Visitor Agreement.
leng05, "Got a Quick, Technical Question?" #1551, 15 Jun 2005 4:52 pm
discussion and hope that someone there, maybe Alcan, can tell you what is really wrong. The oxygen sensor is just an indicated problem. There most like is another single part that is not right. Before you hang a lot of parts, I'd see if thsi is a typical problem that someone can diagnose.
My question is I'm trying to find which relay module controls the alternator.
The first question I have is whether it makes sense to go to a transmission shop or to the dealer.
Second, is it likely that the valve or solenoid need work? Some have also seemed to have luck with replacing spark plug wires and coil packs. If this is common then the dealer should be my first stop and if they can't fix the problem, they should, in theory, refer me to a transmission shop.
What kills me is that I am the original owner of this 2000 SLE with 55,000 miles. The shudder just occurred within the past two weeks. But, I owned a 1992 LeSabre with almost the same condition. I should have learned my lesson.
This is likely the last GM product I will ever own. (The list of defects is now between 15 and 20 items long and includes an intermittent cabin leak that I doubt will ever be cured.) Toyota will be the number one car manufacturer in the world. I am sad for GM but they need look in the mirror for answers. Too bad we can't fix our cars with some sort of smoke and mirror trickery.
http://www.troublecodes.net/GM/
The service specialist seems to think there is a problem with one or more of the three blend doors behind the climate control panel behind the dashboard, but beyond that, he cannot seem to replicate the problem. Is this a problem that anyone has encountered with post-2000 Bonnies? Any thoughts on what might be the cause? Suggestions and logical guesses will be appreciated. Thanks! :confuse:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/15/e4/5f/09- 00823d8015e45f.jsp
In some cases service shops try to find something to ring up more service dollars and scare people into changing things not needed. And it might be the tie rod ends have worn. I'd check a dealer--quick. Shouldn't cost much for them to check the ends for you and if there is wear there might be some help from GM in replacing them especially if you're a squeaky wheel.
I recall having tires put on my 67 Mustang and the Sears people telling me the ball joints had too much play in them while they had the car jacked up and needed replacing at 20,000 or so. I went immediately to the Ford dealer who checked them with the jack under the lower A-arm so the ball joint had proper load on it for checking--they were fine. Sears was checking when they were hanging with no weight on them.
Is there water in your oil? How does the oil look on the dipstick when the motor has been running.
This has to been a consistant problem with my 94' have you had any replys with help? If so could you pass on the good word?
Cheers!
Actually , its like a big 1/2 inch large screw with a large expension outside the motor, which is screwed on the motor to pick up any unsual knock. Anyway mine , the cable was plainly disconnected...But I performed the test from the info on the internet site where you sent me.It proved my sensor was good.One of the test is amazing as when you knock on the motor with a hammer near the sensor it does developpe an AC voltage(without the key on) . The harder you knock, the more voltage. Anyway I plug back and return the new one to CT. My gas performance have enhence a good 20 %. Thanks for your help on that one. I will need another info from you when you will be free of time..., Sometime the car stall when you are getting out the high way. Happened twice. The two times, I was on Overdrive. When on Drive, it never happened. The idle is at about 700-800 , spark plug changed recently and wire one month ago. One thing I see is the gaz filter. Do you see anything else? Thanks.
I did get a little satisfaction. I went home and looked closely at my other 2001 Bonneville with 78,000 miles and the corrosion had started all under front edge of the hood. I took it back to the same place and yes, they did repaint the hood. I have a third 2001 with 88,000 on it with the same problem and it will be interesting to see what happens when I get take it in.
P.S. where are you located?
http://www.lightsout.org/disable.html
http://www.imcool.com/articles/aircondition/fix_vacuum_line.htm
Intake Manifold
GM Bonneville/Eighty Eight/LeSabre
1995-97 VIN K ENGINE
On these engines, the upper and lower intake manifolds must be removed separately.
1. Properly relieve the fuel system pressure, as outlined in Fuel System of this repair guide.
2. Disconnect the negative battery cable.
3. Drain the cooling system into a suitable container.
4. Remove the fuel injector sight shield and air intake duct.
5. Tag and disconnect the spark plug wires on the right side of the engine and position aside.
6. Remove the manifold vacuum source.
7. Remove the fuel rail.
8. Remove the EGR heat shield.
9. Unfasten the cable bracket-to-cylinder head mounting bolt.
10. Disconnect the throttle cable.
11. Remove the throttle body support bracket.
12. Unfasten the upper intake manifold bolts, then remove the upper manifold.
This engine has two bolts which are hidden beneath the upper intake. These bolts are located in the right front and left rear corners of the lower intake manifold. This is why it is necessary to remove the upper before servicing the lower manifold.
13. Disconnect the upper radiator hose.
14. Remove the alternator, as outlined in Engine Electrical of this repair guide.
15. Remove the drive belt tensioner.
16. Remove the EGR valve outlet pipe.
17. Unfasten the intake manifold bolt, then remove the manifold from the vehicle. Remove and discard the gaskets. Thoroughly clean the gasket mating surfaces, intake manifold bolts and bolt holes.
To install:
18. Position a new gasket, then place the lower intake manifold over it. Apply a suitable threadlocking compound to the bolts, then install them. For 1995 vehicles, tighten the bolts twice, to 24 inch lbs. (10 Nm), in the sequence shown in the accompanying figure. For 1996-97 vehicles, tighten the bolts to 1 ft. lbs. (15 Nm), in the sequence shown in the accompanying figure.
Intake manifold bolt tightening sequence - 1996-97 3.8L (VIN K) engine:
http://www.autozone.com/images/cds/jpg/small/0900823d8015dfc1.jpg
18. Install the EGR valve outlet pipe.
19. Install the drive belt tensioner.
20. Install the alternator.
21. Connect the upper radiator hose.
22. Position the upper intake manifold on the lower manifold. Install the retaining bolts and tighten to 24 inch lbs. (10 Nm).
23. Install the throttle body support bracket, then connect the throttle cable.
24. Install the cable bracket-to-cylinder head mounting bolt.
25. Install the EGR heat shield.
26. Install the fuel rail.
27. Install the manifold vacuum source.
28. Connect the right side spark wires on the right side of the engine.
29. Install the fuel injector sight shield and air intake duct.
30. Fill the cooling system with the proper type and amount of fluid.
31. Connect the negative battery cable. Start the engine and check for leaks. Check the cooling system, and add as necessary.
