and in the sun. Why? If the car body and the paint are hot and the car is in the sun, and you then blow dry the car, you will get some water spots if you do not towel immediately (to pick up the small bits of water that have not been blown off the car). Of course, we are not supposed to be washing our cars in the heat, particularly if the cars are also in direct sunlight. But, sometimes I don't get up early enough on Saturday morning!
    A final note on blowers. The consensus from the other discussion groups is that one should use an electric blower. They are worried about spraying micro-drops of oil on the paint. I have no idea if this fear is legitimate, though I understand the concerns that would lead to the fear.
    So, why would one consider a gas blower? Gas blowers blow harder. Electric blowers have lower air speeds. But, I have not found this to be a problem if you buy a top rated electric (such as the top of the line Toro). Also, electrics cost about one third of gas blowers (a top of the line Toro is about $65, gas models are around $200 and go up from there). And, as noted, electrics are quieter. Now, if you already own a gas blower, I guess you could just give it a try and cease use if you noticed a problem.
  • pjyoungpjyoung Member Posts: 885
    <<Can a PC monitor be adjusted for screen resolution too?>> Yes
  • emaisonemaison Member Posts: 60
    Too...tired...to...post...response. Reading...making...eyes....tired............
  • pblevinepblevine Member Posts: 858
    pj: Yep, you can adjust the size via the MS Windows "Control Panel's" Display tabs. Its a bit tricky. Also, the IE settings can be adjusted too.
    darbh: Wow, that's a great post. And yes, I do find that my method leaves a few 'wet spots' behind. Usually around the rear trunk lid's encloser lips and the rear 'plate holder. And yes, its a pain after you think you've finished drying only to find some water when you're applying Z2.
    By the way, that train wreak in Baltimore cut some of the main T1/T3 backbone's between NY and DC and a lot of routers at various ISPs will be in the act of re-programming their router tables today. Expect lots of delays and outage situations.
  • mbdrivermbdriver Member Posts: 426
    In your advice to bat in your post # 2355, are you sure that Z-5 should not be used on an older car with non-clearcoat paint? I may be wrong, but I seem to remember asking Sal and my local Zaino distributor about this more than a year ago, and as I recall they both said it would help diminish the swirls and scratches, even on the light ivory original paint of my wife's '77 Mercedes.
    I applied several coats of Z-5 over a period of a week, but it didn't do much. They're mainly visible when the car is in the garage, under an overhead light. But after several more applications of Z-3, the paint looks great and still does. Ideally, I should have started with an abrasive polish. But I'd used NuFinish on it for years, buffing with towels with polyester content. Now I know better, but I'm not sure if it's worth starting over with an abrasive polish, then Zaino, on a car that's 24 years old.
    As for San Miguel, I agree it's a great brew, but only the domestic variety sold in the Philippines. IMHO, the export version isn't nearly as good.
    I think you just proved the point. Your use of Z5 didn't do much without first applying Z3. Again, Sal knows best and I'm no expert. But since Z3 was developed for those older non-clear coat paints, I would think that it should be used as the base Zaino coat. Also, although Z5 might help for some of those old swirl marks, many of them may now be embedded far down in the base paint. For those types of swirls, only an abrasive polish will remove them.
    Hey, don't feel so bad, I just created a bunch of swirls trying to dust the pollen dust off my car. I think my towel was less than clean.
    Ah, San Miguel! When I was stationed in the Philippines, we drank it all the time. Local people would even put ice in it without killing the flavor. But the stuff sold here is just not the same.
  • cdnpinheadcdnpinhead Member Posts: 5,621
    Having not read postings in this board for awhile, I just paid my dues (and read them).
    I use this stuff. My car's original finish was cruddy enough that I'm not inspired to do the completely anal drill that so many who post here embrace. That said, Zaino is better than wax. Some months ago a participant pointed out that using Zaino was, overall, a labor-saving approach. He was right.
    Agonizing over towels and detergents and swirl marks and God-knows what else doesn't quite drive me to distraction, but it does make me feel good about the country (generic -- Canada is included) -- an excess of leisure time isn't necessarily a bad thing.
    However, people who have this much time to indulge in the care of their vehicles, as evidenced by this board, probably either need to: 1) get a life, or 2) be thankful that they live in a place where this kind of excess isn't outlawed.
  • homer2000sseihomer2000ssei Member Posts: 159
    So, the industrial revolution and the computer revolution have finally reaped us some benefits that matter.
    Spare time to lovingly care for our loved ones, and family :)
    Pblevine -- thanks for the complements.
    Re "What a country." Well, car care can be obsessive, but it is usually not destructive, so, unless it has gotten to that point, it is a somewhat harmless vice. Plus, the cars look great (!).
    People have hobbies. There is something satisfying about personally producing a result of excellence with your own hands. Not everyone is a world class musician, who can play a piece of music perfectly as a hobby. But, with knowledge, care, and work, if you want, you can keep a near perfect car. OR, just Z it every 4 or 5 months and that is OK, too. I like to keep my car immaculate, but that is simply a personal decision. And, after working in an office all week, I like to do this other kind of work.
  • automophileautomophile Member Posts: 780
    MBDRIVER - Your beer comments are RIGHT ON! My opinion of your opinions has gone up a notch!
    Ever tried "Dixie Blackend Voodoo Lager" from New Orleans? Very Unique!
    BLOWERS - Be sure that you use an electric blower. A 2-stroke gas powered blower can also blow some oil out at the same time, ruining your nice wash job! After Dawn, before polishing, I take a drive on the freeway for 10 miles or so to blow out all the water drops.
    darbh-
    I agree with you. I like to keep my car clean too. Using Zaino certainly makes it a snap to keep it looking great with that wet look shine. I love having free time. Glad my job affords me that luxury.
    To some people, a car is just a means to get from one place to another. Doesn't matter if it's a Pontiac Sunbird or a Mercedes 500 series. Wash and wax it once a year and that's it! Good enough for them. I would classify those people as ........... Don't want to start any wars. Fill in the blank yourself.
    fastdriver
    I was leaving a vendor's office with a client, and the vendor commented on how clean and shiny my car always is. Ahhh - if they only knew how easy it is to keep your car beautiful with Zaino products! I am sure that they think I spend hours and hours keeping the car so gorgeous, instead of a few minutes here and there. I didn't discourage them!
    fastdriver - Once a year? I see lots of folks on line that NEVER polish their car - and they think that they look as good as new! Just drive through the local car wash once in a while (shudder). Oh well - it takes all kinds.
  • 330ismynewcar330ismynewcar Member Posts: 6
    Nice test you conducted, but is it just my monitor, or do I see swirl marks on the up-close pictures? Strange, because I found out Zymol HD-Cleanse removes most swirls.
    automophile-
    You have mail!
    ME at a car wash!!! I don't think so. Ever notice all the real expensive cars that "look" clean until you look at their front wheels and tires that are covered in black brake dust?
    fastdriver
  • tmarttmart Member Posts: 2,403
    Have not tried the "blow job" method, but it certainly sounds reasonable. My problem, and one no one has mentioned, is standing on a WET driveway with any electrical device. If there was a problem, it could be your last one!! Tmart
    Aye - but they didnt test the "HD-Cleanse" or the Zaino "Z5"...
    The proper cure is Z6.
    Ha! Actually I probably spend more time talking about Zaino than actually applying it. 'Cause it doesn't take much time and as a result I'm so impressed I want to talk about it. The law of diminishing returns (or spare time). Its true that I'll take a few moments after lunch to remove some bugs or dust from my daily commuter. But I don't usually have the time every weekend to "Z" or even wash my car. Part of the problem is I live in NYC were it is very hard to get space for detailing. And when I'm up in Otis,MA, my family is always dragging me off to do something cultural - like shopping. He He, don't tell my wife I said that.
  • lex430lex430 Member Posts: 52
    because it's so easy, I wash, let it dry, apply Z5, let it dry, wipe off, the actual time it takes for each process is ~15-30 min, but it's the waitinng time inbetween that takes overall a few hours! Well, I take my time inbetween suring the web, or work on my other tasks.
    But to my neighbors, it seems like I am wiping my car down for 2-3 hours every other week, I don't even bother explaining anymore, it's easier just to let them think that I love my car more than anything else! it true anyways!
  • mike_542mike_542 Member Posts: 128
    This is what it said on the test:
    "6.) The third section was cleaned with Zymol's HD Cleanse, "Paintwork Cleaner". The directions said to apply the Cleanser with a terry cloth towel and using medium to heavy pressure, work the product into the paint until it feels sticky. Then buff it with a clean cloth. This took some work, but the paint looked very nice when we were finished."
    As you can see, they used the HD-Cleanse before the Zymol NSX Glaze, which eliminates swirls. Something makes me question the accuracy of the test. (Or the swirls might be too deep)
    Or are they "angel eyes" as some Lexus dealers call swirl marks on their "Touch of Class sealant?" lol
    Fast driver: I filled in the blanks. Well done on not using inflammatory words, starting a flame war.
    Re a car being, for some, just a way to get from point a to point b: the French, have similar feelings of contempt for such unfeeling, ultra practical attitudes, but about food. One of the greatest insults in France is to say someone "eats to fill his stomach."
    tmart -- Re: electrocution (yikes!). The Toro blower I use is double insulated. I also wear tennis shoes or tongs made of rubber (though I have questions about how helpful that is). So far, I have not been killed. Unfortunately, if I am, it will be difficult for me to report that experience back to the group.
    automophile -- I tried driving on the freeway, but it left water on the car. Also, I have to get the speed up to about 85 to get a lot of it off. I have found the blower quicker and more thorough. But, as many of us say, many things re car car are matters of personal preference and there is no right or wrong (except applying too thick a coat of Z!)
    Have a good weekend, all.
  • hud116222hud116222 Member Posts: 46
    My gosh! It is NOT that difficult. I think it was automophile who suggested using a hose without a nozzle to rinse the car. I found this to be very efficient. I can dry my car in 10 minutes with one large towel. As to the crevices like door handle, etc., it takes only seconds to wipe as I speed around my Solara on my Ames cart putting on Z-2 or Z-6.
    Incidentally, got a mother nature Zaino wash yesterday. When I pulled the car in the garage, it had water beaded all over it; but it was late, so I just left it. I took me five minutes to wipe with 100 percent cotton towel today and it was spotless.
    While the discussion concerning local beers was quite interesting, I still find my Bud Light sits very well in my cart.
    hud116222 - Actually it is fastdriver that suggests using the hose with no nozzle. I feel that the best way is to use a cheap plastic "fan" spray nozzle from the garden shop. I think this is better because it covers a larger area at once, and makes it easier to create the "wall of water" that flows off and takes the rest of the water with it. The pressure is very low, so it doesn't splash and leave more water drops on the car.
    fastdriver - Yes - those shiny cars with dirty wheels! It's like someone wearing a new suit with grubby shoes! Too bad.
    automophile-
    "those shiny cars with dirty wheels! It's like someone wearing a new suit with grubby shoes!"
    EXACTLY right!
    Beautiful day here in CT. Sunny, cool, very low humidity. Great day for some Z2/Z6!!!
    fastdriver
    Re your post #2371, thanks for the kind words. I spent 4 years in Louisiana, but wasn't fortunate enough to try the local New Orleans brew.
    One thing you wrote bothered me, though. Do you really use Dawn to wash your car before applying Zaino? Methinks you probably meant Z-7 -- or you're leaving a "Dawn film" on your paint, according to Sal.
    I have only used Dawn to remove waxes, etc. before polishing. Perhaps I mis-spoke about this. However the last time I re-did our Accord, I first used a glazing compound to removes some serious older swirl marks, and then Dawn to remove the residue.
    After that, ONLY Z-7, as you surmised.
    Look for the Dixie brew - it's worth it!
    Dispite all my protests of doing nothing on my car, I did wash and Z6 it this weekend. My in-laws are visiting us and driving me nuts. So I took them out to LI to visit some friends. As long as I was there, and was parked on a nice driveway, I figured it was better to wash the car than to pretend to be awake at this family 'gathering'. It only took me a half hour, but I was trying to make it last longer.
  • fish8fish8 Member Posts: 2,282
    Let Zaino dry over night. if it still is not dry, you may be puting too much polish on the paint. I have never had a problem with drying.
    fish8 is correct. Drying is a function of temperture, humidity, and the amount applied per sq. inch. Too much "Z" equals no "Z". Thin is in. Try cleaning your car again (which you would do for any product), and applying on a thin layer of Z2.
    1. What kind of car do you have?
    2. How much of the bottle did you use?
    A little goes a very long way. In fact - If you had it on thick enough to easily see a haze, you most likely used too much. The only problem I ever had with drying was on a January day with the temps at about 35 degrees. Also, try putting it on in direct sunlight. Even with humidity here, I never have to wait more than an hour for it to dry, In fact, by the time I finish the last panel, the first one I treated is ready to be wiped down.
  • mpynempyne Member Posts: 120
    im sold on these polish products and im gonna order some for my new black sand pearl corolla le
    how long does it take to recieve them after you place you order also whats this i hear about washing your car with dawn to remove the polish from the dealer. i didnt see anything mentioned on the site. and will it work on the corolla hub caps? also what Zaino products would you recommend being a new a brand new car (2002)and last question is can you really apply them in sunlight? sorry so long but i want to treat my car right
    The orders ship very quickly. Usually I get my order within 10 days from the time I mailed the order. Even if you're paying with a personal check. You might e-mail Sal to see if there is a distributor in your area...saves the mailing time.
    Dawn is a high alkaline detergent and it will strip off any old wax that the dealer (or you) might have put on. He talks about that in the FAQ's on his website.
    What are your hubcaps like? I use it on my chrome wheels with no problem
    I never clayed, so I can't(won't) recommend it. Many will. At the very least you should get Z1, Z2, Z6 (gloss enhancer), and Z7 (wash). I dunno what it is about Z7, but it does a tremendous job, and like the rest of the products, a little goes a long way.
    Finally, I always apply it in direct sunlight, on my white car or my wifes deep blue car. I think it helps to dry faster. The last time I did my wifes car, it was about 95 degrees with a blazing sun. No problems whatsoever. Good luck, and enjoy the shine! Oh, and remember...a little goes a very long way. Don't be tempted to use too much.
    also is the Z-5 necessary, ive read it is because the dealer car wash is pretty harsh.is black sand pearl on the corolla a clearcoat?? thanks again
    No, you are not the ONLY one that thinks Zaino is a crock, but you are not in the majority either. I have never had a problem with drying. I live in the humidity capitol of the world, South Florida. If I were you, I would look to see what I was doing wrong, and if you can't figure it out, then use something else. Life is too short and there are lots of products that make your car look nice and protect your paint. I find Zaino to be a superior product, but it is not the only product that works. Why fight it? Obviously you are not happy with it, so switch. No big deal!
    mpyne-
    DON'T use the Z6 gloss enhancer in the blazing sun. You don't want that to dry on the car. You put it on and wipe it off immediately. Don't lean too far when you do it or you'll slide right to the ground! LOL...
    Also, DO NOT let the dealer wash your car! That will only add to the scratches/swirls. They will not use the same good washing mitts/cloths that you do. The Z5 is good to get rid of swirls/scratches, but it does not perform miracles. Close though!
    I assume the paint is clearcoat, but check it out. If it's not, you'll need Z3 and not Z2. Ask the dealer, call Toyota or e-mail/call Sal Zaino. He always answers the phone.
    fastdriver
    When and if you start seeing swirl marks or "spider webs", then order the Z5 product. In the beginning, it would be better to order more Z6, IMHO.
    PJ or anyone: Does anyone know when the new Zaino quick curing additive will be ready?
  • nokuy2001nokuy2001 Member Posts: 4
    I am planning on applying zaino to my older car this week. I am first going to wash it in dawn then clay it and wash it again in Z-7, then apply Z-1. I purchased some Z-5 and since my car has a lot of swirl marks I plan to do 3 coats, or how many ever it takes next. My question is, how long do I need to wait before I apply the next coat of Z-5? After I buff the Z-1, and Z-5 off can I just keep adding coats of Z-5 untill my finish is to where I want it to be and then put a coat of Z-2 on it to finish it, or do I put Z-2 on after I buff off the Z-1, and Z-5 and wait to apply more Z-5 later? Thanks alot Marty
    pblevine-
    Sal just says- "be patient"!!
    fastdriver
    fastdriver: Ok, I'm trying.
    nokuy: 'Just to make sure, apply the Z1 and then the Z5 directly after it. Only buff the residue off after the Z1/Z5 combination has dried. Then wait 24 hours before the next application of Z5. Actually, as an option, you could apply a quick coat of Z6 Gloss Enhance between coats of Z5. The 24 hour waiting period is the "offical" curing time wait period. If, however, you are in a low humidity / very quick drying area (say Sacramento, CA), then you could probably get away with a 10 hour curing period. On varying between Z2 and Z5: I'd (again, I'm no expert and maybe fastdriver or pj or automophile could help out here) apply only up to 3 coats of Z5 before using a coat of Z2. Three coats of Z5 should really do the job, and Z2 also has some anti-swirl properties too.
    Well said Joe!!
    I think Zaino is the BEST product I have ever used and I have used them all. Actually, I told my Dad about Zaino and it is the only product he puts on his car. Unfortunately, all the wax on his shelf in the garage will probably go to waste now!!!
    All those other waxes need not go to waste! You can, for example, use the Turtle Wax to protect your home A/C unit. After all,.. rain, sleet, and snow could damage central or window A/C units. Some wooden tables are also good candidates. And driveways need protection from oil and tranny fuild slicks. Lawn furniture and Mothers, perfect together. Zymol and surf boards hanging ten! Ah, the list is endless. :)
    Good advice from Pblevine.
    One thing nokuy: do not expect the Z5 to handle heavy or even medium swirls. It will decrease their visibility to some extent, but it will not completely cover medium swirls and if they are heavy, forget it. In such cases, if you want a swirl free car, you are going to have to physically remove the swirls, not cover them up. This is done by using products like 3M Swirl Remover (very mild), 3M Finesse II (stronger, but still pretty mild), 3M Fine Cut (stronger, a cutting compound), etc. You should only use strong cutting compounds, "rubbing compounds," etc. if you know what you are doing, or else have a pro do it. The strong ones, used with a buffer, can cut through your paint.
    If you have an extensive problem and you want a swirl-free car, better to eliminate the swirls now, before you spend the time putting 5 coats of Z on the car.
    darbh correctly makes some valid points. There are "swirls" and then there are SWIRLS. We see them as tiny concentric little lines. But some swirls are scratch on the actual paint surface. Z5 will help "decrease their visibility" but will not remove them. And as darbh recommends, the 3M Swirl Remover product can cut them down. The lighter swirls which only appears at certain angles in sunlight and the "spider web" effect are also tiny scratches. But they are only at the surface and are limited to damage to the "Z" coating. When I, for example, tried to "dust" pollen (which is gritty) from my hood, I produced a series of such "swirls". Z5 is effective against these types of swirls.
  • kenyeekenyee Member Posts: 738
    If the grain of a "swirl" (don't ask...screwed up a paint chip flattening using the Meguiar's sanding block and put scratches in the clearcoat)-: goes one way, would you use the 3M swirl remover with the grain or against the grain?
    I'm not sure. Logically you should go against the grain to abrasively cut down the top edges of the swirl scratch. But as the product is designed to 'fill in' those swirl depressions, going with the grain might be more effective.
    Its raining here in Westchester and I walked through the parking lot here at Con Ed. Its amazing to see the difference between my Zaino protected hood and the other cars. The water beads up and runs right off my car. I ran out and gave it an extra little spray from my bottle of Z7/water, and now I'll let the rain do the rest. Nothing like a free car wash.
    Don't let the negative knee-bobs deflect you. Humor them.
