Longest Lasting Car On The Road
carlvr1carlvr1 Member Posts: 4
edited March 2014 in Ford
I thought I would start this topic title for us to
discuss what is the longest lasting car on the
road (with the original engine and transmission) in
terms of miles. I think this is the ultimate
tribute to an automakers success and commitment.
Too often it is just brushed off to Hondas and
Toyotas but are they really what they are made out
to be? Perhaps, but can they or others not only
exceed 150k or 200k but 300k miles? The longest
lasting car I've had was a 1987 Ford Escort with
167,000 miles on it when the water-pump seized and
the timing belt snapped. It was running quite well
up to then but the body was gone so I did not fix
it. Perhaps I could have passed 200k but I don't
know. My dad's 1993 Ford Escort just passed
140,000 and he has vowed to keep it forever so I
guess I'll see if maybe his will pass the 200k+
mark....
«134
  • amoraamora Member Posts: 204
    Pop's '74 Chevy Cheyenne pick-up. Went 377,000 mi before engine replacement with newer '77 Z28 engine. Still owns vehicle. '77 engine was bored
    .030 6 mos ago. All new parts..i should be so
    lucky with my '00 Chevy 2500.
  • mike350mike350 Member Posts: 9
    Bought new in 1976 an Olds Cutlass Supreme 350 V8 with the 4 barell carb. Drove it 17.5 years and 238,000 miles before got rid of it. The motor needed no work and the transmission had new seals at about 100,000 miles. The two universal joints in the drive shaft lasted - 150,000 miles for one and the other 225,000 miles. (and at $19.95 each plus labour it was deal)Rust problem at 5 - 8 years solved with a complete body job and Rust Check application in Canada. great car!
  • rea98drea98d Member Posts: 982
    I've got a 95 t-bird that's just a hair over 163,000 (A LOT of miles for a car that new). I'm aiming for 300,000 out of that car.
    My last car died at 122,000, but it was 22 years old. (1978 Grand Marquis with 400M engine and FMX trans) The engine still runs, but barely, but the transmission is as dead as Elvis. I still have that car, looking to do some major ressurection work on it after college. Maybe eventually it'll get to 300K ;-) (though not w/the original trans.)
  • johnlwjohnlw Member Posts: 28
    My Brother in Law has a 1986 Chevette with about 160,000 hard miles on it. He does the maintenance himself. It is the ugliest car I have ever seen. He deserves this award because one Chevette mile equals 7 normal car miles.
    I asked him why? They are quite wealthy. He says, "Anyone can get 150,000 miles on a Taurus, but a Chevette?"
    He has had, in the past, a twenty five year old Corvair that had the floor literally rot away, and a CHEVETTE DEISEL(!) that he also got many, many miles on it. I would like to add he drives slower than molasses in January.
  • andre1969andre1969 Member Posts: 26,172
    I bought my '68 Dart in 1992 with about 253,000 miles on it. It currently has about 338,000 on it. The engine runs fine (it was rebuilt at around 240,000) but the car has a lot of body problems. Typical Mopar rust in the rear quarter panels, and leaks around the front and rear windows. It was also hit twice on the front right fender (once by new Dodge Ram, and once by a new Toyota Tacoma... they both lost...miserably!) Someone also pulled a hit-and-run on the driver's side fender and door in a parking lot, and someone else backed into it on the street, hard enough to push the fender into the door so that you get a nice loud groan when you try to open that door! Still, it runs good and strong, and only needs ball joints (currently on order) to get it roadworthy again.
    My next high-miler was a 1979 Newport that I bought from the junkyard in 1996 for $250. I thought it only had 130K miles on it, but when I received the old title, it stated the previous owner bought it in 1986 with 105K miles on it. So I'm guessing it was more like 230K. It needed a new tranny, but after that lasted to about 250K miles, and I finally got rid of it after the water pump went and I wanted something newer. I remember the speedometer was off by a wide margin. I got clocked once doing 88 mph, but the speedometer only read 73! This car had no problem burying the speedometer needle and then some. By the margin it was off, 85 mph was actually 102. And, for having as many miles as it did, it had no problem passing the emissions test. In fact, the numbers were so low that it would've almost passed by current (1997) standards! Say what you want about 70's cars, but if your typical modern American car was built as sturdy as this Newport, you'd be hearing about the Asians struggling to catch up to us in quality, instead of the other way around!
    Currently, I drive a 2000 Intrepid that already has 30K miles on it. At the rate I'm driving, it'll be a high mileage car in no time!
    -Andre
  • tjaliziotjalizio Member Posts: 1
    I'd like to see statistics on the number of specific makes and models with high mileage. A cousin of mine had a Toyota pickup truck with over 300,000 miles and had the engine rebuilt at that point. It had about 335K before he sold it and it's still on the road. He had very few problems. My 1990 Toyota Camry V6 had 180,000 miles on it when it was wrecked - my daughter did the honors - but it did not burn oil between changes to speak of. I had virtually no problems with it in all those years except the A/C compressor last summer.
    My wife had a 1988 Taurus we bought off a friend with 100K miles a several years ago and we gave it to my son with 195K this summer. It used a quart of oil at oil changes - 4K miles. It always started and ran well, but the previous owner had the transmission fixed at 60k and I had some electrical problems that were a nuisance, replaced the alternator and had the heater core replaced 3 years ago. The last straw was that the A/C went and we did not want to put the money into it. That car should go well over 200K.
    My daughter, the one who did the Camry in, has a 1986 Camry with 240K miles on it. She's had it almost since new. All she ever did was have the clutch replaced at 225K miles - last year. It burns oil but that's because she never took care of it until recently. She's now feeling the challenge to see how long it will go before it dies. Also, she's married and does not want a car payment. The car keeps on going despite her lack of care.
    We favor Toyotas. My wife and I have a 2000 Sienna we use for our business, and a low mileage 1996 Avalon we got to replace the 1990 Camry. We also got an excellent deal on a low mileage 1993 Sable wagon to replace the Taurus wagon. I expect to get well over 200K trouble-free miles on each of these vehicles, especially the Toyotas.
    You hear of some old American cars with unbelievable miles on them but they are rare. I expect that you'll find more and more newer high mileage cars (American and foreign)on the road today than ever before. They are generally made better, in my estimation, and the lubricants and filters are outstanding. Paint jobs are much better (remember the horrible GM cars of yesteryear?), rust protection is superior to anything before and there are many more maintenance-free items on a car - 100K mile plugs, electronic ignition, no mechanically connected distributor, etc.
    Happy driving.
  • newc230newc230 Member Posts: 7
    I have 87 camry with 220,000 miles and going strong. Minimum maintenance done at home. My daughter wrecked, repaired and works okay.
  • kareskikareski Member Posts: 5
    We have a 93 Toyota Corolla five speed. I have done most of the maint. myself. Changed oil every 5K (commuter car) tune ups and belt change. Car runs like a bat out of hell with no oil burning and still gets 35/42 MPG with 205,000 on it. Putting a can of restore in the crankcase every other oil change has helped over 200%. Clutch is factory.
  • retrevretrev Member Posts: 1
    Have a '92 Sable wagon; purchased as program car from dealer in '92 with 18,000 mi. Still own it. Now 229,000 mi. Burns no oil; nothing major in repairs except AC three times - different component each time. After last AC breakdown (compressor), said, "phooey"! Driving it without AC. Wife says I should sell it before major repairs. Any advice? retrev
  • patpat Member Posts: 10,421
    Welcome to Town Hall!
    There are a couple other discussions here that may have some help for
    you. Check out the "Board Search" at the top left of this page. Look
    for sable problems and also airconditioning (no space for that last
    one!) and you'll find at least two discussions here on the Maintenance
    and Repair Board that may have some helpful comments.
    Good luck and again, welcome!
    Pat/Roving Host.
  • siepelsiepel Member Posts: 2
    My '92 Previa has 240,000 on it and is still going strong. Routine maintenance and a quart of Marvel Mystery oil every oil change forever. Only repairs have been a new starter and an oxygen sensor. It uses no oil and runs like a champ. My 'oo Sienna (32,000 mi.)is in the shop right now -- it started missing and check engine light came on. They found and replaced 2 injectors, I drove it 10 miles and the check engine light came back on so took it back in.
  • breaksrbreaksr Member Posts: 9
    I have to give the award to a friend of mine that has a '95 Toyota Corolla with 148,000. The car had it's first brake job at 130,000 and is still on the original timing belt. Never had engine or transmission work done on it except the usual fluid changes and tune-ups. It's killing me since I have a Q45 that goes through a set of belts and brake pads every 40K.
  • ccotenjccotenj Member Posts: 610
    yea, but...
    would you rather be driving the corolla or the Q?
    -Chris
  • carnut2002carnut2002 Member Posts: 1
    My uncle has a Volvo Wagon Turbo that has over 270K on the clock. All he's really done was to replace the turbo. It uses a quart of oil every tank of gas. Most of that is going through the trubo seals and into the intake. not by the rings. Time for another new turbo.
    My personal Honda CRX has 180K on the body. the timing belt let go at 120K and I put a junkyard engine in but still have the old block and it would run if the head were rebuilt. the pistons are fine. maybe someday...
  • talk2splattalk2splat Member Posts: 2
    I have a beautiful (blue) '86 245 that has just a hair over 250,000. The car has had no big repairs besides normal maintenance. It was first a family car (read: trips to Cali, dogs, car seats), the interior still looks almost new, and now it's a teenager's car, (read: lead foot, hard turns, some light rallying on the wkends). The car has nary a scratch (strong strong paint), the engine burns no oil, and leaks no oil. It's safe as a tank, can haul half an Ikea store, and IMHO looks pretty slick (tinted rear windows, alloy wheels, perfomance Yokohamas). We also have a '92 940 Turbo that's approaching 90,000...when it's wet that thing will spin it's rear tires up to 70mph, even with a rolling start at 30. VOLVOS FOREVER!
  • rwardlerwardle Member Posts: 2
    Purchased an '87 Topaz GS Sport 2.3L w/ ATX 3 spd.Automatic new. Put 220,000 miles on it before I sold it in '96. It is still being driven on the original engine and trans. Neither the engine nor trans has been rebuilt. It was a good car for the price, I replaced tie rod ends about every 70K a fuel pump at 130K and an ignition control module, both half shafts and a tansmission mount at about 150K, other than that, no unshceduled maint that I can recall. At the time I sold it, it did not use any oil, but the a/c had a slow leak.
    My stepdad had one of these, purchased brand new. I think it had about 160,000 miles on it when they traded it on a '91 Stanza. It was still running on the original engine/tranny, but I know they'd had to put a lot of other work into it.
    I believe the 2.3 4-cyl they used in the Tempo/Topaz was basically just a Falcon inline 6 with 2 cylinders sawed off, so the basic engine dated back to around 1960 or so...plenty of time to get it right!
    I used to hate that car with a passion, mainly because it was a Ford and I thought it was ugly and small, plus it was my stepdad's, and I came from a mostly GM family...but I have to admit, it held its own over the years. BTW, the Stanza only lasted to 120K miles, and needs a new transmission and enough other work done to it to exceed its highest blue-book value.
    -Andre
  • mattjettavr6mattjettavr6 Member Posts: 7
    216,000 when I sold it for $1000! No major engine or drivetrain defects. Put a clutch in it and a slave cylinder for the tranny (hydraulic clutch) at 145K. It did need 3 batteries, a starter, and an alternator but that aint bad for that kinda mileage. Other than that....gas, tires and oil. I went to hell and back in that UNBELIEVABLE PICK UP! Long live Nissan! (I still love German for passenger cars though:)
  • leslieldfleslieldf Member Posts: 32
    You might check if it's the torque converter - some cars made in July and Aug. (including mine) got a bad one that causes the check engine light to go on. Toyota will replace, and everything's fine now. The diagnostic sends back an error code (P007 I think) indicating some other minor problem - there's a Toyota Service Bulletin with all the info. If you get that error code, you might just make sure the service dept. is aware of the TSB. Good luck!
    Hey gang,
    I remember reading somewhere, awhile back, that a Canadian cabbie with a '62 Fury (forget what engine, but it was one of those "downsized" ones for 1962 that didn't sell too well) set the record for highest mileage on an original engine.
    The guy was in an accident which totaled the car. And he didn't even think anything of the mileage at the time, but when converting kilometers to miles, it was discovered that this thing had broken some kind of record. Anybody know anything about it? I heard about it over a year ago, but can't find any info now.
    -Andre
    I found this little gem in the Guinness World Record website:
    Highest car mileage
    Who: Irvin Gordon
    When: 1999
    Where: East Patchogue, United States
    What: 1,690,000 miles
    The highest recorded mileage for a car is 2,719,800 km. (1,690,000 miles), for a 1966 Volvo P-1800S, owned by Irvin Gordon of New York, USA, as of February, 1999.
    Irvin Gordon bought his red Volvo P–1800S for $4,150 from a Volvoville dealership in New York, USA, one Friday in 1966. The following Monday, he was back for a 1,600-km. (1,000-mile) service! When he reached the 2.6-million km. (1.6-million mile) mark in 1998, he said the Volvo “still handles like a new car. It's never been garaged.” The retired teacher – who used to make a daily 201-km. (124-mile) round trip to work – does his own car maintenance. While clocking up his record-breaking mileage, Gordon traveled through 48 US states, Canada, and five European countries. The P-1800S, a two-seater touring car with a sweeping hood, went into production in May, 1961, and was made until June, 1973. The car was made famous by the TV series The Saint, in which one was driven by Roger Moore.
    Guinness World Records are governed by certain rules and regulations. There are general rules and regulations that apply to most records and specific conditions that apply to particular records.
  • mhall02mhall02 Member Posts: 38
    I have a 1978 Ford F-100 with a 300 c.. (4.9 I) incline six with 201,000 and still going strong. My Dad ordered it from Ford in the Spring of '78 and I took it over my Junior year of high school (Dec. of '86) with about 50,000 miles on it. Drove it to and from college and still drive it to and from work each day. It has been a pretty good truck all in all. Factory parts are great, it still has the original alternator, liters were replaced not long after I took it over and that is about it for the engine work. Uses some oil but I use 20W50 in summer and 10w30 in winter (maybe a quart every 1,000 miles?). My wife had a '91 Dodge Shadow with a 2.2 and 5 speed. We put 183,000 miles on it, used no oil just dripped some, then sold it to and bought a 00 Jeep Cherokee Sport. The Shadow is still going with over 190,000 miles. Changed the oil every 3,000 miles on both and kept on top of other maintnece issues (plugs, filters, cap, rater (ps?), check all fluids, grease etc). I hope the 4.0 liter Jeep will hang tough as it is supposed to.
  • eharri3eharri3 Member Posts: 640
    My grandfather, a carpenter by trade but also a skilled mechanic and electrician, pushed an 86 Accord to 250,000 miles with normal maintenance before it finally began to gasp its last breaths. His '89 Toyota work truck still runs like a champ at over 100,000 miles and will soon be traded in on a nissan frontier. One thing about early Toyota trucks... the engine feels like it might run forever, but the body started rusting out years ago. Holes in the bed I can fit my fist through.
  • merlebertmerlebert Member Posts: 3
    I'm the original owner of a '88 Accord LX, bought in January '88. Driven essentially daily since then; currently at 274,000 and still running well with original engine and trans (other than the carb is unhappy first thing in the morning when it's cold). Uses less than a quart of oil in 5,000 miles, and much of that seeps past a seal that's begun to leak a little in the past year. Dealer maintained every 30K; I do oil changes every 3 - 5K. Great gas mileage, handles beautifully, upholstery not showing any wear, cheap to license and insure. Unfortunately, I will probably sell it when our new Odyssey arrives-- if it ever does. It's in No. California; if you're interested, make me an offer by e-mailing .
  • leomortleomort Member Posts: 453
    which has 151,000+ miles on it and it still runs great. This was my first Toyota (first foreign car). It still runs great with original engine and trans--although new clutch. I'm getting nervous about it's high mileage and was thinking about getting a new car. Hmm, might have to rethink this! If Toyota's last as long as it's reputation, perhaps I can wait? I'll see how it does come inspection/emission time in May. I put on 25,000 miles a year so it will be fast approaching 200,000 miles very quickly.
    Leo
  • justinjustin Member Posts: 1,918
    no one has mentioned an old VW Beetle or Toyota Tercel.
  • dogbiscuit8888dogbiscuit8888 Member Posts: 3
    I put 300,000 on a 89 5th Avenue. Had a lean burn 318 with a 2 barrel carb. Only replaced voltage regulator,water pump,smog pump, radiator,u-joints
    and brakes.
  • joecugjoecug Member Posts: 15
    I perform emissions tests on cars at a
    central test station so I see numerous
    high mileage cars coming in for tests.
    Without a doubt the Volvos have the best
    track record for high mileage vehicles.
    I see many Volvos with 250-300K miles
    that pass the tests no problem. I sure
    this is due in part to the good care their owners give them. Surprisingly,
    one of the best cars are GM cars (mostly
    Buick and Pontiac) with a 3.8 liter V6
    engine. This engine has been around for
    decades and most of them still seem to
    run well. And you can get them used cheap!
  • odd1odd1 Member Posts: 227
    I bought in in 88 with 60,000 something miles,all original, for $1,000 and sold in 97 for $1,000 with 287000 miles on it. the only repair was a rebuildt starter at 159000. Otherwise just oil changes and tires/brake pads. It was the go cart of pick ups. I can't begin to remember the number of oil change jockeys that offered to buy it and extolled the virtues of the Toyota 20R engine.
  • lumbeelumbee Member Posts: 2
    I BOUGHT A 79 MUSTANG NEW. I DROVE IT HARD AND TO EVERY STATE AT LEAST TWICE. TEN YEARS LATER WITH 278000 ON IT I SOLD IT FOR $200. AFTER 50K I ONLY CHANGED THE OIL EVERY 20K MILES. I THINK THE SLUDGE KEPT IT FROM LEAKING. THE 302 WAS A GREAT MOTOR. IF YOUR QUIRIOUS AS TO WHY I SOLD IT, THE NOW EX WIFE HATED THE CAR. 16 CARS LATER I WISH I STILL HAD IT.
    I sold my '82 Tercel 4 door with 112,000 miles for $850 in May '99 when we moved and consolidated to one car. It cost me .18 a mile to purchase, insurance and operate it those 17 years, and I bet it's still cruising the streets of Anchorage. Very dependable, and little rust over the years even though it spent its entire life on salted roads.
    Steve
    SUV and Vans Message Boards
  • marrilionmarrilion Member Posts: 1
    Anyone having / or had problems with oil leaks? Are you happy with the car in general? Looking for any valuable feedback on the car please.
    Also if anyone can recommend a decent mechanic in the Boston, MA area who knows these cars that would be great.
    I'm trying to keep track of this on my Intrepid, but one day, just for kicks, I went back and tried to add up everything I ever put into my '68 Dart, which lasted me well for 85,000 miles, and is still running strong.
    Well, the Dart over the course of those 85,000 miles, cost me about .11 a mile. That doesn't include insurance, which has ranged from over $700 a year when I was younger, to $258 a year now, as part of a multi-car policy. Also doesn't include gasoline, which, considering its 318 got anywhere from 12 to 17.8 mpg, really hurts. I didn't keep good track of fuel costs. Still, averaging $400 a year for ins and .10 a mile, it comes out to about .24 a mile. And that's assuming I gave it away and got nothing for it.
    The Intrepid, on the other hand, has gone about 39,500 miles in 15 months. Insurance is about $560 a year, and gas runs about .065 a mile. Couting the down payment, monthly payments so far, and miscellaneous stuff, I figure this car comes ou to .19 a mile, and about .27 a mile with gas/ins added.
    It'll be interesting to see how this car ends up comparing to the Dart over the long run. In all fairness, the Dart would cost more like .11 or .12 a mile in gas now, the way fuel prices have gone up.
    Anyway, Steve, congrats on that .18 a mile to own and operate over 17 years. Sounds like that Tercel was a good little car!
    -Andre
    Was an 82 two door, that typical early 80's electric blue color that Toyo seemed to favor. It had about 158k miles on it when I gave it away in 93. I bought it used in 91 from a lady who had it since brand new. It needed a water pump and an alternator. When I gave it away the clutch was GONE. Would not go up the hill in the driveway - it would roll backwards. Was like the car was in neutral. It burned oil - not bad considering I was 17 - don't think I ever changed the oil and drove from DC to Richmond literally EVERYDAY for a year... Fun little car! The A/C worked the entire time as well....
    It's best not to get me started on this subject, Andre, or I'll start posting my spreadsheets. The '99 Quest (through 12/30/00) is running .31 a mile (depreciation plus operating expenses less est. trade), which is less (so far) than my '89 Voyager got lifetime. Gee, I'm past due for my monthly update:-)
    Steve
    Forgot to enter The December and January payments on the Intrepid, so it's really more like .21 a mile, + ins/fuel ;-) I haven't figured in depreciation yet, just what I've actually spent on the car (down payment + monthly payments + repairs/maint).
    In theory, if my Intrepid can go 210,000 miles without ANYTHING breaking or needing maintenance, it'll come out to about the same .11 a mile the Dart did. Considering things like brakes, tires, tuneups, tranny services, it'll take a lot longer. Throw in a transmission failure there goes any hope at all of EVER reaching .11 a mile!
    -Andre
    PS: Pat, you should see the spreadsheet on the Dart's repairs over the 85K miles I've had it! It's lengthy, but at least most of the repairs were cheap! I just wish I'd kept better records...I've been trying to recall most of it from memory, and then just estimating high to cover for anything I may have forgotten.
    Well, now that I think of it, I didn't have a column in my Tercel spreadsheet for the ratty seats, the one passenger door with the busted hinge (permanently locked at ~90k), the busted trunk hinge (1x1 stick made a good prop), the tape deck that ate tapes, the volcanic ash "polished" windshield....
    But it was a great car:-)
    Steve
  • tacomawheelstacomawheels Member Posts: 6
    My friend just traded in his volvo for about $300. Still running fine with a rough idle that he couldn't clean up. It had 260k on the clock, but his mechanic said that he thinks it had more because something he noticed when working on the odometer.
  • jwootangjwootang Member Posts: 2
    Merlebert,
    I used to have an 87 Honda Accord DX with the same carb problem. It costed me about $5 to fix it. The problem is so common that when I simply mentioned it to a Honda service manager he said, "Yeah that is the choke diaphragm." I bought a new diaphragm from Advance auto for under $5 and fixed it myself. You can buy the whole assembly from Honda for about $50.00 or just buy the rubber diaphram, take the part off of the carb. and replace the diaphragm on the inside. Mine had about 170,000 miles when I noticed it. After taking the old one out you could tell it was worn out with a small pinhole in it. Hope this helps.
    Door permanently locked on the Trecel? Did you have to get in & out Dukes of Hazzard style?
    I owned a 1967 Chrysler Newport for a brief period of time, a 2-door hardtop with the passenger-side door sealed shut. I didn't keep it long enough to find out what was wrong with it. I had friends doing the Dukes of Hazzard entry all the time. Always wondered how they did it on tv though...watching someone climb through a car window in real life is anything BUT graceful!
    I know a guy with an '88-92 generation Corolla. If you roll the front passenger window down far enough, it will make the door pop open!
    -Andre
  • dc_sports_ruledc_sports_rule Member Posts: 134
    My friend has over 300,000 miles on his 1994 Honda Accord LX I-4 automatic sedan which he uses for business purposes. He drives up and down the eastern seaboard to various cities East of the Mississippi River. At 270,000 miles he blew his balancer shaft seal which cost him over $700.00 to replace along with the timing belt and other components. He was later notified that Honda had a directive on placing a clip on the seal. Honda sent him a check for the blown seal after he submitted the necessary paperwork. He firmly believes the best tires you can buy for a card are the Michelin X-Ones with the 100,000K wear warranty. He is still driving the car daily and loves the car's reliability. He did have to replace the exhaust once, and his brakes once. He changes his oil just about once a month due to the highway miles he drives and maintains that it is the secret in driving Hondas for many miles.
  • shehzadshehzad Member Posts: 52
    I have a 1985 mercedes 300D with 330,000 miles on it. I had to change the transmission at 70,000 miles, and the AC compressor changed at twice-but beyond that, it's never given me a problem. I will keep this car forever, as it's not only been reliable, but was my first mercedes and I'm very emotionally attached. I also had a 1991 BMW 525i that got up to 205,000 miles b/f I decided to sell it in 1999-it needed transmission work at about 90,000 miles, but beyond that, never gave me a lick of trouble. At first I was going to trade it in for the Jaguar I wanted to replace it with, but the dealers were only offering me $200-$500 dollars for the trade. At the advice of one of the Jag salesmen, I went home and ended up selling it on Ebay for $8500.00, which is more money than I could ever have dreamed of for it. I replaced it with a 1999 Jaguar XJ8, which has 60,000 miles on it now, and I'm praying that I can get another 200000 miles on it.
  • westopemshopwestopemshop Member Posts: 6
    Is my 1986 Chevy Sprint (made by Suzuki) has 218,000. Still driven daily, had to replace clutch at 165,000 and installed rebuilt head at 198,000. The a/c works great, however I do turn it off while starting off from stop signs and traffic lights(to much pull on the 3 cylinder)! Still has plenty of pep, with a/c off.
  • curtis234curtis234 Member Posts: 1
    Bought for $ 1000 for a commuter had 100,000 miles on it,now has 185,000 and still going stong and drives great. Have replaced the timing belt and clutch. Shooting for 250,000 miles.
  • ddair1ddair1 Member Posts: 1
    I bought a 1990 Volvo 240 automatic new and drove it 9 years, 285,000 miles, then sold it to a friend. The car now has 325,000 miles on it and, with the exception of an oil seal replacement, has never had a drive train problem. I paid $17,500 for the car and sold it for $2500. I had the oil changed every 5000 miles and had most of the maintenance done per Volvo's recommendation. Not counting insurance the car cost me about .14 mile. I'm now looking for a 940 wagon with low mileage.
  • chevytruck_fanchevytruck_fan Member Posts: 432
    I know a lot of people that have had good experience with GM trucks,
    mine is a 1981 C10, original tranny went out at 330,000 original engine at 250,000 or so. The truck has about 333,000 on it now. Daily driver, about 16,000 miles a year.
    MY uncle (who has asphalt business as well as ranch) had an 82 K20 with the diesel in it, had to replace head gasket at 40,000 but then the engine went to 400,000 , dont' know about the tranny it was a manual.
    Another uncle has a 75 GMC with 186,000 on it, no rebuild 350V8/muncie 4speed....he never changes the oil either, but it is starting to have carburator trouble
    Friends dad had an 79' Chevy 1/2 ton, went 276,000 before rebuild.
    Some people may not like fit and finish of American vehicles, or that they squek to much but there powertrains are rock solid.
  • xcarnutxcarnut Member Posts: 81
    I was the second owner of my '82 Supra. Bought it with 75K on the clock. I sold it to my cousin at 155K and he has since, put on another 20K. I replaced the timing belt at 120K and always took it to dealer for 3k oil changes. Had A/C seals replaced twice and starter and alternater once.
    No other repairs. Never got stranded and always started on the first crank. This one has the best drivers seats EVER.
    I had '78 Corolla with 135K before insurance totalled it when a rogue Chevy Blazer turned left in front of me.
    My '86 Legend has 150k on it and runs good, but has some things not working. Rt rear door windows come down from drivers side but can't go up, have to do it from the rt door. Same with rt front except its the opposite from drivers side goes up and down but not from door.
    Other than that the car looks new with no major problems.
  • andy2470andy2470 Member Posts: 9
    We have a 1988 Integra in our family that we bought in 1994 with 64,000 miles and paid $7,500 for it. Now seven years later this car has 184,000 miles on the odometer and we have never had any regrets about buying the car. The car has been in three accidents. It was hit by a 300ZX in the front, was rear ended by a Ford van and was hit again in the front by a Cadillac and this car held up well every time. The A/C died three years ago and is a $500 fix that we did not opt for. This was a hard thing to do since we live in Florida. We do however seem to have a lot of problems with mufflers on this car. They just do not last. Other than a couple of batteries and alternators this has been an excellent car. By the way the timing belt has been changed twice. I would highly recommend this car or any other Honda product if you want a car that will go the distance and not leave you on the side of the road.
  • old_guy_in_txold_guy_in_tx Member Posts: 12
    although not as much as some cars my 1994 caravan has 220k miles and is still running strong. strange for a dodge, huh??? they must have messed up at the factory.,....
