Visitor Agreement.
I just bought an 03 GTS, silver with 14k miles on it a few months back. It was fully loaded with all the available stuff except for the action package and was in excellent scratch-free condition with just a few stone chips up ahead. The only flaw I could catch was that the rear tires were still the OEM Yokos and were kind a worn out. The front tires had been replaced. The dealer started out from 20k but I finally got it for 16.9k + taxes. So I think you should definitely push the guy. Play dealers against each other, and ya, check the classifieds for private vehicles. Specially recommended coz I had seen this very same car listed on cars.com by a private seller. By the time I got in touch with his, he had sold his car. But once I got the car from the dealer, I realised that it was the very same car! I called him and asked him how much he had traded it in for, he said 14.2k!! So the delaer made a neat profit of 2.7k for nothing
Thanks and best regards,
Trish
If all combined forces acting on the car allow the engine to rev up to 7800 RPM, the car will run at 178 MPH, since the gear ratio does not change.
If air resistance is a limiting factor then the load on the engine will not let it rev up to 7800 RPM. But then this is also a theory which must be proved.
top speed of 134 MPH.
Would the test in 1999 be for the first batch of 2000 Celica GTS model?
Yes. The car actually hit the market in October of 1999 and the road tests in the various magazines were in either the October or November issues if memory serves. I got my GTS in November of 1999.
Not too sure about that 138mph number. Seems somewhat high. I would believe a number closer to 134 or perhaps a bit lower.
FYI - top speed in the GTS is achieved in 5th. Shifting into 6th drops the rpm too much and the car actually begins to lose velocity. For top speed runs, one must run essentially up against the rev limiter in 4th before upshifting into 5th, taking care that the rpm does NOT drop below 6k.
Or so I'm told......
Are there any aftermarket names that work well with this car? Any I should steer clear of? Any common modifications that are made to this year?
I need to buy another car this summer and the GTS is it. Dealers still have new GTS delivery. I was told the factory is still producing Celicas until their existing inventory of parts runs out. I found 1 new GTS in Southern California. Unfortunately it is the same color as the one we already have.
How can I find out what's available in other dealers? Out-of-state cars may need emission upgrades for California and may not be worth the trouble and the time.
I have been using Autotraders.com, Cars.com, Yahoo's Auto etc..to look for used GTS. There are plenty of used GT in the market but GTS supply is very limited.
Any suggestions for where to search?
So, how long are the celicas going for before they need major repairs? I know Toyota is great as far as reliability, but how long should I expect a Celica engine to last? I always try to put a ceiling on the mileage I look at when I consider used cars, and was wondering, is 60K miles too high to consider when buying? I am planning on using this car about 1500 miles a month, and want to make sure it will last for 5 years.
At any rate, I enjoy toyota having a rep as far as being solid and million mile engines, but was wondering if this applied to celicas as well.
Also -- as a sidenote, is the GTS that much cooler than the GT? :lemon:
The struts were all original and working well. The car was running straight and very stable at high speed. The steering was precise. There was no shimmying or wandering in the steering during lane changes, unlike what I have found in older Honda Accords and new GMs, FORDs etc..
The car had full power. Everything in the car worked well except the rack and pinion unit which was starting to leak. The front and rear engine seals were also leaking oil. It consumed about 1 quart every 3000 miles.
To keep the engine and transmission to last long, you need to replace oil and filter every, say, 5K miles, transmission fluid every 20K miles or when smelling burned.
Overheating does the worst damages to engines. So keep the radiator clean by flushing every 2 years or 30K miles to prevent corrosion and blockage. Use only Toyota's red coolant which is less corrosive than the normal green fluid. Use only distilled water, never tap water, to prevent calcium deposit to block the radiator core.
Toyota's engine and transmission should work reliably for about 300K and Lexus 500K miles, if you do half way decent preventive maintenance like I do. I did all preventive maintenance, oil, brakes, tune up etc.. myself, except a few major jobs like replacing the leaky power steering line and starter.
There was time when the Camry was running slightly rough. I checked the records and found the plugs had not been replaced for 150K miles. I put in new plugs and it ran smooth again.
Regarding the GTS, the engine has special valve design that allegedly pumps out a lot of HP over 6000 RPM. I also has firmer suspension than the GT and 4 disk brakes. It's designed for high-speed racing. You definitely feel every bump on the freeway, however small. I feel kind of tired driving the GTS for 1.5 hours, 100 miles freeway trip, whereas the GT's softer suspension is less tiresome. The GTS is priced about $5K more than the GT.
The only feature that I wish the GT has is the tiptronic manual shifting on top of the automatic transmission, which is fun to rev up in street cruising. If you can put up with manual transmision, you are not missing much. You are more likely to find leather seats and side airbags etc...in the GTS.
The bottom line is I would buy a GT with tiptronic shifting, side airbag and leather seats.
With a GTS, just make sure to buy from an older person if buying used, as some kids have really made this model their street racing darling, and you wouldn't want one of those once they are done with it!
The GTS has bigger rims (the way all the ones sold were actually equipped), and razor sharp handling (including a slightly punishing ride, as someone mentioned). I am sure you will not find one WITHOUT leather, and xenons were pretty common in the early years, and I believe standard for the last year or two? Its power is all above 6000 rpm on the tach - below that point it actully has slightly LESS torque and power than the GT. Above that, it takes off like a rocket, similar to the VTEC Hondas of the mid-90s.
Oh, and 60K miles is NOT too high a mileage to consider buying. Look for records of maintenance.
peterpan: while new Celicas may still technically be available, I believe they stopped exporting them to the U.S. several months ago and they are pretty much all gone. As far as new, check out Longo Toyota's inventory on-line - they are located in Southern California and are the biggest Toyota dealer in the world outside Japan (and maybe including Japan). If they don't have what you need, it is unlikely that other smaller dealers will.
I have also noticed the phenomenon you mentioned - owners are hanging onto these Celicas a lot more than the Celicas of the past, and used ones are hard to find. There were only 150K or so sold in the entire model run throughout the United States, so it's not a huge population. AutoTrader is a good source for that, also if you are thinking about possibly looking for a certified car, Toyota's own website will help you locate the car you are looking for.
Since the GT engine is completely different from the GTS engine (larger bore/shorter stroke in the GTS motor), which Celica engine is the same block as the (std.) Corolla engine?
There have been no problems with either engine in Toyotas, to my knowledge. However, a couple of different magazines mentioned that when Lotus did high-speed testing on the GTS engine for the U.S. Elise, there were "durability issues", annd Lotus beefed it up some more. Never saw anywhere that these "issues" were elaborated on, so I don't know if it was just extreme stuff that only Lotus would worry about.
I've heard the same thing regarding the 'Lotusification' of the GTS motor. For some reason, I think it had to do with oiling issues under high-g loads but I could be completely off base. It's been known to happen from time to time (the offbase part; not the oiling issue part)
I've always wondered why in the heck Toyota would kill the MR-2 when they should have dropped the GTS engine in it to offer a low cost alternative to the Elise?
Frankly, I would be more learly of 300 hp in the hands of a novice in a Mustang than 180 hp in the hands of a novice in an MR2.
Toyota is still making the Celica. That's what the fleet managers of a few dealers told me. They are mostly either white of black, with cloth seats. They told me I can order any color I want for MSRP with 6 weeks lead time.
Longo has 1 white GTS. I was at the Longo Lexus dealer next door and went over to look at it, just to check out color compatibilty. White color looks OK on this car. Longo Toyota usually has the highest prices and the rudest sales people on earth! I would not buy from them.
Other dealers do have Celicas. Cabe in Long Beach has 1 red GTS. Carson has 1 white. Pasadena has 2 GTS. Kearney Mesa has 1 white. You just have to call and work with them.
I will do another 100-mile test run. If it wears me out, I will probably buy a GT with softer suspension and more comfortable ride.
As for Longo, I am surprised at your response, but certainly they can't please everybody. I have a number of friends and family in the L.A. area, ALL of whom have bought from Longo and gotten a significantly lower price than other dealers they cross-shopped. But I just thought of Longo because it has such a large standing inventory. I DO think it is telling that in a huge and heavily populated area like the LA basin, you only found a half dozen Celica GTSs...they are definitely down to the very last of the new ones.
It is sad we won't have a Celica here any more. :-(
My work load was light during this trip, However, I still feel a deep fatigue 24 hours afterwards. This is unlike any other trips that I have done with other cars.
The fatigue must be caused the rough ride with the very firm suspension in the GTS.
I felt no soreness or pain after this 200 mile 3-hour freeway run in the GTS, just deep fatigue similar to jet lag after 10-hour flight across the Pacific.
I feel much better this week, so I will have to redo my test run.
I was at the Porsche dealer this week and took a test drive of a Carrera. It retails about $75K, has 320 HP compared to 180 in the GTS. The new 05 Carrera type S retails about $180K.
The Carreras are very nice, solid cars. It's faster but is heavier and the steering is also heavier. Porsche's tiptronics shifting is very quick and smooth, while the GTS shifts slowly. The Carrera has a lot of engine, wind and road noise. The GTS seems to have quicker handling and lower wind/road noise. While the GTS I4 engine has the high-pitch whine of jet engines spooling up, the Carrera's flat 6 rumbles loudly in low frequency, sort of like the big Harley bikes.
I wouldn't want to spend that much money for a set of wheels and make the same kind of noise as the Hells' Angels in my neighborhood. Do I look like the kind of tough guys with leather jackets, tattooed forehead, cruising around in noisy cars, terrorizing women and children?
There is no way I can justify paying 3 times the GTS' price for the same amount of fun. Besides that I don't trust German engineering. German products have lost a lot of confidence among consumers with lower reliability and high life-cycle costs.
I also think that your feelings of fatigue after your stint in a GTS could be attributed ENTIRELY to the flu. As a 42 year old with occasionally back/neck stiffness, I can honestly say I could drive my GTS for a solid 8-10 hours with no problems. I definitely think you should redo your test run.
Well, it's kinda hard to NOT mess up the valves if you downshift at 75mph and grab 2nd gear instead of 4th. :surprise:
Don't think that's really the fault of the engine. More of an issue with the shifter (both the one installed by Toyota and the one sitting behind the wheel IMO).
Sincerely, Toyota94
The only reason I ask is that some of those things you mentioned have a slightly bogus ring to them, but I could be wrong. For instance, replacement of all fuel injectors at that mileage would not only be unexpected, but also would have given you significantly noticeable symptoms, like poor running and idling, lots of hesitation when accelerating, etc. And why all four injectors?
Yes, it is possible that the radiator could develop a crack there, although for it to blow during a pressure test is mighty "convenient". No, if performed properly, the pressure test itself, and the resultant radiator failure, should not have harmed the motor in any way.
On the plus side, a replacement radiator is something every older car will need sooner or later, and not super expensive, so if you plan to keep the car a few years it is a good investment.
I say this only because Toyota are generally fairly durable, and you have a model that has proven to be particularly durable. Many of the extra things you paid for may not reflect your car's lack of durability, but rather the dealer's ability to recommend every single unnecessary maintenance operation he can think of in order to make a better profit.
Edit...I just went back out of curiosity to look at what you mentioned you had done, and holy crap! They asked for $2500 for this???
"I recently brought it into the dealer to have its first major (60K) tune-up + its annual state-required safety inspection. The dealer's mechanic also found the following "problems": the timing belt needed to be replaced; the power steering fluid was thick; the brake seal hose needed to be replaced; the ignition wires were arcing; the temperature switch (thermostat?) opened only half-way; the antifreeze was now "5/0" and should be "25/0"; and the fuel-injectors (4 of them?) needed to be replaced"
60K service on this car should run around $400 at a dealer, and would INCLUDE replacement of the coolant they found so out of whack. Another $100 or so should buy you a new thermostat. State inspection would be around $100 where I live, so that's $600.
Timing belt replacement including new water pump: $500 MAX, and then they should have reduced the price of the thermostat replacement. Now you're at $1100 or so.
Fuel injector treatment: $100 or so, and such a rip-off at any price.
New wires, $75, fresh P/S fluid another $75. Both acceptable after this many years. What are we at, $1350?
I don't know what a brake seal hose is, sounds imaginary, but there are brake hoses and brake cylinder seals, maybe it was both? And then what, another $1000 for a new radiator? Just for future reference, Toyota OEM radiators (the kind the dealer would probaby use) cost hundreds and hundreds of $$ more than an aftermarket radiator, which would get you at least three or four years and save you big bucks.
Except for the brake seal, I can't fault the car for much at this age, and of course Toyotas in the 90s were more expensive to maintain with that timing belt coming due for replacement every 90K. I haven't checked the interval for your particular car, but I hope you did. Dealers recommend timing belt replacement every 60K miles to make more money, Toyota itself only recommended replacement every 90K miles for most of the cars with this engine. If the dealer did that little "service" early, that would have been $500 or so you could have saved right there.
I hate that dealers push so hard to sell their most profitable service items, even though the service to the customer is sometimes marginal at best, and often not warranted based on the manufacturer's own recommendations.
Have you used the vehicle appraiser tool under the 'Used Vehicles' section of Edmunds to try and appraise that car?
http://www.edmunds.com/used/1995/toyota/celica/4310/options.html?tid=edmunds.u.prices.utmv- .vdpprice.13.Toyota*
Having had both cars, I would add that you will get a SIGNIFICANTLY less tacky interior, better climate control (always had a hard time getting my Celica to cool down on hot days), and slightly better outward visibility, as the Acura does not come standard with the rear-end spoiler which totally blocks rear view in the Celica.
The Acura also has a better shifter, and of course leather seats. The ride is less jittery, but as for handling it is a wash between the two cars. And the Acura has more road noise inside.
Oh, and if you care about cupholders even a little, like I do, you will be only too glad to jettison those STUPID cupholders in the Celica, which block your arm every time you want to shift, if there is anything in them! :-)
Footnote: if all this has you thinking you want to get an RSX-S, you should bear in mind that the '06 Civic SI has all the same mechanicals PLUS a limited slip diff, only in coupe form, not hatchback, for thousands less $$ - this car is just beginning to arrive at dealers as we speak, and should be well stocked within a month or so.
Plus, the GTO is all engine - the handling and much other stuff about that car are just so-so. If you want a cheaper car with the Corvette powertrain and have $10K more than the cost of the RSX-S to spend, it is your most powerful choice for the money.
The 350Z is heavier and totally claustrophobic inside. Apart from that, it has much to recommend it, and if that is the type of car you are thinking of, definitely look at the Mustang GT as well. (same price range)
I almost traded it for a GTO but couldnt do it because I didnt want to give up the handling, brakes, stereo sound etc. I am hoping the 350Z would be a good mix of both cars - handling and some better/more torque.
Spend the extra money for the next step up - RX8/350Z/Mustang GT - and you get more power, but with a huge fuel economy penalty. In regular driving, those will all be 20 mpg cars, far from the Celica/RSX's 30 mpg. But if you have the money and don't mind spending more to buy and then more to gas up, they definitely have their advantages! :-)
The poster above is right - the only one of those three with a mix of handling and comfort close to the Celica is the RX-8. The 350Z is a rock-hard ride, and the Mustang has sloppy, heavy handling.
also to all the other responses. i am not a fan of mustangs let alone fords. i live in maine and need a decent car in the winter and mustangs, 350Z's and whatnot would not be the best option..although i am fond of the 350Z but its just not resonable with gas prices, and a winter car, and way to pricy for me.
Two different mags recently did comparisons that included the RSX-S and the Cobalt S/C. In one, the RSX won by a goodly margin despite being the much older of the two, but in the other one the two cars were neck and neck - they liked that the Cobalt had much better torque for round-town driving and stoplight drags. Worth a look perhaps. It is certainly the right price, as long as it is not being marked up.
Can you tell where the noise is coming from? Front/back, right/left? Start there. I suggest you jack up the car, take the wheel off, and tap the shield that is around the rotors. Is that the sound you hear when driving? If yes, look for a shield that the garage gorilla BENT when he removed the brakes. One of the shields may now be hitting another part of the car as a result of being bent. Most likely you yourself can use a crowbar or such, and bend the shield back away from whatever is contacting it. Be very careful not to put leverage or torque on critical parts. If you're not sure, just find a mechanic to check it for you.
One other possibility is that the new brake pads do not have clips, and they are rattling around. I think more than likely in that case, you would feel a small clunk, a shift in the pads, when you step on the brakes, rather than what you currently are experiencing.
Just recently, there was a pebble inside my GTS's front right rotor "hub", and it would clang against the shield as I drove. Loud like an annoying bell! The pebble must have shot into that space from above, past the caliper or such. I could not remove it from the open available space below, the gap is smaller than the pebble. So I finally reached inside with some forged needle-nose pliers, and crushed the pebble, 3 times, until the pieces were small enough to fall through the crack.
A clutch that's just starting to slip perhaps? Maybe the clutch is just starting to slip, revs build a little higher than normal and as you approach the shift point and lift the throttle a bit, the clutch 'catches' and the revs drop without the vehicle speed dropping. The engine would seem a bit softer since now it's only turning 3k rpm instead of closer to 4k.
That's my guess.
also don't feel the "softness" in the motor.
