Visitor Agreement.
As far as anyone knows, it can't be done (other than by pressing "I Agree" each time). Blame Toyota's lawyers.
Worse going down a hill with the road slightly wet.
Luxurious Appointments
The interior of the LS hosts an abundance of genuine leather and rich wood trim. Both the steering wheel and shift knob are graced with wood and leather, and the audio controls are ergonomically integrated into the steering wheel for added convenience.
Due to certain characteristics of wood (weight, warping, etc), all of our wood trims are made from plastic.
If you require further assistance, please respond to this e-mail, or contact Lexus Customer Satisfaction at 1-800-255-3987, Monday through Friday, 5:00 am to 6:00 pm, or Saturday, 7:00 am to 4:00 pm, Pacific Standard Time.
Sincerely,
Something is terribly wrong here. Look at the 2005 LS large-size brochure, and it references "genuine wood" in many places. For example, "choose from either golden bird's-eye maple, walnut or antique walnut wood ..."; "rich premium leather and burnished wood trim can be found on everything from the steering wheel to the door panels"; and "Genuine bird's-eye maple, burled walnut or antiqued walnut and leather interior trim".
If it is only wood-grained plastic, then Lexus should be on the lookout for a class action fraud lawsuit. But I don't believe they would be that stupid. When car manufacturers use plastic, they always refer to it as "wood-grained trim", not "genuine wood".
If that email you quote is truly for real, then there must be some misunderstanding of what the writer meant by "trim", or they simply didn't know what they were talking about. Or someone is attempting to pull all of our collective legs.
Certainly wouldn't be the first time an employee unintentionally gave out incorrect information on behalf of their employer. That's a more likely case than a company lying about its materials.
As I said previously, if there is no real wood in the LS, this could be the first class action case that I will have ever supported the plaintiffs attorneys for bringing.
So both statements referenced above are partly correct.
"The only difference between rape and rapture is salesmanship." --- unknown
OK, care to share with us why you know so much about these matters? Have you worked as a automotive tech, engineer, sales, executive; or are you just self-taught? Time to come clean!
Thank you so much for your smart reply & sorry for the late reply, as Thanksgiving vacation & family affairs have required lots of my time lately.
Please let me shed some light on the issues you have brought up:
1. I have new battery in the car (about 6 month old).
2. When the problem appears, all I hear is clicks, so I
believe you were saying I have a problem between the
key switch and the starter, including both, which makes
lots of sense.
3. I do not have a problem of "turning over and not
starting" or "slow cranking". When it finally turns
over, the engine is starting.
This morning I had the most serious problem to date. Tried to start about 100 times and got only clicks. Tried to jump start from my wife's car, and of course it didn't help, because my battery is charged. Called AAA and told them I needed help to start, so they sent a guy in a van with a carry-on battery. He knew right away that jump-start would not do it, so he sat behind the wheel and within 3 tries started the car. When I asked him what he did, he said he "wiggled" the key in the ignition, which makes me think maybe the ignition assembly (?) needs to be replaced???
The car was OK throughout the day, let's see what tomorrow brings...
What is your take on this?
Thanks again for your help and happy holidays!!!
Thank you for your advice and sorry for the late reply. Please see my previous post replying to paul29 regarding the same issue.
The battery is rather new and Vista Lexus of Woodland Hills, CA quoted me $800 over the phone (I'm sure the total would be closer to what you have indicated). I have an independent and experienced mechanic, who can do it for about $500 - $600, as the part is about $300 and labor is about 3 - 4 hours. I am waiting for his final quote now. However, it may be the ignition that's causing the problem.
The biggest problem is that the mechanics need to see the problem duplicated to analyze it, but it happens only sporadically - once a week, once in a few days. When it happens, I can't drag a mechanic to my house or office and when I bring the car in, it starts without a problem!!! If they run an electrical system test, everything shows great!
It's a real dilema, because if it's the ignition, why should I throw away a $1,000 on a starter?
Any ideas?
Thanks & happy holidays!
In that case it really does sound like a dead short on only one winding of the starter. If by pure happenstance the starter stopped on that particular commutator segment when you last used it then it will exhibit the very symptom/problem you describe.
Even a shorted winding will provide some minor level of rotational force so with enough "clicks" the short will sometimes rotate out of place.
A friend of mine picked up a brand new Ferrari Scarletti here in Seattle and within days drove it to Daytona. Along the way, SFO, LA, he had numerous instances of non-starting and Ferrari service not finding ANY problem.
The evening after driving it, successfully, on the track at Daytona it did it again. Ferrari trucked it to Orlando where they discovered the chassis end of the battery cable had never been fully tightened.
And your problem is NOT w3ithin the ignition circuit. The starter solenoid is clicking on and off because when it engages the load is too much for the battery/cable/connections to carry and the voltage is dropping below the level that can hold the starter solenoid engaged.
The problem can even be a poor/broken connection inside the battery itself. If the problem began shortly after installing that new battery I would check that first by substituting a good battery.
Thank you for your quick response.
Are you saying there is a short between the ignition & the starter, or maybe in the battery chasis?
The most common cause is dirty or corroded battery terminals and that for some reason most often occurs in the early spring. Second would be a discharged or defective battery.
The problem is not likely to be ANY relay. The continuous clicking is occuring because when the starter solenoid engages, the battery itself or the battery circuit cannot handle the load and so the solenoid drops out due to the drop in "battery" voltage. As soon as the solenoid contacts open the battery voltage rises and now the cycle repeats......
I doubt if anyone could hear the smallish relay clicking and it likely doesn't have enough current load anyway.
Whereas the clicking of the huge, relatively speaking, starter solenoid can be heard quite readily.
I am humbled and impressed by the time you dedicate to try and help me out - I'm really touched. Although I'm an idiot when it comes to mechanics and especially the electrical field, and do not understand some of the stuff you are discussing, please be sure I am taking notes!!!
Let me clarify some more things and narrow the guessing game (and again, thanks in advance to anything you post in reply):
1. The battery is new and the terminals are NOT corroded.
2. There is only one click per key turn and a pretty loud
one.
3. The car has NOT been inspected by the dealer, although
an independent mechanic looked at it briefly. Because
the problem was not duplicated, he talked about voltage
drop, but asked me if I wanted to replace the starter...
Most important thing is, since my encounter with the AAA guy yesterday morning, I am doing what he did: "Wiggling" the key while trying to start the car. Today I had a few "clicking" instances, so I wiggled the key while turning it in the ignition switch and Voila! the car started.
This makes me think (again) that the problem is in the ignition.
Question : when you wiggle the key do you get extra clicks.
Answer: No.
I will try to follow up on your instructions with my mechanic in the next few days.
There is totally no effect whatsoever on the headlights. These Xenon lights are as bright as ever.
My '92 LS400 exhibited the same problem in '96 that you have until I had the starter replaced for $800 at Lexus service.
My mechanic stopped by my office this afternoon and we took the start relay out of box. When I tried to start, there was no loud click and nothing happened.
My mechanic says that if he would run a voltage test while the problem is no present, everything will show perfect (I had Firestone run an electrical system check and all was good), because if you run this test when the problem is not present (not duplicated), you can't know what causing it.
By the way, when the car clicks but doesn't start, I wiggle the key while turning it, i.e. during the actual motion of turning the ignition key. It then starts.
Usually you can use a diluted solution of Woolite. If that doesn't work you can use Fast Orange Cleaner. A leather restorer told me he uses that to clean surfaces before he re-dyes them.
Hope this helps,
SV
You & the other forum members who replied to my problem were a lot of help & inspiration. I thank you all.
What I think I should do - since everything is pointing to the starter itself - is take the car to my mechanic and have him access the starter to find out if the contacts are dirty. If they are, I'll ask him to clean them & put everything back together and I will give it another shot to see if the problem has been solved.
If the contacts seem to look clean, I will order the $300 starter from the Lexus dealer (they give you a rebuilt one, anyway, according to my mechanic who installed one on a 1993 LS400, but at least it comes with the dealer's warranty).
Does it sound like a good plan, or should I try something else prior to that? Remember, if I cannot duplicate the problem, a voltage drop test will come out perfect.
Thanks again!
The Lexus dealer's mechanic said we are hearing wind noise from the outside since LS is a quiet car.
Is the wind noise normal during high speed on freeway?
There is also a higher level of noise when I drove the car faster. For example, when I am on the interstate, I definitely have to increase the volume on the sound system. Quite a lot.
If it's windy outside I can tell a difference, too.
I don't think any car is totally soundproof. Our LS is the quietest car we have ever owned.
Happy Holidays!
