I had the transmission recently serviced (flushed) and wondering if that had something to do with it.
Any comments? Thanks.
On my 98 SSE, which I've had since Jan of this year, its a little better- around .50 to .75 max every oil change (3000) miles. Both cars have the normal 3800 Series II (205-HP)
Chuck
Thanks for the education re: Post# 539,575,614,615,637,645. Thanks to "Alcan" for the personal help. We abused GM owners need to unite and force the issue to resolve these failures. There are plenty of posts re; this 3.8L EGR/coolant leak/misfire issue.
My saga....I recently purchased a ’98 Bonneville SE and drove and performed beautifully the 2 times I test drove.....of course . then read a few past posting after it started acting up after 60 miles on "Town Hall" on the intake manifold coolant leaks. My '98 Bonneville suffered from just such a leak as described here and in the TSB. The original upper plenum, intake manifold, 2-5 coil, plug wires, and platinum plugs were replaced by previous owner 2K ago @ $1300 done by private repair. Prior owner left oil change sticker in window and I was able to find mechanic and spoke directly to the owner/mechanic of the one-man shop. He is a straight up, former, 20 yr experience GM-Buick trained mechanic and followed the "All Data Repair Book" for these symptoms. He gave me the failed parts (plenum and intake manifold)the prior owner saved. He says there is a GM -TSB on the very subject and wonders why GM isn't making good on the design flaw. Car was cherry until 42.5k. Prior owner took car to him exclusively since new in 9/98 for all service. No vehicle service history on Car Fax. Clean title. 1 Owner . MyGMLink.com has no history.....She wrote a complaint letter 3 months ago to GM. I bought Bonneville last week and same drive symptoms described now, ie surging and choppy acceleration, particularly evident in O/D when negotiating even the slightest incline........like when you are running out of fuel w/ fuel injection, here now exist at 44.6 K total miles, are occurring after 600 miles since i bought last week from wholesaler as-is. Do I have another intake manifold leak after only 3K miles or do I have a tranny problem?......such as Alcan said I should also investigate? What is GM doing about these failures?? What can we do as disgruntled GM product owners? What can I expect from a after market warrantee program offered through the credit union???..should the same problem reappear??
Thanks in advance for your cooperation.
Rgds........disgusted and concerned
Who do we write to complain these re-occuring issues?
A) If you hear a knocking (no matter how slight, it will get louder eventually) you will needed a new torque converter.
Radio control buttons located on the steering wheel stopped working after 2 years.
C) After 5 alternators it was the ECM went bad and it just happened again 1 month ago for the second time in less than 2 years!
D) O-ring that goes between the exhaust manifold and your exhaust line - went bad 2 times in 4 years.
E) A/C will blow air through the top registers on the dash board once in a while then it will go back to normal.
Had a really bad MOJO although I loved the power of the car and the comfortable ride, I had to DX it (Army term for exchange / trade-in) and selected something more reliable a 2002 Toyota Camry V6. Great little car, very fuel efficient.
1. When I leave the car the sit for more than a few days, the battery tends to go dead. I have replaced the battery, to no avail.
2. The interior lights do not work. I have replaced the fuse, and still nothing. The power mirrors are on the same fuse, and they still work.
3. When driving, the right speakers (front and back), tend to completely cut-out at the slightest bump/jerk. I've tried "wiggling" various wires throughout the dash, when parked, but haven't found the one.
Any ideas?
1. The car will sometimes quit as if I had turned the ignition switch off. It starts right back up.
2. The clock sometimes resets itself overnight as though the battery was disconnected.
3. Most recently, the interior lights are staying on. The only way to turn them off is to pull the fuse.
Any help would be greatly appreciated!
Thanks, Ducatibob
Answer for me: On the floorboard on the drivers side to the left of the front seat where the carpet meets the molding where the door shuts. Did you get all of that? Anyways pull back the carpet and you will see a bus bar of black wires. I had a faulty ground at this connector, I could wiggle the wire and get the windows to work and the car would start. It was the larger wire going to this ground bus. I fixed this connection and have had no problems since.....that is until now...my transmission will act up until I shut off the car and restart it....that is why I came here.
Hope this helps somebody
Also, ever since we had the brakes serviced (front and back) we get a hard shudder when we put on the brakes around 65-70 mph, and a slower, almost wavelike shudder when braking at less than 10 mph. It feels like something isn't balanced correctly. I brought it into a competing brake dealer and they said the brakes look fine. But the car still shudders.
The shuddering, as anyone more familiar with brakes than me could have pointed out, was caused by my front rotors getting too thin and warping with the heat. So, new rotors. And new cylinders in the back to replace the leaking ones there. Cha-ching! I guess it was time for the quarterly wallet emptying.
Next stop, the electronic climate control, which refuses to give heat half the time.
I wonder if I'd save money by putting myself through auto mechanic school and buying a hydraulic lift for the garage.
Thanks for link but batauto.com is not showing the codes. Are there any other sites that might have them?
http://www.batauto.com/GM/
Sometimes it works on 1 push and other times it takes 5 or 6.
Engine Coolant Consumption or Coolant Leak (Inspect for Material Degradation/Replace Intake Manifolds) #01-06-01-007A
Engine Coolant Consumption or Coolant Leak (Inspect For Material Degradation/Replace Intake Manifolds)
1995-1997 Buick Riviera
1995-1998 Buick LeSabre, Park Avenue
1996-1998 Buick Regal
1998 Chevrolet Lumina, Monte Carlo
1995-1996 Oldsmobile Ninety-Eight
1995-1998 Oldsmobile Eighty-Eight
1998 Oldsmobile Intrigue
1995-1998 Pontiac Bonneville
1997-1998 Pontiac Grand Prix
with 3.8 L Engine (VIN K -- RPO L36)
This bulletin is being revised to correct parts and labor operation usage. Please discard Corporate Bulletin Number 01-06-01-007 (Section 6 - Engine).
Condition
Some owners may comment on excessive engine coolant consumption, or an engine coolant leak near or under the throttle body area of the upper intake manifold.
Cause
Upper intake manifold composite material may degrade around the EGR stove pipe and could result in an internal or external coolant leak.
Correction
Follow the upper intake manifold removal instructions found in the Engine Unit Repair Section of the Service Information Manual.
Refer to the arrow in the illustration of the upper intake manifold above. Inspect the inner diameter of the EGR passage for signs of material degradation. Degradation will appear as "pitting" of the composite material in the EGR port passage.
If degradation of upper intake manifold composite material is found, replace the lower and upper intake manifolds with the following part numbers:
Lower Intake -- 24508923
Upper Intake -- 17113136 (includes necessary upper intake plenum gaskets)
Lower Intake Gasket -- 12537197
Follow the lower and upper intake manifold installation instructions found in the Engine Unit Repair Section of the appropriate Service Manual.
If degradation is not apparent, skip to Step 7.
Verify the repair.
If no degradation is found, evaluate the vehicle for other causes of excessive coolant consumption as noted in the Engine Diagnosis Section of the appropriate Service Manual.
Parts Information
Part Number
Description
Qty
17113136
Manifold, Upper Intake*
1
24508923
Manifold, Lower Intake
1
12537197
Gasket, Lower Intake
1
* Includes the necessary gaskets for upper intake replacement.
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J0258*
Manifold, Lower Intake R and R
Use Published Labor Time
J0255**
Manifold, Upper Intake R and R
* Used for replacement of both the upper and the lower intake manifolds.
** Used for inspection purposes only, where no condition was identified and the upper intake manifold is re-installed on vehicle.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
© Copyright General Motors Corporation. All Rights Reserved.
I just got my (used) 02 SE and that trim was down when I got the car (at a Buick dealership). Went to Pontiac one to have some under wrnty issues served, and that trim was one of them. The service manager decided to irder a part # 25723806 at NO charge!!!
I Still don't know what it is, but will post an update upon installtion/fix.
Has anyone found a solution???
As for the column-mounted shift lever blocking the radio and/or climate controls, that's a problem I've seen in lots of cars and trucks, present and past, some worse than others. Most Bonnevilles have the console shifter. Just as bad as the shifter blocking the radio is the steering wheel blocking the odometer (at least from my seating position). It's just one of those details that make the Bonneville just less than great.
1990 Bonneville SSE
350,000 km
Is this something I could do myself or is this better left to him? Has anyone else had experience with this? Car has run a little rough at times. I've replced plugs and checked all vacuum lines. The only other code he got was for the cruise control position sensor. Cruise has not worked for months. Does anyone know whether the servo unit is repairable or that I just need to buy a new one?
My problem is that the car has become noticeably somewhat harder to start. Still starts after it makes a little effort (2 to 3 seconds) but just a short while ago would fire up at the twist of the key.
At this same time I have noticed that after I drive for about two to three minutes, I will be stopped at a light (Same ones, either near my house on my way to work or near my office on my way home.), and the tach will drop to 0 for a split second as if the car has died and then surge over 1500 for a second as if the ignition switch has been turned on. The car tries to lunge forward but luckily my foot is firmly planted on the brake (and I don't tailgate!). This has happened about a half a dozen times over the last month. Then yesterday the car died as I pulled on to a freeway on ramp by my office. I pulled it over and it started back up, again with a couple of seconds of effort, not the flip of the wrist I had been used to. In this same time frame I have noticed some minor sputtering and surging while cruising down the highway.
I get no check engine lights and my dash amp meter reads as it always has. Is this an alternator going bad? What else should I be looking at?
This doesn't seem like a tranny problem, but I could be wrong. Seems more like some type of sensor or something. Doesn't feel like its searching for gears. I'm thinking i'll turn my search to the fuel, air, emissions sensors(?)
Of course it's out of warranty now at almost 44K so I'm hoping its not the tranny. I plan to have that serviced at 50K so I'm hoping I can find a simpler solution before then.
I went back and looked at that petition. I noticed that it appears to run through the years 95-2000. So I'm guessing that no, the problem hasn't been resolved.
But, the part they are using for the repair is metal, not plastic. So for your 700 bucks it looks like you get the part that was meant to be on there in the first place.
Any thoughts.
I appreciate your comments.
thanks,
Mike
