Mazda has a strict substance abuse policy.
...Ok, Bando, Mitsuboshi, Gates, Goodyear and others. Your Pro came with what was the best ($) choice at time of production but most likely Bando or Goodyear.
Or "yank for the yen," as it were?
Meade
On pinging, I think the 1.5 and 1.6 designs are susceptible to carbon buildup when used for around town, low speed driving. I know this because after 150 miles cruising at 75 my intermittent pinging disappeared. I don't think it is a problem with the O2 sensor. I'm not going to test it unless the problem becomes a constant. Anyway, the O2 sensor is in an awful location for the home mechanic to access (near the fuel pump which I vowed after the first replacement I would never do myself again).
I know of other older cars, friends late 80's Corolla, that also pings upon hard acceleration. This car is also used mostly around town.
I use 87 octane.
Thanks for the info. I did get Gates belts from my nearby NAPA strore and plan to swap them this weekend.
As for the pinging, no problems for the past two weeks. I think that a) going back to my original gas station, b) adding a bottle of Techron to my last full tank, and c) driving 50 miles @ 75 on the highway a week ago have all helped a lot. The car, at least on the butt_o_meter, feels better and does not ping (on 89...).
The beast I'm having to deal with now is the wife's 626, which is pinging. Problem is, it's hard to get feedback from her regarding what the car is doing. She's a "goes forward when I press the gas, stops when I press the brakes" kind'a gal...
G.
I have to correct what I typed earlier about pinging. I said O2 sensor, but I meant EGR valve. I have changed both O2 sensors in the car and it's not that difficult a job. But getting to the EGR valve is the pain I was referring to. My Haynes manual describes pretty well how to check the valve, but I'm not looking forward to ever doing it.
Good to hear your Protege is ping free again.
Thanks for clearing that up - I didn't recall an O2 sensor being close to the gas pump. Also, I think you mean that the EGR valve is close to the fuel filter, and yes, BOTH are a pain to get to. I think the fuel filter is even worse than the EGR valve (I think this last one is bolted on to the back of the engine block, right under the throtle body, right?). I don't understand why a part that has to be serviced routinely is so inaccesible.
In any case, if pinging was due to the EGR valve, wouldn't the car idle really bad? Just a thought... Anyway, I don't plan to check it on the Protege for now, although I may on the 626. Plus, the thing is nearly 200 bucks, so I would like to have proof before mucking with it...
G.
G.
One might think I'm on drugs or just an idiot by reading my last post. Actually I'm just an average home mechanic who needs to stop typing these messages at midnight when my brain is obviously not functioning.
Last night, driving home after dinner, my '99 Pro LX with AT again (3rd time in 4 years) suffered a strong jolt while cruising on a smoothly paved street. It feels like hitting a raised edge of pavement (2-3in tall) head-on.
I can't figure what's causing it. It's almost as if the transmission tried to downshift, or the brakes got jabbed very strongly. It feels like it's coming only from the front end, which makes me suspect the transmission instead of the brakes, but I don't notice the tachometer moving (then again, I'm kind of distracted by the sudden jolt). I'm worried about a major component failure, or losing control of my car while in the middle of a lateral manuever or while driving on ice, snow or during a heavy rain.
Any suggestions about what could be the root cause? I strongly suspect the computer and software (based upon a runtime version of Windows). Could there be a sensor that's misfiring? I don't have ABS, but do have cruise control.
Hopefully it really was something on the road - like a pothole.
Do a visual inspection of wheels/tires/shocks etc as well. Both ends (upper linkages?) - especially if you've added srtut or sway bars/braces.
And please be careful and observant while driving for the next few days!
At least it's not changing or locking into different gears, but others have described it as hitting a pothole or getting rear-ended (it feels like that too). Before and after, my car behaves just fine (other than the rough jerk when I step on the gas after the car has just stopped or come to a near-stop...I've learned to delay and feather the throttle to avoid this). Dang.
I'm noting the dates it's occured. The funny thing is it's happened only on smooth roads so far. I even retraced my path the first time to check the pavement (back on Feb. 12 1999....my post to NHTSA is still there). And each time it happened I was cruising...barely had my foot on the throttle and only to maintain speed.
I have also felt that jolt twice in 4 years when cruising on the highway. felt like the engine died and started off almost instantly. kind of like it forgot that it was running. I personally think it has to do with the electrical circuit or ECU programming.
So how do you get to the horn? Hubby did a visual, but didn't take anything apart yet. Advice greatly appreciated!
I think a sensor is going bad, connection is going bad, or the ECU, TCM may need reprogramming (a new program, not just reset by disconnecting the battery).
I didn't have time this week for them to investigate (wish I still had my '89 323 about now), so I'll schedule next week. I want to go on the test drive with the tech so I can duplicate the other (I think related) issue: transmission "stumbling" when I step on the gas right after coming to a stop or to a near-stop, as in stop-and-go traffic.
Meade
Front Bumper Removal
That's what I did when I swapped out my horn for a Mercedes twin horn.
Pete
Since that trip back in Oct 2002, I can hardly remember any episodes of pinging. I'm not positive about what made the pinging go away, but there seems to be a strong correlation between when I made this trip and when the pinging stopped.
I also want to mention that my car continues to be rock-solid in terms of reliability.
Now the question: Where can I get specs for the alternator bearing withouth having to take the old one to a shop for comparison? I looked in the web to no avail...
TIA,
G.
I also couldn't duplicate the shudder this morning with the service adviser in the passenger seat. My car's AT behaved perfectly fine.
At least I logged the complaint into their database on my car. I'll just have to watch out for that "rear-ending" sensation and alert them ASAP the next time. I think I'll post my complaint into NHTSA's database too.
Now after 10,000 miles, I have to really step on the gas to make the car go. The engine doesn't seem to rev as quickly as before and the automatic transmission sometimes make clunking noises when coming to a stop. The shifts also don't seem to feel as smooth as before.
I think it might be the automatic transmission acting up. Would changing the ATF fix the problem?
Note the situations when it acts up and report it to the dealer: cold/hot engine, warm/cold/humid day, electrical load on the car. The more info they have the better. The tranny is covered for 5yrs I believe so since yours is fairly new, if it's something wrong with it, they'll fix it for free.
There's no point to spend $ now to change the AT fluid - if there's something wrong with it and they need to fix your tranny that $ spent on the flush is wasted. I did change mine at 48.000kms (30.000miles) along with the coolant and will continue to do so as a preventive measure since we plan on keeping the car for a long time.
Good luck and let us know how this develops!
Dinu
My 96 1.5L 5spd is, I believe, a little hesitant. It may be that I am imagining things, but I feel that in the mornings, with the engine cold, I get a very light hesitation while I step on the gas in second gear. It is very minor, not hard buckling or mis-firing. It's like someone would push against the car here and there, and after a couple of miles everything is fine. It's so minor that my wife told me I'm paranoid, as she does not feel anything.
As I said, I may be imagining things (very likely...). Plus, I have changed everything but PCV and fuel filter on the car not more than 2 months ago. One thing I was fearing was the plug wires: I replaced the cables but left the old plugs in for a while, and then I changed the plugs - Could old plugs (0.055" gap) screw up new cables in that short a time (1 month, 500 miles)?
Other ideas I had was a dirty MAF, PCV, and fuel filter, which I will do in a week or so. Anyone has felt this?
TIA,
G.
It is not the AT.
The intake manifold gasket has developed a minor leak. Because of that, power is lagging and the AT makes a clunking sound because the vacuum is "just" out of whack.
Take it to your dealer and mention to him the intake gasket manifold issue has developed on my car. Mazda techs know about this problem.
There is a "check engine" forum on Edmunds, but you need the code for the experts to assist you.
TIA.
1.
asbestos content in the brake pads (use premium pads to reduce the noise)
2.
All auto trans do this noise
3.
De-glaze the brakes or something
I haven't asked my dealer about it yet.
I have a lot of water sitting in my passenger side floorboard and believe it is caused by a clogged AC drain line or something similar. The water just sits in the car(ie its not draining back out of the car) and it hasn't rained in several days yet the water keeps coming back so I ruled out the typical door/windshield/trunk leaks.
Does anybody know how to check the AC drain hose and how its leaking back inside even if it is clogged? This is for a 1999 Protege ES 5 speed.
NcGuy
REMOVAL & INSTALLATION
Disconnect the negative battery cable.
Remove the inner door panel and remove the inner door screening.
If the locks are power, disconnect the power lock controller from the lock assembly.
Remove the door lock mounting screws and disconnect the linkage. Remove the lock assembly from the door.
Installation is the reverse of the removal procedure. Tighten the door lock mounting screw(s) to 37-55 inch lbs. (4.2-6.2 Nm).
Meade
2000 ES
2002 Protege5 (wife)
It took me 2 hours in a damp, cold, windy day. I also used a Protege flap instead of the plastic one on the 626. They sell you the flap for the Protege ($1.5), but only the whole drum for the 626 ($50, plus re-keying...).
Hope this helps,
G.
I dropped the glove compartment and looked where you indicated and it appears that the drain tube is "integrated" into the Cooling unit and thus I can't squeeze the tube or do anything from the inside to clear the clog... I was able to verify that this does appear to be the problem though because with the glove box pulled it was really apparent that the water is leaking into the absorbent liner under the carpetting. The liner was soaked and because the carpet is rubber on the bottom you don't notice the water at all until it builds up enough to start seeping out of carpet slits that are next to the underseat heating ducts. Unfortunately by that time you have around an inch of water sitting in your floor pan.
I then started searching for the drain tube from the engine side and am able to see it(it is probably a 1/2" diameter rubber tube that only sticks out of the firewall about 1/2"). My problem now is to figure out how to reach it. I can't get my arms down to it from above so will probably try to either jack it up and see if its reachable from the bottom or rig some type of extension on my shop vac and thread it down to the drain pipe.
Will let you know if I successfully unclog it.
Thanks for all the help!
NcGuy
1+ month sometimes I have on my Pro/2000 cracking sound while turning stering weel from left to strieght position on low speed. Techn from dealer drove the car but didn't hear. They checked the car and found bearing failure. Replaced the bearing ($216) but nothing is changed. Is anybody experienced such problem?
David
