Mazda 323
I got a used '93 Mazda two years ago, stick shift
w/ air condition. It has been the most economical
yet reliable little commuter car I have ever own.
Compare to my wife's Sienna minivan it cost almost
nothing to buy and operate. It's got 100000 miles
on it now, leaks a little of oil from the value
cover gasket and the camshaft oil seal, but still
it starts everytime at the first crank, no matter
how hot or cold the climate it is.
It just keep running and running ! And it's seat
is more comfortable than any vehicle I have ever
own.
I wonder if there is any 323 owner in this town
hall who also loves their car ?
own.
--good headroom/visibility
--confortable seats
--enough power for highway
--good stability for a small car
--excellent price
--Good standard features (60/40 rear seats etc.)
Negative points
-on its 3rd head gasket
-on its 4th driveshaft (have replaced both twice..only last 2 yrs each)
Leo
You are right, don't pay more than $1500 for a 1990. And get youself a 5 speed one if you could drive one, it is much more nimble than the automatic version.
The car is going to be used to teach my wife to drive. So we need something reliable. She'll probably only put 4-5,000 miles a year on the car. She wants an automatic. Thanks for the help. I'll see if I can get him down in price.
Leo
great except for one thing when its cold and wet
it doesn't start, it just cranks and cranks, but doesn't start, its a 1992 323 with 104K and a five speed, can anyone help me out? my spanish
teacher, who's a car enthusiast, and has owned around twenty mazda's, says its probably the distributor cap getting moisture in it, can anyone corroborate this? i'm also looking into mazda RX-7's, anyone know about em?
The 323, especially the strip version, on the other hand, is the car for cheap guys like myself, who is constantly looking for good reliable transportation for the least money.
that no one has been able to solve. If you have advice about how to solve it, or if you know
where I can get good advice (via another web-posting or some other source), I'd really appreciate
hearing from you.
The pattern of stall-outs is seemingly indecipherable. It will stall on the highway or just going
around the block. It usually gives a hesitation or two, and the accelerator becomes useless for
10-60 seconds before it stalls completely. It's a standard transmission, and if necessary while
driving I can turn the car turn the car off as the stall threatens and then turn it back on–and it then runs fine again. Likewise, if it stalls out completely, I can turn off the car and then start it
immediately with no problem. The interval between stall-outs is usually at least a day and
sometimes weeks. Go figure.
This problem first occurred in about 1993. No one could solve it, but it disappeared. Then it
returned a few years after that. And now it's back again, off and on since the fall of 2000.
Here's a record of what my latest mechanic has tried:
–Tried to duplicate problem but couldn't.
–Completed tuneup: sparkplugs, cap, rotor, air filter, fuel filter, oil change.
–Checked for computer fault codes. Found code 17. This code refers to the oxygen sensor, the fuel pressure regulator, fuel pump, and the computer itself.
–Fuel-pressure test showed fuel pressure to be just a touch above normal (if it was lower than
normal it would have been a good chance that it was source of the stalling problem). This test
was done with the car hooked to a gas analyzer which registers the fuel/air ratio.
–Replaced oxygen sensor and fuel pressure regulator, and checked these new parts with the car hooked to the gas analyzer. The car was run for quite a while and monitored throughout the day but never stalled, nor did the fuel/air ratio change at anytime. Car stalled out several days later, and a few more times after that.
–With no facts to condemn the fuel pump or computer (which are the only items left that the fault code refers to), the mechanic feels there is not much else to do except replace the fuel pump and/or computer. But these items are not cheap and there is no guarantee that they will fix the problem.
Please help. Thanks!
--ny10
Leo
Anyways, we took our car to a mechanic and he changed or cleaned something...which seemed to work for about a week but then it started up again. I decided I should change the PCV valve becuase it blocks up and supposedly can cuause that problem...and it seems to have worked. It's only like 5 or 10 bucks so I'd try it. You can get it at any auto parts store. It's a little black thing on the top of the engine with a 90 degree turn to it...one side is in the engine, the other side has a small hose attached to it. Actually you can take it off and try to clean it, you should be able to feel something moving around innside.
Hope it helps, not sure if you already tried it. I agree, this is one of the best little cars you can buy. Way better than a honda civic of the same year...more power and quite nimble this car.
Other than these little things it is a solid small car.
Regarding the trunk leak you can find it with the help of a garden hose. Sometimes it takes a while to figure out where the leak is.
seemingly most cars die in the 200K range which gives me abt a year and a half on both cars..wondering if anyone has more info.
The thing is, I've heard a lot about Mazda's bad reputation for transmission problems. Someone I know who had a '99 Protege has already had his replaced and he told me his mechanic regularly deals with Mazda transmission.
Has anyone had these problems with 323's? I need to know whether I should buy the car or look for a similar model by Honda or Toyota.
And btw i think the price is a bit steep.
Also, as this will be my first car (I'm 28. I was a late bloomer.) I'm trying to figure out if they're really as low-maintenance as rumour has it. I understand the parts are a little dear, but oh well.
Mostly the car is destined for city driving with a fair amount of time on freeways and the highway out of town. I'm capable of doing basic maintenance myself (filters, fluids) but I'm wondering what major items are prone to dying on these models so I know what to budget for a slush fund.
Thanks in advance from the newbie!
-Betty-
Revka
Hatchbacks & Station Wagons Boards
Oh I did that already. I walked into the dealer's office with about 15 pages of Edmunds and Carpoint data, a Carfax report and a lengthy checklist of stuff to look at before I took her out. I demanded a safety, title documents... the whole enchilada.
Car dealers hate girls like me.
The asking price was in line with LemonAid and the Edmunds prices (after conversion) so I didn't haggle too hard, but I tried for the sake of appearances. The Forms Must Be Obeyed.
Of course, I STILL managed to have problems. *lol* Apparently I have magical invisible power steering on my model - I can't find a resevoir, even with a Haynes manual.
At the moment, she's undergoing a vehicle check at Canadian Tire so that if anything ELSE is wrong, I can specifically ask that it be fixed. (She idles high, she whines a bit when changing gears, and the one that worries me - she wanders all over the damned place... I think the wheels need to be aligned.)
I bought her, and she runs like a kitten when she's *warm*. It's mostly aggrivating little things. And for those who don't think little things matter, sleep through a leaky kitchen faucet sometime.
I'll keep you posted. Thanks for the help.
Revka
1. gas tank leak (~$300 canadian to replace with a brand new one)
2. exhaust (cost varies depends on OEM or not)
3. radiator leak from the plastic top (~$200 canadian to get a brand new metal one)
4. timing belt water pump (maintanence item, $400 canadian parts and labour)
Once these big items are taken care of you might have a few years of trouble free (well, almost) driving.
A) Is this dangerous (i.e. am I risking my own or others' safety by not fixing it immediately) or merely annoying?
C) How much will this type of repair cost (I live in Missouri, FWIW), and what's your experience with having it done at a dealer vs. at a private shop or transmission-only repair shop?
I've seen some helpful posts on this forum and would like to thank those who've helped keep it going. Good job, everyone.
If is quite amazing how durable these small mazdas are. Too bad this kind of quality are not shown in the 626 or MX6.
We just put snow tires mounted on Miata rims on the car. Looks great.
Should I get rid of it?? Or is it worth keeping??
If you have some spare change (like $20-25K CAD), you can get a new PRO LX/ES for 48mths/0% interest and get a great new car. The PRO is turning into the 3 next year so I think dealers will be glad to sell you one for a good price.
If you can't you gotta look at used cars...
Dinu
Tuesday nights - 6-7pm PT/9-10pm ET.
