Visitor Agreement.
I have/had the same problem in my 95 accord. The light actually goes off when it thinks that the glovebox is closed. The reason your light comes on when the headlights are on is that it doesn't think the glovebox is closed. The problem exists on the handle of the glovebox, its not as tight as it should be. Open the glovebox door, and check the back of the handle (same part with the keyhole on it). There should be one screw in the back. Screw it in tight and it will tighten the handle which in turn will trigger the switch near the latch to turn the glovebox lights off. Give it a try!
Greetings from sunny Miami.
fig.
If they do the repair correctly it will last a long time. The port hole is supposed to be drilled open and have a sleeve installed that is supposed to resist clogging which so far has worked well and long term. Good luck
Rattle from front windshield
For those of you that still have this noise try taking a piece of card board and inserting it near the bottom of the windshield bettween the glass and the molding on the left side. If the noise goes away the molding/weather strip needs to have its clip repaired. I have seen a few of these..
inkie
I will look as soon as I can havent had a chance to look yet but I will..
I don't really know anything about the workings of the car, anybody have a clue about this?
They are resistor plugs also and the 4pack costs less than 1 plat. Since the plugs on the Accord I-4 are easy to get to, I don't mind having to replace every 30K.
Any knowledgeable input would be appreciated.
as they advised me before pick-up, the driver window noise is caused by air turbulence, which sure doesn't sound like it. i let it go.
i found that if the window is cracked open just so, the noise stops, suggesting that the window's top edge rubs against the window surround. i'll apply some lubricant/dressing and post what happens.
Heres what the letters stand for Z=extended gap, F=measurements, R= resistor, 5= heat range, I or P = iridium or platinum, no letter is normal and 11=the gap which in this case is 1.1mm.
my input is to change them around 30k as the gap gets wider and wider as they wear which changes the performance as well as the efficency of the cylynder..
Besides, there is joy in making machines run better.
The used plats will go into my emergency parts bin.
mike1qaz
mike1qaz
(1) Had trouble starting the car in the morning, 4 times in last one year. It felt like as if the engine would die immediately after starting it, but it did not die and came to it's normal running condition.
I took the car to the dealer 2 times for this. They had the car overnight. The first time the dealer told me that they could not reproduce the condition. But the problem occurred again. I took the car to the dealer again and they had the car for 6 days (there were some other problems that the dealer was working to fix). I was told that they put the car one the computer and looked at all the data stream and everything looked normal. Also, the dealer did not encounter the morning start problem (which is believable, since it happened only on random ocassions with me).
(2) As per my driving habit/condition I used to get about 350 miles for a gas fill up of about 15 gallons regular unleaded gasoline. For the last couple of months I have noticed that I have been getting about 320 miles for about the same fill up. I have not changed the gasoline brand or octane rating and taking gas from the same 2 gas stations always. Again I was told by the dealer that they checked the engine and things look OK. The dealer did confirm that I am getting about 320 miles for about 15 gallons fill up, but could not explain the DROP in fuel efficiency.
I would appreciate response to my problems.
Apart from the above 2 problems These are some other problems that I had to take the car to the dealers to get them fixed:
(1) Thumping Noise during Starting
The first dealer that I took the car to told me that the noise was normal. But I took the car to a 2nd dealer and they found a service bulletin about the engine start thumping noise.
Engine mount solenoid control valve had to be re routed to get the problem fixed. This required NEW parts to be installed in my car.
(2) Driver Seat Noise.
I took the car to the dealer 5 times (2 different dealers) for driver seat noise. For the first 3 times the dealer would put some teflon lube, tighten the bolt and give the car back to me saying the problem is gone. the 4th time I took the car and spoke with the shop foreman. This time they told me that the seat base was cracked.
The Seat Base was REPLACED the next time and the noise is now gone.
(3) The car lost it's alignment after driving about 2500 miles. I do drive carefully and I am the only driver (so no rough handling or driving over pot hole etc. is involved)
(4) Noise almost all over the car. The really bad one is at the lower left corner of the dash. At one time the dealer had the car for ONE full week to get the Rattling/Rubbing noises fixed. Still the lower left dash noise could not be fixed. After my last visit to the dealer, the dash noise seems to be better but not completely gone. I did not expect this kind of rattling from a new car (I have driven other new cars before and still own one that's now 8 years old).
Overall I had to take the car 11 (ELEVEN) times to the Honda dealers in the last one year to get one thing or another fixed. I feel that the 2nd Honda dealer that I am taking my car to is trying to get the problems fixed. I did talk to this dealer's Service director, service manager, shop foreman (and they know my name now). I always drive with either the shop foreman or the service manager to make sure that they agree with me there are problems and then I leave the car with the dealer to get it fixed.
I expected better than this from Honda (By the way this is my first Honda).
I did write to Honda Consumers Affairs Division with a list of all my problems.
Any suggestion is appreciated as to what I should do with my car.
If there an enthusiast site where these are posted?
I used to have a Maxima, and there are tons of resources for TSB for it...I'm surprised I don't see it for the Accord (but I may not be looking in the right place.)
Thanks in advance.
treoster
TSB's as of now are not openly available yet but really are not in a need to be either except for if you are having a specific problem, in which case all you need to do is post and some one can check for you..They are supposed to be releasing the TSB to the general public soon but not for sure when..
according2me
No I dont think there will be any problems in stepping down as the heat range and the construction is the same except for the core of the plug.
I wonder if other manufacturer sites at edmunds also have their own gurus lurking out their.
About the amount of fuel in the tank, I can not say for sure. But there should have been at least 2/3 gallons in the tank, as none of my fill up takes more than about 15 gallons (I do fill up soon after the low fuel light turns on).
I live in Portland, OR. I thought about the fuel blend (winter fuel) too, for fuel efficiency drop. Then again I could not convince myself because of the following reason. I bought the car at the end of December, 2001. I started to keep track of the fuel efficiency soon after buying the car and I used to get about 350 miles for about 15 gallon fill up. But for the last couple of months the fuel efficiency has gone down.
gee35Coupe: Thanks for your comment too.
Anybody else got any ideas.
I want to disconnect my power antennae for 94 Accord EX. its winter now, and its really noisy while retracting. i want to put the antennae up, and disconnect the power (leaving antennae up) for the rest of the winter.
Does anyone know how to do this? What does the power cord look like? Will this affect reception?
Failing that, is there any type of lube I can add? I tried spraying WD-40 on the anteanne, wiping it etc. Dint really help.
That said, are there TSBs for the 2003 Accord for:
Hard starting - engine does not turn over immediately; needs repeated efforts.
Rattles - all over the interior cabin.
procedures.
Where can I find the bulletinre: the A frame rattle?
Typicaly your complaint is a clogged screen in the ATF filter, which unfortunatly is internal and requires a disassemble to repair. You could try a flush and may want to have the transmission computer checked as they can cause this also..good luck
venanzik
Sounds like a bad headlight switch to me but leave it over night at a repair shop and have them check it to be for sure..
FRONT CHASSIS: Coming out of turns sometimes this deep creaking noise comes from somewhere under the front of the car. I read somewhere that someone had this problem and all that needed to be done was a little bit of lube.
FRONT DRIVER'S SIDE RATTLING: I haven't had this problem. Drove on a rough road today and turned off the radio, but everything is quiet in the cabin.
HARD STARTING: About twice the car has not started on me like it should. I had to turn the key a second time to get the car started. I think it is an immobilizer problem too.
JUMPY TRANSMISSION: I never noticed this when test driving the car, but hey the car's got some pep, and when you are coasting around a parking lot and step on the gas, it does jump a bit. I don't mind it at all.
If anyone does know for sure about the creaking noise and what to do, please let me know. Other than that, what an awesome car!!
Perhaps it would be worth noting if the problem occurs most frequently at certain locations.
I have also noticed jumpy transmission quite a few times mostly when I slowed down with braking. It seems that it gets jumpy sometimes when it goes to lower gear. I guess this jumpy transmission problem is quite common with many different models as I noticed on my XG300 too.
Anyone could help me figure why the "Maintenance Required" light's On on my 1998 EX V6 (78500 mi).
It is designed to come on every 7,500 in order to remind you to change your oil/perform maintanance.
- With the key in the off position, press and hold the trip odometer reset button
- While holding the button, turn the ignition key to the On position (don't start the car, just leave the ignition switch in the position where all of the warning lights are on)
- Continue holding the button until the maintenance light goes out... you're done!
If you still have your owner's manual, this is detailed in there.
What can I use for creaking windows? My Honda dealer today told me about some special lubricant, but I don't buy it.
Supposedly, the seals around the window(the seals that come in direct contact with the window as it slides up and into the door frame), dry out in the winter and cause a creaking noise. What can I use that I can find at Pep Boys or such to get rid of the noise from time to time?
THanks.
