Mazda 626 Troubles
1111214161750
  • johnny01johnny01 Member Posts: 8
    Hello. I just got a CEL at 59,540 mi. I'm thinking it came on because it's telling the 60k mi. check is almost due. It's been two days now and nothing noticeable to report other than the CEL. What do you think windowphobe6?
  • windowphobe6windowphobe6 Member Posts: 765
    OBD-II cars (and this is one) aren't supposed to click on this light unless there's an actual code set, regardless of mileage. The most common cause of these things, actually, is a gas cap that isn't maintaining pressure.
    If nothing else is going on, the computer may decide that it's a temporary glitch and blow it off - under some conditions, if an intermittent problem doesn't recur, the standard allows for the code to be erased - but if the light stays on, I'd have it looked at when you get around to your 60k service. (At the very least, you need an oil change and a timing belt.)
    Now if it starts flashing, don't wait.
    - The CEL has been steady on for two days. Speaking of the timing belt, I would like to delay the change for at least 10k. I want to trade the car in for something newer next yr, and if I spend $500-700 on the 60k service I feel obligated to keep the car (and get my money's worth)for another 2 yrs.
    Next week, I will take it in to my usual Mazda dealer for a Lube/oilchg and ask them to read the codes also if the CEL is still on. thanks
    Beyond the gas cap, one thing that often sets this critter off is an oxygen sensor on the edge of decay. The engine computer will compensate for these things to a certain extent, and you may notice little or no change in driveability, but its effect on emissions is not favorable, and some places are more anal about emissions than others. (Somehow, that doesn't sound very good.)
    And let it be stated here that I've never heard tell of a timing belt actually breaking on one of these cars until quite a bit past 60k; this may be Mazda's attempt to respond to California's attempts to suspend the laws of physics. (In the Golden State, timing belts last 105k miles; the Assembly says so.)
  • cmeyer3cmeyer3 Member Posts: 1
    I have a 1985 Mazda 626 lx. Recently the electronic light kept flickering on and off during driving and it seems to lose power while driving it. I took it to the local Mazda dealer who for $80 computer analysis told me the fuel pressure modulator (i think) and the intake gasket was sucking in. I then took it to a mechanic I know well who said it is registering 40 lbs of pressure which should be fine and the gasket looked ok. He did replace the plugs as they were all mismatched and checked the exhaust to make sure the converter wasnt plugged. It still loses power while driving it. He is at a loss, I suggested the fuel filter from reading some of the message boards. Could anyone shed some light???
  • 626blues626blues Member Posts: 2
    Hi, I am new to the forum and have been reading the posts related to transmission failures in the 626. I have not read every single post, so I hope I am not beating a dead horse here, but I bought a new 1999 Mazda 626 ES 4-cyl in October 1999. In March of this year at 27,000 miles I was returning from a ski trip with a gaggle of girl scouts in the car. I had stopped at a stop sign at the bottom of a not-very-steep hill, and when I tried to proceed, I had to floor the accellerator just to keep from going BACKWARD. The transmission had felt like it was slipping a bit for the previous week, but I had no inkling that it would get so bad so fast. Thank God I was fairly close to home, and limped back cautiously with the O/D light blinking furiously. I took the car to the dealership the next day (with absolutely NO problem, no tranny slippage, nothing) and the transmission was replaced. I felt none too happy that at such low mileage I had to have the trans. replaced, but I am such a Pollyanna I figured that was the end of it. Of course I was mistaken. Even as I type this my car is in for its SECOND transmission. I now have 30K miles on my car, so that averages out to, what, 1 transmission every 10,000 miles??
    Not being a litiginous person, I have no idea what my legal rights may be, but I still owe too much money on this car to feel that this tranny problem is something I should have to deal with. I went into this purchase with a ton of Mazda loyalty, my 1989 323 is still in my driveway with 170K miles on it and it has been nothing but reliable, although understandably it is now older and tired.
    I have little faith that this problem will ever be put right, and I basically want my money back.
    If anyone has any suggestions for me, they would be very much appreciated.
    Your 99 626 should be under the orginal manufacture's warr for the transmission. Correct me if I'm wrong, but isn't it 36 months or 50k miles?
    Yes the '99 is under mfg warranty, but when they replace the transmission, although the CAR is still under the same warranty, the warranty for the TRANSMISSION changes to 1 year. It's dictated by Mazda, I checked with them when my dealer told me because it did not sound right. And yet, that's the way it is. Yet another reason that I am uncomfortable.....
  • kifil032kifil032 Member Posts: 1
    I'm considering buying a USED Mazda 626 EX, for a first time car. This will be my first car and just trying to get something to get around with, but at the same time looks decent for under $6000. Has anyone had any problems with this car. If so how expensive is it to fix? Any reliability issues? Appreciate any help.
    Take the time to read the prior 659 posts to this msg board. 1994 was the worst year to own a 626. State whether your car is a 4 or 6 cyl and auto or manual. Might as well tell your milage, also.
  • rayfbairdrayfbaird Member Posts: 183
    I have a 1991. It is a fun car to drive. It can handle mountain roads and curves with aplomb. My wife was scared of a canyon road and went down the canyon at 15 miles over the 35 MPH speed limit. When asked why, she said because I knew the car should handle it. We have really enjoyed the car.
    I have a manual transmission. It works well. If the car you want has an automatic, smell the fluid. If it smells burnt, or is any shade darker than a bright pink. Go the other way, or ask for a 2,000 reduction (the cost of a replacement transmission)
    Timing belts probably should be changed every 60,000 miles. My shocks had to be replaced at 80,000 miles.
  • mrdetailermrdetailer Member Posts: 1,118
    If you have it from the original owner, or one who has owned it a long time, you can find out how often maintenence was done, and what repairs were performed. Then you can find out if the pedigree is good or bad.
  • katty2ukatty2u Member Posts: 3
    I looked at a '95 Mazda 626 LX this afternoon. It was a 2.5 6 cylinder with 91,000 miles on it. I didn't know much about Mazdas going in to looking at that car, and I told the salesman I didn't know if they were as good as Toyotas and Hondas. He of course tried to tell me they are just as good. From what I see on here they aren't. It looks like they have transaxle problems, AC problems, and are expensive to repair. The one I drove did shift rough, but so did 2 Accords I drove the other day. The salesman told me the Japanese use some different shifting mechanisms than American cars. I don't know to believe him. I wish I could find a Camry or Accord for the price of this 626! Anyway, I'd like anyone's opinion on what I should do. Thanks!
    Who worked for a dealer for 20 years said when purchasing a used Mazda with an auto Transmission, if there are any problems don't purchase it. He and I both have manuals.
    Mine has 115,000 miles and aside from steering repairs caused by an accident on Ice, and some normal maintenence items, it's been very good. It's a fun car to drive.
  • johnlwjohnlw Member Posts: 28
    Our 1998 626, 4 cyl. auto is about to run out of warranty--end of August. It has been mainly driven by my wife.
    It has about 36,000 miles. I have changed the oil every 5000, did the 30,000 mile service on schedule, and have had the transmission replaced under warranty. I believe the new tranny to be rebuilt.
    I wonder whether to cut my losses now, and trade it in while I can get something for it. The car is nice, sunroof, alloy wheels, roomy, clean. We have garage kept it, polished the paint like new.
    So why trade it in? BECAUSE OF THE STUPID FORD TRANSMISSION! (sorry) I think I can get $10,000 or so.
    Has anyone had a positive experience with this car and transmision? What % fail? We thought it slipped the other day, but no. Next time we'll get a Honda.
  • qbrozenqbrozen Member Posts: 33,798
    Trust me on this one - you're not getting $10K trade-in on that car. I've got a '99 with the six-cyl (the 6 adds about $1000 to the trade-in value) and trade-in is about $9K on it.
  • jim243jim243 Member Posts: 7
    I having a stalling and then a no start problem with a 1990 626 LX automatic with abs. I think it is the fuel pump and I need to know where the fuel pump relay is located so I can check it. Also to remove the fuel pump after taking off the access panel under the rear seat, do you just remove the 8 tiny screws or is there something else you need to do? I would appreciate any help you could give me.
  • jskhojskho Member Posts: 107
    Has anyone replaced the clutch on a 94 V6 5sp?
    I am wondering how much will it costs.
    I guess it is more valid to ask how much the parts cost and how many hours of labor will it take since labor rate is $75 at the dealer in my area.
    I know it depends on how you drive but in general, how long would a clutch last on the V6s based on your experience?
  • aggiedogaggiedog Member Posts: 238
    I own a 1993 626 ES v6 with 165,500 miles. I had the clutch replaced about 8 months ago. The price of replacement all depends on where you go. I live in Maryland (Washington DC metro area). The dealers all wanted about $1,500. AAMCO was about $1,200 (12 months/12miles warranty). PEP Boys said they could do it for $400. Of course I took it to them and they proceded to tell me it was my transmission and not my clutch and they don't do tranny work. I then went to AAMCO and I haven't had any problems since (roughly 6,000 miles of driving). This was the first major problem I've had with my 626 but I try not to drive it that much any more because of the high mileage. I'm going for 200,000.
  • lint0rlint0r Member Posts: 1
    I recently had to get my distributor fixed. does anyone know how much that should cost? cause the bucking mechanic charged me bucking $820 to fix that and get my oil changed. well since I got that fixed it wasn't been giving me any problems. my "engine electrical" light is also going off all the time. the mechanic said that might be a weird 02 sensor, which he'd gladly replace for $300. the [non-permissible content removed]. besides that, it's a good car. does anyone know what I can do (cheap) about the engine light?
    I also just put in two O2 sensors. I had to because my car failed an emissions test and I wasn't going to pay dealer rates for an O2 sensor. Why this car needs two I have no idea. I got them at AutoZone (again in the DC area - although they do have a web site and will ship them to you) for $64.00 apiece. I think the dealer wanted about $189.00 apiece plus labor. They are easy to put in yourself and I didn't need that stupid O2 slotted socket that I paid 8 bucks for. I just used a 12 inch long 1/2 wrench. I think an adjustable wrench will work as well. Just don't burn yourself on the exhaust pipe. You have to let the car run for a couple of minutes because the pipe these things go in expands and contracts. It gets hot real quick. I let mine cool down enough that I wouldn't get burned and they came out rather easily. Of course you can always take out that check engine light from the dash.
  • haroldhxharoldhx Member Posts: 2
    It's me again with a 94 Mazda 626 LX.
    Recently, I found that it's quite rough to start my car. After I left my car to the dealer for two days to repair a fan switch, it's getting worse. I don't mean that the car cannot start. Just that after I turn the key, the engine or the car ( I couldn't tell) trembles and knocks loud before it's started. But if the engine is warm (after a short trip), it starts quieter and smoother.
    What could be the problem?
    Do I need to go to get the fuel injection system cleaned?
  • josie5josie5 Member Posts: 3
    Hi
    I just purchased a 1990 Mazda 626 DX Sedan with 103,000 miles a few months ago for $2300.00. (Too high?) My mechanic (whom I purchased the car from) put in a used transmission (30,000 miles on it)- which is still under warranty. I also purchased all new engine mounts for the car as well (almost $500 bucks).
    Besides the check engine light always on (which my mechanic said it's "nothing to worry about") and the shaking that happens when my car's in drive (but not in park) my question has to do with a transmission gasket that I recently learned from Jiffy Lube, that's leaking...
    Is the trans. gasket part of the actual transmission? Or is that something I'll have to pay extra for? And if so, how much?
    Appreciate the help,
    Jolene
    Let's discuss Jiffy lube and leaks. When I take my cars in for oil changes I always get the comment from Jiffy Lube that I have oil leaks. the last time was after I first put in synthetic. Normally I put in 3 quarts of conventional oil in 6,000 miles, but with synthetic it consumed only a quart.
    They always notify you of leaks no matter how slight. Sometimes they are not serious.
    Another time, they discovered a major oil leak from my valve covers that I hadn't noticed before. Oil levels had dropped a quart in 3 weeks. I got the gasket replaced and it stopped.
    Did Jiffy report that your Tranny fluid levels were low? If they didn't it might be a slight leak. Put a piece of cardboard under the tranny overnight and see if there is some dripping. It it's serious take it in.
    I would also take it in in a week to have the level checked again. If it is normal then check it once a month.
    It is a part of the transmission? It might as well be. A normal service on most transmissions requires removal and replacement of the gasket. If it leaks and causes significant loss of fluid it will ruin the transmission.
    when is the last time it had a tune-up?
    could be a weak spark.
    Josie5 - you bought it from a mechanic? I would say there should be nothing wrong with it. If there is, take it back to him/her and tell them to fix it.
    Thanks for the advice :)
  • matthewa1matthewa1 Member Posts: 1
    I have a 93 626 that i purchased used. It is an ES model with a 2.5 V6. It has plenty of power and is quite fun to drive. The automatic transmission shifts very hard, and when it is cold when you first crank it up it will eat second gear up. It had pretty high mileage but every thing seemed fine except for the AC not working. But one week after i bought i had to replac a front axle, and about two weeks later i had to put another one in on the other side. And now a few months later the damn thing wont start. It wasnt getting fire to the distributor cap so i replaced the coil. But now it still wont start and still isnt getting any fire. I have no idea what the problem is so if anyone knows or has any idea what the problem is please let me know. And if your thinking about buying a 626 dont. If youve got the money get a camry, there more expensive but well worth it.
  • agt_cooperagt_cooper Member Posts: 202
    You mention that you bought this vehicle used....how used? Did you know the history of the car before you bought? Is it possible that the previous owner didn't maintain it properly?
    It's a shame you're having problems, but that is not necessarily grounds to condemn the entire 626 line. I happen to have a 97 with the V-6, and it has been virtually flawless. I looked at the Camry at the time I bought this car, but found the Toyota to be far too expensive with the V-6, as well as being really boring to look at and drive.
    To each his own.......
    As for recommendations on how to fix your problem, I'd consult a qualified technician. You might end up spending more swapping out parts on your own than you would having someone familiar with the car diagnosing the problem.
  • ian18ian18 Member Posts: 133
    My '93 ES V6 626 is doing fairly well. It is a 5 spd and terriffic fun to drive. After 80,000 miles it has had some problems but on balance it has not been too bad and seems quite reliable. I did have a problem at around 60,000 miles when I had to replace the distributor. As I recall the symptons were that absolutely nothing happened when the ignition key was turned. Unfortunately the distributor was quite expensive to replace although I understand that rebuilds are now available.
    How many miles on your car? Has the timing belt been changed?
    Naah!, it's just older. Things wear out and have to be replaced. On the bright side I've found steering components to be much cheaper than on my Subaru. I'm surprized your mechanic didn't recommend replacement of both axles at the same time. These along with tie rod ends, struts and strut mounts are best replaced in pairs. My wife slid on ice, and we have had to replace several steering components. Insurance paid for the wrecked side, but I had to pay for the undamaged side. The parts at 115k were showing wear anyway.
    If your regular mechanic can't find the starting problem, find an automotive electric specialist. They can diagnose and repair difficult things like this better.
    Put 150 miles on the Mazda just yesterday. Just as much fun to drive as the first day I got it.
  • steelerfan826steelerfan826 Member Posts: 1
    Hello, I own a 1998 626. My automatic transmission failed at 51135 miles. I've purchased the car in 99 w/20,000 mi. Ford makes the autotrans. Knowing this I changed the fluid(easy to do) every 10000 mi. but it still failed!
    1000 mi past warranty just my luck right. anyway,
    this is what happened first the tranny started to shift real hard(like a shift kit) then the check engine light came on. this happened on the freeway. I got off the next exit.checked all fluids checked good.when I exited the parking lot
    I noticed the car was taking off in 2nd gear not 1st. The Dealer wanted to charge me customer pay.
    I complained to the Service manager and got it fixed under warranty thank god. this tranny is not cheap try $2700.. I talked to the mechanic and he told me the Protoge, Pick ups, SUV, Minivan
    have Ford trannys. The Miata and Millinea have
    Japan made tranmissions. My confidence in my car has been rattled. good luck to my fellow mazda owners.
  • conradsmithconradsmith Member Posts: 10
    I've got a '93 626 LX 4-cyl with about 170,000 miles on it. I'm quite happy with it and have had very few problems. However, just last week 2 of the plug wires started popping out of the 'silos' in the valve cover. They are hard to re-seat. It feels like air is compressing under the boots. When they pop up the plug wire is still gripping the plug, but the boot pops up, so the wire starts arcing to the valve cover causing rough idle and very sluggish performance. The entire set of plug wires was replaced a few months ago. How do I get the plug boots to stay on????
    The Protegé through 1998 uses Mazda's F4A-EL. Later models use the NA4A-EL, which is related to Ford's 4F27E (in the Focus) but which is not built by Ford.
    The Trib and the US B-series trucks have all-Ford powertrains.
    The MPV has a Ford Duratec engine coupled to Mazda's GF4A-EL tranny. (No, I don't know why.)
    I suspect anyone who swore by Japanese-built transmissions would swear something else after dealing with a couple of Mitsubishis. :)
  • freds5freds5 Member Posts: 5
    I have a 1998 626 LX 4cyl.-auto. Shifting from park to reverse is rough and "sticky"(from park to drive is sitll "sticky" but not as bad), which makes the whole car shake. I took the car to the dealership and told them about this problem when the timing belt was replaced at 60k miles. They said this problem is caused by a "weak mount". To do a propper diagnostic it would take them 2-3 hrs of labor time, they didn't say this would include repair cost. The transmission has been shifting between gears O.K. (jerks between 0-20, and 20-40 in stop and go traffic), but will this "weak mount" problem become aggrevate over time. Has anyone else heard of this problem before? I really appreciate this site and all the useful info on it:)
    It's perfectly plausible, and yes, it should get worse as the rubber bits in the mount gradually erode away.
  • morris19morris19 Member Posts: 1
    I have a 97 626 DX and the engine light came on a few days ago. The car runs fine. I don't have a manual(lost it) so can anyone tell me what this could indicate. Post an answer or e-mail me @ morris31@hotmail.com....Thanks
    This indicates one thing and one thing only: the need to have these codes pulled by someone with an appropriate scan tool. I realize that most people would rather gargle with Grandma's lye soap rather than spend two hours (and two hours of labor charges) getting problems diagnosed, but it can't be helped. Either ignore it, or get it looked at. There is literally no way to know what has happened without those codes.
  • allenbe44allenbe44 Member Posts: 1
    I recently purchased a 94 Mazda 626 ES with a V-6. I bought it from a 1 owner who didn't do good maintenance. The transmission shifts real hard from 1st to 2nd gear. Sometimes it will shift hard from 2nd to 3rd. Is this a sign of major transmission problems or with a little maintenance on my part, I can have this car shifting smoothly. I need help to get this car ready for my daughter who is returning to college this coming month.
    Also the brakes have a loud squeal to them. What is the best maintenance for this?
    It's not necessarily a harbinger of doom, but the tranny fluid is probably a shade of charcoal grey that looks great in suits and lousy in sumps. Get that changed pronto. And be aware that any Mazda tranny (this is the GF4A-EL) is going to have fairly firm shifts; this is a conscious design decision.
    Brake squeal is usually an indication of pad wear, in which case the fix is to replace the pads.
    Of course codes will have to be pulled.
    My son's 1997 had this problem. The air flow was listed as wrong. They replaced the Oxygen Sensors and it ran fine for about 3 weeks. It went on again with the same codes. This time we took it into a Mazda Specialist. They said that they regularly have a problem with the Mass Air Sensor located just behind the air filter. They cleaned it up for $35.00 bucks. If it acts up again, then we will have to get it replaced.
    Those stupid sensors are expensive, but a necessary part of a very low emission vehicle.
    My son has a 1997 626 that had a huge amount of noise from the power steering pump. At 62,000 the transmission is still OK -- Knock on Wood. It took 2 days to get it in, and when it was put on it gave out the identical noise. My mechanic wouldn't let the car out in that condition. Another 2 day wait for another pump to come in from the east coast.
    My 1991 has steering that works great. Never needed anything.
    Have there been many others with power steering issues?
  • craigs4craigs4 Member Posts: 9
    A great source of Mazda maintenance information is www.probetalk.com It is searchable. The Mazda 626/MX6 and Ford Probe from 1993-1997 were the same vehicles under the skin. The 2.5 V6 has the 4EAT automatic transmission. It must be flushed regularly or it will die prematurely, Mobil 1 synthetic transmision fluid and a Magnefine inline filter also help. It also greatly benefits from an additional aftermarket transmission cooler installed in line after the factory one in the radiator, link them up using the lower hose. Finally, the 93-95 models have a famous distributor problem that you can learn more about at probetalk. The Magnefine filter was recently approved by Ford. See www.emergingent.com and the Magnefine subpage. The power steering system also benefits from getting flushed as the fluid deteriorates and most dealers or modern facilities can do this.
    How often should the power steering be flushed?
    Frankly I didn't know it should be done regularly until recently.
    I'm thinking 60k, though there is no specific recommendation for it in the official literature. PS fluid is similar to transmission fluid - some cars actually specify transmission fluid to be used in this application - and it's subject to the same sort of deterioration, though probably not as dramatically as the Dexron floating around in the slushbox.
    And I'd like to second the recommendation for probetalk.com. It is a valuable resource for anyone with a third- or fourth-generation ('88-'97) 626.
  • mrsnoahmrsnoah Member Posts: 1
    I am new to this board. I have a '90 626 that recently has begun to idle badly after the car is warmed up. While it is cold, the fast idle prevents the problem - although even then it's not perfect - but once it's warm the engine idles rough, inconsistent (up & down), and it has even stalled on me once or twice. A lot of times it nearly stalls, but recovers before it actually does. It is a 5-speed. Has anyone on this board ever had this problem and what is the fix? Thank you
    Mary Kay
    I too have a '97 that had problems with the pump. It was replaced at about 20,000 miles... Noise only happened when temperature was below about 40 F, and would go away once the car was warmed up. Warranty took care of it, no problems since...
    This is an older car like my 1991. Have the spark plugs and wires been replaced? Has it had a recent tuneup? Have you gone to a mechanic (not Jiffy lube) and paid for a fuel injection decarbonization and cleaner?
    While power steering fluid may be similar, it does not have the same properties any mores. Not one of my 3 cars specified tranasmission fluid.
    I changed the fluid on my Mazda when smelled the difference between 2 of my cars, and one that had the power steering pump replaced about 20,000 miles ago. It is a stinky fluid anyway, but the older ones, especially the Mazda smelled burnt, and looked a little bit cloudy. I put in lubegard for about $7.00 USD and spend about $50.00 to have the powersteering flushed.
    It seems to work a bit smoother, and anything that I can do to save a power steering pump repair is helpful. On my Dodge, it went out 3 times. Fluid all over the road, and steering really hard, before they finally got a pump that held up OK.
    My son's 1997 626 DID NOT have a power steering problem. After replacing the power steering pump the first time they thought it was defective. They put in a second pump. It sounded exactly the same as before.
    With good reason. It was the air conditioner bearing. The two in some models, this is an auto tranny with a 2.0 engine, are right next to each other. As it stands right now the air conditioner compressor is being replaced at 62,000 miles. Our mechanic is eating the cost for the steering repair. Their view is that they won't charge for an unnecessary repair. However we do have to pay another $235.00 for a new air conditioner. Total repair $635.00.
    Have the air conditioners declined in quality? Is the new R-132 coolant more corrosive? My 1991 with R-12 coolant has had nothing more in five years than adding 8 ounces of coolant. And I have double his mileage.
  • dengle2dengle2 Member Posts: 3
    Is there anyway possible to reset the engine light switch on the car. The dealer I called said its probably on for a service interval (25k, 50k,75k) and no need to really worry about it. I'm trying to get it smogged and dealer wants $75.00 to check the codes and reset it. I just need it off for a couple of hours.
    Don
