-June 2024 Special Lease Deals-
However, its ride was stiff (hard) and it was noisey. By that I mean there were no rattles but the engine was louder than what we were used to especially when accelerating or traveling at expressway speeds. The automatic shifter was just plain goofy, something CU has also commented on. The 4-wheel drive was a waste in flat Chicagoland territory. Perhaps we were spoiled by the car we traded in on the Forester which was a 97 Towncar, which we loved but decided that it was getting too cumbersome in crowded parking spaces and our underground garage.
After looking at a lot of cars we bought the 04 Passat (GLX V6 sedan) and in the 6 months we have owned it we have enjoyed its smooth ride, its size, its good handling, and especially its quietness. For us and our usage and needs, the Passat is far superior to the Forester.
I have a friend in CT who had a Legacy GT that also died last winter, fried head gasket. His mechanic up there said he'd seen at least 4 of the same last winter.
It's definitely scaring me away from Subies, which are near the top of my list when I have to shop for a car next. There's no excuse for head gaskets at 100k or less on a car that's been properly maintained IMO.
Mine has 69k miles, and I'm still on my original brake pads. Repairs have cost me exactly $0.
Passat competes at a price level above the Forester, if you compare the Legacy it's more of a match, more refined, quieter, etc.
Subaru has stretched the warranty on head gaskets to 8 years or 100k miles, so apparently they agree with you.
Besides, it's been nothing compared to the problem VW had with ignition coils, not even close.
-juice
Krzys
In the case of the Passat, it actually gets Audi's Quattro, i.e. the center torsen diffy with traction control added to both axles.
I did some research and found a couple of limitations. First, it can only send up to 67% of power to either axle. Also, while a torsen is fast acting, it's still mechanical and reactive.
Subaru's VTD starts with a 45/55 default power split, but that AWD system can send 100% of power to either axle. It's also proactive in that it'll shift power to the rear axle when you're on an uphill, to the front when traveling down hill, and so on. Power shifts before there is slippage, so I consider it proactive.
However, with available stability control, the VW manages both axles, i.e. power split from side to side. The Subaru has a rear LSD only, so the front axle is not managed.
In summary, the OB XT isn't limited as to how much power can be sent to one axle, plus it can be proactive.
The Passat, however, manages both axles.
On the road both are plenty more than enough, it'll depend more on the tires you have mounted. The OB does have a lot more ground clearance so it would still be the better choice in deep snow.
The post above hints that a Legacy GT would be more comparable to the Passat, and I'd have to agree.
-juice
VW 1.8T compares well to basic 2.5 Subaru engine.
Subaru's 2.5T requires VW to bring 3.2VR6. Passat does not offer comparable engine to 2.5T, for now (W8 had comparable power but was much heavier - it is discontinued by the way).
Krzys
PS AWD system is minor difference in this case. Suspension, tires and power clearly make them different animals. IMHO.
VW has the opposite, base is turbo and upgrade a V6.
W8 was nice but they priced it too high.
Nice to have lots of AWD choices, though.
-juice
The Passat is so much newer and lower mile that it would negate any reliability advantage the Subaru might have, IMO.
Check that leak, however, on the Passat.
Good thing about the Subie is that if the head gaskets have not failed by now, they probably never will.
I might keep shopping and try to find a lower mile Subie. Keep something in mind - the 2.2l in the Legacy wagon is Subaru's most durable engine. Back then the Legacy had it, the Outback did not.
-juice
PF Flyer
News & Views, Wagons, & Hybrid Vehicles
The Subaru Crew Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
Real-world mpg for Subies belonging to Edmunds members.
Diesel fuel costs more than premium gas around me, make sure you factor that in. I do think the Passat's excellent range would be an advantage. But just remember as they fase in low-sulfur diesel the prices will only creep up more.
-juice
If it has been well-maintained, the '97 would be a sure thing in my mind. But, I'd watch out for electrical problems that exist. Drive it; play with it; drop your offer based on any deficiencies. Don't go for it if you hear any grinds, scrape-squeaks, or if the tranny hesitates when put in gear. Look at the coolant and the valve-covers (bottom rear corners) for any signs of leakage. Subarus are good cars but they only age gracefully if they are very well-maintained.
That's my $.02. I haven't much experience with VW - I'm just going by price as preference.
-juice
I can't give you a perfect answer, ie wagon vs. wagon. However I have
just purchased 2 new vehicles in the last 5 weeks close to what you are
after:
1. Got the new 2005 Passat TDI GLS sedan (auto, silver) on 4/30/2005 (19
miles on odomoter). My morning commute (8 miles 40-50mph on 2 lane,
then 40 miles I-5 at mostly 70mph) gets me about 39-40mpg so far, a
couple trips though have seen 42mpg. Return home nets about 1-2mpg
less. Car has about 2700 miles now, still breaking-in I guess. Mixed
driving thus far (w/in-town, stoplights, etc) is netting about 34-35mpg.
I use Flying-J diesel, and add about 4-5 oz of Diesel Kleen each
fill-up. My Flying J here has been $2.12/gal (cheaper than unleaded)
but is currently $2.21/gal. Car now has the optional VW 17" wheel/tire
set on it, I put about 38psi front, 44psi rear in them. This set was
included in my original deal; dealer was stupid and said they would have
to 'order' them in, right; then finally decided just to take them off
another Passat which they did. Handling improved immediately (drove
w/16" set first 2 wks), ride is a bit firmer, but noise only increased
very, very slightly. However, the 16" set is a softer, more 'luxury'
ride so consider that. I have no idea how mileage is on a Wagon version
of this car; I seem to recall though that the weight is quite a bit more
for the wagon...?, as opposed to....
2. We just picked up our new 2005 Legacy GT (non-Limited) wagon (auto,
Regal Blue!!) on 5/31/2005 (100 miles on odometer); I had a very hard
time getting exactly what we wanted. Only have about 750 miles so far,
have seen about 22 mpg in all mixed driving; it is VERY hard not to go
fast or stab the accelerator, it is an absolute rush (yes, yes, trying
to keep 'er below 4000rpm, etc, etc), I use the Sport Mode a lot, and
play with the paddle shifters too. According to Subaru specs, the wagon
only weighs about 60lbs or so more than the sedan (again, non-Limited,
auto tranny), so for me it was a no brainer. I had driven the wagon
before (auto) and the sedan in both versions. Definitely, the manual is
even meaner and way quicker off the line, but once moving the difference
is not quite as great. I haven't even check tire pressures yet, so need
to do that, etc.
One thing is for sure: these cars' suspensions do not compare. The TDI
sedan is nice and is very fun in its own way at highway speeds and its really satisfying gettig the great mileage, but the Subie is a whole 'nother story brother.
For you, you will have to consider how many miles you drive and see what
the cost diff will be; maybe insurance will play a role too. For us, we
were doing 35k miles total (2 vehicles) so I was able to afford one of
each....
BTW: we have replaced 2 SUVs: the '99 Trooper (117,000 miles,
outstanding reliability for us) is gone; the '98 Landcruiser (100,000,
also outstanding) is now listed too. Our new 2 payments + fuel on 2
vehicles = 1 payment + fuel on 2 SUVs (no change in insurance for us);
plus, we have 2 new vehicles and are avoiding higher mileage mandatory
maintenance costs, etc.
Good luck to you!
Ken
I just traded in my '01.5 New Passat Wagon with 54,000 miles on a 2005 Subaru Legacy 2.5i L wagon. I don't know if the '98 has the same problems but mine was a maintenance nightmare from the beginning and wallet drain after the two-year warranty ran out. It's a shame because the Passat is such a great car. But the last straw was when I brought it in for service to the VW dealer on the transmission (covered under the 10-year/100K mile powertrain warranty) which was done for free. However, the service folks said I had to have the rear brake rotors and a motor mount replaced.
Unbelievable. I didn't even have to change the brake pads on my 93 Mazda 626 until 100K miles. Never had to change the rotors.
You might even get all your maintenance for free.
Congrats.
-juice
Subaru - cars before 2002 (I think it was 2002) were prone to head gasket issues.
Krzys
Thanks again,
roadscaller
As for the VW just make sure you don't buy the first/second model years.
I've had both a Subie and a couple of VWs.
A.
Search the web for another forum that specializes in VWs. I can't tell you the name here (against the rules), but the name rhymes with fortex.
I've been reading that forum for a couple of years (I own an 07 Wagon) and I haven't heard of anybody reporting your problem.
Good luck and keep us posted.
Question is, can you find a Subaru from 2003 or later for $7 grand? They hold their values well, so that may not be easy.
If a small wagon will do, consider a 2003 Impreza, or maybe a Protoge5.
Most manufacturers stopped making wagons and shifted instead to crossovers.
Anyone have any comments re: advantages of one over the other in the 2010 models?
Which Sub did you get; is this the Outback? How good is "fairly good" mileage, something in the low 20's?
You saw how much snow we got this year in the mid atlantic - the ground clearance and AWD were a godsend for us. My daughter had a sleep over the day of the 2nd storm and we thought she was stranded at her friend's house, though I was able to pick her up with the Forester even on unplowed roads.
We got sleet last night (here in Potomac, MD) and we should get more on Tuesday night as well.
This year has been a bit unusual, but we will always have at least one AWD/4WD vehicle in our fleet.
I haven't sat in a Passat lately, but I did check out a Tiguan and a Jetta wagon TDI. The Jetta was very nice, great interiors on those. The Tiguan unfortunately does not have the same interior, it's easily one or two steps down from that Jetta. The padded dash, fabric headliner, and wrapped pillars are all deleted for the Tig.
No regrets here. Best of luck shopping.
If you want the mileage champ get an Outback 2.5i CVT - at 80mph it tachs around 2000 rpm. The tall gearing gives it better mileage than the smaller Forester.
The passat interests me more than the outback because it is a car not a SUV. Has anyone drove both of them?
My Wagon is very different from the ones that you can buy today. You can no longer get the 3.6L engine, nor 4Motion. I also have the Lux 2 package, i.e., fully loaded. Unfortunately, they've decontented the Passat quite a bit. The CC has replaced the loaded Passat sedan, but there's no equivalent loaded Wagon anymore.
I'm not allowed to post other forums, but google for vw forums for a lot more input.
Yours was also based on an Audi platform, right? IIRC that's no longer the case.
AFIK, they are still being made on the same platform. Maybe Audi moved on to a new one? :confuse:
