Lexus LS: Problems & Solutions
My 1992 LS400 has leaking LCD dash displays for
both the HVAC display and the Nakamichi stero
display.
The dealer wants $1300.00 to repair!
Does anyone know were the displays alone can be
purchased or can replace the displays after
removal from the vehicle?
display.
LCD is fogged over. After a hot day in the parking lot I can read the display but it's sort
of foggy. I've never tried to sort out the repair
problem or $$$'s.
components on Ebay under Lexus,somewhere out there
there has to be somebody that repairs these
systems,all we have to do is find this place.
Please, tell us about your fix for this problem!
Town Hall is not the typical question and answer board. We discuss things around here at great length and the discussions are always available for anyone looking for answers on a particular problem.
So it would be very helpful for all of us if you would post your thoughts on this problem here.
Thanks, and again welcome.
Pat
If you find out let me know because my one bulb is out for my passenger heated seats button.
When some of the climate control/clock lights on my 91 LS400 started going out I had my dealership (Longo) replace the bulbs. It cost me about $80 + parts and they replaced all the bulbs, not just the burned out ones. A few weeks later, I had an alarm installed on my car and the installer mentioned that he knew how to replace the bulbs as well. I'll probably have him do my stereo bulbs if they ever start going out. It'll be considerably cheaper (although $80 is very reasonable compared to other estimates I have seen on the web) and he knows his way around these cars so I trust him.
regarding leaking LCDs. Do you think the cause of the problem is heat/sunlight related? My 91LS400 had a very dark tint on all the windows for 9 years. Also, it was often parked in the shade or in a garage. I have not (knock on wood)
experienced the LCD problems that so manyother Lexus owners have.
Better yet, post 'em here! That way others can benefit as well. :-)
Pat
Please post !
Thank you, Sheldon
if you replace the whole A/C control panel, you wouldn't need to replace the burned-out bulbsl, right? or is this a separate matter?
Be sure to check out all the topics in our other conferences on these vehicles. You can easily find them by first entering LS 400 and then do a second search for GS 300 in the Topic Search feature on the left side of the page.
Here is a search tip: entering "LS 400" will return topic names containing both "LS 400" and "LS400" but entering "LS400" will not return topics with "LS 400" in the title.
Good luck and again, welcome.
Pat
Other thing is I had a Nakamichi system in my 91-Ls 400 which give only sound to rear left speaker and right front tweeter.I already have my mecanician check the right front speaker and he said no signal come to this speaker.
Any body have any advise for me how and where can fix it.I am in Atlanta, GA. I really love the Nakamichi sound from my wife ES 300.Please note that I just got this 91modelw/93K miles 3 months ago.
Any help will be appreciated.
Few month ago I experienced the problem with the heater. I did not get any heat when increasing the temp. I can, however, get heating by manually moved the control ( under the hood, by the firewall ).
Suddenly, my heater is now working again. I now can get heat by pushing the temp button.
Anyone has similar problem ?
Anyone know how to replace this switch? I don't want to take the car to the mechanic if I can do it myself. Do they sell a repair manual for the Lexus ?
I started having climate control problems as well prior to replacing the LCD unit. The Low air would shut off once the desired temp was reached and when the AC was activated to lower the temp it would just blow ice cold AC air not a mixture of warm and cool. My LCD at that point was totally blacked out. However - I will add that just prior to the climate control freaking out, like the day before, I had it in the shop because my Alternator died and I drained the battery so bad that I had a total brown out of my electrical system so bad that the engine cease to run. I don't know if that fried the Climate control unit or not (everything else is OK) but that same week I replace the LCD face unit (see above)and now my climate control works perfectly.
PS. Just a thought for you - if you ever plan to sell your LS 400 - no one will by it with a burnt out time-temp read out. So you might as well fix it and enjoy it while you own the car. Its real simple and I would be happy to walk you through it. Dugcar
Also - regarding your brake light, I know this sounds really simple but when I first bought my LS400 the brake light would stay on until I figured out to hold onto the brake release handle a second longer and it disengaged the switch. Something to try .
For the brake light, I know it's a faulty switch. I just can't figure out how to replace it. For now, I just use black tape and cover the light and just remember to release the parking brake.
If you know how to replace the switch, let me know
I have replaced two alternators in mine and finally was informed by the mechanic that it was caused by the power steering fluid get into the alternator.
The cost for replacing the booster is under 200 at the independent garage. I don't know how much Lexus will charge.
Speaking about the charge, if your car out of warrantee, have it serviced at an independent mechanic especially for tune up, water pump, timing belt or alike, you'll save half of the cost.
Good luck
1) Can the LCD be replaced?
2) Are there LCD bulbs that go bad and can be replaced. Or does the whole display have to be replaced.
3) What does all your experience tell us that are new to this game. Should we use a dealer, should we buy the part, etc?
I love the car but this is driving me crazy!
Just scroll back and read post from dugcar and silco. It's quite easy to replace. Cost around 400 bucks. Good luck.
Pat
good luck,
Bill Barton bb25e@aol.com
fluid. My 90 LS light has come on when the
fluid is down just a fraction of an inch.
If this is your problem you might notice
that the light sometimes is not on after
parking on a grade, rather than a flat
spot.
The radiator indicator works the same way.
If you're just slightly below the low level
indicator line, then you'll sometimes see
the dash indicator.
Two weeks ago, I took the face of the temp control unit to fix the LCD problem. I was hoping that the problem was the burnt out light bulbs but it wasn't. All I had to do to was to remove each bulb and measure its resistance with the Ohm meter. If I remember correctly, there were 4 bulbs for the front LCD lighting. It would be unlikely that all 4 bulbs to go out at the same time, so chances are you would need to replace the whole thing(the face) if your LCD blacked out.
PS. At what part dealer did you a remanufactured LCD for $375? I am interested in buying one.
dugcar
Jim
