Visitor Agreement.
Can anyone suggest what, if any, the likely implications of this switch from the recommended lubricant may be for the long-term future? Thanks.
Generally this results in more stress on the various bushings and sooner failure of these components.
In a severe curb hit [highway divider] or climb and bash the level of damage [cost] is more on the newer 98 design.
Are you speaking to engineers who design the systems or shops that make their living replacing components?
We had the same problem in getting owners to understand the importance of transmission fluid exchange......the shops were against anything that prolonged life as it decreased their revenue!
Understand WHY an evaporator begins to leak and why the $500 parts cost $500 in labor to replace.
Understand WHY the $800 compressor fails.
People want a cheap fix and shops want a short life fix [a month or two beyond the 12 month warranty is GREAT]......anything more is taking food from their children.
A QUALITY new or rebuilt compressor should last almost as long as OEM [after all they were designed to have 0 to 3% failure for the first 6 years. But there are grades and cost differences in rebuilds and inexpensive Malaysian copies of OEM evaporators [lighter weight and thinner more porous aluminum].....sure you can save $200-$300 but you get to pay again soon.
Always use OEM replacement parts [and these may not even be the same superior quality as the new build parts] as the labor component is significant.
Two years ago, however, when this flush-through procedure was done, I had owned the car for only a couple of months and was not so well-informed about this issue. Besides, I was given every assurance by the operator of this equipment - who, as I've said, is a professional transmission specialist (although not specifically Toyota) that the Dexron ATF he would flush through my transmission was at least as well-specified as any other ATF on the market at the time. (By this time, I had already been specifically told by my Lexus/Toyota dealership to consider replacing as much of the existing ATF as possible, so when I heard about the only guy in the UK with ATF flushing equipment, I paid him a visit. (Dexron was the only option available for the flushing procedure.)
So, rightly or wrongly, the Dexron is now installed, and total removal is not really an option unless I could find someone with the same extremely rare flushing equipment who also happens to work with the specialist Toyota ATF instead of the more generally used Dexron.
The question I'd like to know the answer to, therefore, is what is the worst that could happen if the Dexron is left in. (Two years later - and 8,000 miles since it was put in - I have not noticed anything untoward yet. the car has done around 32,000 miles in total).
Dexron II,III, IIIe, IV is a minimum specification description not a brand!
R134a molecules are much smaller in size [permiate thru microscopic holes in hoses] than the Obsolete R12 and R22 in home AC is a different animal also.
"all for maintaining a car properly, but A/C systems are one thing that need very little maintenance unless they fail. "
When something fails that is a repair not maintenance!!!!!!!!!!!!!!!!
The root case of most auto AC failure is moisture getting into system and the dryer at capacity unable to absorb anymore moisture so the water stays in and free to form acids.
If the silica jell in dryer is wet the cheap solution is evacuation, dryer replacent, and repressurize.
In the past owners just topped up the Freon as it leaked out [today this is illegal and a felony].
Why does a repair only carry a 1 year warranty because the repair does not address the reset of the system which may just be hanging on.
If owners changed all the fluids [diff, brake, ps, ATF, coolant, etc] on an annual basis more than half these shops would be out of business as the failure levels would drop dramatically!
Warning many dealer services are not full fluid changes [suck out the reseviors and master cylinder, drain the pan, drain the radiator---only removing a third of the contamination].
After all they can hardly wait till the warrranty runs out [so they can start to make some real money on your car].
Ac maintenance should be done around every 60k or 4-5 years to prolong the life of the compressor and evaporator as combined they are over $2,000 to replace on an LS400.
thanks!
I am at 99,000 miles on my 1994 LS and I am due for service @ 100,000 and some change, and well what do they do (Lexus) @ 100,000 mile service. Q45man What Fluids sould I have Changed in this service or is it just a regular service and what is the average cost. Also how do I know when my Water Pump goes (my engine temp rises??)ok thank you.
Paul
**Also I am somewhat sad about reaching 100,000 miles , is this normal
You should have all the fluids changed completely [diff, brakes, ps, coolant, transmission, traction? every year plus the oil every 90 days if you want to hit the above numbers with little repair expense.
Don't accept the bull that Lexus doesn't recommend and make sure they change it all not just drain a portion of it.
Be especially concerned with the Power Steering as this is a common problem!
They can hardly wait for something expensive to fail they are drooling with anticipation. But that's what they are in business for to REPAIR failed items. Extra preventative maintenance goes against a good business plan and lowers ultimate profits!
The water pump leaks out the weep holes and stains the front of engine....look for red dried coolant slime.
Driving the car home from the dealer I started getting the trac light on. I never had the light come on before I took it in for service. I
turned off the engine and restarted and it goes a way for a while. Not exactly sure why TRAC light comes on. No other lights come on just the TRAC light in the center of the speedometer.
Any information on traction control or if any one else had this problem is appreciated.
Also with new power steering pump on any suggestion to make sure I don't have another big expense with the power steering.
A sealed system is relative [sealed enough to not let much of the gas leak out] or sealed enough to not let water molecules leak in.
When the compressor is not running the pressures drop tremendously thus the need for a dryer to absorb the moisture that leaks in when the system is at rest.
http://www.apainfo.com/pdf/permeability.pdf
The above has charts for water vapor permeability of many different hose types and gasket materials.
Unfortunately many automobile ac systems have some type of rubber hose to allow the fixed to engine ac compressor to move against the frame rigid rest of ac system [remember motor mounts allow the engine to twist under acceleration]!
I just replaced my front pads, and visully inspected the sensor, no visual damage. I had the rear pads replaced along with the rotors. (96LS400) Had a new sensor put on the rear as well.
Anyone come across a situation similar to this?
I know its a minor thing, but the sensor light is kind of annoying when its lit on all the time-even though your brakes are fine.
Yes Toyota is concerned about the Lexus reputation [to keep resale price high so new prices can be inflated] but the dealers need revenue to keep service department profitable.
So don't be surprised if engineers are forced to underdesign a few things to fail...just after warranty. Likewise the dealers will not offer advice which will decrease future revenue as the service center is a separate profit center.
The current trend is to minimize mainteance expense since non informed owners equate low mainteance with a lower cost of operation....in the short run.
At our INDEPENDENT facilities we servicee over 2200 Lexus [of all models and years---usually older than 1998 includes many 90,91,92,93,94,95].
The major failure areas are PS, Alternator, AC system, and lighted dash displays. Minor areas are suspension, radiator, windows and locks.
After changing some 238 compressors and 247 evaporators in the past 5 years we have a feel for the Lexus systems.
We have many clients with over 200,000 miles and a few with 300,000 miles on 1990-92 LS400.
Our customers are different in that they are offered a list of failures [generated from our data base showing how many of what we have replaced on their model.....kind of a future headsup on what to look for and for bugetary planning. Each model is different and behaves differently in different temperature zones thus our data is only good for Atlanta or in the South at best.
I hope this fixes the problem. Read about a possible valve that works in conjunction with pump.
Hint to buyers of used lexus from individuals. Get the VIN number and get a printout of service performed at Lexus dealers. Found out previous owner was told of leaking PS pump and didn't repair it. I hope it was caught in time because could cause problems with alternator.
In genral how long should the lexus alternator last?
I also noticed battery was replaced at 33K and 36 months, replaced again at 67k and 32months with Lexus batteries.
My son's buying a SC300, 5 speed, either a '95 or a '96, both of them with 75-80k miles.
Any big $$ problems to look out for?
I know about the front suspension control arms and bushings going bad, allowing the front end to wobble with alignment problems, etc. - and that's an expensive one to fix at a dealer, around $120--1300.
I don't think the I6 has the same config up front as the V-8s - power steering assembly over the alternator etc.
Anyway - any thing beyond the reg maint items to worry about? The one he really likes, a '95 5-speed with 78k, has been to the dealer every 5-10k miles since it was new; the timing belt was replaced at the 60k service and the clutch is relatively new.
In advance - thanks!
Jeff
I was the one who started the talk about the pinging & knocking coming from the LS400 engine due to lower octave gas. Well just received the news from the dealer that it definitely wasn't the fuel. the lexus tech was baffled by the sound it was making, he thought it was the chrome center cap. we took the car for a test drive, got back to the dealership he lifted the hood,revved up the engine wham!! their was the noise, definitely wasn't the lifters out of tune, immediately he showed me what the problem was. He said LS400 engines were built like tanks.
Come to find out, it is the e.g pipe sub assembly(whatever that is)(q45mam can explain this hopefully) a small pipe burst. $100 bucks for the pipe, Now the problem he said the trans has to be dropped for the pipe to replaced. Wow (I'm thinking trans dropped $$$$$ hmmm). Well bottom line, about $600 bucks for a $100 pipe.
Well I guess I solved that pinging problem(never was one).
Any suggestions?
Love does dealers.
dj
didn't really mean to doubt you but is that correct?
hell if it's that easy, why on earth would he tell me they had to drop the trans? I'm going to call to find out how they came up with the notion of the trans being dropped, for some reason it's just doesn't sit well with me for them to take the route of dropping the trans for repairing a pipe.
dj
All V8/6 vacuum control modulator for EGR valve.
Cracking coolant expansion tanks.
Listen to this, I got quotes from 2 dealership, the previous one that I always attend
quotes me a price of $692 bucks for the eg pipe assly.(don't understand why)same tech said I had to have the trans removed. Now I called a 2nd dealership told them the same problem, they said the cost would be $345 w/o the dropping of the trans, only would be $220 if I retain the part, hell what a big difference, My ? what gives.
Suggestions?
dj
If the car ties up his working space to cool down you have to pay for the time it sits. Obviously the part cost around $120.
Obviously one dealer had a tech hungrier than the others or spare room to work on your car or both.
The higher price quote was the correct way [by the book way].......you will find that some people with repetiton can learn tricks to save time whether they chose to share the fruits with you is up to them! Applies to many things on limited run lux cars.
Why you should always shop around but at the same time make sure you are comparing apples to apples.
I have seen some EGR tubes repaired with JB WELD which seems to last 6-12 months then the real replacement gets done if you can scrape/grind the mess away.
Broken EGR tubes are the result of some abuse [accidents, hitting something, running over something, or bad motor mounts
the motor mounts, by the way q, how could i tell if the motor mounts are bad?
dj
I can't tell you the grief I have endured from my wife and friends for buying a car off of this well known auction site and "believing" the seller's representation rather than having an independent mechanic examine the car. I can't rewrite history so I am willing to try to fix this myself. I called DENSO (the supplier of the circuit boards) and they will not sell me a new board or exchange my board without going through the dealer. I have borrowed a used board (with another problem) that I can experiment on - so I hope some of you have investigated this problem.
Questions:
- I have got to believe that there is a common ground cracked or cold solder joint in the backplane or ribbon plane of the circuit board. When the car is warm the lights work! Has anyone found that a common component or solder joint goes bad on these boards that would cause a temperature-related complete outage of the lights while the temp, gas, seedometer and tach all still work? The circuit board part number is 83247-5A050RP.
- Can anyone tell me how (or point me to instructions) to change the tach needle after I have removed the guage cluster? The tach needle part number is 83242-50050.
-If I just buy a new circuit board and install it myself I understand it will show "0" mileage on the odometer. My car has 75,300 miles and I would like to keep it original - any suggestions on service outlets where I can go to set the correct mileage?
- Any of you bought a "used" cluster and successfully swapped it out or have you found them to have the same problem?
Im sure I'll eventually spend the $1800 on this Lexus doing some other upgrades - I just hate spending it on things that are already supposed to work. Thank you for any suggestions and help
Thanks for any advice....
I have read posts about problems similar to yours but none offers any solutions. Electrical problems can be very difficult and time-consuming to troubleshoot especially without relevant schematics but not impossible. Fortunately, I believe your problem is fixable.
Here are my suggestions:
1. Look for cracks under magnifying glass.
2. Trace conducting lines for any breaks.
3. Spray "freeze-it"(or something similar at electronic stores) to suspected parts while the instrument panel is fully powered to see if lighting behavior changes. If it does, you have found the problem area. Freeze-it is a aerosol can that sprays very cold gas.
4. Retouch all relevant solder joints with a heat gun. You'll be surprise how many circuit boards can be fixed this way.
5. Replace all relevant capacitors as their service life is about 10 years.
Be patient, take your time, and goodlucks!
1. Remove the first aid kit and the screws behind it.
2. Remove the screws that hold the panel to the rear dash. These are the same screws you would need to remove if you were trying to gain access to the subwoofer. This step will make room for you to remove the CD changer panel.
3. The CD changer panel interlocks at the edges of the panel with other adjacent panels, and I don't recall them fasten together with any type of fastener. Check to see if the CD changer panel is fasten to the car frame at the edges and remove if needed.
4. Use lots of muscle here to break the panels free from there interlocks.
5. Remove the panel from the trunk.
The CD changer internal is complex and non-serviceable but do check for external and internal vibration mounts. Let us know how you make of the CD skipping problems.
