Ford Escort Hatchback
Anyone have any experience on safety/reliability
of 91 Ford escorts
Peter
of 91 Ford escorts
Peter
carlady/host
Is there a faq or web site about Escort I can find on the net? I like to see the problems and solutions on '91 Escort we just got.
gas then put it back onthe gas(usually going
30~60 mph) the car hesitstes. anyone have any
ideas?
I am going to buy a 94 Ford Escort LX. The mileage is 96000. What should I check before the paying?
carlady/host
The only thing that worried me while I had the car was alot of brake noise after the dealer did a full brake job. I think the problem was warped rotors and could have been fixed for a few hundred bucks - better spent on my new Camry.
Ford has a reliable car, at least for the 91 to 95 GTs - better than the 1985 Accord it replaced in my garage. The FORD dealer was a bad experience almost everytime I had to go there, which was a big reason I bought a Toyota. We've had the car a year and have not had to go to the dealer once - yes, Virgina they can build a zero defect car.
I would recommend the 1.8 motor over the 1.9. It is a Mazda mill, with good power and reliability. I drove the hell out of that Escort GT for 6 years and that engine loved every minute of it.
A bit noisy, not much power (88 hp) but good low end torque; great fuel economy; reliable if taken care of.
I'd recommend the Mazda 1.8 over the 1.9. But it would cost more initially and will need more maintenance (timing belt replacements at 60,000 miles). Slightly less gas mileage but much more fun.
Dave
lets see..
if maintained properly mine ought to last another 3.5 years....
when its time to replace it, maybe i will look for a good used escort gt if one can be found..
I always took good care of it, changed the oil every 3000 miles. It was a good reliable car for me. It wasn't he most fun to drive (having the 5 speed helped) but it got me around.
If I had known how long I was going to keep it, I might have spent the extra money to get the 1.8. The problem was, when I bought it the only way to get it was to go with the Tracer LTS, which was about $2,500 more than the regular Tracer. That seemed like a lot of money at the time.
Dave
Dave
i maintain my vehicles very well and
i hope this escort serves me as well as your tracer did. being forced to commute 100 miles per day since my job relocated, fuel economy and practicality was my reason for buying this car.
39 - 43 mpg is the norm for me , also with the 5 speed transmission. i plan to have ford add on cruise soon, then maybe i can relax a little on the interstate.
If you keep the car long enough, I'd recommend having the timing belt replaced around 100,000 miles. On my Tracer, the manual didn't ever say it needed changing, but I had it done anyway. I took a look at the belt after it was done and it needed it. Another relative of mine has a 92 Escort and he didn't change his belt and it broke. It didn't cause any engine damage but it left his wife & 2 kids stuck in a dead car in rush hour Chicago traffic.
Dave
i did see in my owners manual that it didn't say when to change the timing belt on the 1.9 engine... i did actually change it at 62,000 miles out of ignorance, because i had no idea how long it would go before the belt broke.
i use to have an 86 escort, and its belt went almost exactly at 62k. i understand the belt in the 95 has a round tooth design, which may help increase the number of miles you get before it goes.
i had inquired in several ng's about timing belt longevity, i wanted to know what was the normal belt replacement interval before i started to commute this last may, but received no clear answer. thank you!
i will be piling up the miles on this car, but i may wait a little longer the next time before changing the timing belt again..
i actually replaced my waterpump along with the belt, because it was a semi-seized water pump that took out the 1st belt in my 86 escort, a few years ago.
i guess i was afraid that the timing belt in this escort would break in the middle of our indiana winter,, leaving me stranded on the interstate ..
btw, if you are from the chicago area, we may be neighbors as the crow flies anyway. i am from marion indiana and have to drive to fort wayne to work every day. approx 50 miles one way.
your handle is interesting, if dhoff is short for hoffman then we may have the same ancestry somewhere, my last name is huffman.
it has been nice talking with you, i will check into the aftermarket cruise as an option to the ford installed item. (400.00+).
see ya,
lee
synchronizer rings at 100K, a new radiator and timing belt also, but that car hummed! Fast,
could carry lots of stuff, great in the winter.
Had 120K when I got rid of it. I regret that day.
Sigh.
Scott
The big thing is to regularly change the oil, which you are doing. Other than the things mentioned earlier, fix problems as they occur and the car should last a long time.
Dave
done plus the torque converter slips.How much
should it cost for a rebuilt transmission including labor.The other option is a good used one.Has anyone gone through this before.
but it was an 86 escort at that magical 90k mile mark....
holding my fingers now, driving a 95 escort with 78k miles.
I have a '91 Escort LX 2 Door that I am looking to trade in soon. It has 70,000 miles and is in excellent shape interior and exterior(besides a small dent in the left front panel and a few nicks on the doors). I was wondering how much I should expect and/or ask for my trade in? Any suggestions would be appreciated.
I've got my old 1993 Escort LX 3DR. Sure, the 1.9 only pumps out 88hp, and it's styling is a little dated, but the car is still reliable. Over the years, I've replaced the engine (at 180,000) and a few clutches. 10 sets of brakes and 6 sets of tires .. 2 complete sound systems.. a few windows.. and just about every body panel. One motorized seat belt and an overpriced plastic radiator added to the list, and I've probably got a total of $18K invested in the car over it's 8 year life.
Through the various accidents, break-ins, vandals, and HARD driving; the car has been operational at least 90% of the time. All the while, costing me less than $.15/mile over it's life.
Now, with a big dent in the rear quarter panel, and oxidized paint, the time has come to make a decision. If I choose to sell the car in it's current condition, I can expect to get around $2K for it. If I choose to fix the car, repairs and paint will cost me around $1500.
Still reliable.. still gets me to the airport on time.. not nearly as much fun to drive as my 2000 Chrysler 300M, but it does have a better sound system.
Of course, if I do keep it, It'll be a different color and I'll be adding GT brakes and all new suspension components.
What do you, my fellow escort owners, think . ?? Your opinions are welcome -
I have 254k on my 94 Escort I got new, same engine, no blow-by. same clutch. same radiator. 3rd set front brakes, same (original) back brakes, not that I over use them.
Sure a couple timing belts & 1 idler, crank damper & alternator (248k). And had to clean the MAF when the car started running rough & burned the plugs & a coil output had to replace the coil of course. And the front calipers.
My car came with the heavier duty brakes, the pads 1/2 again larger everything else is the same.
My mother who has a long commute put 225k on an 87 on the original clutch and motor.
Both cars were still running good when sold. The 87 is commuting for a friend who now has 238k on it. It still does not burn any oil between changes, but is rusting badly.
-Nate
if your water pump siezed it usually takes out the timing belt. it could be all you need to do is replace both..
lee
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
Here's the full story from Edmunds' Generations section: A Ford Escort/Mercury Tracer History, by John DiPietro. Let us know what you think.
A 1991 Ford Escort GT (Photo courtesy of Ford Motor Company)
Thanks for your comments. ;-)
Revka
Hatchbacks & Station Wagons Boards
Dave J
Hope that helps
Revka
Hatchbacks & Wagons Boards
That 1.9l engine continued on essentially the same for a few years in later Escorts, so I hope many of you had the same good fortune that I did. Maintenance helped alot: timing belts every 60K and oil changes every 3-4K. My baby!
