Thanks for the help.
Almost certain that your car has platinum plugs which do not need changed until 100,000 miles. The part number is a NGK plug#PZFR5F-11.
maxhonda99
I have heard a errrrt sound when rolling down mostly but also on up mode that ended up being the regulator but if you have cured it by lubing the seal then that must be it. The Shin Etsu can be found at Honda dealers parts department othe than that I dont know..
This extended warranty covers the emissions system for 150K miles and even if nothing is wrong you get free of charge, new plugs, cap, rotor, ignition wires, oil change and filter. I have also had several parts of the evaporative system changed-couple of purge and 3 way valves plus today they changed the heated O2 sensor-all free of charge. The heated 02 sensor is a pricey part-$200+ from Honda and $80 from Bosch.
The heated O2 sensor malfunction symptoms were engine stumbling when cold and reduced gas mileage-the engine was running too rich and when cold caused mis fires.
Had an interesting time getting the work done when my regular tech supervisor was on vacation-his boss was a real expert at avoiding doing anything-reminds me of a certain large computer company's software support technicians-real experts at avoiding fixing a problem. Waited till the regular tech supervisor was back and got the heated O2 sensor replaced. Hope that does the deed.
Also, same car, the steering rack is leaking fluid from both ends. Can the seals be changed? I don't want to have to replace the whole rack.
I think these codes are the same and if so this is no big deal. Find the EGR lift sensor and undo the wire connector and reseat it. Then disconnect the fuse that controls the ECM-engine control module for a few seconds-this will clear the code out of the system-if it does not come back on-that was your problem. Would suggest you buy a manual from Helm Publications in MI-this is the same one the honda mechanics use and has really detailed charts on trouble shooting.
good luck
This morning, I tried to start the car and it just wouldnt start. There is enough battery and I checked the oil and esp the transmission fluid. Everything is within limits. There is just about enough txn fluid.
I tried to start the car a couple of times using the winter startup procedure going between brakes and the accelerator(as in the driving manual).
I am at a loss to understand what cd be wrong. I have faced similar problems a couple of weeks ago when it was very cold...can somebody suggest something what could be wrong?
Never had a problem starting a honda even in -38F temp with the car sitting outside.
I'm thinking of buying a used 4 cyl. Honda Accord (maybe a 99,00 or 01). I thought the transmission problems were only with the 6 cyl., are there problems with the 4 cyl. trannys as well?
Also, do you think I would notice a big difference in power between the previous generation 4 cyl. 4-speed auto vs. the 2003 4 cyl. 5-speed auto?
If there is a big power difference or if the previous generation has tranny problems, I might consider buying new, but I'd prefer to buy used to save money.
Any opinions are greatly appreciated.
Now the car is completely quiet, tight, and rattle free.
A couple more questions:
Yes, I went back to the car a couple of hours later and restarted the car. Yes, it would crank. I generally dont keep the ignition turned on for more than 2 seconds(usually the car comes to life by then). This time, I kept it on for say 3-4 seconds and the car shuddered. I alternated with pump gas and start and it worked. But, why shouldnt we pump the gas? Is it not recommended?
I guess, its time to check the car for its batteries and find out whats going on? BUT, this problem seems to happen only when the car hasnt been started for long(like a weekend).
Thanks and i will be seeing the dealer this week, still have another 9months of warranty on the car.
Hope somebody else chimes in on this but I think u should not touch that accelerator when starting.
Thanks for any advice you can give.
1)"...are there problems with the 4 cyl. trannys as well?"
I've not heard of the 4-cyl models having the tranny problems of the V6, and didn't experience them on our Accords. Apparently the trannies aren't able to handle V6's power but are fine for the 4's.
2) "Also, do you think I would notice a big difference in power between the previous generation 4 cyl. 4-speed auto vs. the 2003 4 cyl. 5-speed auto?"
The 03 more smoothly and quietly accelerates, altering the sense of speed as compared to the previous gen Accord, which seems "faster" because of the acceleration raucous.
Actual 0-60 time is shorter for the 03 if I remember the magazine tests correctly.
Overall the feeling is that the 03 is a more refined, quieter and sophisticated Accord although it still doesn't isolate as much as a Camry (I drive a Camry Solara 4cyl).
3) "I might consider buying new, but I'd prefer to buy used to save money."
Upfront cost is definitely lower on a pre-owned vehicle, but future costs like timing belt change, tires, (not to mention higher APRs on used versus low promotional APRs on new) etc. reduce the differential to a point where one asks "is $2000 more over 4 years for a new Accord worth the technology upgrade and the higher overall satisfaction of ownership?"
Each one of us answers this differently, and in my case the 03's new-generation improvements were compelling enough to change.
The road feel and handling is why I buy honda's. Oh if u have Michelin MXV4 tires-don't replace them with the same tire-read reviews on tirerack.com. Michelin X-One is a better choice and so is the Bridgestone ? -- senior moment-potenza I think-there are several types and they are geting good reviews. good luck with your honda.
I also have a 2000 SE with 37K and it has never had a problem starting. Check out page 171 in the owners manual on starting your car. If instructs you to turn the ignition key without using the gas pedal. If this does not work, wait at least 10-15 seconds and try again. (I have never had to go past this point.) If this does not work, THEN accelerate half way (do not pump the gas pedal) and try again. If this does not work, THEN accelerate all the way (again do not pump the pedal) and try again.
Try starting the first time without touching the gas pedal and you will probably not have to worry about all of this other stuff for years.
My initial post was in response to reading #4016. I'd never heard of the problem with the 4 cyl. I'm still not sure if it's an isolated incident or not. Let us know how it turns out.
atlantabenny:
Thanks for taking the time to respond to my post. The fact that you have owned both generations lends definite credibility to your opinion! I've got a lot of thinking to do. I'm afraid to take the 2003 on a test drive since the new car smell tends to diminish my objectivity !
Took it a Honda dealership and I asked for an alignment check. The service manager told me that alignment was little off the manufacture specification. It was realigned and now drives straight. The dealer initially said that it’s normal for the car to follow the crown of the road, and asked me to test it on one way straight road.
I suggest do an alignment (if not already performed) and follow up with what Gotribe suggested.. Escalate.
That 7 seconds rule is very interesting. Did he mention how fast you would have to be going for 7 seconds rule to apply. Good luck.
to all the accord 03 i4 owners:
what gasoline(manuf, octane) do you put in ur baby?
I've posted this numerous times in the civic forum, and I wish there was a FAQ about some of the most common problems.
Also the rotten egg smell of new cars should also belong in a FAQ (Frequently Asked Questions). It is due to the catalytic converter being worn in, it should go away after a while.
Andy
From what I understand sulfur from our crappy gas builds up and is burned off during hard acceleration. I notice the smell too but only after I rev it out. I wouldn't worry about it.
Honda 800# Customer Service acted as if they had no clue. At Honda.com web site, they do address it as part of the car's cold engine being accelerated or deaccelerated and no mention that it is just an initial break-in problem, though that is what a service advisor told me.
I presume that others are not talking of the burning smell, that new Honda's and other car's emit, very noticibly when parked in an enclosed garage. I understand that to be the anti-rust undercoating, which wears off eventually.
I have never experienced smelling a stink (egg or sewer like) while sitting in a new car at the traffic light. Since I have only 500 miles, I have not indulged in hard driving.
My new car came with a factory filled tank and I have filled it with the Sam's gas with 87 octane; but now I will experiment with "better" brand gas.
Any input is welcome.
Very hard to find TSB info for Honda (surprisingly difficult)
Anyone had this problem, gone to a dealer, and had it fixed?
I'm also curious about the comment someone made about Civic and turning it to "ON" for a few secs to get the fuel lines pressurized, and then subsequently, having less wear/crank on the engine. Any mechanics out there want to comment on this?
I had a 2K Maxima, and always had much smoother starts (although once in a while, the immobilizer chip would go south).
Somebody a few days ago posted a very good explination of the "cause" of the rotten egg smell. Has a lot to do with how much sulfur is in our fuel. I can even smell it when my vent is open to outside air when some idiot floors his 7K# UAV in front of me. If a rotten egg smell is the worst problem u are having with a car-oh what luxury.
If i had an 03 accord that pulled to the right-would really be torqued. Lots of people are reporting this-hope honda listens and fixes whatever is wrong. Guess you could under inflate the left front tire a bit to give more drag. Love the "7 second" rule-must have been a high double digit iq sales guy to think up that one. FYI- I sell for a living.
The first one is simple - you get the smell because your catalityc converter goes south on you.
The second one is more complicated and doesn't indicate any problem.
According to that theory you get tha smell because your car is realitively new, and is running a tad on the lean air/fuel ratio mixture side.
The sulfur compounds found in all gasolines.
In a lean engine these compounds are broken down into simpler form, most notably Sulfur Dioxide (SO2) which is changed into Sulfur Trioxide, (SO3) in the catalytic converter.
This SO3 will build up until a rich air/fuel mixture occurs in an engine, such as slowing down and stopping at a red light, or going uphill where the engine is working a little harder and calling for more fuel.
At that point, the SO3 is changed to H2S, (Hydrogen Sulfide), the "rotten egg odor gas" and exits out of the exhaust pipe.
There is nothing that is "out of adjustment" or not working correctly. The smell will cease as the converter ages, in the meantime you may want to try various brands of gasoline to see if that will help.
They said that Japanese cars are notorious for low-pressure fuel lines, Honda & Toyota were the major ones. This trick works well on my Civic when my gas is low.
Today I picked up my car (with the new improved transmission) from the dealership. The car feels excellent. No funniness in first gear, no hard downshifting and no gear crunching. Honda definitely fixed the generic problem in this improved transmission.
I would highly recommend the Accord as a used car option. It is a refined vehicle that has good resale values (sold my 1992 10 year old 130000+ miles for 1/3 of what I bought it for). Honda stands behind their product with extended warranties when generic problems occur. I would also look at the Camry although smaller in size a very good car from an excellent manufacture.
I took it to the dealer, actually 2 dealers, the first said they heard no noise, the second told me if was the "freon depressurizing after being used and that it was going back to liquid after being in a gas state."
Does anyone else have any noises from the air system after turning off the car? Shouldn't there be no strange fan noises coming from a car with under 3000 miles on it?
I just cannot accept that this is the way the car is supposed to be.
Thanks for any advice/opinions.
