-June 2024 Special Lease Deals-
My 2000 Dodge Durango IS A LEMON!
I changed the oil every 3000-4000 miles and I have the proof of that. The owner's manual says I only have to to change it every 7,000 to stay in warranty. My first checkup was not due until 30K miles, 5K away. THIS IS NOT MY FAULT!! I DID WHAT I WAS REQUIRED TO DO BY CHRYSLER!
So what do I now? How do I fight this? I can not afford (nor should I have) to pay $7K for a new motor. Any suggestions?
Any other way sludge can appear besides not changing the oil? I always used high-quality oil (either QuakerState or Castrol). What could go wrong in the engine that would cause sludge?
Troy
The old Jeep 4L engine is reportedly also set to expire soon, to be replaced by a new design DaimlerChrysler engine (that will likely be cheaper to produce as well).
I firmly believe that all the problems that I have read here and experienced first hand... are direct reflections of were you get service.
I loved my Durango... ride, comfort ruggedness and its ability to get through snow. My biggest complaint was a howling noise the A/C would make after in use 5 or 10 minutes. This did not seem to impact the use of the vehicle (I would, however, compare it to water torcher) it was very annoying. What was most annoying is that after about nine repair attempts at Dodgeworld and numerous calls to the office of the "National Director of Customer Relations" for Daimler Chrysler North America (his initials are R.J.), they still could not put their heads together and fix this... it was after 5 calls to this man's office (explicitly requesting that HE return my calls) only to get return calls from equally inept managers that I got disgusted. Disgusted that the last manager did not even have the courtesy to return my last three voice messages I decided to trade the vehicle.
Since '98 was the first year, I paid a higher price... limited models.... the next year... Sports, 6 cyl and 2WD models reduced the resale value.... I traded a 34k, 2yr old truck w/45000 miles for 17k .... I really took it in the tailpipe buying this Dodge!
I now own a 2001 Chevy Venture LT... not a big mini van fan... I love it. I WILL NOT buy another Daimler Chrysler product again! I also advise anyone who reads this to not purchase one either! Daimler Chrysler DOES NOT care about your satisfaction!
My research has come up with some shocking details. Troy (tallensr), Dan Trickel (trickeld) and anyone else with valid information, please contact my e-mail (Durango318@aol.com). I am gathering names and stories for a legal complaint, litigation and possible CLASS-ACTION LAWSUIT. If you find anyone else who has run into this problem, please get their information and keep in contact.
Pat
Does anyone else have, at freeway speed, extremely loud wind noise? Sounds like it is coming in through the upper part of the door and windshield.
I just had the oil change at the dealer with my 2000 durango, at 3000 miles (their recommendation) and it was free. We always do our own oil changes with high quality filter and oil. Guess we had best keep the same or better records if this turns out to be a problem with others.
I am hoping someone has found a cure for my '99 Durango's front end problem. I only have about 20k miles on the stock tires/rims. The dealership states abnormal wear on the outside of the tire is a normal "characteristic" of the Durango and recommended tire rotation (again) and had me pay $50 for an alignment which did not cure the condition. Rotating tires has only managed to cause the same wear on all four tires. I am sure rotating the tires every other week would make it less noticeable though (until the vehicle is out of warranty). The symptoms are: front tires lock, squeal and even skip as the vehicle is turning either left or right. I've never experienced any of these problems with any of my other vehicles (new or used).
The other problem (which I consider a minor one) is the hatchback lock not securing when the keyless remote is used.
When a vehicle turns the outside tires go through a bigger arc than the inside tires. Therefore, the outside tires need to spin more than the inside tires through the turn. If your 4WD has the 2 front wheels locked together, they can't accomplish this hence the locking and skipping of the tires.
Can you manually disengage the 4WD? If you have the AWD setup you probably can't do this. I would concentrate on having the front drive components checked out based on your description of the ires locking and skipping in turns.
Maybe the keyless remote hatch problem is a solenoid that is staying engaged after it is pressed. You might try it and see if it stays "on". If that's the case, it won't go back to the secure position. Just a guess.
You don't have to have an accident to prove there is a problem. Get rid of it. Check your state's lemon law - check the web for a lemon law lawyer in your area. The brake failure alone is enough to warrant buy back. I am going through my own battle with Infiniti on same issue.
Good luck
Does anyone know about the rattles and squeaks with the 2000 and are they present in the 99's as well? I have a very annoying squeak coming from somewhere in the front end and a distinct rattle coming from the rear-end especially when driving down hill over subtle bumps. Does anyone know how this can be fixed? I have taken it to two different dealers and they can't seem to figure it out.
Sorry everyone this is a long one. Two other things.
I had the back door lock problem and took it to the dealer. They fixed it no problem.
After running my Durango for approx 2 hours or so with the a/c on, on a couple of different occasions last summer it spilled out anti-freeze after parking the car. I was not towing nor was it extremely hot out. Any ideas/common stories?
Is it the 4.7l that has had the problems with seizing up at 25k miles (I need help with my metric conversions)?
However, (there's always an "however" isn't there) I have a problem with the air conditioner. When on the highway, the fan cuts out while going uphill. (I have the 5.9 liter engine, so there shouldn't be a problem) Also, the A/C can't keep up with 90+ degree weather. The dealer has looked at it several times and insists that it is operating normally. "Plenty cold when we checked it". Of course that was during 70 degree weather. The Service Manager told me that the fan will cut out when the engine is under load. Maybe so, but why does it blow hot air when I go uphill? Anybody?
Anyone else having these symptons?
Several of the Road Tests have mentioned it. I don't think there'll be much done to remedy that problem.If you think that's noisy...try having you front windows rolled up and your back windows rolled down about 5 inches.
Something I've learned for the future. When I called the Chrysler dealership ,w/ the Quaker State Quick Oil change bay, for a printout of receipts...they had it on the computer that I had taken my truck in for oil changes for the 2 consecutive months after I bought my truck (not including the 1'st free one I had done at the Dodge dealership. Meaning I had 3 oil changes within the first 3 months. At one instance, (2) oil changes 12 days apart. They claim that a computer reads your license plate when the vehicle is driven into the "bay". Check your receipt for correctness on the day you have the oil changed....so even if you misplace it....at least you'll know that you will get a correct breakdown from the computer.
The bitterness and frustration people experience with their dealerships will hopefully get better as Businesses start to realize that focusing on customer service and support are a great way to generate repeat and referral business.. If the dealership would have stepped up and assumed responsibility for these recurring issues maybe some the posts would be on a more positive note..
Everybody have a great 2001 and keep on posting!
I suggest phoning Chrysler and putting in a complaint. Then make the request for the Chrysler field rep to review your problem. If you can convince them, they can make the dealer do something. Good luck.
Add me to your list. 98 Durango, 65,000 miles. Driving back to Charleston, SC from Atlanta on Saturday morning, New Years Eve weekend. 20 miles out of Atlanta my "check gauge" light came on and then suddenly off. This happened several times within the next few minutes. When the light came on I noticed that the oil pressure gauge would go down and then just as suddenly back up and light would go off. I felt confident my oil was fine since it had been changed recently and I had checked it that morning before beginning my trip.
However, I quickly used my cell phone to call my local dealer. The response was that it could be a faulty gauge and that if I was not hearing any engine noise I was probably Ok. He added that they would be open the Tuesday after new years and that I should bring it in then (if I was lucky enough to make it back).
Less than a minute after hanging up the phone I heard some pinging. Believe it or not as I was approaching the next exit to get off of I-20 out of Atlanta I saw a Dodge dealer. As I was exiting and reducing speed the noise became louder and louder. I pulled into the dealers service lot 10 minutes before they closed. Bad news, he immediately said I probably would need a new engine. Good news, they had one rental so I could get my family home. Bad news, with the rebuilt engine and rental car (for almost a month), it set me back $6,800.
I have had many vehicles, and most of them I have put a lot of mileage on. I had them serviced and I have never had this kind of a major problem. I felt a bit held hostage since I was out of town and out of warranty. I just thought my luck had run out, and it was my turn to pay out. However, after doing some research and reading I think there may be more to this.
A business associate that had been in the auto parts manufacturing business told me to find out who the regional Dodge factory rep is and contact him/her. The point being is that most people (including me) do not have $5,000. to $7,000. sitting around to fix a vehicle that failed way before its time. So if hell is raised with the right people, many times they might meet you half way on the cost. Don't know if it will work but my fight begins tomorrow.
Any other suggestions would be helpful.
P.S.and FYI Before returning the rental car I had it washed in and out. In return, after spending $6,800 at the dealer I received my red Durango back with a months worth of dust and dirt on it. Now that is customer service.
i think the common denominator with sludge, at least from Dodge's viewpoint, is that sludge is caused from neglect. I ask these questions to see if they right?
Unfortunately, I think that when 1000s of individual cars are put out some are bound to have problems, my sympathy to those of you that had problems.
I personally have owned foreign and domestic and have never had one that did not need some sort of repair. Many of the beloved "foreign" cars are actually made here as well, check out the Edmunds Honda info, your precious Accord is made in Ohio.
I looked around compared and settled on another Durango. I wanted the 3rd seat option and didn't want to go to a full size suv. So far we are very happy with 2001, plus I also bought an extended warranty for this one too for 5/100000 mi. and 0 deductable if you bring back to the selling dealer
and if taken to a differant dealer, it would be a $50 deductable. My 98 was a 4wd, Slt Plus, my 01 has basically everything except the R/T package & the 5.9. Wish you all the best of luck with your durangos.
Unfortunately, my "D" has had many, many problems. Engine kept overheating and on the 4th visit to the dealer; had the head, cylinder and gasket replaced from an internal leak, also has spark plugs rewired, power window motor replaced, fog lamp replaced d/t moisture inside the lens, and annoying and continuing rattle in the upper right corner of the dashboard, she shifts hard, runs high rpms and has loose seats. But I was a die heart for my "D". Well, now i'm scared....big time of her! Don't know what happened to the steering as to why she wouldn't turn so I am asking the Durango owners today for help. And I hope to God this does not happen to someone else. One thing more to add is that I have been having trouble with the steering since last march. When I first start her up in the morning or after she sits for a few hours the steering is "hard" to turn...kinda have to force it (feels like manual steering instead of power steering) and it will turn but with alot of effort on my part. After a few miles she steers just fine. Noticed it getting worse lately and taking longer to "warm" up. Took her into the dealer back in March last yr and they were unable to "duplicate the problem". I have continued complaining about the steering and the "rattle" but they can't seem to find anything wrong. The steering does not do this in warm weather and also is unpredictable when it does descide to go stiff".
I have had more things go wrong with my durango its unbeliveable. I know the repair guys by their first name. I did attempt to "lemon" my Durnago, but lost is arbitration last august. My problem then was, she kept overheating. On the 4th visit to the dealer on that problem, she was fixed! Major engine repair....and i payed how much for this durango??? I service my durango every 3000 miles and i have the 75,000 mile extended warrenty...one postive note! My durango sure has been in the repair shop more than the average. Have to admit that the service department has been very kind and patient with me, but i think things are about to change now that i could have been killed with this last complaint.
Anyone out there have problems with their steering?????
I'll let you know what Dodge says.
