Visitor Agreement.
Would you recommend clay? WD-40? Dawn? I have some "Finish Line Professional Degreaser" which I use for my bicycle that "dissolves tar and grime; removes wax and oil." It smells like oranges and is water soluable, but contains petroleum. Would this be safe to use?
If I use the degreaser, clay, or other tar remover, does this remove Zaino? Do I have to go back to Z1/Z2 after using any kind of tar remover?
I know that clay alone will not remove Zaino, I'm not sure about "bug and tar remover" or WD-40. A call to Sal might be in order.
Just because I'm anal about my finish, I would Z1/Z2 the areas where you used the removal methods above.
Let us know what worked.
Yep, my wife thinks I've gone nuts too. You should not get 'tired' from removing the Z2 residue. It should be VERY easy. In fact, the whole idea is that you should NOT have to rub at all. Was the Z2 still wet? Again, a little should go a LONG way. 'Just re-read your post, and depending upon temperature and humidity, 1.5 hours may not have been enough time. Last summer (July 4th weekend), I put on a layer of Z2 on a hot and humid day. After 3 hours, it still had not completely dried. So I left it over night. The result was very good, and very easy to remove (the residue).
But I've also put on a layer of Z2 and it dried in 30 minutes. That was at about 65 degrees, low humidity, and with a moderate wind. Go figure!
--Kevin
It's possible I applied too much of both Z1 and Z2. And I've heard that removing both Z1/Z2 is more difficult than subsequent coats of Z2 alone. I'll find out when I apply my second coat of Z2 whenever this pollen calms down.
Anyone else in the northeast notice the huge quantities of pollen all over everything?? It's impossible to keep an ungaraged car clean under these conditions.
len_a: I guess just waiting an hour is not enough after a Z1/Z2 application. And I hear you about the damn pollen too. Watch out for the tree sap too. Last year at this time I parked under a (maple?) tree and got a full coating of tiny color less sap spots (ie: small dots) all over the car. 'Had to clay them off.
The water beads as if it was just polished. I'll take a shot of this next car wash. I have noticed NO decline in this at all. The surface is not as glassy smooth and slick as 2 months ago, but it still feels pretty good. Since the car is outside 24/7, I notice it seems to stay cleaner between washes, also.
Trees -
Because of the angle of the reflection and the cropping of the photo you can't see the trees that are reflected in the hood! I was trying to show as much of the gloss as possible, not the neighborhood. No Algae! I'm in L.A., not Florida! LOL!
- JON
Clay - I used my Clay Magic with some diluted Z-7 as lubricant.
Finish First degreaser - This is a citrus/petroleum product, marketed for bicycles. I emailed Sal Zaino and he said it wouldn't hurt the Zaino. It dissolved the tar well and doesn't seem to have affected the finish. FYI, Sal recommends using WD-40, out of direct sunlight for tar removal.
After cleaning the tar off, I respritzed the whole area with diluted Z-7, rinsed with clear water, and dried with cotton towels. The water still beads fine, but I'll put another Z-2 coat on this weekend.
bigboy3-
LOL...... Everyone laughs at me when I suggest a new use for Zaino. Even this is a new one for me though!! LOL..........
fastdriver
I use Z-6 on the car windows all the time! No problem. I also use it on the TV screen and the computer monitor. I've also thought about using it on the shower tiles too, but haven't tried it yet! ;-))
fastdriver
cornhusker: Yep, Z6 on outside windshield will do as fastdriver says. Works great with one exception. Fastdriver is better than me at keeping his car clean the right way. I made a mistake and allow a commercial car wash (ie: drive thru - no brushes) to 'clean' my car. Never again. The junk in their 'washing' formula affected the Z6 layer on the window. I had to remove everything (ie: Z12 & Windex) and start again. But its worth the effort and if you wash your car with Z7, you should not have a problem.
bigboy3: Wow, fastdriver will now have to think up some more creative uses. The Kitchen Sink, gotta love it! LOL.
Although the initial application of Zaino was not easy, it was within reason of what I expected. (NO PAIN-NO GAIN). It also helps going through the initial process knowing that the worst is behind you. It has only been 2 weeks since I Zainoed, but I am very impressed so far. The shine is unbelievable! Time will only tell how durable it is. If it is as durable as everyone says, then I am sure I will be happy. It looks like I have finally found something that will meet all of my expectations. I will update everyone on how it holds up on my truck and on the kitchen sink. I know it sounds crazy, but if it works I am willing to try it.
Fastdriver..
Let me know if you come up with any other uses.
The Z-5 can be used to remove scratches from CD's.
One question: I have a small piece of the rear bumper (actually, the piece of trim under the bumper) being repainted because I don't like the color match.
How long should I wait--or do I need to wait--before applying the Zaino?
Hopefully not--I want to get this stuff on there and see if it's as good as all of you claim!
ME
Losy: Maybe I should read your other posts first, but is your problem existing non-dirt related markings within your present finish? If so, the best approach would be to fix that aspect of the finish before applying any type of wax or Zaino product. Washing with Dawn and claying are very good procedures which should be used in any case. But you might also have to use a slight abrasive to get rid of those marks. The 3M Pad and other products which are 'designed' to eliminate such scuff marks are probably good, but I'd 'verify' before 'trusting'. That is, try them on a very small area first, and evaluate the results. Only when the surface is 'repaired' and meets your standards should you start the Zaino application procedures.
Let us know how you do.
Now Sal can advertise that Z-6 shines everything, including the kitchen sink!!! LOL........
bigboy3-
If I find ANY new uses for Z-6, I'll post them here. You haven't been around here long enough to have heard this story, but one morning, while I was having my coffee and cigarette, I noticed that my ashes were flying to the TV and sticking all over the screen on the TV that was on my right side. A "light" went on. I thought I would try the Z-6 on the little screen to see how anti-static it really was. I cleaned the screen and forgot about it until a little while later. I THOUGHT I saw something fly by me. I figured it was a gnat or something. I still didn't pay any attention to it mainly because it was still early and I wasn't awake yet! It happened again. This time I looked at the TV screen- my cigarette ashes did fly onto the screen, but within seconds, they flew OFF the screen!! LOL..... It was just like a science experiment! The ashes would NOT stay on the screen no matter what I did. This is certainly a test that anyone can try. That's why I try to think of what to use Z-6 on next! Soon, I'll have to start buying it by the case! LOL.....
fastdriver
I think cannon and Land's End are the only one's licensed to do Supima cotton. Cannon's are called "Charisma"
Read more about supima here:
http://www.supimacotton.org/supima/cotton.htm
bigboy3: Does it last on a kitchen sink? If so, how do you think it would do on a marble table?
True...alcohol will remove old wax, but I'd be fearful of rubbing it on your if it hasn't had any water (for washing) on it in two years. There would bound to be dirt/dust on the car. The alcohol would not suspend this dirt like a Zaino wash would and you would end up moving it over a "dry" finish resulting in scratches.
It seems that wiping off the old wax with alcohol wetted towels is the way. Probably best to do it outside, yes? It is assumed that the car is not covered with dirt that would scratch your paint.
Good Luck, and send us photos when it is finished!
Anyway, a while back, I posted how my paint had developed fine scratches which I could only attribute to the usage of my new California Duster. Since, I have applied z5 and thus screwed up my durability test. However, i did get rid of the scratches!!!!
From a durability perspective, the Zaino did outlast the previous products I used (mothers and meguires). After two months of my routine, the mothers and meguires shine would essentially have disappeared, and certainly, the water would not bead. Not so with Zaino. When I washed prior to the z5 last weekend, water was still beading like initial wash. Shine was not quite like freshly applied Z but still incredible non-the-less. Hopefully, I can go without another application for a while to see how long this stuff lasts...so far its quite impressive.
Bath Towels on sale for $19.99 each
Hand Towels on sale for $13.99 each
I never paid this much for towels in the house. I will never let my wife know what I paid for these towels.
George
on what to do and not to do. hopefully everyone
here is as happy with their zaino products as
i've been. it does make your vehicle glow does'nt
it. however, my only problem is windows. yes, i'm
a real loser when it comes to windows. does
anyone here have a good basic idea for someone to
follow on getting the windows to look as good as
the rest of the vehicle. even if it's a book
called cleaning windows for dummies. he he
any help would be greatly appreciated.
thanx,
...red
I do use Zaino's window cleaner, but only when I can't see out the windows anymore! I HATE cleaning the inside of the windshield and the inside of the back window because you have to be a contortionist to do this on my Chrysler 300M! I'm exhausted after I'm finished! I'd rather polish the whole car with Z-2/Z-6 than clean the windows!
fastdriver
