Ford Focus ZX3
1161719212256
  • vadpvadp Member Posts: 1,025
  • fgaydos1fgaydos1 Member Posts: 5
    This site will allow you to rotate in 3-D, the new concept cars including Ford.
    The Toyota Matrix looks like a cross of the ZX3 and a PT Cruiser. :>0
    http://carpoint.msn.com/autoshow2001/default.asp?content=media
  • cgsangelcgsangel Member Posts: 79
    Hi focusmatt,
    I agree with silver bullet (again). From my own experience, I've had alot of problems with out of balance wheels and tires over the years. Particularly on my small cars, although it has happened on my large ones too, just not as noticeable.
    It could be just one bad tire or wheel causing all your problems. I've tried both alignments and wheel balancing, and almost every time it was the out-of-balance wheel and tire that was the culprit. On my older cars before radials, the vibration was more harsh. On a Pinto I had, I had all the stock non-radial tires replaced with radials, and the vibration was completely gone afterwards. I lived with the shake and vibration in my Vega before that because I couldn't afford radials back then and I really wasn't thinking wheel balance. The car was known for bad rear wheel hop over rough roads and I assumed the problems were all due to that. (I also had a knack for choosing cars? back in the seventies :)
    My experience also showed that tire rotation will prevent alot of vibration and tread wear problems as the car puts on the miles. My Cougar had a bad vibration at 40mph and that was due to my negligence... I hadn't rotated the tires. Just by doing that smoothed it right out. But with your new Focus, it's probably the wheel balance.
    Charlie
  • foxtoxfoxtox Member Posts: 5
    Hi, i havn't posted here before so here goes. I will recieve my new zx3 in a month or so and am wondering about what after-market engine mods will void my warranty or if any will. I would not be installing any internal mods, just external like exhaust and intake.
    go to www.focussport.com , they have a lot of stuff.
  • northguynorthguy Member Posts: 14
    Focus matt:
    Your vibration problem should not be occurring. 16" wheels should have no bearing on the problem. The previous two postings regarding wheel balance point to the most likely cause of the problem. It is possible that you have a bent or out of round wheel too. This doesn't happen too often but it does happen. Also: Have you checked your tire psi lately? A couple psi off optimum or worse a couple psi difference between the front tires can make a difference. I've got the 16" wheels on my car and it runs down the highway smooth as silk. It's hard to believe that such a small car rides this nice.
  • cobiecobie Member Posts: 108
    I was reading an article today that recommended that vehicles w/ ABS should have their brake fluid changed every 2 yrs.
    Has anyone else heard this before? If this info is correct, why the frequent changes?
    What if, in two years time, you don't activate the ABS?
    Comments are appreciated.
  • silver_bulletsilver_bullet Member Posts: 1,339
    Brake fluid should be changed every two years, no matter if you have ABS or not. Brake fluid is hygroscopic, meaning it absorbs moisture from the atmosphere. This moisture causes corrosion of hydraulic components, and lowers the boiling point of your fluid which can cause brake fade. When you have the system flushed, a quality DOT 4 brake fluid should be used - Castrol LMA is a decent choice, as are the DOT 4 fluids from brake manufacturer ATE (like their TYP 200 or Super Blue). Do not postpone this service if you plan on keeping your car for an extended period, and wish to minimize maintenance costs - it is essential to keep your hydraulic system in good condition.
  • drebe73drebe73 Member Posts: 243
    I brought my Z in for the recalls ...I get it back and what do I find? My break lights stay on all the time when the car is running, and my dome light doesn't always come on when I remove the key from the ignition like it usually did. You bring it in for one thing and the always mess up something else.
    Hi drebe73,
    I'm sorry to hear about your brake light problems after the recall service. Are the brakes still ok and it is just the light on, or are the brakes themselves on all the time?
    Why I ask is that my brother was driving his Focus with his daughter following him and she noticed that his brake lights never went off. They found out there was a problem because the brakes were actually on all the time. I think the calipers were partially closed, sending the signal for the brake lights to come on.
    I'm not sure if it was a coincidence that the brake light problem started after they serviced it or if it just happened coincidentally. Let me know what they find out. It could be the same problem my brother had with his car's brakes.
    Charlie
  • jimzzx3jimzzx3 Member Posts: 5
    I have been reading through about 200 of these comments, here is mine I have a 00 zx3, love it except for the recalls. I expected them though mine is black my only problem is an annoying knock sound from the left front side while idling it is intermittent though. my other problem is keeping it clean what can I clean it with to get a real glossy wet look? and wash and dry it with? I use meguiars polish, wax deep crystal but I still dot like the look, I have had white cars never black but any case no problems 13k miles bought it in may 00. I have only seen about 5 other as around here I live about 50 miles west of chic ago. concerning speed my friend had his 00zx3 cut off at 114!! that was fun!! vie had mine to 100 no shimmy shake or flunks smooth sailing hope to talk to you all later, drive on.
  • jimmyfocuszx3jimmyfocuszx3 Member Posts: 65
    Yeah, I had the same problem. Seems that the do-hicky that the break pedal rests against broke it's interior spring. Since the spring was broken the connection between the battery and the break lights was never broken, hence the lights stayed on all the time. They didn't have the part, so they pulled in one from the lot and switched them for me since I am a "Irate Customer" [I wrote a letter to the dealership GM and threaten to write a worse letter to Ford]. they also wash my car after every servicing. =)
    Jimmy
    I posted this in the ZX3 Owners Club, but not sure if anyone has been there to see it?
    Would any ZX3 owners be interested in having your own chat here on Edmunds.com? We'll be happy to set it up for you. Let me know!
    KarenS
    Owner's Clubs
  • focusmattfocusmatt Member Posts: 8
    I'll have to deal with the balance problem later. Someone backed into my 3-week old ZX3 and now there's white paint and a dent on my front fender and bumper. I'm afraid that it's going to cost a lot :|
  • shov6shov6 Member Posts: 177
    Okay, gang, here's MY horror story.
    I was driving to work one fine morn and heard a "whup whup whup" from the back, thought nothing of it, figuring it was merely snow lodged in the wheel (this has happened to me before)... Parked the car, and went about my business. Next night I get back and get into the car, forgetting entirely about the previous morning's problems, and start motoring on down the road. Now the "whup whup whup" has become a "WHUP WHUP WHUP", so I pull over... Flat tire. No biggie, but for the fact that it's about 5degF outside and I am changing my tire in a snow drift.
    Next day I drive the thing to my local garage, thinking I simply need to plug a puncture, and he says "hey, lookee here, the sidewall is ruptured and there's nothing I can do". Indeed, the sidewall cords are clearly not as they should be, though nothing is immediately obvious (there's no tear in the rubber or anything). So there I am, with my just-under-two-thousand-mile car, wondering what the heck is going on here... So I drive across town to the dealer and insist they give me a new tire. Naturally, they have no such tire in stock (which, since I haven't mentioned it, is the 16" tire, the Firestone Firehawk)... And the local Firestone dealer doesn't have them either. Great.
    So I suggest, somewhat tongue-in-cheek, "hey, why not simply pilfer a tire off of a car that's sitting on the lot?" They say NO WAY JOSE, and unlucky you, you'll have to keep the car here. Lucky for ME, I got the deal with my financing that they will supply me with a rental car for any duration my car is in the shop, and wouldn't you know it, at 4pm on a friday, there are no rental cars left in town and now THEY are stuck! :)
    In the end, they did exactly what I suggested they do... Only better, since they grabbed a whole tire AND wheel off a car in stock and popped it on my car. :)
    SO... Horror story ends with me having a new tire and wheel and it cost me nary a penny... Just the aggravation of changing a flat in the snow and cold. The ancillary point here is that the local garage I went to originally suggested that Firestone was about to issue a recall of these Firehawk tires, too, though that seems a little TOO convenient for my tastes. :)
    Anyhow, obviously not FORD's fault, and I couldn't be happier with the outcome. Happy motoring, all!
    SHOV6
    If I were doing it again, I'd take a VERY close look at any car I was considering buying off the lot - with Ford's ongoing parts supply problems, and random failures occurring on Foci, it seems there's a good chance that a car sitting around a dealer's lot for awhile may have been cannibalized at some point. Maybe a good argument to special order your car?
  • KicKMan1KicKMan1 Member Posts: 45
    Any news on the cause of poor mileage with some Focuses?
  • pcleveland2pcleveland2 Member Posts: 516
    Possible cause: Heavy Foot and Fun Driving!
    A five door Focus is going to be sold in the USA!
    Today at the Toronto auto show the ZX5 was displayed and it will be sold in US as well as Canada.
    Glad to hear the ZX5 will be sold in N. America. It's a nice looking car. I don't understand this love affair Americans have w/ sedans.
    My mileage sucks!! Granted I've less than 2,000 miles on my ZX3 and I've only done "around town driving" and it has been cold, however, 18MPG!!?! Consistently. I'd be happy w/ mileage in the 20's.
    My previous car (a four cylinder ford product) never got below 23MPG in the 10 years I had it and I consistently got in the mid and upper 30's on the highway.
    I love the ZX3's other attributes and it is fun to drive, but the mileage for a 4 banger is really crummy. Not a happy camper in the mileage dep't.
  • rwgreenbergrwgreenberg Member Posts: 154
    Very bad, and I drive with a very light foot. Get over 30 on my 12 year old Colt in suburban driving. Get about 22 on my Z. I think we're stuck with this flaw. Too bad, I love the car, but would not recommend it for this reason alone.
  • pd01pd01 Member Posts: 25
    Okay, I've had my zx3 for a little over 2 weeks and it has about 700 miles on it now. I love the car except does it has one flaw. The mileage isn't too great. Been to the pump three times now and I'm getting an average of 22mpg of mixed driving. Gas mileage in rural driving isn't too great, as I noticed yesterday. I put gas in the car Monday and then on tuesday I did a lot of city driving. I had alomst 100 miles on the tripmeter and the gas gauge was at 1/2 a tank, pretty bad. Well, just wanted to let people know whats up with my car. And I hope the mileage will get better.
    Hang in there guys, it should get better. You have to get some miles, about 3000, before she loosens up. I'm averaging 29 to 30 mpg overall even with winter tires all the way around and the automatic. Manual 5 speed should do better.. Have to agree that it should be somewhat better than that, but it's double overhead cam with 16 valves. that cuts out the economy for sure.
    Pat
  • eyefieyefi Member Posts: 5
    Hi fellow Foci owners it been a while since I been here but had to comment on the gas mileage. I just turned 10k this week on my silver 5speed. But sad to report the mileage is still around 20mpg, no matter how I drive. It was about 18mpg so I switched to 89 octane and got a little bit better. even cursing on the highway I never got more then 24! So why do some get 39 and I get 24? Yes I have been to the dealer and they put their little mile-o-meter on it and tell me its ok, yes I have written Ford and bey send me a nice Hallmark telling me about the bright tomorrow instore for us all (a.k.a. NWO) but no mention about the gas mileage discrepancy between cars. I have talked to other Foci owners with auto's that are getting in the 30's, in town!!! OK we know the car can deliver so what gives. I think I'll go up to blueovalnews.com and see if those guys can figure it out. In the mean time my little ZX3 has been great, just the clutch spring replaced so far. No way am I going to let those gorillas try and replace the trim on the interior!
    Pat, DOHC and 16 valves usually result in better breathing and higher efficiency - and that generally means better fuel economy, not worse. Honda has no problem squeezing pretty decent MPG out of their twin cam 16 valve powerplants. Having read many of these posts, I feel Ford has a quality control problem involving the 2.0 Zetec engine - perhaps manufacturing variations are to blame for some of the abysmal fuel economy numbers being reported by some ZX3ers. Since fuel economy numbers are the responsibility of the U.S. EPA (and not the DOT or NHTSA), a letter writing campaign to the Feds might be in order. Who wants to start?
  • zx3beastzx3beast Member Posts: 661
    the dohc and 16valve zetec in the zx2 is a more consistent performer
    than in zx3, in terms of gas mileage auto or 5spd. it also has been more livelier and tractor-less . cheap parts are more than likely to
    blame for the ills plauging the current zx3. the zx2 has 35,000 mi.
    not one complaint. i sometimes regret trading my 5spd. zx2 for the zx3.
    the gas mileage that varies from one owner to another is pathetic. it is
    a real problem and not an isolated issue.
  • gmzx3gmzx3 Member Posts: 5
    My ZX3 is a 5 speed and gets 32-34 mpg. It has 4K miles and has always been in this range. I expected high 30's based on my old Escort GT. Figured that the new technology and better FI would help. I expect it to go up in warmer weather.
    I keep the tire pressure at 35F/33R. I drive it pretty easily with about 70% highway. Shift at 2500 or so. The shift light comes on way too early so I ignore it.
    My previous car (still have it) is an 87 Escort GT with 165K miles and it still gets 3-5 more mpg than the Focus. It is geared about the same but the Focus weighs about 400 lbs more and has 20 more HP.
    The mileage hasn't gone up. I think if you drive the car hard, the mileage drops very fast.
    Someone in a store parking lot told me his son has one and got in the teens for mileage. The dealer changed the O2 sensor as some have the wrong one installed. Hard to believe that it wouldn't get a check engine light.
    Gary
  • stevehoutxstevehoutx Member Posts: 8
    Based on the gas mileage, I too will not recommend the Focus to my friends (at least not without a lot of reservations). My ZX3 has 10K+ miles, and in mixed/in town driving I get about 22 mpg with the AC on. In the summer, I get about 19 with the AC. Best ever is 27 mpg on the road with no AC. This is not a plus for Ford, considering I have a reputation as a motor head and that my people frequently ask me for info when buying cars. While I love the rest of the car (it's been relatively trouble-free - knock on wood - save for squeaky brakes), based on my experience, I would be unlikely to buy another Ford. I haven't bothered writing Ford again after they sent me some boiler plate telling me I could save gas by picking up riders or taking the bus.
    As tempting as the upcoming SVT Focus looks, I'd never consider buying another Ford either. My ZX3 (now my fiancee's) gets decent, but not great mileage, but she doesn't drive enough that fuel costs have been a problem. I'm also dreading the return of hot weather, since running the A/C last year produced water on the passenger's floor that the dealer "could not reproduce", despite the TSBs pertaining to evap case leaks in many Foci. Ford's idiotic response to stevehoutx is just more supporting evidence for my "just say no" decision.
  • fdannafdanna Member Posts: 263
    The ONLY way anyone in here is getting 32 to 34 MPG's is if they stick to the speed limit, live in a flat area and feather the gas pedal OR if they're very bad at math. For the rest of us, I don't think we can expect better than 27/28 in mixed driving. My Civic was rated at 30 city 33 highway and I consistently got 30 mpg from the day I bought it (70% highway). My average speed in the morning on the way to work is between 75 and 90. My driving style has not changed since I got the focus but I only get 25 to 27 and I think that's all she wrote. The engine is 400cc larger than the Civic and you can definitely feel it.
    My gas mileage with automatic transmission gets 27/31. The 31 came on two trips north from Maryland to Massachusetts, 450 miles, I-95 all the way. I would agree that the mixed driving is about 27, and it would be lower if I were sitting in bumper to bumper traffic. I also do feather the pedal to get the most out of it, but once up to speed I cruise with the traffic (65-70mph).
    I probably would be complaining more if I had been driving Civics and other small cars with great mileage all my life. But I also remember the vans, big V8s and even some sixes that never could make 20mpg. It's a compromise, and considering the ride and room inside, it works for me.
    Silver Bullet: You've probably already tried this, but a change in service depts might solve your A/C problem. My brother had that same problem, and they pulled his car apart to fix it, but fix it they did, including replacing the entire carpet.
    Charlie
  • harlekharlek Member Posts: 8
    I tested both cars. I loved the Focus, and really liked the Echo, and in the end bought an Echo. Its looks really do grow on you!?!! For those of you that like the interior dimensions, high seating and great trunk of the focus, but are not happy with the mileage, give the Echo a try. It is not as refined, but is FAST for a small engine and I always get + 30 MPG, even in cold winter weather, consistently get +35mpg in the summer, and as high as 43 mpg on freeway trips.
    I am not knocking the Focus - I really like it, but if MPG is a major factor, the Echo delivers what is advertises. You may want to consider it??
  • zx3zx3 Member Posts: 167
    Hi guys: I like to drop in periodically with a "report" on my car. (Also I have a "Big Question").
    But first, here's my latest "Z Report"....
    ***Dlvrd last Jun.
    ***Autumn color zx3.
    ***5spd.
    ***Air.
    ***Mobil-1 Synthetic oil (switched to @3000mi.)
    ***25/31mpg. (70% city/30% hiway).
    My Z is now at 6000 miles. Still flawless.
    From "Day One", not a defect, not a failure.
    Has never been in to Ford shop (except for oil-chnge or recalls).
    The Z is sure-footed, handles road-curves like a cat.
    Bottom Line: Would I recommend a Z? Answer: for this price range,YES.
    MY BIG QUESTION:
    (We all know Oil Co. opinions -- but what do YOU guys say?) Should I .....
    (1) "Change my Mobil-1 synthetic oil/filter at reg intervals."
    (2) "Just change filter."
    (3) "Change nothing."
    (Note: The last one, (3) makes me real nervous).
    Thanks for any and all opinions....
    zx3
  • planetredplanetred Member Posts: 15
    change oil and filter at reg intervals. the filter is only $5 .
  • sellingzx3konasellingzx3kona Member Posts: 12
    Silver with Charcoal interior
    11,300 miles Automatic * Power Everything * Factory DC Player
    16 inch Factory Alloys * dona Blast Mountain Bike * Factory Roof Rack
    Factory Water Proof Seat Covers * Every available factory option
    SELLING FOR $13,000 (o.b.o. within reason)
    I have ordered my new car so I must sell. I am in the callas area! (214) 629-3061 or prince@myfirstlink.net.
    EM-AIL FOR PICTURES!!!
    zx3,
    Until your warranty runs out change the oil at the required interval. After that you might consider increasing mileage between oil changes. My feeling is that the break even point is at 10,000 miles for doing it yourself vs the dealer doing a dino oil change. Mobil 1 has been well documentated for holding up for the long term.
    Pat
    It's something I can't get through my thick skull. My Nissan 1.6 liter and past Escorts 1.9 liter have walked all over the ZX3 mpg wise. I've always, in my mind, equated more horsepower with better mpg. But I know that is not the way it works. What I have found interesting is accessories, i.e. ac and winter tires, do not cut back the mpg on the foci, while it has on past vehicles. The nissan got 38 to 39 mpg consistantly, even with ac on.. The escorts, one a wagon, got about 37 mpg until you hit the ac button, then it dropped to 30. All were sticks.
    Pat
  • peterzenpeterzen Member Posts: 4
    About this mileage issue: I posted a quick note a while back about my MPG. Sorry to tell you fdanna, but my 2000 ZX3 5sp gets a rock solid, consistent 25 mpg in town and usually around 33 on the hwy. I usually drive around 75 MPH on the hwy with the AC on. In town I hammer it pretty good and still get a solid 25 mpg. There are so many posts comparing the mileage of the Focus to that of the civic and such. There is so much more to fuel mileage than the engine size. The Focus presents a rather tall profile to the wind and that little 4 banger has to work pretty hard to punch a hole in the air at 75 mph. (that's why there is only 5 - 7 MPG difference between city and hwy mileage). Most small engine cars like the Focus are much more efficient in the city where they aren't trying to move the air out of their way. My Lexus SC300 has the in line 225 hp six, automatic and gets nearly 28 MPG hwy at 80 -100 mph with the A/C on, but when I park them side by side in the garage, the roof of the Lexus is even with the top of the seat in the Focus! Overall I'm really happy with the Focus. Now, if I could just get rid of that darn 2,100 RPM stumble!
    Did you have the dealer check the injector wiring harness?
  • elantra00elantra00 Member Posts: 225
    But I went with a 2000 Hyundai Elantra instead. Both were in the price range and had excellent options to offer for the price. However, the Focus was high in demand at the time and I couldn't talk the Ford salesman down below 13,000. The elantra wasn't as high in demand, so the dealer was able to drop the price down to 10,800. So I went with that. Im kind of glad I did, reading about the MPG gas issue. I put one of those K and N air filters in my car and I squeeze out about 40 MPGs on the highway and about 30-33 MPGs in the city! One thing I really liked about the Focus was the styling inside and out. Absolutely beautiful! Easy to hook up and there are a lot of aftermarket parts out there. But in value, I believe the Elantra outweighs the Focus
  • elebutelebut Member Posts: 5
    My '01 is egg yolk yellow. I bought it at night (mistake) 'cuz I thought it would be more orangy, but the next morning I was startled to see a canary yellow, very bright vehicle in my driveway. Besides the slightly crooked bumper and the weird color, I like the car's looks. I really like the ride, comfort, and overall quality in and out. Like everyone else (almost), I'm disappointed with the mileage. (one of the reasons I bought it was for mileage). Has anyone out there seen the yellow '01? What do YOU think?
    -Gary
    fdanna,
    I think you are now just as guilty of berating the good-mileage-getters as we have been of you mileage naysayers... I don't have a light foot, I don't live in the flatlands, and I don't necessarily follow every speed limit sign... And my math skills are up to snuff, as well. On the highway I am routinely getting over 28mpg, and once as high as 31 or 32 (?? I'd have to go back and check to be sure), and this involves driving through the Adirondacks, Catskills, and two other mountain ranges between my home and my folks' place in downstate NY... At exactly 8mph over the posted limit, so that's 63-73 depending upon the location.
    Now I will say that the mileage IN TOWN is pretty low, down in the 20-21 range for the one tank that I did that was exclusively local, below-50mph driving... so that piece of evidence leads me to believe that gmzx3 is exactly right... The second you lean on the thing AT ALL, the mileage plummets.
    In case it needs to be said, those of you with automatics and those with the 16-inch wheels should expect lower mileage than those with the 5spd and the 15-inch wheels... I am stuck in the middle, with the 5spd and the 16's. Furthermore, the more options your car has, the worse off you will be, simply from a weight standpoint... Although it wouldn't seem like it would make a big difference, keep in mind that an additional 100lbs of electric motors for the windows, mirrors, various ABS/traction control hardware, etc. has the effect of adding up to another whole person. A SMALL person, to be sure, but more weight=worse mileage. Not to mention that on a car this light, 100lbs is a larger difference, percentage-wise, than it would be on, oh, a Lincoln Town Car. :)
    SHOV6
    One more thing... I just read two posts from ZX3 owners who now say that they wouldn't recommend the car to a friend, based upon the mileage they have received. I'm sorry, but unless I am reading this wrong, you now think the car is no good because you have to fill it up more often?
    I have done a little math before, comparing the difference between an average of, say 20mpg vs. 30mpg, and over the space of a whole year, the difference in out-of-pocket expenses is relatively small... Even with the cost of gasoline the way it is, it would be no more than $300 over the space of a year, or about $25/mo, assuming you are spending $1.50/gal for regular unleaded. Keeping in mind, of course, that this is a rather extreme example of differences in mileage, and is probably about twice as large a gulf as is really accurate (as in nobody REALLY expected their car to average 30mpg overall, did they? I expected 25, and that's pretty much what I get on average, and those who are doing worse claim in the lower 20's for the most part, so this $25/mo difference is wildly wrong, it's more like $10/mo).
    To ME, this car is worth the (absolute worst case)additional $25/mo over anything else in its' class, for the superb combination of handling, styling, space efficiency, quality, and overall vehicle dynamics. If you don't agree, fine, but if you DO think that the $25/mo would be better spent elsewhere as in $25/mo more on a car payment for a Corolla or whatever, then you don't really like the basic car all that much after all. Perhaps you should have gotten a boring, nasty-handling, strange-looking, squirrely, nightmarish Toyota Echo instead. Then you could crow all day long about mileage.... :)
    SHOV6
    For those of you who are changing the oil in their car every 3000mi, keep in mind that modern motor oil will last much, much longer than that, even in a relatively high-revving, small-displacement four. There was an excellent editorial some time back in Car and Driver (?) wherein the columnist spoke with various engine oil specialists, and they basically shook their head in wonder when asked about this 3k oil change thing. They basically said that we are throwing good oil down the drain, which both costs us more money and adds to our environmental problems unnecessarily. They basically said that if you are concerned about engine wear, go at LEAST 5k miles, but the normal 7500mi interval is just fine for almost every imaginable purpose. If you are using a true synthetic, you can easily push it to 10k.
    Keep in mind... The BMW line of cars has a computer that calculates when an oil change is due, based upon the number of starts/stops, engine speeds, coolant temperature, trip duration, and total mileage... And the car in a recent C&D long-term test needed its' first oil service at, get this, 18,441 miles. Even if you chop THAT particular example in half, you still would be over 9k before you needed an oil change... So, in brief, I am only going to do the recommended service interval and not worry a whit about Jiffy Lube's assertion that I need it done every 3k. Perhaps they have a vested interest in our getting a $25 oil change every three months? :)
    And there, my friends, is how you can offset the cost of the lower mileage than you all expect. :)
  • hecknerheckner Member Posts: 1
    I have been reading this site for several weeks and I got a lot of useful information out of it. After ordering my silver zx3 in Nov. I had to wait until January - and I enjoy driving that car it handles beautifully. Coming from Germany it was quite hard to find a car I like. The cars here are so different from what we drive in G. I wanted to drive a small car and knowing the Focus from G. it was amazing to me that I couldn't buy a 4-door hatch back. And the fact that there is only one engine available!? In G. there are 6 if not more. But still, I got great service from my dealership and I don't think that you get the zx3 with cruise control in G. I changed my tires from freestones to bridge stones potenza 730 (205/50/16) and got Michelin arctic lapin winter tires + steel wheels, because I am used to drive winter tires in winter. Regarding the gas mileage. I can feel the pain of you all! My MPG is between 23-24! And the time to drive the car how it should be driven is still to come! I am scared...
    Above that, I love the cargo net and the AS works very well. I was surprised to see that most of the people drive this car with automatic transmission. In G. 95% drive this car with manual transmission and so do I.
    I had no problems so far (no recalls or other stuff)
    k. that's it. Thanks again for the useful information and keep on writing :-)
    Don't think that I can disagree! Points are well stated.
    I ordered the rubber floor mats for my ZX3 from my dealer and they look great! I have a light gray interior but I ordered the black mats, thinking some contrast would be nice. The Focus name is in raised white lettering.
    The carpet mats I'll use in the (hatch)back to protect the floor there. I didn't order the rear rubber mats, thinking that they get hardly any use, but it's an option later on if I need them. It's my driver's side that's been getting all the wear this winter. Too bad they didn't offer this option when I first bought the car.
    Charlie
    Hi all. I've kindof decided not to risk going in to Ford to have this recall done (It's inconvenient, life has been very busy, and I don't trust them). My feeling is that if I ever put weight on the rear seats when they are down, I will check afterwards for the operation of the seat belts and only have the recall done if I see that the hinge and/or belts are not working? Does this make sense to you? Or, is it not possible to easily and properly test the functionality of the rear seat belts?
