Visitor Agreement.
I recently purchased an 1987 4x4 Toyota 4-runner
with the 2.4L engine. It had been running great
until it suddenly stopped. I was about to leave
from work and the truck was running for about 3
minutes when it suddenly stopped. The engine light
illuminated as it stopped. It would not start
after
this. I have checked for spark and it is ok, I
have taken the spark plugs out and put gas in the
cylinder, put the spark plugs back in and started
the engine and it ran for about 2 seconds. I've
checked the main EFI relay and the other circuit
relay and both are fine. I'm down to the fuel
pump/filter and the ECU for the fuel injection.
Has anyone had this problem and would anyone know
what the likelyhood is of the ECU being faulty.
Also what would be the best way to check the fuel
pump for proper operation.
I thank anyone for their help.
Elias
Pat#1 of 1: I'd put money on the chip being (obyone) Sat 16 Sep '00 (01:55 AM)
the problem. Being thirteen years old, its about due.
You say you're losing air in all 4 tires? Very strange problem. I've heard of one tire losing air because of a valve stem problem or sealing problem but it's unusual to have all the wheels have this problem with sealing. Use a little spit on the valve stems and check for bubbles. Use the same air gauge each time to check the air pressure - you'll lose some each time you check so don't check'em too often.
Lastly, I hope they don't have to break them down and seal them. Makes me nervous too. They're going to have to rebalance them after and this is critical on Toyotas with big tires. Goodyear tires have been a big problem with shimmy problems but Toyota won't openly admit it. Toyota has a special wheel balancer because they say the alloy wheels aren't machined so they're not true. Good luck!
Any suggestions before I take it into the shop tomorrow? Thanks
I haven't noticed bubbles in my dashpad, but I'll look now that you mentioned it. Maybe the vibrations made them disappear. The factory rep will BS you into keeping an eye on them which you really want to do, right, but if they fix it, you will be one unhappy person forever with this vehicle. They're guaranteed to screw something up bigtime worst than the problem with the bubbles, believe me. You will have problems with rattles, etc. and they'll damage something else too. If you can't live with it, by all means have them fix it, but I've been there before and what they are telling you is they've never done this before, don't know how to do it, and don't want to do it. On top of this, the guy that's going to do it doesn't care cause he's driving a junker and can't afford a vehicle like yours.
Good luck everyone.
Is it a transmission problem? Second, when I come to a stop, after a few seconds the vehicle lunges forward. I was told that the air wasn't out of the brakes (or some excuse like that). I find that unacceptable since I have owned about 5 cars and that has never happened before. Naturally, that doesn't happen all the time either. What gives? Thanks for your help!
Or if you want to talk about things other than maintenance/repair type stuff, our SUV Conference would be the best place either in an existing topic, or a new one named similarly to what I suggested.
Pat
124 miles on it. Noticed it looked crooked while
parked in my driveway. Took it to Toyota . The
master mechanic came back with his findings listed
below after putting an identical 4-runner next to
mine. Wheel arch moldings have significantly
different clearances to bumper ends. Tailgate fit
to body and taillights different from side to
side.Lower finish panel
under right headlight does not fit as well as
left.Rear bumper ends to quarter panel fit varies
from side to side. Headlight movement compared
to other new vehicles is excessive. Toyota
customer service in portland wanted me to take it
to a body shop for three days and have them "FIX"
my car. And extend the warranty to 60 months
or 60,000 miles. I said this was unexceptable as
my car was NEW or suppose to be. Sent Toyota in
Torrence , CA a certified letter. I requested a
buyback or replacement vehicle. Toyota has not
been cooperative at all and it was their master
mechanic that came up with the findings. I also
contacted the dealer which was City Chevrolet-
Toyota in Great Falls, Mt. and they wouldn't help
me. NO service after the sale. Has anyone ever
heard of this problem? Any advice on what to do?
Two people with Toyota said they have never seen
such a car. I questioned Toyota about Quality
and they have been terrible. We had a 94 Toyota
4-runner that we traded off that had only 49,000
miles on it and loved it. HELP!!!!
earlier) with Bridgestone Dueler H/T Tires (P265
70R16)? These tires would be part of the Sport
Package. Anyways, I was reading an article in my
local newspaper and it stated that Toyota had found
"small cracks" in these exact model of tires which
they were placing on new Tundras and Sequoias...I
called Toyota and they said I shouldn't be
concerned because this only affects those other
vehicles...still with everything that has been
going on with Bridgestone and Firestone, it has me
worried. What should I do?
Thanks...
I'm looking for an interesting fun ride, but feel weight and safety underneath me. I drove the 2001 4 runner 4wd today, and liked it alot. I have now read all these horrow stories, and am frozen as what to do. This is a $35M car(truck). I sure don't want problems before I start. Any suggestions?
Bridgestone says that it was a 'venting' problem in the mold and in no way affected the safety or performance of the tire. Toyota continued using the tires. There have been zero complaints or incidents involving this tire.
If you own a new Tundra or Sequoia you can request your dealer replace the tires with Dunlops. There is no recall since there is no problem.
I wouldn't worry about it. I've used Bridgestone tires on my Toyota truck since it was new in '89. I've never even had a flat in over 151,000 miles.
I've noticed lately the body fit on 4Runners is terrible - doors stick out from body at top or bottom - liftgate in back has poor fit around taillights - large gaps - bumpers are installed crooked. You can write the President of Toyota (real waste of time), call their 800 number (I'm surprised they don't laugh in your face), talk to their Customer Relations Person at the dealership (a wasted position cause they only want to hear good things and can't help you one bit),threaten to sue, but all this will get you no where. The lemon law in your state may help if you vehicle has a major use problem but don't expect any results if the body fit is bad. Marti (#76 - crooked car) should have his vehicle checked by a body shop to see if it was in an accident or had major body work done, yes, even though it was new when he purchased it. If it has, then sue the dealer and Toyota.
I'm telling you all this from real experience, believe me. Good luck and remember, never get hung up on buying a new vehicle where you fall in love with one. It can cost you much money and happiness!!!
I am anxiously awaiting a more reasonable response.
I just bought a 2000 4runner limited. Let me get to the point, the sales person is great. But once you deal with the finance people (AMOS) bunch of lies. Also, dont ever deal with the service guy (Todd the redneck) his the manager. Bunch of lies and BS. Just a warning, spent $40,000 for a truck, but you get no service after you buy it. Dont get me wrong, I love my 4runner.
I agree with willingford (#82).
This topic exists for the sole purpose of discussing maintenance or repair issues our members may be having with 4Runners that they have already purchased.
Pat
It may have always been there; I've had it about 6 monthes. I just noticed it about a month ago when I was driving with the stero off. It happens whether the radio is on or off. A/C is on or off. I took it into the dealer and they didn't have time; told me to bring it back another day -- gotta love thta Toyota service, huh?
Anyway -- I had the factory security system installed after I bought the truck; wondering if that may be the problem. It does not happen continuosly. I notice it mostly when I'm accelerating for a extended period of time -- like getting up to speed when entering a freeway.
Does this sound familiar to any one. I'd like to have some direction when i take it back to the service department.
My bigger complaint has been a "kick" or "jerk" at around 12 mph. when accelerating from a stop, i.e. the vehicle is not shifting smoothly (certainly not as smoothly as my '97 did). Once again, two dealers said that they have not heard of the problem and were "unable to duplicate it." The dealers did not have any 2000 automatics left in stock for comparison. It's really annoying. Help!
By the way, the gas gauge problem and two bumps on the dashboard don't bother me and I'm getting anywhere from 17 mpg (city) to 22 mpg (highway), which I'm very satisfied with.
I'm enjoying my newly purchased 97 SR5 4X4 !! Seems like when the clutch is fully depressed, the clutch pedal is extremely close to the steel housing where the steering shaft runs. There's a flexible plastic boot around the housing.
I'm bonkin' my left foot against the steel every time I shift. Ouch !! My feet are about normal size. Seems like any overhang at all on the pedal would result in this. What's going on ??
Any thoughts ??
Thanks !!!!
-Steve
I came to this site and found others having the same problem.
I tried cleaning the fuel injection system with a cleaner like Techcron and noticed an improvement.
Hope this is the solution.
To those having problems balancing the wheels, I had a serious case with my former 96 Camry. With the regular balancing machines I still had a vibration after several times.
I found a place, a Butler Tire dealer, who had a wheel balancing equipment that balances the tires
mounted on the car. This way wheels are balanced under real road conditions and it definitely solved my problem.
The car had a few hundred miles and I asked for a refund to the dealership. It took them three months and many callas to get the refund ($70)
Hope this can help someone
I reported my problems to Transport Canada (who are investigating) and also posted a complaint on the NHTSA website. I encourage everyone else to do the same. Toyota's opinion is that this is an isolated incident. From what I have read here and elsewhere, it is not. Please let them know about your problems.
Marcell
PLeeeease help Sean at hsburg@sisna.com
