Honda Civic
1456810
  • igloomasterigloomaster Member Posts: 249
    thanks only1harry, carlady, and amandac! this website is soooo coool! i appreciate this: we are all in the same boat, so we try to help each other get the best deal. knowledge IS power!
    Hi all
    My 1990 Civic had levers on each rear side window that would prop and lock them open.
    Do the new Civics have the same levers? When I logged onto the Honda website, and took a look at the inside of the vehicle from the "visuals" section, I did not notice those levers. Did I miss them, or do they still come equiped with levers to open the rear side windows?
  • only1harryonly1harry Member Posts: 1,140
    I don't think you can open the rear windows in the new Civic Hatchbacks. The coupes you might be able to, and surely the Sedans. Although I 've only looked back there once or twice, I 'm pretty sure my '97 Hthbk doesn't have them. The car is out in the parking lot and it's raining out, so if I 'm wrong I 'll let you know later.
    What kind of Civic are you talking about? 2 door coupe or 3-door (htbk)??
    '99 Integra GSR
    '06 Civic LX coupe
    '11 BMW 335i coupe xDrive
    '13 Honda Accord sedan (wife's car)
  • lwilmeslwilmes Member Posts: 1
    My wife drives a 96 Honda Civic EX coupe and it doesn't have the side window (rear passenger) feature that you desire...it would be nice however!
    Sorry, I was asking about the HATCHBACK. My Hatchback had the levers on both passenger side windows, so you could pop them open and get a nice cross-wind from the front side windows thru to the back. Does anyone know for sure whether the new hatchbacks have openable rear side windows?
    It is recommended by all of the Oil Changing companies out there that oil is to be changed every 3,000 miles. I've been doing it myself every 2,000 to 2,500, to insure that the Oil is always clean, and to prevent the engine from burning Oil prematurely. Does anyone else do this? Does anyone see any potential problem with changing the Oil earlier than the recommended intervals?
  • mznmzn Member Posts: 727
    igloomaster, I'm sure you'll get some help here from our knowledgeable Civic crowd. You may also want to use our Topic Search on the Left side tool bar to see if there is a similar discussion in the Maintenance Conference.
    carlady/host
    Nope, just checked.
    My '97 hthbk doesn't have those levers. It would be a nice feature though. Don't know why the early Civics had them and not the new generation.
    Probably because people got hurt with them in small accidents? Who knows? Maybe they 're saving money...
    '99 Integra GSR
    '06 Civic LX coupe
  • quelaquela Member Posts: 1
    Well, I am planning on buying a 99 civic, but I was wondering if the 2000 models will be redesigned or if they will look the same, and if anyone has any idea how much invoice is. Thanks.
    My Honda is great
    How great the Honda Civic
    It runs forever
    I didn't notice in the literature from Honda whether or not there existed a cigarette lighter or some other 12volt power supply - so I can plug my radar detector in. Does anyone know for sure whether the 1999 hatchbacks have cigarette lighters?
    and one more thing......
    I'd be interested to hear from people out there who have put an absolutely incredible amount of miles on their Honda Civic hatchbacks, and what kinds of preventive maintenance (if any) folks have done to enable such excessive mileage. My cousin has almost 300,000 miles on his '89 DX, SAME ENGINE. It doesn't burn oil, and it passes the emissions inspection every year without a hitch. All he has done is change the oil every 3,000 to 4,000 miles. He uses regular, 5w30, NOT synthetics.
    Anyone else?
  • vidabvidab Member Posts: 6
    Good to see that Civics are being discussed. I bought mine with the help of Edmunds last May. By now I have 10500 miles and I already have some problems. The car does not start immediately as expected but sometimes the engine rotates several times before it picks up. The transmission is also grinding on average every third time I put it in reverse. The brakes are sliding if used at high speed on a highway and my emergency brake needs to be pulled up all the way otherwise my car slides. So much for my Honda. I took it to the dealer but they sort of blew me off saying that nothing is wrong. I know something is happening because I drive it. It may be that it was all working when they were checking it or, perhaps, they didn't check it at all? Some people tell me that the Honda dealers like to wait until the warranty is over... What should I do? How do I make the dealer take care of the problems before they really become problems? I bought the car in Texas but I now live in Pennsylvania. How is it possible that these things are happening when a car is a year old?
    You guys were very helpful when I was buying it last year. I very much need your help again.
    Vida
    They 're not really categorized as problems.
    I have the same symptoms in my '97 Civic DX.
    When putting it in reverse it grinds sometimes or a little but that 's normal in almost all Civics from what I 've read.
    If I understood right, the car pulls when you stop on the brakes at highway speeds? Could be the surface of the road or the rotors are starting to get warped - although you should have noticed a vibration on your Civic. Unfortunately the dealer will tell you that this is a maintenance item and need to resurface your rotors unless you raise hell with them and convince them you 've been babying the car and rarely apply the brakes... Civic are notorious for warped rotors. I 'm getting mine replaced soon and resurfaced because I have 76,000 mi. on them and I think if they resurface them I will only have problems again in a few thousand miles.
    Ok, as far as the iginition not turning fast enough, there was a "service bulletin" out for '96 and '97 models from Honda that warned dealers of a semi-defective Water Pump whose only symptom would be delayed engine start-up. Mine does exactly the same thing. Sometimes it takes 2 sec. to start the engine but it's been like this for a very long time - probably since I 've had 10K mi.
    Have been neglecting it and I 'll probably have it replaced when I do the timing belt around 85-90K miles. I will however try and have it replaced for free due to the service bulletin.
    Service Bulletins are not recalls and Honda is not obligated to have the owners notified. The dealer is supposed to correct the problem if you take the car in with those specific symptoms/problems but 99% of the time they don't do it! You have to ask for it. Honest and mechanically good dealers will recognize the symptom of a slow starting engine right away and diagnose it according to the service bulleting AND repair it for free. Don't know why they don't fix 'service bulletin' related problems because they get paid by Honda to do it. I guess it must be because they don't make much from Honda. They get a predetermined amount of money for the work. It could be true that they wait until the warranty is over and then charge you an arm and a leg to replace the water pump. They make more money that way! Something to think about... good luck and keep fighting them!
    There is a place on the Internet that used to publish service bulletins but I haven't been there for over a year. If I can find it again I 'll let you know.
    '99 Integra GSR
    '06 Civic LX coupe
    NO they don't have cigarette lighters but they do have the 12V "accessory outlet" as Honda calls it.
    There is not even an ashtray in my '97 Htchbk.
    Come to think of it, my Integra doesn't have one either. I actually don't mind because my car doesn't smell bad like my other cars used to, due to the ashtray being full all the time. I just throw my butts out the window now. One of these days I 'll get a ticket (or cancer) :)
    '99 Integra GSR
    '06 Civic LX coupe
    Thank you so much, only1harry!
    Let me reiterate this to make sure that I understand:
    I should go to the dealer and tell them that I have a delayed starter and that I know that 97 and 96 HOndas have defective water pumps that cause a slow start. I should ask them to replace the water pump?
    As for the reverse gear, it grinds but also, often it does not "fall into place" in which case I have to repump the clutch and than it jumps smoothly. Is this what you are experiencing?
    The brakes; actually it feels like when I had an old bicycle that had loose brakes and when I would go down the hill it would slightly pool. With the car, of course, the feeling is more subtle. So, what you suggest is to go in and insist that they resurface the rotors (and of course not charge me for it)? I have no problem arguing with them and I will tell them I am very gentle on the brakes and do not use them. I took the car to a random mechanic who told me that I have 60% of the brakes left. Should this be normal for 10800 miles? I am not a wild driver at all and really only use the car on the weekends to go out of town.
    Thank very much. I would appreciate, of course, if you would forward the service bulletin site if you find it.
    thanks for the help.
    where is the 12 Volt accessory plug located? I looked in the catalog for the 99's and there is NO mention of it; I can't find it in the photo's either.
    At least recycle the old oil; that's the best thing you can do.
    vidab, you may also want to visit our Maintenance Conference.
    carlady/host
    You 're right, you probably can't see it in the pictures or even when you sit in the car!! It's all they way to the bottom of the climate controls or above the cup holders. It's way in there so you have to put your head down to see it. It 's actually a cigarette lighter holder without the lighter. I use it for my radar detector.
    '99 Integra GSR
    '06 Civic LX coupe
    How is the acceleration/"Pickup" in the automatic tranny 1.6 liter engine? I've never owned a Civic Hatchback Automatic, but certainly will next month. My wife wants the automatic. I had a '90 4 speed manual with the 1.5 liter engine, and it was quite a peppy car with decent pickup. Anyone?
    Does anyone use a full set of Snow tires on their Civic Hatchback? If so, what brand? What about "studded" snow tires? I use the studded Cooper Weathermasters on my Ford Ranger, and really feel like they make a difference in the tough New England winters.
    I'd be curious to hear from any Civic owners out there with Snow Tire - Yes/No - opinions.
  • goteygotey Member Posts: 6
    I have a 98 EX coupe and mine does the same thing. I dont think its any problem at all. to get rid of the trans grinding into reverse, put it in neutral, let off the clutch and try it again...works every time for me. As far as the engine not starting right away after sitting for a little bit, not worried...my Taurus does it too. Just my .02
    i am going to install a stereo in a 1999 Civic Hatch CX.
    obviously the front speakers will go nicely into the doors.
    where do the rear speakers go? the Crutchfield catalog says 'rear deck', but I don't see an open port anywhere back there.
    Civics with an auto tranny are much slower than the 5sp. Test drive one and judge for your self.
    '99 Integra GSR
    '06 Civic LX coupe
    gotey is right. Any car with a stick is apt to grind a bit if forced into reverse. Let the car roll a bit, or double clutch it and you'll have no problem. This is not confined to Hondas and isn't a "problem" at all.
    Also, what does it mean if your brakes "slide" or "pool"? I've been in the business a long time and have never heard these terms. I doubt if resurfacing the rotors would solve anything.
    And, if it takes two seconds of cranking before your car starts....So what? Do you expect it to have "instant on" like a television?
    What am I missing?
    Hatch CX.
    the doors.
    I think the crutchfield catalog listing youre looking at is for coupes and sedans. I dont know where the rear speakers are in a hatch
    I think you are right.
    Although, the DX comes with 4 speakers...so the DX must have some additional plasic back there to house rear speakers. The CX doesn't.
    I had a 90 base model, and there was wiring back there for rear speakers but no place to put them. I guess you could put speaker boxes back there, but in this day and age they'd probably get lifted. Thanks.
  • rosamrosam Member Posts: 1
    What seems to be a good price for AC for the same car?
    Welcome, rosam! We have a very knowledgeable group here so I'm confident you'll find someone who can share their experience with you.
    carlady/host
    Does anyone know how long the break-in period is on a brand new Civic?
    No formal break in period. Just take it easy for the first 3-500 miles. Easy on the brakes, vary your speeds and avoid full throttle take offs.
    Actually, it probably doesn't make much difference. Not like the old days!
    thanks for the tip. I am picking the car up on tuesday. do you think it's ok if my wife drives it to maine on the saturday afterwards - about 2 hours of highway driving?
    by the way - it's a 1999 cx hatchback, no stereo. i have a stereo to put in, but would you know if the vehicle will be "stereo ready"; like with an antenna and speakers installed, without a radio?
    thanks again!
    Thank you for sharing your experiences,only1harry and isellhondas! My concerns come from my past experience. This is my first new HOnda after owning four used ones. On my last Honda which was an 84 CRX I had to replace the starter and the way the problem started was with longer and longer periods of cranking the car. Since this is a new one (well, a 98 is new to me)I just want to make sure that no such surprises are coming. If you thing that waiting for 2 or 3 seconds when it has been sitting over night or when it is very hot is normal that I will no longer be concerned.
    The same with the stick shift. That 84 had such problems at starting with 90.000 miles and people advised me to sell it before the transmission went bad. I never waited long enough to see it gone. I sold the car at 105.000. As for the brakes, it just does not feel smooth when I brake at 75mph and up and I am wandering if perhaps the brakes are not wearing out properly.
    Thank you for all your clarifications. I just want to stay on top of it because this HOnda has to work for me for at least 10 years without major expenses. I will go to the dealer and ask them to adjust the brakes. I have about 11000 miles on the car now.
    Yes, go to the dealer and complain about he brakes so they do it for free. Although adjusting the rear drum brakes is considered maintenance, you are within the warranty period and it could be they 're really loose and dangerours if you can't stop in time, thus making it a warranty issue..
    As far as the slight grinding noise when putting it in reverse, it's normal. My car had that from day one! Sometimes it won't even engage the first time. You have to let the clutch up, try again and it always works good that way and without a noise. You 'll get used to it, and do it unconciously next time..
    '99 Integra GSR
    '06 Civic LX coupe
    I just bought a 1999 Civic CX with automatic transmission, in Silver. I pick up the car on Tuesday. I want to thank everyone at Edmunds for providing us with great resources!
    there are NO MORE Silver CX Automatics in all of New England....I got the LAST 1999. There might be a blue or red one around still, but they are rare.
    Production on the 2000 models is not far off, so if anyone out there in New England wants a Silver one, it's best to see the dealer in September to order one. I learned that the dealerships typically do not buy many of these hatchbacks - only 2 at a time. The one that I got had to be sent down from another dealer.
    Good Luck all!
    I just noticed something with my new Civic CX.
    It came with 2 keys. They are different keys, buy both work for all locks and ignition. One is even a bit longer than the other. Any ideas? What's up with that. I asked the salesperson, and he said one was cut at a different dealership......I don't buy that one.
    Why do I have 2 different keys that work the same?
  • mdpattermdpatter Member Posts: 1
    Does anybody own a '90 to '91 4sp manual hatchback? Is this generally a reliable car? I'm looking for an in town commuting car and found a very nicely kept '91 with 95k miles for $3200. Does the lack of a 5th speed make freeway driving too noisy or buzzy? Any common problems I should look out for? Thanks for the help.
    i had the '90 4 speed.
    it would have been nice to have the 5th gear, but i really didn't miss it. freeway was fine.
    i sold the car with 150,000 miles on it.
    i loved it.
    most automatic transmissions only have 4 gears, and they do great on the highway.
  • trantitranti Member Posts: 51
    Dear Iglomaster;
    I don't know about Honda, but VW (and Toyota) has 2 keys. One open every lock ( Master key) and other ( Service key) can't open trunk or glow box. This service key is convenient when you give your car for service man. He can start car, drive it but he can't open your trunk or glow box.
  • torr1torr1 Member Posts: 1
    We just bought a new car and are selling my husband's trusted ol' 94 Civic CX Hatchback. We have checked all the guidebooks and net sites that tell us what trade in and retail is on the car, but we can't find the car listed for sale in any of the papers in our area. We want to put it in the paper on Saturday morning and have it sold by noon. In other words, get more than they'd give us on a trade-in, but price it low enough to sell fast and thus avoid the hassle.
    It's a 94, red, 50,000 miles, never been wrecked and a good reliable car. Any suggestions for a good price for it?
    Does anyone know where I can get 14" Rims for my CX? They are the kind that do not require hub cabs; in fact - they use the good ole Honda logo center caps. The rims have a unique design: small circles stamped out, all around the entire diameter. I am wondering where I might get them (without having to go to the dealer and pay a ridiculous price). I want to use a set for snow tires.
    I can get the cheap black steel rims from aftermarket places, but they look like crap without hub caps, and I hate hub caps anyway.
  • mookstermookster Member Posts: 3
    I thought I was going to buy a new DX Hatch. Did my research, made my inquiries to feel out the "invoicers" and even went through the "grind" with a dealer.
    Truth is, my '87 Si Hatch with 242,000 miles is *still* more fun for me to drive! The power steering is great in the new vehicle and I'm sure the susupension is improved (wishbone was only available in Preludes I think when I bought mine), but...I gotta love my engine over the new one even after all these years.
    No offense to those purchasing DX Hatches, I'm just giving another testimonial to Honda's build quality. I'm keeping mine through Q1 '00 and will have to increase my search (and down payment) for a peppier vechicle.
    I'd consider the Si Coupe, but I hate to give up the Hatchback handiness and I can't say I dig the styling of the Coupe...oh yeah, and I want a light color this go around.
    MOOKSTAH....
    ya might wanna wait for the 2001's; word is that they are changing some things for the better.
    on another note: i just bought the 99 CX with an automatic; it ain't as peppy as my '90 manual, but i did get the groovy power steering that comes standard with the automatic.
    i'm saving on speeding tickets. hey, what's a good radar detector anyways?
    Gloostah -
    I dunno for cars...I have always used big eyes, rear view, and a rubber neck!
    For motorcycles, the champ seems to be Valentine...but I don't know if they are moto-specific.
    Mook
    tires.
  • rebbfirerebbfire Member Posts: 1
    hi,
    I'm looking at a 1992 civic hb si with 120,000k. engine in good condition.
    one owner/ all records/ reg service- timing belt changed @ 90,000k, new
    tires, new muffler. Car drives well, very tight, clutch was good- small prob
    getting into reverse.
    Only major problems are cosmetic- small dent in right front fender/ paint
    chips, etc. no rust. Owner asking $ 4800.00 but I get the feeling he would
    settle for around $ 3,600.00 Is this a reasonable price? Cosmetics are not a
    major issue for- looking more for reliability. And how many more miles do
    you think I could get out of this car?
    randy
