Im not sure if this is because it is so cold out, or because their may be a problem. When it is warm out, or when the car has warmed up , the engine starts like a gem. Maybe its just due to the cold weather.
But if anyone else has exhibited these problems, which after reading these forums I see is true, has anyone spoken to Customer Reps at Honda or contacted a technician. Thanks
"Today I picked up my car (with the new improved transmission) from the dealership. The car feels excellent. No funniness in first gear, no hard downshifting and no gear crunching. Honda definitely fixed the generic problem in this improved transmission."
I thought transmission failure was a result of defective components, not design. In other words a badly designed transmission may not shift nicely, but it will not fail. Do you think the first gear problem of your old transmission was a defective component problem or a design problem?
I have heard people say that a hesitant first gear is a characteristic of this generation of Accord. My parents have an 88 Accord that has had the same problem for 150K miles but it has never failed, it's just annoying (on an otherwise bullet proof car).
What are your thoughts?
Being that cold, I have had no problem with starting. A couple of cranks, but the car fires up without a hitch. Thank god for those heated seats too!!
I dunno, maybe it is a problem with gas, or being low on fuel, but I've had no problems and it has been really cold here.
zolare
Wonder if the tech screwed something up when he replaced the emissions purge valve. Tried turning the ignition to the ON position for a few seconds before starting and did not help. No big deal but wish it started as it used to almost instantly.
Oh the symptoms of a bad primary heated O2 sensor in addition to the usual CEL are stumbling engine when cold-too rich and causes missing and gas mileage lowered by about 10% from 30 to 27 on the road. Pricey part about $225 from honda - that is why the extended warranty be a good thing.
Has the tranny been shifting hard or differently recently. Suppose u have checked the ATF level. When you do-dab a bit of fluid on to a glass to try and see the color-should be pure light red and no brown - also smell to see if it has a burnt smell.
To mdx kid: could you post more detail from Honda on this? Thanks!
And when it wouldn't start, you then had to try to start the tractor to pull the car.
Now there are complaints about 3 second cranking.
Just because something was hard to do 35 years ago, doesn't make it an excuse for today. Remember when the only way we could exchange information was by sitting around a fire and grunting while we ate the fresh kill? Come on... I expect more each day and I do my part to make sure it happens.
Besides, my 78 VW Rabbit would start right up and didn't have problems until below 20F. At the time the car was 20 years old.
Just had the first oil change done at 4K. It has always shifted differently--sounds like it's straining to get into the next gear w/o being unduly pushed. Didn't see any check engine light. I just thought that maybe, in this weather that w/o having really warmed up the car more, that maybe the oil hadn't warmed up enough. I'll def have it checked out by the next service, or if it does it again sooner.
But of course that's nothing compared to the nightmare that you've experienced... getting stranded 3 times with a brand new car. What exactly has the dealer done? Have Honda's regional service folks been involved?
Having an unreliable vehicle is a royalPITA. good luck.
Can you give me some pointers on how to access these bulbs?
Auburn and any other Honda techs out there... any comments? Has anyone else in the discussion had problems with a 95 Accord trans?
If so, any luck with Honda? Sorry for the long winded message, but I'm a little frustrated... Thanks in advance.
Told this before but I got a CEL code which was tranny related at about 70K-checked the tranny dip stick and the stuff was brown and had a burnt smell. All I do is highway driving-no extended traffic idling. Well my experience tells me driving at highway speeds can and does cause ATF breakdown-so change it at 30K. WOW what a price for a new tranny. Now I only have 150K on my 97 I4 auto-want to get at least 250 and possibly 300 before getting another. Honda just went up on their ATF also-new design on the jug so I guess somebody has got to pay. At least they don't charge $8 a quart like DC.
My Lexus LS400 has special Lexus synthetic ATF. $12 a quart for like 10 of em needed for a change. Geez.
I brought it back to the dealer and they said it's more complicated to find out the problem since it won't happen all the time. Finally, they said no prob. with it. I talked to some repair shop and was told to ask the dealer check "Idle control sensor".
Anyone has same prob., please share. I am going to bring it back again.
Go figure.
In another thread you said the reliability of the Accord was proven?
But I don't buy automatic cars in general when I have a choice. If they made a 5 speed manual LS400 I would have one.
Sammy Castagna
Does anyone have replacement tire suggestions? I don't really want to spend $160 per tire for the OEM Michelin Energy tires. I also want a tire that has less road noise. Thanks!
Rich
This sounds like the initial ABS/TCS test that the car is doing.
I have the exact same this when I start my car each morning...back up about 20 feet, turn, go go forward...within a few seconds, I hear the "clunk".
From evertything I hear, this is perfectly normal and is working as designed.
The dealer may or may not be aware of this. If you find out there is a TSB about this, please share with the group.
However, the 7 year warranty on the transmission is not applicable to the '02's......yet.
I too will be looking for replacement tires for my '98 EX V6 Coupe. I no expert, and am still trying to learn more about this subject. Thus far, I've heard good things about the Michelin Pilot series and the Dunlop Sport A2's. All comments are welcome.
I took my car (2002 Accord EX V6) for 15K service and they discovered that the transmission shift lever seal was leaking. They fixed it under the warranty. The question is how serious it is? Also, is it an indicator of future transmission problems?
I have an appointment this week with a body shop to check for leaks. Any other ideas about what the problem could be?
Paul
I've heard good things about the Bridgestone Turanza LS-Vs. I will probably pick them up.
Have any of you had a similar problem?
One transmission shop is telling me it may cost $1800 to fix. Does that make any sense?
