As for the brakes, your fluid may just be old or you may have air in the lines. Have the brake system bled. This should help provide a firmer and more consistent feel to the brakes. You could have a bad master cylinder but if you do, you will notice the problem more and more often.
Have any of you changed the cabin air filter and how much of a job is it?
I cant believe there is no Chilton or Haynes manuals for recent Hyundai models and the factory shop manuals are a bit pricey at $52 and that is just the mechanical manual as there is a separate electrical manual.
http://www.hmaservice.com/webtech/default.asp
Sopman
Resurfacing the rotors or fixing the calipers via a kit should be cheaper than replacing the parts.
Let this be a learning lesson for you. You shouldn't neglect a car's brakes, but I believe Meineke knew they could jab you for more stuff then you really needed. Once brake system repair estimates get that high, its time to get a second opinion if at all possible.
how fast were you going when the tach was at 5,000 rpm?
Either the car was not shifting out of third gear or the overdrive was turned off. Even at that it would not be turning that many rpm's, that's almot redline for that engine.There is a indicator light on the panel that tells if the overdrive is engaged or not. Did you notice that ? it is not too bright and easy to miss in bright sunlight. WOW, how many miles did you drive with that engine wailing away like that ? I get a consistent 37.5 mpg on the interstate crusing @ 75to80 mph. The relaxed rpm at highway speeds is one reason I picked the Accent over some of the other econo boxes I drove. plus that little engine developes its torque @ 3000 rpm so no need to rev the crap out of it. You are right, if all the customers run the poor thing at those rpms it will see a early grave for sure.
believer
Thanks for your info on the Hyundai's.I"m looking to buy a 01 Accent.It has high mileage for that year.It's at 104,910 miles.It is a one owner car but unfortunately I don't know to much of how well kept up it was.I did a carfax check on it.3 accidents with only minor damage to car.Everything runs good in it and looks good just been doing some research on them and happened to come here.
I have been reading and I found out they have shabby transmissions. I'm kinda wondering at what mileage did the transmission need replacing and maybe at what cost?The warranty has expired so I will have to pay outta pocket whatever work needs to be done on it.Any info would be appreciated as this is my first car and I can't afford to spend 500 on it the first month I get it.
Jen
I have a 95 Accent with 28K miles (seriously!). I've only had the car for two years, and haven't had the brakes changed yet. They were fine at first, but within the last year or so they've been acting odd. At first the brakes were only occasionally spongy, but they seem to be soft more often than not now. Sometimes I feel like I have to press too hard on the pedal to make the car stop.
Within the last couple of days, I think the brake light has been going on in my car; I've seen a flash of red out of the corner of my eye a couple of times, but when I look, it's gone. When I had it in for an oil change I asked the shop to check the pads, and the mechanic said they were fine, only 30 percent worn. (This was a couple of oil changes ago, about six months.) I don't abuse the brakes on my car, so what could this be?
Problem number two is that sometimes after I've been driving for a while, a squealing sound can be heard coming from the front of the car. Sometimes this only happens when I'm making right turns. Other times it happens when I'm driving, and stops when I brake. This happened a lot during the summer, but doesn't seem to be happening during the colder weather. My dad suggested that the calipers may be sticking. I wonder if the dealership didn't reinstall the brakes correctly on the right front side after replacing a bad bearing last year...any ideas?
If it's been idling for a while (upwards of 20 minutes), the idle can get very rough, almost as if the engine's on the verge of dying. If I try to drive when it does this, the car has no power and barely moves. The other thing is that recently my car has had smelly exhaust, with a hint of that "running rich" odor. I'm hoping it just needs a good tune-up. What do ya'll think?
1) seals dry out
2) Luburicant hardens.
3)Things rust.
First thing I would do is have your master cylinder checked to see that it not leaking brake pressure thru the seals. I've had bad ones and they failed like you are describing.
Your brake light may be momentarily going on due to a very quick drop in brake pressure (seals). By the time you've moved your eyes toward the light pressure has recovered.
As far as squealing while driving...does your car pull one way (right or left) when that happens? Could be a partially seazed brake caliper. Could be a wheel bearing failure.
I would have a competent mech that you trust go over the whole car.
I just can't imagine driving 800 miles with that little 1.6 liter engine screaming away on the other side of the firewall. LOL. I just feel sorry for the poor guy that buys that car from the rental agency when they turn it in !!
Mine just has a little over 5000 miles on the clock and it just seems to now beginning to loosen up. I just put synthetic oil in for the first change and that seemed to add about 1 mpg to the mileage.
This is my second Hyundai. I had a Tiburon (4 cyl) automatic that had over 100K on it when I traded it. NO tranny problems at all. In fact I didn't have any problems with it and it still had the original brake pads too. Great cars and vastly underated by the toy-honda crowd who are getting a little nervious about the strides the korean cars have made in the last few years.
believer
For some reason I had always thought that Hundai's were cheap quality, although I had never even been in one before. (Maybe they used to be?) But a friend likes the Santa Fe he recently bought. At the rental place I wanted the cheapest car. When I found out it would be a Hundai I felt that would be a good opportunity for me to become familiar with a Hundai product. And I am VERY VERY impressed with the handling, the ride, the comfort. It is a real nice car. The only thing I didn't like is the cup holders are so flimsy. In fact the little "clip" broke when I put a large cup of coffee in it. (Or maybe it was broken already.) And while the cup is in it you can't access the ventilation controls. Other than that I was so impressed with everything about it - that just might be the type of car I will buy next.
I spoke to the service mgr. @ my dealership & he said that if someone had a problem with their engine and was only changing the oil even @ 12000 miles they'd have little or NO chance of getting any help from the factory regardless of what kind of oil they were using. He stated that most synthetics are only rated @ "SL" service rating as are virtually all premium regular oils on the market.
If you were getting a new set of wheels would you really use such a long change interval while the car was under factory warranty ? Just curious.
regards, Believer
I do my own changes too as the guys @ the "quickie joints" always pester you to replace the K & N filter and wiper blades as well and Tranny flush ?? I wonder if that tranny failure would have been avoided if you had put Amsoil in the trans too. I've heard a lot of good reports about Amsoil here in Florida as the hot temps in the summer are hard on trans especially in stop-and-go traffic.
regards Believer
As far as the tranny failure goes, I did have it serviced at the correct intervals. A friend at work bought the same exact Accent as mine a few months after me and he got the recall notice shortly thereafter. His tranny blew before he was able to get the recall work done, and needless to say he was unhappy with the situation, not even having a few thousand miles clocked yet. (Did I mention he replaced a still good running Accord with 250,000+ miles on it when he traded it in). They replaced the tranny and he still drives it every day to work and he has clocked over 148,000 miles so far without further problems. We always mess with each other at work, seeing who has the higher mileage on their Accent. Hopefully, we will get to the 200,000 mile mark without another tranny failure, as the engine runs as good as it did when new. To me, just getting to the point where the car actually outlasts the payments is a great thing these days, considering the mileage I do and the harsh winters we endure in upstate N.Y.
And yes, the heat is definately the worst thing for trannys, especially in Florida, but it would be nice to see some temperatures over 25 degrees this time of year! So long and take care. Vinny.
(documented please, not just hearsay)
I have the same problem and i reached to the point that my brake light switch needs to be changed but i don't know hot to replace it,is it easy?
now i am getting a grinding sound and the Bridgestone master care guy gave an estimate of $900 to replace the rotors..pads..to fix brake fluid leak in the rear ..he says..the brakes may fail on the highway if not fixed immidiately...appreciate if anybody can reply asap..
by the car is 96 hyundai accent
If any of you need any help on simple annual service and maintenance procedures for your hyundai, check out my website:
http://www.ennerdale.freeserve.co.uk/dave/hyundai_accent_repair_pages.htm
Hope it can be of help to someone
Stay away from ALL those shyster stores connected to muffler repair or tire stores.They are all overpriced and do questionable repair quality as well. Go to a local independant, get a estimate from more than one and you'll see what a rip-off that you may have been getting into.
Believer
The parts for all the brakes on the car shouldnt come to more than £300-£400, unless your wanting performance pads and rotors etc...
Try asking roud different garages, labour costs vary from over £60/hr to less than £25/hr.
I had the suspension re-built with performance parts on my Accent in less than 4 hrs labour, so putting new brakes on should not take too long. Couple of hours at tops. I wouldnt pay any more than £400 for the whole lot myself.
