Toyota 4Runner problems?
as I see it. The back end seems to be lower than
the front end of the vehicle. What causes this
situation? It is the springs or shocks? Can either
one be upgraded or replaced to prevent or solve
this issue? Thank You.
If you notice ,the 96 and up runners do not sag in the rear.
When I was looking at all the option, I thought I could have body color-keyed running boards added later, but now I'm told that's not an option out here in California. Odd.
Anyway, my 4Runner came with the keyless entry remotes. Then I paid about $150.00 for the alarm system + another $150.00 to have it installed. Yikes! A friend suggested I look at third-party alarms and now I wish I had, but at the time I wanted all Toyota parts in the truck.
Hope this helps.
Michelin and Yokohama are really the best tires you can get for your SUV if you want a smooth ride. Some customers thought that we were trying to boost sales of a specific brand..they were wrong. We usually based our judgement on experience.
On all Japanese cars I really recommend Michelin and Yokohama for a smooth ride.
Pirelli's perform better on European cars;Jaguars, BMW, Mercedes Audi, Saab and Volvo. Pirelli has a stiffer sidewall and contributes to the sports car feel. Most American cars do well with all tire brands except the crossover Japanese brands like Metro and the Corolla equivalent of Chevy.
Pat
4Runner automatic. Had it completely checked by my
mechanic and thru carfax. Only has 18K original
miles. Completely new looking Bridgestone DEULER
tires.
Drove it in the rain today for the first time --
light steady rain. On a hill at a stoplight it
slipped backwards, and then was spinning out when
i gave it gas to make it go forward. Made a right
turn later in the day, and it FISHTAILED to the
left like CRAZY -- almost had a serious accident
-- all traffic around me had to brake to avoid me
-- it was scary as hell. I did NOT have the 4 WD
engaged, but isn't this alot of loss of control
for practically a new car? I have been driving for
15 years, never had an accident. But this is my
first 4WD vehicle.
Is there a special way to drive these SUVs?
Should the 4WD have been on?
Did I oversteer and not realize it?
If you have had any type of similar experience
please reply here or to munpreetz@yahoo.com.
Munpreet
I don't think I'll buy another 4 runner.
Package and I notice that every time I start to
accelerate after the SUV hasn't been driven for a
while, I hear a twanging kinda noise from the right
front passenger area. Sounds like an antenna
hitting a tree branch (my antenna is not up when I
hear this and there are no tree branches around).
After this initial acceleration it goes away and I
don't hear it again until the next time. Has
anyone had any success in finding out what this
noise is? Is it fixable? Also, I have bubbles in
my dashboard. Has anyone had any success in
getting this fixed?
Thanks...
hub-centric.If you have ever seen your tires balanced, the tire is slid over a conical hub which centers the tire on the balancer and is then
balanced. Well 4runner/Tacoma rims are know as lug-centic meaning the tires/rims are mounted on the balancer by the lug holes via this adapter. Only with this adapter will you be able to get a true balance. This has been a hot topic on the
4runner boards I've been posting on. Toyota has
issued a technical service bulletin requiring all
dealers to have this adapter.The fact of the matter is not all have. Blaming the tires is the easy way out although it is true in some cases. There was a few cases of bad rims but very rare. I can dig back through the archives of some of the forums and post to this forum if folks are
interested.
Ciao,
Trongod
Does anyone have any info to back-up or refute Consumer Reports findings?
Can this problem ever get fixed? Should I invoke the Lemmon law?
There are several topics around Town Hall that may be of assistance to you if you are interested in looking in to the lemon laws. You can click here to get a list of them.
Some are frozen, but may still provide you with some good information. To find an active topic in which you can post, check the "last post" date by each topic name.
Pat
Hope this helps!
Also if anyone knows of a new 2001 SR5 2WD base model in the state of Washington or Oregon please Email me.
Thanks again!!!!
Anyone have this happen? The 4WD mechanism should have been lubricated, as I did have it in 4WD a bit this summer.
rajuncajun1 - I'd suggest you head to the active 4Runner discussions on our SUV board to get a good answer to your question.
Pat/Roving Host
Doc Barbay
Boston MA
At this point the Monroe Senceatrack looks the best. Does anyone have
any background with this subject. Thanks
However, I have experienced something lately when utilizing the 4WD that is of concern. If I attempt to make a sharp turn, greater than about 15 degrees, while the 4WD is engaged, the truck seems to bind up.' By bind up' I mean that if I attempt to maintain a constant speed through my turn, I have to accelerate otherwise it will eventually slow to a stop. Straight forward motion does not seem to be hindered at all.
I have not had a chance to discuss this issue with the dealer yet. Has anyone experienced this problem before? If so, what, if anything, was the fix?
Thanks in advance for your assistance.
The steering wheel lock is (de)activated with the ignition cylinder. If the steering wheel is under tension against the steering wheel lock, it will be difficult to turn the key in the ignition cylinder.
Simply apply a slight turn to the steering wheel in both directions to see if it is indeed against the lock. If it is, turn the wheel so that there is no tension against it and then attempt to turn the key.
Some automatic transmissions also have a safety interlock that prevents the turning of the ignitions cylinder if the transmission is not in either "Park" or "Neutral" and/or the footbrake is not depressed.
