Showed it to the dealer, and he says that it is a problem with the 97 model. Have anyone of you have had similar experiences with your 97 Accord. Please Advice.
Thanks again and will keep you posted on the ongoing soap opera - "The Days of the Accord Problem"
97 accord howling-this could well be cupped tires-waited too long to rotate mine and now get a howl at around 40-is it louder on asphalt than concrete. Look at the outside edge of your tires for cupping-just a little bit will cause the tire to howl particularly after you rotate them. For some reason many FWD cars cup the REAR tires even though everything is cool with the alighnment. Had one to howl so bad I changed the rear bearings until a friend pointed out the cups on the tires. Rotate at least every 10K-sooner is better but I am lazy and only get a little howl at 10/12k.
On other note, I had installed cold air intake on my Accord 3-4 months back. No doubt pickup improved to some extent (178K on my car). Yesterday I was changing the oil and thought to clean the carb. I was horrified to see that the whole carb was full of carbon (blackened out). Took half a can of carb clener to clean the gunk. I have replaced it with the stock air box and filter now. Never have I seen my carb so dirty since I have cleaning it my self(55K). Filter was not K&N just regular cone. I don't know about K&N but IMHO if you want to keep your car for a long, think twice about installing cheap air filter.
Funny thing is I can tell when car is going to die. Instead of kicking up its heals and screaming and yelling, I all of sudden sense the car is very calm and quiet. Then whack - the engine just dies.
Also funny is like I said before it always happens in the same places around the city. I am beginning to wonder if I should try a UFO chat site to see if its "car death rays" from out space tracking me on my travels. Well, at least its a possibility and it would sure put Honda to shame!
Does anyone know of any after market struts that are better then the Honda's struts? Should I also replace the springs? I just need a stable and secure ride. Thanks
Anyone else notice this.
The service rep said they could not start it outside, it took five of them to push it into the workshop. It started for them inside after the workout. They tested the fuel system by taking it apart and found "excellent flow and pressure" (something all of us guys hope for in our older years). They went through the ignition and distributor and discovered a lack of spark - as they said it was intermittent. Ergo the the ignitor was little tipsy and moody.
No charge as yet, towing costs are being paid. The proof will be the first 48 hours, then one week, then one month.......
Will keep you posted (cross your fingers for me!!!!)
Part two
My wife hit a 5 gallon can of kerosene that fell off a truck she was following. I washed the underside of the car as good as I could at a car wash. I'd like to get the engine compartment steamed cleaned as the car still stinks. Anyone steamed clean the engine? Bad idea?
Don't take a chance with it. also, it is NOT a DIY job.
Some of the chain stores just love selling ball joints, struts and other item like these.
That's why I suggested a second opinion.
I did not hear it when I test drove it. I guess it's very noisy on the busy street.
Does it have something to do with the engine or transmission? Is the engine or transmission system not so good on this car? I am feeling bad... PLEASE please give some imput. Thanks a lot.
Actually I signed the contract yestoday. But I still need to go back to the dealer to do tag, registration stuff. Would the dealer deny the problem even if it has? They could say it would be no problem at all. If there is any problems, I should get another instead. right? I really need some suggestions for your guys. I would appreciate them.
Doubt that they will give you another.
P.S. auburn63, you were right about the shifter rod cable needing adjustment. Once the dealer did that the stuck key in ignition when away.
Sounds like they are doing the right thing in your case.
Had a neighbor ask me to help him change oil/filter on an accord one weekend-he had been using a Honda dealer for oil/filter change for over 2 years. When I looked at the filter-could not believe my eyes-it was the oem filter all covered with crud-had never been changed since the car was new.
There are all sorts of people in the car biz-be careful out there.
new air filter, change transmission fluid, adjust parking brake, adjust front and rear brakes-brake slide service for front brakes, change brake fluid, change anti-freeze, adjust and inspect all belts, rotate tires, inspect and tighten exhaust system connections, replace windshield wiper blades and hand wash car.
The timing belt change isn't called for until the 90K service.
starting the engine, an ABS light should show up.
after you start the engine, the light should
go out.
to really test it, drive fast, then when safe,
hit the brakes hard and if the brake pedal
pulsates, you have abs. if your car skids,
you have no abs.
It is not hard to do the maintenance yourself including adjusting valves, replacing brake pads/linings and changing atf and coolant. Not only do you save time/money but you know it was done and done correctly. Just get a Honda service manual-only takes a few tools. Oil change in less than 15 minutes, brake pads less than 25 and ATF change in 5 minutes-and that is not being in a hurry.
I've called several maintainance shops in my area, and they all want $200-$250 to replace the belt. How tough of a job could it be? I'm fairly well mechanically inclined, couldn't I do this myself?
Are there any timing belts available that will last 100,000 miles? Supposedly, the newer surpintine belts last that long, I don't see why a timing belt couldn't as well.
I replaced mine because it was a nice weekend and had not a lot to do but would not do it again-took about 3 hours.
Most people say these are interference engines-a couple of tech I have talked to say they are not-only have problems if there is a carbon build up on the top of the pistons-maybe valves also.
You can not just look at a belt and really tell if it is about to go. If you see visible cracks and the teeth of the timing belt are worn off-then you know it is about shot. When mine broke-the unbroken part of the belt had no visible signs of problems.
If you do the job, you will need a manual to figure out where to set the position of the valves as compared to the lower end of the engine. Once helped a friend-we marked the valve pulley and engine timing spot and just replicated that and it worked.
Oh-getting the pulley off the crank can be a bear-you will need a torque wrench to set this one.
Bottom line-at that price-let someone else do it.
So all of you who suggested the ignitor can take a bow. (If anything changes will let you know - unless you see a Canadian Honda dealership flying into outer space first!)
Thanks!!!
A guy I work with has changed several timing belts on Hondas, and he told me he would do it for a case of beer. I know people who this guy has done repairs for, and they all said he does top notch work. I don't know of any beer that costs $200-$250 a case! Should I buy a belt directly from Honda? Better quality? Thanks.
Be sure to give him the beer AFTER he finishes the job, not halfway through!
I first thought that the brakes were "giving" a little, but my dealer couldn't find a brake problem at my 3750mi. oilchange.
I determined myself that it was the transmission, because when I put the car in neutral and braked to a full stop, the car braked just fine.
Have you seen this type of problem before, or have any suggestions for this ? I hope to get the transmission looked at when I take it in for the 7500mi. service.
Any info would be appreciated. Thanks...
