Visitor Agreement.
Pat
It is very interesting to see what's in store for 2001 Foci. I will be even more interested to see what one of those fully-equipped ZX3s is going to sticker for. Features and frills are nice, but manufacturers seldom give them away free. I hope Ford keeps a lid on their pricing. And I hope they get a handle on their parts supply problems.
I washed it then spent 1.5 hr using Meguiars "Gold Class Clear Coat Liquid Car Wax" ($10).
I suspect (not sure) it is carnuba wax, they have somehow liquified. They also added oils that soak into car paint (to prolong its life) and mild cleaners (in case car's not fully-clean).
PROCEDURE:
Using sponge pad (included) I applied a thin film to entire car (Instructions say "Do entire car first").
Then wiped the hazy dry film, with terry cloth towels.
Film wiped off EASILY .... and a few light polishes with clean terrycloths, finished the job.
RESULT:
The little Z is bright in shade, brilliant in sun.
zx3
concerning the overfill issue.that was a much
appreciated piece of info.as i stated previously
i had mine done by a shop that was fully aware of the proper fill.they had mentioned 4.5 was right
on the button.again,much thanks.
to zx3-sounds as though you enjoyed waxing the hatchling + are satisfied with the results.
BTW, exactly what does "1/2 over" do to car?
zx3
lubricates internal engine parts.also,it helps cool the bearings.the total amount of oil in the engine
serves as a heat sink.this of course being a good
thing.now,too little oil can heat up an engine and cause pre-mature wear.too much oil in the engine
is just as bad.as the crankshaft spins around with
an overfill of oil it can be whipped-up into a foam.this will then result in a drop in pressure.
therefore,critical engine parts are not being lubricated.it also can cause leaks,as extra oil is
forced past seals + gaskets.if anyone else can elaborate on this topic,it sure would be welcomed.
good question zx3
Prior to using Meguiar's new Liquid ClearCoat Car Wax (see Post #489 above) I washed the car.
I used Rain-X's new "Self-Drying Car Wash".
(They claim the water "sheets-off" car, so you have "little or no wiping" to do). Here's how I made out, following the Directions.........
PROCEDURE:
Parked in shade. Blasted car with garden hose spray.
Poured 4oz RainX Car Wash in 1 gal pail of water.
Removed spray-nozzle from hose, so water just pours out on ground. (NO nozzle or spray-gun is used at all).
Using a "big mitt", washed car roof w/Rain-X. Poured water from hose onto roof, rinsing away the suds. Then, working downwards, repeated that procedure for each major section of car.
RESULT:
The "Rain-X Car Wash" did good cleaning job. Plus, it did mostly "self-dry". There was very little dry-wiping needed.
This reduced my work. Plus it saved time, for I was able to begin Meguiar Waxing job right away.
And, as you can see in Post 489---the Meguiar job also went easy and gave great results.
zx3.
The foaming is news to me. The overpressure is more familiar.
With too much overpressure you can blow seals.
Thanx.
5spd.+present zx3 5spd.at this point in time i have
taken it for granted.there was mention of this in the zx2 forums as well.seems to be commonplace with
the zetec engine.however,silver bullets suggestion
makes sense.i notice it happening while accelerating up,subtle but noticeable.
to it with the zx2.i havent really been paying attention to it, till i read your post.by the way,
how many miles are you at? my z really smoothed-out
at about 2800 mi.
What sort of things are we talking about? is there much interest? If you give me a list of the items you need, I'll try find out some prices for you based on the quantity required and we can work out the shipping details and costs, and see if it is feasible. You should also try and obtain the cost of the original US spares as a reference.
My one reserve would be the compatibility. Just how similar are the Euro and US foci?
That is not a problem for BMW, as I imagine you guys are driving exactly the same cars as we have here, but Ford has tailored the Focus to the various markets. How much of the stuff under the skin is common to both our markets? What is different? and, of the latter, will they fit on US-spec cars? I wouldn't care to send you a container-load of shocks just to find you can't fit them or find that they are exactly the same units you already have. Either we find someone who knows these details, or someone is going to have to act as a guinea pig and test fit and drive the parts. Another issue could be the warranty and we would have to sort out a policy for defective parts. It may be more trouble than it is worth.
5spd.however,i did drive the auto,and liked it very
much.personally,i believe this car has so many fine
handling characteristics ,pick-up +braking abilities,you will probably enjoy it just the same.
there are others here, such as pcleveland2,who have
posted that they thoroughly enjoy their auto trans.
enjoy!
Anyone out there beat me to the punch yet?
"..........The only fix/remedy is probablygoing to lye in the replacement of the computer
chip with a re-designed curb. I hope this will
solve the problem and plan to install one soon!"
Question:
What is a "curb"? Did you mean "chip"? If so, where would I get one? Dealer? Has Ford issued a notice about this?
When cruising between 2k and 3k, my z sometimes does same thing (develops a faint hesitation). It seems to appear on a slight uphill grade. I'll watch closely to see if it also appears on levels. It's very intermittent, though.
zx3
hesitation that was pointed out by project.it seems
at this time not to be as pronounced, or i am not
consciously aware of it being that obvious.for me,
in one way thats o.k.i am quite satisfied with the
overall performance.as i have stated earlier,things
seemed to smooth out about 2800mi.then it got me to
thinking,i bought this car in the dead of winter.
thats why it may actually seem to be running smoother now but then again,im leaving well enough alone.i do know exactly what you mean about the hesitation.
to wolf1313-i agree,it sure is an idiot light,if there ever was one.as i stated above,im probably in denial that it exists.quite frankly,i enjoy this car so much,that i tend to overlook or shall i say forgive,some of the minor issues.
Used NuFinish paste as per Consumer Reports Recommendations. Looks great! Will see how it holds up.
While cruising in Jersey I was 'racing' with a Focus Sedan. Really glad I got the ZX3 as the Sedans are not very distinctive.
PS Left him in my dust across the Ben Franklin Bridge. Thank God for 'Easy Pass'
What's easypass?
Glad to hear you like your z.
zx3
After dinning, I took the car for a true driving test. I got this problem. My car was hesiting at low rate 2000-3000 rpms. I was realy surprise when I saw reports in this forum about this phenomene. Like I told you, I did'nt know about why my zx3 does that, but I felt it in same day where I bought the car and I was anxious. I thought that I got a bad one from assembly plant (you know... mexico).
Also, me too I expect to get rid of that stupid shift indicatorvery soon. I tried to following his indication but that did'nt work. He's stupid!!!
I have a question... I tried the Ford Focus (hatchback 5 doors) in France 2 weeks long (I did rent it). I was able to reach 185 km\hours (90-95 miles\hours) easier than mine. Also the motor revolution to shift up (gear in transmission) was'nt the same. I'm not sure but i think that the transmission is not the same... if someone knows more about that should be good to unmystify this point (I means since the engine too).
About european focus... the exterior trim is not the same too.
Yan
With 210 mi. on it, my z is troublefree so far.
Glad I bot it. What nice, careful workmanship it has.
A local kid snapped up my 87 GT/GTI with 149K on it. When he drove happily off, the exhaust purred sweet and engine sounded smooth as 13 years ago.
This z feels/looks/handles like it might turn out to be a worthy successor.
What's up with this "engine skipping" business you're talking about? Does Ford have a fix?
zx3
referring to that fact that you only pay one way
across the bridge,therefore traffic keeps moving on one side if you have the easypass,which you pay for a month up-front.the other guy probably had to stop to pay his 2.00 bucks at the toll.fgaydos would have beat him anyway,knowing how he drives on i-95.
thats a feat in itself.i use to cross that bridge
daily for ten years.
at your place like here. i dont believe the engine
issue is a big deal.i had posted previously my impressions+experiences with what was discussed.i
put 35,500 on zx2 zetec engine-no problems.
personally,im not really concerned about. it. but it
would be nice to know why.im sure someone here will come up with it.
Very high tech.
Read all about it at:
http://web.philly.com/content/inquirer/2000/05/28/business/
on euro focus engine + trans but im sure someone here will check in.
easypass.i knew it was a radio transmitter but i
thought it was like a smart card sticker that was
on the windshield,like an inspection sticker.is it
actually a piece of hardware?
http://www.thefordsource.com/store/motorsports/focus_2.htm
the borla improves throttle response and improves on high end power. the engine revs more freely at high revs.
as for wax jobs the best way to go IMHO is to do the three step job. you need to be anal and have a lot of time on your hands. i know meguiar's and mother's have this system. step 1: prewax cleaner step 2: glaze and sealer and step 3: pure carnauba wax. you're basically "waxing" the car three times or at least following the procedure of waxing. it took me nearly 3 hours to complete this process but the car shines like no other, it's like a mirror. you only need to use the prewax cleaner once or twice a year, i'm assuming it works like a polish. the glaze and sealer is great, it gives you the "wet" look and gets rid of those annoying swirlies.
my dealer says you can order june 3... delivery early september
The 'Easy Pass' hardware is about the size of a pack of cigarettes but flatter. It gets velcroed to your windshield near the rear view mirror. Saves a lot of time, I never stop anymore.
A great idea whose time has long come.
respect to all those who sacrificed their lives
and gave of their service.after all ,their sacrifice allows us to speak freely.GOD BLESS YOU. + THANK YOU !
There are tremendous benifits to on board computers.They record a lot of information that can lead to solving intermittent hard to troubleshoot problems when you request service at a Ford dealer. They have the ability to connect there diagnostic machine to a port under left drivers dash. This allows them to test for codes eliminating the old 'style' of process of illimination with regards to servicing.Although,the computer only goes so far and sometimes 'process of elimination'is still necessary, the computer is still VERY helpful when it comes to servicing. If you have modified the cars engine and electrical than you have defeated the whole purpose and need to eliminate or work around the computer.
The chip is a simple replacement part available off the net at places like Focusparts.com and places that sell aftermarket Ford performance parts.It should not effect anything except attack the cars weaker points.It should make a world of difference on an automatic! It will im quite sure, if the company/manufacture you buy it from does their homework, cure the hesitation/bogging problem. Finally, im also sure it will eliminate the 'governor' on top end speed which kicks in at 106 MPH. This prohibits you from accelerating above this speed and is a built in safety booby trap courtesy of Ford and it's factory chip. Alan
The difference in feel may also have been due to a stiffer suspension set-up (the Zetec versions here are set up pretty stiff) which makes you feel more in control and lets you carry higher cornering speeds.
Top Gear - a BBC motoring programme - recently tested the Focus (their 1998 car of the year) against 11 of its main rivals here. The Focus came in joint second with the Golf. They gave first place to the Seat Leon. They reckoned that the Focus was the best drive but they criticized its quirky looks and build quality. The Golf beat it in build quality and resale value. The Leon was judged to be the best compromise. Personally, the fun factor matters more to me, so make mine a Focus.
Anyone mechanically inclined enough to be interested in installing power mirrors into their ZX3? This is the only power option I wish I had, and I'm temped to get the mirrors, switches, and harness out of the first wrecked ZTS I see and have a go at it. Has anyone out there sprung for the shop manual and/or electrical manual?
