While this is not a sure-fire diagnosis, it is very likely that this symptom will exists with bad alignment.
While not a sure-fire diagnosis, it is very likely that with bad alignment these symptoms also exist
My 03 EX-L cycles between
-3, -2,-1,0,1,2,3 degrees in Farenheit. I wish it did +/- 5.
I have taken it in but the service rep told me there is nothing he can do to adjust it.
Why would service rep told you that he can't adjust all he had to is replace new sensor unit
on front bumper(your car still under warranty )
you may have to push them to do it don't be too easy. Oh!! did you see any change when you change
+/-3 setting on Temp read out ?
Anyway, I think you have figured out by now, due to the lack of response, that the Accord has neither a pervasive nor localized system mis-design (such as the apparent need for submersible circuit boards in certain Passats that you mentioned) that would affect the ECM.
The Accord's on the way to Wellville...once the part comes in from some warehouse.
To be honest, this thread's a lot busier than I thought it would be. Our 97's been pretty good though. At this rate, I'll be posting again in about six years. See ya then!
Are you looking for a mechanic in Austin, TX?
The PO's mechanic told them it was a $500 chip that needed to be replaced. They declined to pay them for that chip.
Any Suggestions?
If anyone might know what the chip may be, please feel free to chime in.
For those of you buying new Accords, please make sure that yours does not have this problem.
Any thoughts would be great!
Greg
Please help.
Please help.
The vibration when idling is most likely not related. If your idle rpm speed looks the same as it has always been, then it is likely a bad motor mount or possibly misfiring. If your rpm is lower than usual, you can manually adjust it up.
BTW, the front brake was serviced 6 months ago at a honda dealer. Now that I think about it, it seems the vibration during braking probably appeared after the brake work.
What fluid change are you referring to Whitecloud?
To lelandhendrix: how much should I expect to pay if the problem is warped rotor and is it fixed? Also about the rough idling, the speed is low at 500 rpm, but the dealer shop seemed to have a lot of trouble bumping it up (see message #6960). Any ideas?
The temp gauge was OK. The needle stayed between H and C. On the way home, after 5 minutes of driving, I noticed the temp needle still stayed at 'C'. And there was no heat. Thanks goodness it's not single digit temp outside.
Guessing that the thermostat probably stuck open, so I continued driving. When I got to home and about to park the car (after 17 mile driving), the temp needle started rising again and there was heat.
After dinner, with engine cooled off, I started the car and waited for several minutes, the temp gauge behaved like it should be.
I experienced the thermostat stuck open while driving before, but not when the engine was cold.
Does anyone have any idea what happened?
Let me tell you about my driving habits. I drive a mix of urban and highway driving. I don’t tailgate or ride the brakes. I don’t wait until the last second and then hit the brakes hard to stop. On the interstate, I very rarely use the brakes unless someone cuts me off. I turn off the cruise control with the ‘cancel’ button, not by tapping the brakes.
I have taken three trips of more than 200 miles one-way. In March 2003, I drove from Indianapolis to Daytona Beach, Florida. Driving around Daytona Beach (about 6k miles), I felt a vibration every time I stepped on the brake. After I returned (about 8k miles), I took the car in and my dealer turned the front rotors. After another 2-3k miles, the brakes started vibrating again, but not too bad, so I decided to deal with it for a while. The second trip was in September 2003 (about 18k miles), when I drove to Washington, D.C. The brakes felt about the same driving around D.C. as they did when I left, but seemed much worse when I returned. Again, I took the car to the dealer and they turned the front rotors again and turned the rear rotors (about 21k miles). Since the second time the rotors were turned, I have babied the brakes, stopping like my grandmother does. Still, some vibration returned. I drove to Birmingham, Alabama, last month (about 27k miles). You guessed it, the brakes seem worse now than they did when I left.
Anyway, the similarity between all these trips is that I drove for several hours at 75-80mph, stopping only for gas and restroom breaks (every 250-400 miles). Shorter trips don’t seem to be a problem. I have driven to Chicago three times, Cincinnati once, and central Illinois once, and didn’t notice additional brake vibration after these trips.
Honda has apparently changed the materials of the pads so that there is not as much heat buildup. I plan to get new pads (and rotors) installed at my next oil change—in about a month. Does anybody know whether Honda changed the both the front and rear pads, or just the front?
Do you think this is simply a matter of the pad materials causing too much heat or do you think there is something else wrong? If so, what else could be the problem? Is there a way to test for this (other than driving 500 miles at over 75 mph)? Thank you for any and all suggestions.
I would definitely ask your dealer to put on the new type of pads and see if you can get new rotors, too. It's seems likely that the poor performance of the original brake pads caused premature problems with the rotors. I talked to Honda Corporation and got my pads/rotors free as a "courtesy." My car had a lot fewer miles than yours, though, so I'm not sure what the outcome would be.
How long has it been since you had the new pads/rotors installed?
Replacing the pads and rotors should help, if the new type of pad handles heat better.
Is this normal? Would this be covered under warranty.
Thanks for your help.
so, i am seeing the District Rep to see what he says. i will let you know here once i find out.
Our Accord stops straight and smooth as glass from 100mph. They all should.
So check if
1. you have enough coolant in the radiator.
2. the radiator fan comes on when the car idles for a long period of time.
3. you have a thermostat failed to open? Have not experienced this yet. Failed to close (underheating), yes. Matter of fact, my 89 the thermostat is failing to close last few days. When the part comes and outside temp next week, I will replace it. In the mean time, I just have to drive it underheating & high idle.
Try placing a pillow lower than the lumbar "bump" then you can distribute some of the pressure across your back rather than at one place.
Sorry to hear about your experience.
for about 2 min until it warms up.I have done a tune up i havnt touched the timing and i have
checked all fluids.I have never seen this on my civic unless the cooling sys was empty..pleeeese
help. thank you.
