Visitor Agreement.
LOL.... You KNOW I use Z6 on my monitor. It keeps my cigarette ashes from sticking to the screen. Same with the TV!
fastdriver
I see Mr. dhanley is back with a stock collection of negative vibes. Ok Dave, PJ's math shows that Zaino may cost more per bottle but each such bottle lasts much longer. And much more manual effort is required to produce an equal shine from most wax products. Conclusion: Zaino users have a slightly higher "startup" cost, but in the long run, Zaino users will be more economical and will produce a superior shine with much less effort.
Dave, your advantage will be that after a few years, you will be in slightly better phyical condition than me due to all that extra work you will have done to maintain your shine.
The same 3 or 4 people yappin' about the same thing, like it makes a difference.
Seems to me that there's is nothing left to discuss, debate, uncover, or clarify.
One solution if you can't determine whether you still have clearcoat: Do the blue Dawn wash, clay, Z-7 wash, Z-1 -- and then use Z-5. The Z-5 is for use on either clearcoat or nonclearcoat paint. Some posters here even believe the reflective properties of Z-5 are superior to Z-2 or Z-3 (Sal doesn't, BTW). That way, you'll be able to get a head start with Zaino and can continue with multiple coats of Z-5 -- which will probably enhance the finish by "attacking" the swirls and minor scratches.
Eventually, when you're certain whether or not you have clearcoat, you can switch to either Z-2 or Z-3. And FWIW, I also used NuFinish exclusively over the years on my wife's 1977 Mercedes 300D and always kept the car clean and garaged. Almost two years ago I switched to Zaino. The Z-5 didn't completely remove all of the swirls. But the shine and "wet look finish" on the 24-year-old car, with multiple coats of Z-5 and then Z-3, is fantastic! So you can't go wrong!
WOW!!! I remember the day you first started asking about Zaino! It's been that long already? Time flies when you're "Zainoing"! ;-))
fastdriver
All the above is good advice. You can either do the "newspaper" routine as pblevine points out, or do you remember seeing any pigment (black in this case) on your buffing towel the last time you waxed the Celica with Nu Finish? If so, the clearcoat is worn and the finish will look dull as only the black pigment will show through on the finish. The finish will also feel a bit rough if the clearcoat is worn. That's the "magic" with clearcoat. It will look shiny when the clearcoat is "painted" over the colored pigment.
If you really want the Celica finish to shine, try using some 3M Perfect-IT Foam Polishing Pad Glaze before doing the Zaino routine on it. This is perfect stuff for a 10 year old Celica. I've used it on my sister's used (abused) black '92 Blazer before Zaino. She thought she was going to have to have it repainted. Not anymore. Your Celica should be a ton easier to shine than the abundance of real estate on a '92 Blazer.
BTW--pblevine, I would have disagreed that I had "good eyes" before. I had LASIK done on my eyes last week. Best thing I ever did. First time in 25 years I didn't have to wear glasses or contacts. Vision is now 20/15 (used to be 20/800).
MB DRIVER--you are officially an "old timer" here.
92 black Celica. I sent my check yesterday with
my order for Zaino products and can't wait to get
the stuff. I just wish it were here before the
weekend (doubt that will happen), so that I have
plenty of time to use it.
I have one more question about the Nu Finish. Is
the Dawn going to be sufficient to remove the
Nu Finish? I think I read earlier in the postings
that someone recommended using vinegar and water
for removing water spots... Would that also work
for removing the Nu Finish?
By the way, I'm going to take some pics of the
car before and after. I'll try to post them
here after I do this.
Thanks again for all of the advice.
Zaino is great stuff but one does have to be reasonable in approaching the subject!
graphicguy: Glad you're seeing better. I too am considering zapping my eyes. How's your night vision? Any glare spots?
One, it's easy to take off the wax by just washing with Dawn, and you are going to wash the car before putting on Zaino anyway.
Two, wax will yellow over time, and so eventually you will have a foggy layer between the polish and the paint.
Three, a polymer bonds to the paint; it won't bond to the wax, so it won't stay on the car as long if it's trying to cling to wax.
Also, Sal does not say to take off the wax first just to hear himself talk. I'd listen to his advice.
Finally, I may be wrong about this, but I think NuFinish is mostly wax with some polymer stuff in there. I've never used it, but I think I have read that here, and it sure looks like a pink liquid wax to me. Since it does not go on like Zaino, I doubt it's pure polymer.
Email Sal; he'll tell you how to take off the NuFinish. If you are going to go through the process of applying Zaino, you may as well wash the car first with the right stuff and start correctly.
According to Sal, there is no difference between Z-ing a new car or an older one. He said to do the basic steps of dawn,clay,Z-7,Z-1,Z-2 or 5,
Z-6. I am finally going to do it this weekend, as we are suposed to have nice weather in the NY area. I'll let you know how it comes out.
Mark
Prices can get outragous, Zymol has a hard wax that sells for over 1400 bucks!!!! Check it out on their website.
I am a person that used to use Nu-Finish. For most of my purpose it was okay. Fairly inexpensive, easy to use and provided good protection for the finish. However, now that I bought a brand new bright red truck I thought I would try something different. One that may have a better shine. You know how it is when you have a new baby. In addition I finally convinved my wife that her 97 truck has no protection as the "permanent" polish job the dealer sold her was a scam. It took me and the body shop experts to convince her.
Being a cheapskate I picked up the Zymol Cleaner Wax 2 pack they have at Costco for 15 bucks. Used it on my new truck, excellent shine. Visibly better than Nu-Finish. Also smells a lot better. Smells so good it almost made me want to eat it.
Tried it on the 97. Retored the OEM shine quite well. Luckily the paint and clear coat are still in good shape. I am happy with the finish the Zymol Cleaner Wax gave me.
In my opinion, the Zymol Cleaner Wax is a good product. One that I can feel I can use without feeling like I have been ripped off nor is it a product that takes all day to use. I want a fairly easy to use wax. I am not interested in claying and using multi stage products.
Zaino because it is a polymer instead of a wax will probably last longer if you subject the finish to a continuous spray test. That is an area polymers excel in. If I lived in rain country this might be a better option. But here in the cereal state (California, land of the fruits, nuts and flakes) the weather does not justify the longevity difference.
Either way, Zaino, Zymol or anything else, in the end what matters is that you use something to protect the paint finish. That is the key to keeping it looking good.
fastdriver
My main one is HOW to wash my car. Sure, use Dawn (my wife picked up Dawn Ultra from the grocery store - not sure if that's the right stuff, it's blue and "original scent", but I'm going to go to the grocery store and double-check just to be sure).
She says I should use a hose and a sponge to wash the car. Our outside water is VERY hard = bad mineral spots (I tried once), so I'm leery of that. OTOH, softened water from the inside faucet (put in a bucket) has salt in it. What to do, what to do? Bottled water? (he says half-jokingly)
Also: sponge or towel? I would think the sponge would be more abrasive...
Otherwise, I think I get the sequence:
wash w/Dawn, clay bar (lubricate w/Z-7 and water), Z-7, Z-1, Z-5, 2-3 hours to dry, then remove it, and apply Z-6. Wait a day, then repeat with either Z-2 or Z-5, depending if the swirls are gone...
I have my Fieldcrest white 100% cotton Made in USA towels (thank goodness for the white sale at Kohls), with the edging cut off...
Please let me know, and thanks, in advance, for any advice,
--Robert
-Larry
-Larry
Yeah, if you don't use enough of it to really protect your car. I can spend $3 on wax and do that.
As for your assertion that you will recoup all the extra expense with time savings--bs. I did the 'Z' process. I still have the bottles in my garage. I haven't used 'em up because the zymol is, if anything, easier. There's one layer, you take it off damp, and it doesn't stain the black plastic trim.
dave
As for my assertation about my time savings bs - It is apparent that the Zymol must have affected the portion of your brain that recognizes farcical humor.
Just wanted to add some perspective.
Clay: I have found that using the Dawn wash water as the lubricant with Zaino clay to affect the clay; it seems to separate and develop "bumps" and become harder to manager. Even just the residual Dawn wash water can do this; I would thoroughly rinse the car, perhaps even wash it after the Dawn wash with Zaino. If you can, use distilled water mixed with Zaino in a spray bottle as your clay lubricant; you will have less worry about mineral water spots occurring. Then, use the remainder as a spot cleaner for bird droppings and the like.
If you have used Zaino clay with Dawn wash water as your clay lubricant, it will return to its normal more easily handleable state once you change to the recommended lubricant mixture.
Respectfully,
Larry
Yea, garypen. What he said! No wet blankets! Even with wet blankets, we Zainoists/Zainoholics still will have a great, long-lasting, spot-free shine! ;-)))))
fastdriver
I think the Zaino folks are idiots because they spend so much time and money on car "polymerizing" products.
No. Wait. I think the Zymol users are backwards morons that don't understand the basic principles of today's car finish technology.
I'm so confused. It's tough trying to come up with pasionate opinions about car wax. It really is.
I thought you guys were a little over the edge. I realize now that I was lost, but now I am found. Today, I join you. Salut.
Respectfully,
Larry
No edge intended. I'm also a moron that uses Zymol, and an idiot because I plan to try Zaino at the suggestion of others on this and other Forums.
I like my car to shine, too. But, it's still only car wax.
Just looking for a quick confirmation that this is correct. Can someone in the know confirm for me so I don't make a mistake?
Also, I am getting ready to Z my daughter's new car. I notice you folks talking about "blue" Dawn. I seem to recall that the last time I used Dawn it was a light amber color. I there more than one version of Dawn, and does it make a difference which one you use? Thanks.
So...yes, you can apply Z1 after multiple coats of Z2 (or Z5). Do you need to??? I'd say after you applied 5-7 coats of Z2, go back and re-apply Z1.
IMO..the key to keeping that Zaino shine looking fresh is Z6. Using a separate 100% cotton towel (and sometimes a California Duster), I wipe off the dust nearly every morning as the car warms up. I then use a different towel to apply Z6.
When you do Z1 again, be prepared for longer drying time.
In answer to other question:
Best thing to do is use the original "blue" Dawn.
Now if Zaino has a single stage cleaner polish or whatever, I might be tempted to try it. What I won't do is have my wife spend a whole say using multiple products to polish my trucks. Before anyone gets in an uproar that I am making my wife a slave, I am temporarilly handicapped and cannot be on my feet so someone has to do the work around here.
Anyway, is there a single stage Zaino product and what is it?
http://www.properautocare.com/kla-16.html
It exceeds all of your requirements. Klasse All-In-One polishes away oxidation and leaves a deep acrylic shine that can last for 6 months or more. All-In-One is not a wax, silicone or polymer but an acrylic formula. It matches the depth and clarity of a high quality carnauba wax or Zaino, but lasts much longer. It's a one-step product! It cleans, polishes and protects in one easy step. It cost $22.95 for 16 oz. bottle and I get about 8 waxes per bottle. Is very easy to use! Simply wipe on and wipe off. No drying time is needed.
http://properautocare.com/kla-16.htl
I have order it from Autopia Car Care on line and received great service. The stuff, I order comes in 3 or 4 days and they take credit cards(unlike Mr.Zany)! Check out this link.
http://www.autopia-carcare.com/
Respectfully,
Larry
i did the whole process a few months ago and it was great. a few months went by and
the other day i used z5 and let it dry and it came off great. the next day i used z2 and i am sure i put it on too heavy as it took forever to dry and did not come off as well. i then z6 the car and it is still not even and a little smeary in some areas. should i just z6 again as i sure as hell aint gonna dawn and start all over.
Zymol doesn't seem ti last that long, it's true. However, it's pretty easy, so i don't mind doing it once a month; i did my car last night in about 20 minutes, and i'll spend maybe 10 minutes this afternoon getting wax out of the seams.
I do want to try klasse. I think i'll order some after my zymol is used up.
dave
I've been using Finish First recently and while it works great, it takes a minimum of 90 minutes to cure betwen coats. Each application is super easy but it does take several applications before any benefit is noticed. So far I've got 6 applications on my car. Each took about 15 minutes to apply, but the curing time is 90 minutes per coat. That's 105 minutes per application or 630 minutes total. Not everyone wants to spend 10.5 hours to polish their car.
None of those considerations have to made with a carnauba-based product. If anything, it's the opposite. A product like Zymol or Pinnacle needs to be removed almost immediately after application. Letting them set up will only make it harder to remove. I can glaze and wax my car in the 90 minutes it takes to wait for the polymer to cure.
And the results are noticeable immediately. There is no significant benefit in applying multiple coats. By comparison, polymers absolutely require multiple coats to derive their maximum benefits.
Don't believe the posts from the hypersters of polymer products. The results are good but it takes a major effort to get them and I think most folks do not want to go to that extreme.
