Zaino Car Care Experiences
17475777980137
  • joebob6joebob6 Member Posts: 239
    I drive a white vehicle also and extra coats of Zaino polish make it look noticeably better than just one. I found a significant improvement in look after putting on another Z1 coat with my 4th coat of polish. I don't know whether the protection is any better.
    Plus, if you just like to add coats of Zaino polish there is never any worry that you will be removing any clearcoat paint because Zaino does not have any abrasives and Z1 has very little cleaning ability.
  • pjyoungpjyoung Member Posts: 885
    But compare your car to pics of fastdrivers red car...are you getting those kind of results? I haven't found multiple coats on a white car strong enough to warrant multiple coats (why use up product fast...make a bottle last a year or so) but you do. That's great. But if you weren't one who wanted multiple coats, or if you were someone who hadn't really waxed cars a lot in the past and was looking for something that worked well and lasted a long time, don't you think you'd find the waxtest site a little helpful?
  • dbordbor Member Posts: 5
    Just purchased a new car. The color is black onyx, I believe it is clear coat. Very new to the Zaino board. Have briefly read some of the earlier comments about dawn and claying and some of the Zaino products. However, not sure what steps I should take to do things right. Can someone briefly explain. Thanks
  • scottc8scottc8 Member Posts: 617
    Go to the source, www.zainobros.com. If the instructions there don't answer all your questions, e-mail them. You'll get a prompt and helpful response. The support is as good as the product. One bit of advice, don't be overwhelmed by the application instructions, as I was. It looks like a bigger job than it really is.
  • fastdriverfastdriver Member Posts: 2,273
    pjyoung-
    :-)) Thanks! Shine on!
    dbor-
    If it's a black Lexus that you have, check with Sal or your dealer about whether or not it has clearcoat. I seem to remember past messages here that black Lexus cars do NOT have clearcoat.
    At any rate, Zaino will look fantastic on your car. Click on my profile above. You'll see not only my Zaino pics, but I believe my cousin's black 2-seater BMW convertible pics are there also in photopoint.com. You won't regret getting the Zaino. Trust me.
    fastdriver
  • automophileautomophile Member Posts: 780
    Actually, one of the first tests posted a while back used non-subjective means for judgement. They used a reflectance meter to measure the shine, and measured the height of a calibrated drop of water to determine the beading. Of course, Zaino was the winner, especially in the durability. I will try to dig it up if anyone is interested.
    Also - the REAL deciding factor is that this single product has such a fan club! Does this exist for any other single car maintenance product? Unless Sal is putting some addicting substance in the fragrance, it is because of the performance, isn't it?
  • squidd99squidd99 Member Posts: 288
    I got a black Lexus recently and applied Zaino, using Z1, Z2 and Z5. I'm not sure if it has clearcoat or not, but the dealer said yes.
    Anyway, it looks great.
    My advice on the new black car: use the clay.
    I did not, because I thought I did not have to. After about 3 or 4 months, and after using clay on some other cars I was working on, I found out what the clay could do, and I could feel the bumps on the new Lexus. So a few weeks ago I clayed before applying the pre-winter Z1/z2 coat, and the difference is amazing. Now the surface of the car not only looks like glass, it feels like glass also.
    The clay step does not take much time (although my car is small) and does not take any effort, since you are not rubbing hard, and it's well worth the effort, even on a new car.
    Good luck; you will love the look. Don't be fooled by how good it looks right away; you will be amazed at how much more better (?) it looks after the 3d or 4th coat of z2.
    Sorry it took so long to get back to you.
    I've used the water/vinegar mixture with newpaper trick for a while. Sometimes old habits are hard to break. I'm sure there are other methods for window cleaning that are as effective. I just haven't found them yet. Plus, water/vinegar/newpaper is cheap.
    I also found that the water/vinegar mixture tends to "freshen up" the smell inside the car.
    I still think Z6 applied to the windshield every once in a while is better than Rain X and easier to do.
    Have fun with your "3".
  • genie1genie1 Member Posts: 398
    Z6 on the windshield? I'll have to give it a try.
    squid99 - You are right on! Until you have done the clay, you can't imagine how super smooth the car can get. THEN you Z on top of it, and it is just amazing!
    squidd99-
    Hey! Where are those new pics you were going to send for me to post? I forgot about them with all the crazy stuff going on at my job!
    fastdriver
    Sorry; the weather turned bad for a few days, and then I had to be out of town, and then something else came up, and I just never got around to it.
    But I have found out that, because my digiital camera is so old, (less than 1 meg), I can get a better image using my 35mm and scanning in the print, so I may try that the next time I get a chance. But it's getting cold, so I will have to wait for a reasonably warm day.
    Hang in there, and I'll get them to you.
    Noticed last week some discussion on the best way to clean glass. For the past five years I've been using a combo of Griot's Garage polypropelene window towels and Eagle One's 20/20 glass cleaner. This has been a great system (or so I thought) as the towels leave no lint, they're strong, and the 20/20 cuts thru all kinds of gunk.
    But after some research and testing of new products, I've found a better method of glass cleaning.
    Microfiber towels are all the rage with detailers and I'm sure most of you are using them. Classic Motoring Accessories sells some great towels including one called the Viper Glass Cleaning Cloth. See it here: http://properautocare.com/vipglasclean.html
    I use it in combination with Sprayway Glass Cleaner and the results are amazing. No streaks, no smears, no lint, no nothing except perfect glass. The Sprayway works better than the 20/20 ever did. It's kinda hard to find but I've seen it at Restoration Hardware for $4.95/can. I ordered mine at Top Of The Line for $2.77/can. http://www.topoftheline.com
    Anyway, thought I'd pass on a new system for cleaning glass. I now return you to your regularly scheduled programming.
    bretfraz-
    Thanks for the tips. I'll have to try this window cleaning technique. I hate cleaning the windows. I have often said that I'd rather Zaino the car than clean the windows! The results are always better! LOL.....
    fastdriver
  • mbdrivermbdriver Member Posts: 426
    Bret - I agree with fastdriver about hating to clean the windows. But it's a necessary step in cleaning the car. So, as you recommended, I ordered two of the Viper Glass Cleaning Cloths (a bit pricey at $10.95 each) and a case (12) of the Sprayway Glass Cleaner (reasonable at $31.92 -- 2.66 each by the case). Hope it works as well as you say. Will keep you posted.
    A case of Sprayway? You da man!
    Seriously, if you want a partner I'll go in halves with you. I have two cans but could alawys use more. LMK if you want to unload a few cans.
    bretfraz-
    When I saw the picture of the Sprayway glass cleaner, I know I have seen that at SOME local store. Just have to visit the usual stops to remember where! ;-)))
    fastdriver
  • emaisonemaison Member Posts: 60
    When will it be available? How much? Will it be announced on Good Morning America as being what "IT" truly is? (couldn't resist)
  • pblevinepblevine Member Posts: 858
    bretfraz: Good tips, thanks
    graphicguy: I don't recommend Z6 on the windshield. Z6 does fine on all other windows, but the wipers will rub out the Z6 in a good rain storm leaving little streaks. I actually use Z2 on my side and rear windows and then apply Z6 over the Z2. It seemed to work well on my 'moon roof', so I then tried it on my other windows as well. Again, the wipers will do a bad job on Z6 on the front windshield, and I'm back to just keeping it clean via Windex. But I'll give bretfraz's suggestions a shot.
    Hmmmmmm....
    The Z6 on my wndshield actually stays on for a while (maybe a couple of weeks) through rain.
    My wipers work much smoother with the Z6 on the windshield.
    The Vinegar/water/newspaper that I use when cleaning them gets all the road tar/oil/debris off the windshield (both inside and outside) with no streaking so I have a "clean" surface to use it on. Don't know if that makes a difference or not.
    emaison-
    When "IT" arrives, you won't need Good Morning America to hear about "IT"! LOL...... "IT" won't disappoint you either!
    pblevine-
    Mmmm... WHEN I do decide to clean the windows, I use Z6 on the windshield too. It's like RAIN X- the water FLIES off!! ;-)) I never used Z2 on the windows.
    fastdriver
    The wait is over. IT is now available. www.zainobros.com
  • kenyeekenyee Member Posts: 738
    Looks like it is time to refill my supplies :-)
    emaison-
    SEE! That was fast! ;-))
    joebob6-
    Thanks for the heads up. Already filled out my order!
    fastdriver
    joebob6-
    NOT me! I knew what IT was! ;-))
    fastdriver
    Oops...I just deleted the post...I re-read the posts above it and noticed they were discussing "IT".
    Wow, I've got to order some.
    On using Z6 on the Windshield. Its true that Z6 can act like RainX - for a while. But again, I've found that it washes off too easily during a rain storm due to the action of the wiper blades. It is nice while its first applied, however, and I'm now thinking of using Z2 on the windshield. Has anyone tried Z2 up front, and how long will it last.
  • whitecapswhitecaps Member Posts: 11
    Are there any benefits to mixing together z3 n z5?
    In another forum I was told someone mixed z2 n z5 to save time he said the results were excellent and it was like putting two (2) coats of Zaino in half the time. Also a couple claybar questions:
    1. Is it okay to use Zclaybar on a non clearcoat?
    2. Will Zclaybar remove my previous couple coats of Z3?
  • keyrowkeyrow Member Posts: 214
    Does anyone know if there is any detriment to having Z2 cure faster? Specifically, does ZXF cause any changes to the optical properties or longevity that we all have come to love? Being very anal about how my cars look I would rather take the extra time to allow for a "slow" cure if it also produces a better shine.
    Also, I know this is a very new product but has anyone compared this is with that "B" polymer? They seem to be making the same claims as Zaino, but I can't help thinking it is just a copycat. I'm not switching from an excellent known product to an upstart without there being something extraordinary about it.
    "Are there any benefits to mixing together z3 n z5?" Will not hurt anything but there is likely no benefit.
    "In another forum I was told someone mixed z2 n z5 to save time he said the results were excellent and it was like putting two (2) coats of Zaino in half the time."
    It will work fine but the comment about putting 2 coats on in half the time sounds like nonsense.
    "1. Is it okay to use Zclaybar on a non clearcoat?"
    YES
    "2. Will Zclaybar remove my previous couple coats of Z3?"
    It may remove some of the previously applied Z3. I would follow up the claying with another coat of polish.
    "Does anyone know if there is any detriment to having Z2 cure faster?"
    No it does have any detriment. In fact, some users have reported increased shine. I have not heard of any users report any changes with regard to its durability.
    "Also, I know this is a very new product but has anyone compared this is with that "B" polymer? They seem to be making the same claims as Zaino, but I can't help thinking it is just a copycat."
    I assume you are referring to Blackfire. It is an oil in water emulsion polymer system. It is not a copycat of Zaino. The website description of it makes it sound like it is similar to Zaino. It uses its own type of polymer system. They claim it gives the car a carnauba look with the durability of a polymer while Zaino gives a nearly optically perfect highly reflective look.
    I'm verrry happy with Blackfire. Exactly the product I've been looking for.
    I am glad you are happy with Blackfire. How does it compare to Zaino?
    Sorry, I couldn't tell ya. Perhaps a Z user somewhere could provide an answer........
    with week 6 results. Zaino holding up quite well (no pun intended).
    Their notes for 12/4 were:
    "12/04/01: This was one of the only products to survive the snow and ice. After we washed it, the slickness was still there, and it beaded water well. It did the best job of protecting it's "optics" too. We're believers! "
    Normal application of Z2 should stop when the temperature is below 40. With ZFX added to Z2, the old rule may not apply. Does anyone know if we can now apply Z2 in colder situations?
    Not to dispute anyone's experience here, but a while ago, someone on the "corvette chat board" (LS1) actually was successful in mixing Z2/Z5 with the results you describe. It's been quite a while ago, so I can't remember what the exact mix ratio was.
    --Z Clay will work fine on "non-clearcoat". Use aplety of lube as you will be actually claying the pigement coat of the paint.
    --According to Sal Zaino, claying will not remove Zaino. Don't know if it has any effect on its durability, though. You might want to give Sal a call or e-mail.
    Someone may have said mixing the two gave them results that were like two layers of polish. I do not dispute that they said it.
    It is nonsense though. If it were that easy everyone would do it because it would be a hell of a timesaver.
    There is no problem mixing Z5 and Z2. It will not cause any problems. I have done it myself with the last bottle of Z2 so that I could use it up. The two products are totally compatible with each other. But if you think by mixing them you will get all the swirl/scratch hiding abilities and then on top have another coat of Z2 all in one easy step that just does not happen.
  • luthor1luthor1 Member Posts: 15
    Does anyone know if soap used in car washes will remove zaino? In the winter it's diffucult washing by hand, so was wondering if doing a quick wash at a wand car wash will be ok before putting on another couple coats of z2. Hope it won't remove any of the previous coats though.
    luthor1-
    No problem! I do it all the time in the winter. As a matter of fact, Northwest CT is expecting 4-6 inches of snow tonight! I'm on the shoreline, so hopefully we won't get any! We have had temps in the high 60's until yesterday.
    Oh well, you know what they say about New England weather!
    BTW- I am sending this from the new Apple Macintosh store in the West Farms Mall in Hartford, CT. What a place! I am on a Titanium PowerBook G4 with a 15.2 inch screen and WIRELESS internet! Great place! I'm surprised I remembered my password because I am always on autologin! I'll have to remember to log off from this now. If any crazy messages show up with MY name after this one, it's NOT from me! ;-)))
    fastdriver
    I've been busy and haven't been here for almost a week. Meanwhile, the Viper cloths and Sprayway glass cleaner arrived. Last Thursday I washed both cars and used the Viper cloth and cleaner on the glass. It was a snap, and the glass is as clean as I've ever seen it.
    One caveat, however. I was surprised at how small the Viper cloth was, 16" x 16", I believe, and particularly at $10.95 each plus shipping. By the time I did one car, the cloth was pretty wet. But as a newbie to this system, I may have used too much Sprayway. I wonder if the NicSand micro fiber cloths from Pep Boys might be better and cost less.
    Bret - Thanks loads for the tip and for the offer to share the case of Sprayway. But I'm afraid I'm hooked, and unfortunately my wife saw the process and results. She now has her eye on several of the remaining cans for the mirrors and windows of the house.
    Thought you'd like to see some current pics of my cousin's 1998 black BMW that I last Zainoed in November of 1999!!
    http://albums.photopoint.com/j/ViewPhoto?u=912729&a=14087589&p=57196633&f=0
    Granted, she doesn't drive it in the winter, but she does drive it in bad weather and does go to car washes. I'm afraid to ask her if they're brushless!
    Last Saturday when I took these pics, the car was not particularly clean. Well, not as clean as mine! ;-))
    Talk about a long term test! I did ask her if she has applied any Zaino since I did it for her. She looked at me sheepishly and said NO!
    fastdriver
  • harry31harry31 Member Posts: 128
    Finally decided to take the Zaino 'plunge'. Received my Z stuff before the new car arrived (dealer said two weeks and dealers NEVER lie - Right?). With all that Z just sitting around I was getting anxious - had to Z SOMETHING. Tried Zaino on the old car. Everything seemed to go well ...
    Hard Wash, Claybar, Show Car Wash, Polish Lok then Polish. Outside lookin' GOOD!! Finishing up, I Z'd the dash with 'Leather in a Bottle'. Woof! Where'd that wet dog come from?
    The Wife says 'Leather in a Bottle' smells like wet cardboard. I've gotta agree that it isn't a very pleasant smell. Wha' hoppen here?
    harry31-
    Mmmmm...... I have the leather stuff too that I bought back in the summer of 1998. Since my previous car had the dark gray leather, I never used it. Since March 2001, I now have a car with the light tan leather and will probably use it on these seats one of these days. Everything that I have read about the Zaino leather stuff is that it brings back the real leather smell. I never heard anyone say it smelled like wet cardboard? LOL...
    Are you sure you're not from that OTHER topic?? LOL.... J/K. I'd say to call Sal and see what's going on.
    fastdriver
    PS When I use my stuff, I'll let you know what it smells like. Don't want any wet dog/wet cardboard smells in my car!
    I have used nothing but the Zaino Leather Conditioner on the seats and other leather surfaces in my new Lexus since May. It smells great, and in fact, most people who get in the car, especially when the top is up and the windows have been closed for a while, comment on how good and rich the smell of the interior is.
    I find that it keeps the leather soft, I think it aids in cleaning when you use the Z leather cleaner (but I'm not sure), and I know it makes the leather (and thus the whole car) smell good.
    I have read nothing but similar posts here about this product. Your experience is quite different. First of all, what is "the old car?" Maybe the "leather" isn't really leather. Some cars use only a leather insert in the center of the seat, and use vinyl or "leatherette" on the rest of the car, and yet market it as a car with leather seats. This other stuff is some kind of faux leather for which the Zaino was not designed.
    I don't know why the Z conditioner would make these products smell bad, but maybe that's what's happening. Or, maybe the leather in the old car was not so well cared for over the years, and is more dried out and/or dirty than it would be if new. Re-conditioning it may take time, and maybe you even need to try some "cleaning" products first to get off the dirt that might be there.
    I'm not sure; my experience is limited to new leather of pretty high quality, and I know it's clean because it's white, which is another story for another time (so who said, "Yeah, let's get the white leather interior for the convertible, what could be the harm in that?")
    Or maybe a squirrel curled up in the backseat and died, and the smell is not the leather at all; check around back there and let us know.
    I have to ditto squidd99. My 300M is just over two years old, yet I still have people comment on how "new" the car smells. The leather in a bottle smells like, well, leather. If the stuff smells repulsive in the bottle, call or e-mail Sal Zaino and tell him - you might be able to send it back and get a replacement. But the stuff I have smells good in the bottle and good in the car. There's always a possibility you got a bad batch. Or there's the possiblity that you and your wife aren't real fond of the way leather smells....
    Let's back up, Harry.
    I just re-read your original post, and I see that you said you put the leather conditioner "on the dash."
    I don't know of any car that has a leather dash, so I'm sure that's one problem right there. Almost all dashs are vinyl of some sort because of the heat and direct sunlight they have to endure.
    The stores are filled with products to clean/protect dashboards. I'd clean off the Zaino leather conditioner and use something designed for the dashboard.
    As pj says above, it smells good in the bottle and on the leather. Rub some on your hands like lotion; it should feel very rich and smooth, and should be absorbed into real leather when you rub in on. If not, you got a bad batch, which is possible, I guess.
    But don't put it on the dash; vinyl does not absorb anything, so it just sits there and gets baked in the sun.
    To test all of this, I am going to rub some into some cardboard later this afternoon, and report back.
    I used the Z10 on my dash as well, and with excellent results - richer look and not a shiny finish. And it still smelled good!
    fastdriver and Luthor: I don't recommend commercial car washes - they manufacture swirl marks. I'm a bit surprised you use them, fastdriver. Anyway, If you must (who knows, I too may break down this winter too), PLEASE only use the "brushless" car washes. And specify no wax, no brushes (especially on the wheels), and absolutely no hand drying. Those drying guys all specialize in using Nylon towels which haven't been cleaned since 9/11. And they'll still want a tip! And oh, oh, yes, try to stay away from those establishments which use recycled water.
    I too use Zaino's Leather In a Bottle. It really does smell like leather. Guess I used too much and the smell got to be a bit much. But I discovered a cure for that leather smell. Rub some cigar ashes into 5 day old beer and apply using an old dish towel. And leave the wet towel in the car for at least a week. ONLY KIDDING. HEHE. :)
    fastdriver: That Beemer looks great.
    Yes, my dash is vinyl. No. No squirrels in the back seat (dead OR alive). And I HAVE used Armor All on the dash. Maybe AA and Leather-in-a-Bottle together are giving off some strange gas? Will this cause all my children to have four arms and become professional detailers?
    Also, used to wash my car with a sponge and blue Palmolive dish soap. Heck, everybody does it, right? Then one day, this misguided soul dropped into the Town Hall forums and while there, found a link to Autopia-Forums/Detailing. Jeeze - I thought ALL you guys were way anal. My old daily driver has never seen the inside of a garage. Wax? Maybe four or five times in fourteen years ( but you just can't kill that cast iron V-8 ).
    Well, there I was - this carton of Zaino 'stuff' had just arrived. Had to do something with it, right? Right? And the label on 'LIAB' says, "Good for all leather AND vinyl". I gave it a shot. Maybe the dash was too hot on Saturday? (82 F.) Put the LIAB on too thick? Today the smell from the dash is much less. No better - just less (LOL). Guess I'll hold the LIAB for the new car's leather and pick up a 303 kit for the vinyl dash.
    Now that Show Car Wash concentrate - that REALLY smells good. =;-)
    Harry31 in Florida
  • hud116222hud116222 Member Posts: 46
    I use the Zaino leather cleaner and treatment not only on my leather interior, but also on ALL vinyl in the interior, including the dash. Close the windows, let it sit, and it smells BETTER than new leather. I have not ecountered a single problem. '01 Solara
    Now, a survey question I have not seen since since I started reading this forum. How many of you ALWAYS remove your license plastes to Z your car; assuming that it covers a portion of car surface that COULD be polished?
