and i checked the blinker lights and the front right was out
could this be why its not blinking at all not even on the dash.
i had the same thing
do u own a timing gun
if you dont then you would have to play it by ear
frist you losen the distributor just to the point were you can move it.
your going to want to turn it troweds the car but not to much.
also when is the last time you change the plugs and wires
and change your oil?
I noticed someone had the same problem I'm expereiencing and am wondering if they were successful in getting the matter fixed. I went to Mazda, they charged me $300 to tell me I need a new transmission. THe car drives perfectly fine, and when I put the gear in reverse it kicks like it wants to move, but the sits there.
the last time i changed my plugs and wires was probably january or feb 07.. not too long ago.. my car wouldnt start and it had just snowed so it sat for a couple days and the i bought both and some mechanic changed it for me. And i change my oil every 3 thou miles but i think ima hav to start changing sooner and more often.
ima try what you said tho..
thanks for the info
http://www.troubleshooters.com/toverheat.htm
Just as a general rule, your symptoms are signs of a cooling fan/shroud problem.
"Serious overheating in heavy traffic but not in open driving is an indication to investigate the fan, fan clutch or motor or relay, or shroud. Some cars have two fans, and both should be on if the engine is hot."
Visiting Host
I've tried three different gas stations, different grades of gas too. At first I thought it was the hot weather expanding the gas but then it has happened each time I've filled the car no matter the weather. One gas attendant said it was because something needed to be cleaned out and it would probably cost $700 in NJ but cheaper in NY.
Not only do I not want to get ripped off, I want to know what the problem is in case it's an easy fix I can do myself.
I own a mazda mx6. Recently i was told that my catalytic converter was blocked. My car has not been shifting gears and going very sluggish like at times i cannot get it to go above 20 mph. I was wondering if there was a quick fix to this because im about to trade my car for a honda prelude and i have to get it to the guy because we are trading cars. He is aware of the problem but at the moment i just dont think my car will make it there. IF you could let me know if there is any way i can make my car work for a short period of time that would be great. thankyou.
One issue common to these cars is clogging of the EGR passages in the intake manifold and engine block with carbon. This results in engine light coming on, sometimes intermittently. The code is I believe P400 (insufficient EGR flow). The way to fix this issue is to remove the throttle body and spray carb cleaner into two passages on the bottom of the intake manifold just past the throttle body. These are EGR passages. They run through the manifold and the engine block all the way to the EGR valve. Replacing the EGR valve will not fix this problem! It is an electric valve and very expensive - about $ 350, even from aftermarket sources. So do not replace it unless you are absolutely sure it needs to be replaced.
But first find out what the trouble code is in your case.
At 92k miles you should: replace the timing belt if it has not been done already (recommended at 60k), including all three tensioner pulleys. Auto Zone sells a nice timing belt kit that includes the timing belt and all three pulleys for something like $ 100. Do not even try to price these from Mazda, as it will be about $ 700! And bearings wear out in these pulleys believe me! I replaced mine at 105K miles. Also, check the tensioner pulleys on the engine drive belts. The pulley bearings tend to go bad. You can buy replacement bearings, but you need a hydraulic press to pres them in and it is a tricky process. New pulleys are expensive - almost $ 100 a piece. Even aftermarket ones are expensive. You should think about replacing the plug wires if it has not been done already. What about brakes? Are pads in good shape? Check the outer CV joint boots. They often start splitting around 90-100k miles. You may want to change the water pump if you do the timing belt. Be warned - changing the timing belt on this car is not easy! I have done it myself so I know. You need to remove the front engine mount to install a new belt and to replace the water pump. I do not recommend this job to anybody without sufficient experience. You are best off finding a good mechanic to do this. There is a lot of pitfalls associated with this job.
That said, here's the problem. My fiancee was going to leave for work today and noticed the shoulder restraint motor was moving slowly. She tried starting the car but it wouldn't work. She only got minor accessories - the car would crank but not start. We figured the battery must've gotten drained because the accessories could've been left on over night (our car somehow allows this).
So I came home to give the car a jumpstart and off to work she went. She called me and said that the car wouldn't start again, so the alternator must not have had a chance to do its job, even though she let it idle for a half hour in addition to the five minute drive to her job. I came over to her place of work to give her another jumpstart and so we went home, with me following in case she got stranded.
Sure enough, one block from our house, the car died at a stop light. I came around and tried to give her a jumpstart again but this time the car wouldn't start. It would crank but not turn, as if my car's battery weren't connected. We brought the battery to Wal-Mart to have it tested and charged. They gave it a clean bill of health and said it was charged, ready to go. After putting the battery back in the car, it wouldn't even crank. Dead as a doornail.
This is extremely frustrating, especially after spending over $500 on the above repairs. Does any one have any idea what could be the cause or solution to this problem? Thanks so much!
Has any one out there experienced anything like this please.
Will appreciate if you can share the solution with me....
Thanks in advance,
Perry
-Perry
Please assist!!!
Thanks you all....
The Mazda Club Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
....Every time I take it to the shop it it rarely acts up or they say they don't know what it is. Has anyone experienced this?
One last thing....I have noticed that after a long road trip my engine light will flash when I accelerate .....is this a sign of transmission issues to come?
New Issue ---today I smelt coolant so I looked under the hood and a tube(right in the center and above the spark plugs) had come loose from the engine! I put it back in and it seems to have stayed throughout the day...How big of an issue is this?
There is a weird noise that appears 5 minutes after warming up the engine and gets louder. Noise is localized in the area on the passenger side from the valves. Noise is dependent on engine speed.
Does anybody know what is that?
<img src="
But then my battery died this summer (2007) and when I put a new battery in the idle surge problem went away. Unfortunately it came back again after about 4 months.
Now the lock on the shift automatically locks on it's own, I am trying to help her with this problem.
Can any one give me some insight on this transmission problem ?
dennis
Anyone know what this code is and how to repair?
I'd like to know how to access the trouble codes stored in the computer.
is there a cable and software that I could plug the car into a laptop with?
ok now the question of the day...
193,000 miles, at idle the engine runs a bit rough, new NGK plugs installed and didn't help. think it may be ICS? has a vibration at 1500 rpm in neutral, oscillating somewhere.... harmonic balancer?
This is the first small car I've ever owned, I love it so far, but I really am not used to dealing with computer controlled cars. sometimes I wonder if I've got the rubber band wound too tight.. LOL
thanks for any help ya'll can give...
John
with the trans of this era is they are too small for the weight of the car causing
them to overheat.
