Visitor Agreement.
My front door panels creak like an old wooden chair everytime I lean on them too. I have heard several complaints in the board about the same problem. Let us know if reattaching the door panels solves the problem!
Jstandefer - the doors creak 'cause there is no foam between the door paint and the panel vinyl. so they creak when they rub. A Dealer should do it free of cost.
1. Detach the weatherstrip from the top/side portion of the door.
2. Clean the weatherstrip channel with isopropyl alcohol.
3. Apply a 1/4 inch bead of clear RTV silicone in the weatherstrip channel.
4. Reinstall weatherstrip into the channel and apply pressure in the
effected area, making sure that the silicone makes even contact with
the weatherstrip.
NOTE:
* Verify weatherstrip is completely inserted into the channel.
* Check weatherstrip at belt line for a firm fit against the door
frame, if necessary slide the weatherstrip upward to remove slack.
5. Clean any excess silicone.
NOTE: Weatherstrip must not be disturbed for at least 24 hours.
Interesting that they suggest RTV silicone. Seems like it could be ready for action immediately with weatherstrip adhesive.
I'll also ask them about the creaking door panels! It is probably my number one complaint! Thanks again!
up or use the hand brake to stop. Has anyone else had this problem
with the rear brakes?
Thanks in advance.
http://pub70.ezboard.com/bprotegepower
if u guys dont support it, at least u take a look of it pls
-Larry
GAM
MARTIN
Respectfully,
Larry
That's the only thing I'd complain about so far.
Also, the sensors I'm thinking of are the throttle position sensor or the transmission range sensor. On the other hand Henry, it could be a bad trans that's about to fall out the bottom of your car.
That's a good one.
Historically, duct tape seems to last pretty well on everything except actual ducts, but if it's working properly while it's taped up, I could probably live with it.
2) Don't know, never had a '93
3)Most cars I have worked on are very sensitive to vacuum pressure changes, especially if it is is a key hose. Duct tape should only be a temporary fix.
Lunch time!
I better go put on my hip waders, it's getting thick in here.
Actually, I'm not sure of the exact composition of the stuff I used, but it definitely looked like death warmed over - and it never budged.
There is a wrap at the auto stores that looks like Duct Tape, but is really a heat cured epoxy. You wrap it, then wrap a wire over it, then wrap aluminum over it, then clamp it. It works pretty good for about 6 months to a year. It works best at fixing hairline cracks before they separate.
If there's a jerry rig to be done I've probably done it. I once went a winter (in college) running windshield wiper fluid in my radiator when there was an antifreeze shortage, about 1977. It was about $6 a bottle and that was really high back then. Wiper Fluid was about a buck a gallon just like it is today.
-Larry
-Larry
GAM
Engine Miss:
Those cars were notorious for not liking certain aftermarket distributor caps. Also, make sure you choose your plugs and wires carefully. I would try to stick with NGK plugs and wires.
Usual suspects for me are:
Clogged air filter.
Bad spark plug wire (or wires connected to the wrong cylinders, which can really cause your engine to run roughly and drastically reduce your mpg). Also check to see that each one is connected...you may not be running on all cylinders.
Bad spark plug(s). Check the gap.
Old engine oil or clogged oil filter. I notice about 1-2mpg improvement after every oil and filter change.
Low tire pressure. 32psi is recommended by Mazda.
Wheels not aligned. You'll see uneven wear across your tire or "cupping" along one edge as a symptom.
O2 sensor (this now starts to get more costly).
Thermostat (do you notice your car overheating or no heat coming out of your vents?).
Is there something clogging your exhaust system? (Never put leaded fuel into your Pro; you will damage your catalytic converter and this may clog up your exhaust to boot).
After that, I leave it up to the trained techs, as it's usually something with a sensor, computer or other electrical problem.
When I pulled off the panel to install an aftermarket speaker, I found that one of the plastic fasteners wasn't attached to the trim panel. This allowed the panel to flex and squeak.
After I pulled the fastener out of the door and put it correctly into the trim panel and put it all back together, the squeak has been banished.
Of course, you can always turn up the volume on your stereo. Hee, hee!
They are limited-run production. Not surprising. Most dealers do that: Chrysler with the PT Cruiser, Toyota with the new MR2 etc. Most MP3s aren't marked up as much as these previous cars have been though (as much as $10k above MSRP, if you can believe it).
The same will happen with the Impreza WRX and the Lancer when they arrive. Limited supply and plenty of people willing to pay the additional profit margin.
Maybe you can wait 'til next year? They may increase the supply if they see them being snapped up. Then again, maltb did hint that there are engine upgrades coming up (possibly super or turbo-charged, even rotary?).
Newcar hinted to a turbo charged MP3 in years coming. I tend to agree with his take, though. Supercharged: I'm less likely to believe today than 2 days ago. Rotary: just me dreaming about utopia.
With the MP3, there are only 1500 of the 2001 model. Automakers are not required to re-certify emissions on these small runs, so to keep the cost down, they must also keep production down. Don't expect more than 1500 next year if they do make a 2002 MP3.
Lastly to merrymex's post, although it is hard to stomach paying over MSRP for anything, the dealers will easily sell what they have at $2k over. The content upgrades from the ES would cost much more than that if you did it yourself. Besides, when was the last time you saw Racing Beat offer 35 month/50k mile warranty on anything they sell?
Re: rotary, I like to dream too. Now if they put that in the P5, that would be cool. Would one fit as an aftermarket refit?
I took it to the dealer today and they detected it to be a problem with the left front alloy rim and they moved the wheel to the back(rear) on the left side.
Also they told me that my front brake pads are worn out, so I should replace it SAP. I asked for a cost estimate on the front brake job and the estimate was $286+tax.
I was in no way going to pay $300 for the replacement of front brake pad job.
So I took it to Good Year Service center and the got the brake pads replaced for $131. Now the brake are very responsive but that did not fix the clicking and knocking noise from the front. Dealer says they could not hear any noises before then and even now.
My question is has anyone else heard such noises from their 99 protege etc. I would really like to know what the noise is before my 50k warranty runs out? I don't think it is a engine timing noise. I think it is a noise from the strut, ball joint etc but dealer says that the struts and ball joint are perfectly fine condition.
Please help me out, I will appreciate any help from fellow Protege Owners.
