We have several new topics asking about various
Mazda 626 troubles. One was clutch related and we
have a clutch topic, but....
Let's use this topic to discuss all of our Mazda
626 troubles. I have copied a couple of posts here
to get us started.
Your host, Bruce.
My 1996 Mazda 626 LX 4 cyl AT has been giving me
idle problems since once the battery went dead and
the codes were erased. The idle sounds rough,
specially during cooler days, and it is very
sensitive to any electric load; even a turning
light makes it shift up and down; in general there
is a significant delay in idle compensation after
electric load is applied. The local Mazda dealer
told me that the idle control valve was bad and
the
throttle body needed to be cleaned. I replaced the
valve and cleaned throttle body, but didn't solve
the problem. Another mechanic found a cracked
vacuum cap and a tiny leak on the air intake pipe,
after the computer. He told me that unmetered air
was causing the idle problems. The leak was sealed
but the idle is still rough and wavy. Does anyone
have a clue about it? Why would an electric load
affect the idle if the problem is really unmetered
air?
I have a '91 Mazda 626 with 172K miles. Overall,
this has been a great car. However, recently I
have noticed bucking at low speeds after the car
has warmed up for about 15-20 minutes.
I had it into the shop and they replaced the air
intake hose which had a leak. It worked for about
a week and started doing the same thing again.
Any ideas on what this could be? I don't want to
sink alot of money into the car but the bucking is
beginning to bother me.
Incidentally, my idle got much buzzier this month, to the point that things actually seemed to be shaking. And it turns out that something was shaking; the plastic bracket that mounts the air tube to the metal bar that supports the radiator had broken through. I have no idea what this costs to fix, so in the meantime the bracket is being held together through the miracle of duct tape.
After the demise of my 90 626 I had to replace it. I looked at the sport sedan field and wanted a VW Passat but it would have been an extra $5-7K equiped the same as the 626. My past experience, test drive, and the reviews were good so I bought a loaded 626ES V6 5 speed but am now having problems with it. The first being hesitation problems. This happenes in the mid range as mentioned in the other posts. You'd swear the thing was turbocharged. It also often hesitates when shifting causing the car to lurch.
To overcome this I wind her up and shift very quickly. I've tried every type of gas to no effect. I took it in to a Mazda Dealer and went for a drive and the technition experienced the problem but said it was not significant enough to justify trouble shooting it(dull looks and shoulder shrugs)!! So for now I'm like everybody else waiting for solution.
I am also experiencing intermittent ABS problems. Sometimes the warning lights come on when I start the car and stay on. If I shut the car off and restart it sometimes they go out other times not. Sometimes water from puddles or a carwash will cause the system to fail.
Other than these minor problems (ha, ha, wink, wink)I like the car. It is more posh than my 90 was but I can see no love affair in our future.
Which yr is yours anyways?
#17
If anyone has any helpful information please reply
I was driving about 65 mph for 30 miles and then turned into city, stop-and-go traffic. My car chugged and stalled twice while driving through town. I parked for five minutes and started it up going 50 mph for ten more miles with no problem. Any thoughts on this?
I've also noticed that when it idles, it stalls if the oil cap is removed. Is this normal? There is evidence of a small oil leak somewhere.
It's still under warranty, so I'd like to approach the dealer with some knowledge. Thanks.
cbharvest
Also, on hot days (over 90 degrees), the car is very sluggish. From reading some of the past posts, maybe my O2 sensor(s) are bad. How can I find out if these sensors (how many and where are they located) are bad and are they costly parts to replace (can I do it myself)?
Thanks for the help. -Bruce
Had an independent tranny shop look at it and they confirmed that the only fix was a rebuild and this problem is pretty common for 93 to 94 Mazda 626. I was told that the 95 models and later had redesigned transmissions to address this premature failures.
Has anyone had similar problems to mine?
I did the same thing and voila! The rough idling is gone. The cost was about $100 CDN ($60 US) to buy the parts and install myself. Mazda parts were a bit expensive; I picked some up from PartSource.
Doug
The Mazda slushbox used in all '93s and the six-cylinder cars afterwards has its own set of quirks.
I'm certainly no mechanic, but here's a list of some of the problems I've encountered which I don't consider ordinary maintenance (correct me if I'm wrong): (1) new transmission (to add insult to injury, they installed a defective rebuilt transmission which failed 3 months later); (2) shift lock repair; (3) leaking valve cover gaskets and freeze plugs; (4) replaced air bag module and control unit; (5) replaced stop light checker and relay; (6) air conditioner gasket repair; (7) repairs to the lifters and cruise control; (8) air conditioner compressor repair (after this point the extended warranty expired); (9) something called the "rocker pulley harmonic balancer" (are they yanking my chain?); and (10) replacement of the "air flow monitor".
And yes, I am getting rid of the car. By the way, I had the same stalling problem as cbharvest -- replacement of the air flow monitor seems to have cured things. Now if we can figure out how to fix the idling problem (the latest development). Has anyone else tried replacing the spark plug wires as suggested by dougmckeen?
I had my airflow meter replaced after it shorted a little less than two years ago. The dealer said that this was the problem when I took it to them with an engine light symptom.
Since I have started delivering food for Jason's Deli, I've noticed that the car doesn't like to be run all day without mildly overheating the engine. This could be due to the stop-and-go, high acceleration city driving that is required in the delivery racket, or the fact that my radiator spoiler is in shambles (from hitting a lot of parking blocks).
Recently, I had three of my motor mounts replaced, which remedied rough idling while in drive. This cost about $750 from a SAAB mechanic.
At 102k, the engine still purrs nicely, but I am worried about the AT. I don't know what's wrong with it, and I don't know much about trannies, but it doesn't like to downshift without a big fuss. It also clunks in a lot. The 'D' light on my dash never comes on, but it was like that when we bought it used two years ago and I think it is actually just burnt out.
If anyone can offer any advice to me, I would be greatfull. I like this car even though it is getting old, and I'm wondering wether or not the tranny is altogether spent.
Of Disenchanted's ten problems, I have had one - there's a bit of weeping from my valve-cover gasket. Unfortunately, these aren't the sturdiest automatics in the world, and I figure I'm probably living on borrowed time in my own '93. Certainly I wouldn't consider any of those items "ordinary maintenance". And warranty companies - but I digress.
As for Brendan's tranny, well, it's hard to say how long he has before the slushbox turns to slag, but a lot of people have reported CD4E transmission failures way before 102,000 miles. Were it my car, I'd spend the $100 for a flush - there's no bottom pan, so dropping the pan isn't an option, really - and see what happens.
And, more to the point, kapps and family own three Mazdas. It's definitely in Mazda's best interest to keep them happy; the company might think twice about someone who posts all over the Net that he'll never buy another Mazda, even at gunpoint.
(Disclosure: I have a Web page which details some of the 626 tranny problems. God only knows what Mazda thinks of that, or what they will do when my own 626 gets towed into the dealership.)
I suppose the trade off is $60 for new wires every X?? years versus $400-500 every 30k miles (2 years for me). Are there any other problems with having bad gaskets?
Doug
Here are problems that I have found to be true with bad valve cover gaskets: Rough Idle, & loss of power are the main two, try to imagine your car with two less cylinders. As for keeping on replacing the wires & plugs they go bad shortly after you put them in. Best thing you can do is try and find a mechanic to give you a good deal. Bad part is that to get to the back valve cover gasket on the V-6 you have to take a whole lot of stuff apart, the last mechanic that did mine could not believe how hard it was. Chances are the price will be constant because of this, but I would definatley see a mechanic about this, and also I don't know how many miles(km) you have on your car, but it is very easy to change the timing belt while doing this procedure since the engine is apart anyways, might be worth an extra 50bucks instead of having to pay 250-300 later. If you have anymore questions you can e-mail me at Jco@skantech.net I have been through this procedure so many times, that by the 2nd time I could tell the mechanic exactly what was wrong before he even looks at the car.
I own 97 Mazda 626 97. There only 48k and trans is dead. While car was on a warranty I've heard some rumors about transmission problem Mazda 626 had. I dropped my car for the oil change at dealership in Vienna, VA at inquired about this problem from Service manager. He assured that he never heard about this problem, but suggested to use an innovative transmission service for about $120-130 that changed transmission fluid under the pressure (..new technology). So... my transmission is dead and I barely made to the same dealership.
Their estimation is .....to replace the entire transmission at cost $2,700 + tax.
Anyone experienced similar problem?
If you have the four-cylinder 626, you have the LA4-EL transmission, which is actually Ford's CD4E, and the old drop-the-pan-and-change-the-filter transmission service doesn't work for it, since it doesn't have a bottom pan to drop; you have to do some serious disassembly to get to the filter. All the more reason to do the flush, I'd say. (I had this done on my '93, which has a different transmission, last year, with no discernible ill effects.)
Still, if they botched the job, they could have done all manner of damage.
Stephanie
In response to your valve lasher problem, it is typical. My V-6 ticked like crazy especially when very cold in the morning. My trusty mechanic told me to do the synthetic oil deal, and go with 5-W30 oil, and also cleaning. This helped a great deal, but did not cure the problem. But it is a much more inexpensive alternative. A car of that age you must just live with some things rather than spend a ton of money. You can make the call. Just curious how many miles are on your car? Mine started ticking around 50K and is still doing the same at 94,000. But I don't plan on keeping it forever.
I've been through the normal wear and tear maintenance that all car owners deal with but I've suffered through more than your simple oil change and brake work. Less than a year ago I heard a clicking noise from my engine and ended up spending $1000 having all the valve lifters replaced. Around that time I also noticed an engine light. I had the car checked out and was told it was an 'atmospheric change' that caused it to come on. The second time it happened the mechanic claimed it was some sort of sensor problem. I haven't seen the light since but the fear is still there. I've also been experiencing idle problems. My car runs rough and... to make a long story short... several repairs later and I'm stuck with bad transmission fluid (no one will change it without replacing the whole transmission), horrible shaking at stop lights, and bad rear struts. I've just been told that I owe another $710 for "normal wear and tear" maintenance and I'm sick about it. Anyone want a used 626?
Do these problems seem normal - am I living in lala land thinking that car ownership should be less aggravating?
I'm paying off a $2200 transmission replacment bill on my Master Card.
I just got a quote today for $2,334.96 to replace the trans on my '98 626 LX (automatic, of course). The dealership says it burned out on the inside. It now has 66,000 miles (yes, I drive a lot -- and NEED my car!)
Particularly frustrating is that at about 24,000, two of my plug wires were completely burned out. I got those replaced under warranty, but no one could figure out why it happened. Shortly thereafter, my blower motor went out -- no wipers, defrost, anything, in the middle of a snowstorm. In my opinion, none of this should have happened/be happening at the mileages I'm talking about. I bought another Mazda because my first -- a '91 Protege DX, 5 sp -- was SO reliable. It took a semi-truck to kill it at 153,000.
Right now I'm looking for another car, and I don't think it can be a Mazda. I can't find a Protege manual transmission. This is the first AT I've had in over 20 years -- I got tired of popping my knee at 40 yo! -- and I don't think I'll have another one of those, either.
Can anybody recommend a good, very reliable car, that's within the Protege price range? I can't afford to stay in the 626 class because this has me taking on more debt than I can handle right now. And why or how do folks think this can be put back on Mazda?
Any ideas appreciated. Thanks
If you have any specific maintenance or repair issues on your current vehicle or a new one, then come on back here and talk to us about it.
Good luck!
Pat
There is one I'm going to see this weekend. 1991 Mazda 626LX, 4DR, HB, 5spd. The car has 206K (km), but the engine has been replaced 2 months ago with "low km" engine as per owner. He could not explain why the original engine died... He claims that "new" engine has had only 40K on it and it came from salvaged car. He is asking $3995 CAN for it, but might let it go for $3.5K
I would appreciate any advice on the above. I've read some horror stories about Mazda's AT at http://www.alvant.alva.ok.us/dan/fan.htm but that should not be relevant to this one should it?
Andrew.
Have you been to our Sedans conference and taken a look at this topic:
Mazda 626 - Part 2 (Topic #2993)?
That would be a good place to find out more about what folks around here think of the current model of this vehicle.
Don't lose sight of the fact that this is the Maintenance and Repair conference, so you are more likely to read about problems here than the lack of 'em!
Pat
1) Park the car for a few hours. Then start the car and move it a few feet and shut off the engine. Leave overnight. The next morning, when you start the car, there is a loud rattling noise in the engine (as if there is no oil in the engine) that lasts anywhere from 5 seconds to 30 seconds. The dealer tells me this is normal. What is your opinion?
2) The brake rotors are warped. The car still has 100 miles left on the warranty. The dealer tells me that warped rotors are not covered under warranty. Is this correct?
FYI: I already had the automatic transmission replaced under warranty last week.
Rotors generally are a normal-wear item; I wouldn't expect them to be covered by the warranty.
Now what happened to the tranny?
As far as the Valve cover gaskets, they are not that difficult to replace, I did mine on my '95 Probe GT(same engine as the 626) in about 6 hours, but I also cleaned the intake and throttle body, and installed phenolic spacers http://home.san.rr.com/scmorgan/spacers.
I do have another comment, I noticed that several people made comments that the transmission was a Ford and somehow that may be part of the reason for the Mazda troubles. My current car is a 1992 Ford Tempo, it has 167,000 miles and I have had no transmission problems, knock on wood!
Mazda has been remiss, I think, in not recommending regular fluid changes for its automatics. In the manual for my '93 LX, while there are references to how to read the dipstick and such, there is no indication whatever that changing the fluid might be something one ought to do.
And heat is definitely a Bad Thing for automatics generally, so installing an auxiliary cooler makes sense.
