A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Anyhow, I am looking to purchase my first Lexus (most likely a 90-94 LS or 93-96 GS). I would like to hear what the pros have to say by way of what to look for in a used Lexus. What systems or specific areas should I focus on? How many miles is too many? Any advice for my purchase would be helpful.
I am a DIY car owner by nature, but wonder if the LS is going to be over my head.
Thanks for your help in advance.
The LS I just purchased has also been remarkable. The only thing I am not too thrilled about is the suspension. This vehicle has the optional air suspension which can be extremely costly to replace and as I approach 85k, is showing its signs of wear including the sharp, hard impacts, front end wobble, and wandering on the highway. I'm hoping it will last another 10k or so (about 6 months) so that I can save for it. The cheapest quote I got was from irontoad for a little over $700 a piece. The remote gas door sometimes does not open but that is very unimportant. The interior is still immaculate and the paint is still shining. Even though it's black, a simple wash/wax makes it look like a new one.
As for advice, make sure that any car you purchase has had the 60k service done at a dealer. It's just a safe way to know that at least it has been to an "expert" once. They can give you one of their famous printouts too if you give them the VIN #. The 60k service extends the life of the car by a lot. If the owner chose the 90k service interval, make sure it covered the 60k components (timing belt, water pump, etc). And if you do opt for the 90-94 LS, make sure that the power steering pump is looked at !!! lol. you've seen the horrors they have caused. I haven't had any experience with the GS models...so someone else can pick up where i left off.. Happy shopping. There are very few Lexus lemons. They all give extremely nice rides with high reliability. Just like I tell all my friends, I am a "Lexus4Life" owner.
The timing belt is of course one of the major components to be replaced. But the 60k or 90k whichever you choose to use has a host of other procedures which are essential to the long life of your car. it (re)lubricates many of the parts on the underside of your car as well as inspects for damage the majority of major parts. When changing the timing belt, "all is revealed" and anything requiring the greater access allowed with the engine out can be fixed such as the water pump. The oil pan or whatever was fixed on my 93ES i mentioned could have been done when the timing belt was being performed but I said no. SO, it cost me an arm and a leg in labor to remove it again for a $50 part!
THe reason I said get the 60k service done is only as a safeguard. UNless you get a printout from your dealer, you have no way of knowing whether or not the car has ever seen real maintenance. For both cars I purchased, I had the dealer run a safety check for about $100 that had them inspect the major components for issues. I saved a lot of money just by getting the 60k mile service done since it included replacement of most of the fluids which were left dirty by th eprevious pwner and since the engine was out, allowed them to replace another part which I can't recall at the moment.
Rememner, that any Lex you purchase will only behave like the machine it is. Parts do on occasion fail and you want to minimize their cost. Parts for this car are extremely expensive so why spend extra $$$ for labor. I do not follow my schedule faithfully but I do take it in every 30k for a "checkup". I want this car to live up to its reputation of a longer than usual life, hopefully 200k if possible. Timing belts are very rare to fail in these cars so i'm told but any component will fail if neglected or not maintained properly. Hope this helps paul
I want to Thank Rodmodd and Q45 in advance for your helpfull hints. I am buying a used LS400, from a dealer in Toronto. I had the Lexus dealer do the inspection. Car has been serviced 32 times since new in 178,000kms. Good car everything looks good except the steering rack has some seepage, NO leaks , just seepage on the RHS boot(Passenger side). Mechanic said it could go next week or last 3-4 years. What to do?? P.S pump has been replaced in the work orders and rest of car very strong/// Is there aftermarket racks if it goes?? Are there seals that can be fixed in the rack.. Can it drive many years with seepage.??
Mechanic told me a rack was $500 bucks rebuilt. Checked with the parts counter they quoted $3000 canadian for the whole rack?? Kinda scared... Would appreciate an immediate opinion as I need to make a decision in 24hrs...
Thanks. Claude.
i went for a ride with the technician to help solve a vibration in my car. i asked him about the HSN timing belts. he's been at this lexus dealership since it was incepted (one of the original dealerships). he said he has only seen one break. it was on a 91 LS with close to 240k miles on it. don't know if he was lying or not but he went on to say that it was an old lady driver who just topped off all fluids (never replaced any) except for the oil. i find that hard to believe but it was good for a laugh. when the woman was told that she needed a new belt for the engine, she just opted for a new LS. wish i had that kinda money. i should have asked what she did with the 91!
Have you made any further decisions yet as to what model you want to purchase?
I've now purchased an electronics manual for the LS 400. In tracing the ground I believe that the IH1 ground, which is on terminal 14 of the white connector, is common to the things that are going out on me. (See page 15 of the manual diagrams)
I cannot see an obvious break so I am thinking about splicing a wire into the backplane at some other point so the ground comes in from two directions. Anyone ever tried this?
I also found a complaint filed with the NHTSA. For those that are interested here is the pointer: http://www.nhtsa.dot.gov/cars/problems/
Drill down by looking at "consumer complaints" then "vehicles" then choose, in three steps, 1994 Lexus LS 400 and you will see case ODI ID 857012 filed about the instrument lights. Strange but there are no 90-93 LS 400 complaints. I have ordered the file, will investigate and update this forum.
Based on what I have read on the Lexus forums we may be onto a large-scale 1994 LS 400 problem where many people have, and are paying $1100-$1500 to correct a factory defect!
http://cgi.ebay.aol.com/aw-cgi/eBayISAPI.dll?ViewItem&item=1806933594
Can you guys explain how to get to the rear third brake light bulb, needs to be replaced, I'm baffled on how to get to it, have a 95 LS400.
any suggestions guys?
dj
My 94 LS driver seat belt does not retract. Sometimes it retracts after I physically feed it. I heard that Lexus warrants its seat belts for life. Is that true ??? Please assist. Thank you all in advance. PS read every article and love this site.
Mike
Khakis31@hotmail.com
Please note my comments under posting #620
and
As roddmod11 suggested, anyone would like to join the lawsuite, please e-mail (chewang@homemail.com) me with the year and mileage of your LS400. Thanks.
lx400chw count me in! I too would like to join the classic action lawsuite !
I would be interested in your attorney's argument since many other vehicles [Q45,BMW]have similiar problems a function of the technology available at that time.
PS: The government deems 7 years or 100k as the limit for even safety defects!
The Lexus is one of the BEST but things still wear out.
The major problem is the fancy accessories wear out faster [sun roof, power windows, electronic devices].
Except for EGR control system and egr dirt the engine is bullet proof. Same with tranny if you service it CORRECTLY every 30k.
But it will still cost you 7 cents in mainteance and repairs per mile after the warranty expires!
Suggestions, anybody.
dj
dj
it has 180,000kms on it. Took it straight to my mechanic and replaced all filters (yes, the fuel filter SHOULD be replaced just make sure you soak the connections for a number of hours with some kind of high quality penetrating fluid/oil, and we did not have to cut any fuel lines or whatever horror stories I have read about)), flushed all the fluids (let the transmission flush overnight and you will get more trans fluid out of it than you think) got most of the power steering fluid out, and did coolant and brake fluids and changed plugs to Bosch Platinum+4 and fixed an oil pan leak and a very small coolant leak, and fully serviced the brakes, lubricated the sliders and cleaned them.
My 2 cents are the following: if you have not done this and more at least every 50-60k you WILL have an expensive car to own. If you do you will get as I have in the driveway a car with 534,000kms on it as we speak (92 camry LE) . Lastly if you are not running synthetic you are doing your engine a disservice. the stuff works and is worth every single copper. FYI I paid 11,000 canadian Dollars for the car + tax!!! aboout 7000 US. Why would anyone buy any other used car??? These beauties are currently the best value on the used market. SSSSHHHH... Dont tell anyone. Little more fuel and maybe a little more maintenance but look what you GOT boys and gals.
This week she gets tinted, visits the dent man to pop some small dents and the tire shop to fix a slight wobble. Wonder if one of the "gurus' could help. My compressor on AC appears to be puked!! (one of the reasons the car was a little cheaper as I am not afraid of fixing cars)
Can they be rebuilt??? I can get a used one on the net for 200-400 bucks but I rather get rebuilt if possible. I need a solid answer on this before it gets warm.
Best to you and look forward to all your comments.
Claude in Tillsonburg, Ontario
Dbloodhound
You got a good price on the compressor. How do like the "new" compressor and why is "new" in quotation? Is it brand spanking new and who is the manufacturer?
I am looking for an AC compressor and $450 only gets a rebuilt locally.
dj
Have you checked your LS at your local dealer?
I have a 00 Acura RL, and the engine was going dead twice when I was slowing down the speed. I brought the car back to the local dealer, and they claimed that the ECU has known problem, they replaced the ECU under warranty, the car is running fine so far.
Your car might be out of warranty, so fixing it at dealer could be expensive.
In Atlanta the few shops that know how to work on Lexus [properly] are only $15/hr at best lower than dealer and parts cost are the same regardless since they must buy from dealers [with a slight dicount].
Luxury parts are expensive due to import tariffs [to help keep US job].
Be very very careful about non Toyota remans as most are junk and barely last through the 12 month warranty....especially AC components, power steering pumps, and alternators.
Anyway, I had the local Lexus dealer take a look at it. The tech rode with me until I could show him what I was talking about. He indicated this was an inherent problem in the 93-94 LS400s. He also indicated that Lexus called this condition “fishtailing” (I think this is what he called it, I know for sure it had the word “fish” at the beginning of the term), but never came up with a solution. He said what they do in their shop is adjust the TPS to essentially move the problem to where it isn’t as noticeable. He indicated that a new TPS was ~$175, with an hour of labor, but wasn’t sure that would eliminate the problem. He also indicated that the EGR valve could be involved, and suggested cleaning the passageways between the EGR valve and the throttlebody.
Anybody else experienced this problem? If so, have you been able to do anything about it? Comments and suggestions would be greatly appreciated.
