I agree totally with your synopsis. On my former 850 turbowagon, it never failed that any stop resulted in a multi-page service page for lots of money. Assuming I had to be near the end on repairs, at 80k miles, I went to a independent Volvo service shop for a checkup; he explained all the things I should expect by 100k. It was $6000 more, and nothing was on the base engine. I sold it shortly thereafter.
Just my experience.
Mike
James
2000 V70 & seem to be feeling/hearing noise coming from the steering
column (only in the morning when it is cold out). Obviously when I take
it to the dealer the car is warmed up & nothing can be heard. How did
you describe it to them, given you are talking about a similar problem.
Kulfon.
PS I will not get into the cliking noises coming from my auto. transmission!!!!!!!!!!!!!
They also readjusted the gear selector since it was sticking.
- always at startup but not every startup
- could be driving fwd or rev
- number of clicks varied from 2 to 5 times
- disappeared once underway (by the time I reache d the end of my driveway)
- not temperature or humidity dependent
Hope that helps.
James
By the way, I just received my volvo oil filter wrench from IPD and it works like a charm. No more damaging the oil filter sleeve and it comes off quite easily.
The symptom occurs only sometimes, especially on cold days. It affects the rear right door, and sometimes the tailgate lock as well.
I open the door locks using the remote control or the internal central locking button. I can visually see that the door lock levers pop up on all doors. As a person tries to open the rear right door using the outside handle, I can see how the door lock lever pops down all by itself, and the door locks itself! It happens over and over again - as the person on the outside pulls the door handle - the door locks itself...
Any advise?
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
How do I get the full text of these SB's? All I can see are the 2 line descriptions.
BTW - Of course I already went to the dealer regarding this issue, and of course I received the standard answer - "we can not recreate the problem and there is no reports of similar issues"... but then again who trusts dealers?
Clocked ~28,000 miles to date. MA roads are bad for my tires... I have the P6000 (early V70, as VONN1 said) - and already had to replace 2 tires -both due to road damage. One developed a nasty bubble, the other was a bad flat.
Btw, sometimes just giving dealer the basic nhtsa TSB description/number, from our Maintenance Guide, may be enough. They can follow it up with any corresponding manufacturer information they may have in their computers.
You said: "Of course I already went to the dealer regarding this issue, and of course I received the standard answer..."
Have you tried addressing this issue with someone higher up the ladder (i.e. service manager)? That might be more effective. If that doesn't work, my next suggestion would be to try a different Volvo service. Good luck, and please keep us posted on your situation.
Revka
rash when a customer mentions writing to Volvo
in NJ to complain about their service... I have
a meeting set with him for later this week.
I gave him the TSB's numbers and asked him to get me a copy of these.
Will update... thanks again.
Over 25K and everything is fine. Took of the 17" P6000 and put on the 16" Michelin Artic Alpins for the winter. I am not having a problem with the ISOfix/Latch system, I am using it with a century smartfit base, I purchased a separate strap that century sells. We have a britax on the other side that is not able to use the ISOfit. The care is now a two adult car but we saw that coming.
As for your P6000's, I have a set on the Mazda and I had to replace two after last winter. Both front tires had slipped bands. I will not be buying these again when they all wear out.
I think that my problem is related to static electricity... but am not sure. It seems to be aggravated when it is cold and dry, and I have a child in my arms (thus "charging" myself with the friction of winter coats - like shuffling your feet on a carpet in a dry day).
It also seems to happen more when the car is dirty (road salt etc.) - which leads me to think that one of the solutions is to wash it every week :-)
Have you noticed any specific conditions when it happened in your car?
Also, although a little far-fetched, it may be related to the well documented problem with the remotes and the security system.
Dan
The asking price is a bit steep. At that mileage, Edmunds has a $2300 downward adjustment to TMV. You should use the calculator to find out what the TMV is in your area, with the options that are on the car. In mine, it was under 20K.
The 2 wheel models are a better bet. Check the technical service bulletins and recalls, and make sure all those have been done on any s/v70 you look at. If so, most of the problems will most likely have been sorted out in the warranty period. Volvos are pretty reliable from a "not leaving you stranded" perspective, but they have their share of annoying electrical issues that can drive you crazy if you let them.
http://www.planetark.org/dailynewsstory.cfm/newsid/14597/story.htm
.....have electromagnetic fields up to 80 times higher than levels considered safe, a study published last week said....
Also FYI, the static electromagnetic field of the Earth itself is 25 microtesla. You can look it up.
Volvo has drawn a power cable from the +node on the battery to the stuff in the front of the car. The magnetic filed coming from the current in the cable is around 1-18uT, depending on where you measure it. The original article don't say anything about the frequency charactheristics of the field so one can not tell whether it's safe or not. If it's low frequent or even static it should be no problem, but if it mostly high frequent the measured values can be considered a bit high.
I am wondering how we can independently verify these claims of high EMF. There are several other vehicles with batteries located either in trunk or rear seat and i have not ever heard of any concerns regarding any vehicle but the Volvo. It seems to me that it is something that would be evident on all these cars, not just Volvo.
Obviously the Volvo seat comfort, ride, and overall "grin factor" blows away the Buick. My concerns are reliability, repair cost, seating space with a child seat (does the child seat in the middle really eliminate the other 2 seats?), and reports of Volvo's indifference to disatisfied consumers. Any advice on problems to look for on these vehicles before buying? Opinions on whether to turbo or not? As a former BMW owner, I could stomach high repair costs because they were infrequent, and I knew high resale value was in the bank. Is Volvo in the same category?
I have a child seat in my 2001 V70 and yes, one seating position is eclipsed by the child seat, if you mount the child seat in the middle (safest) position. In my car, its the right rear that is unusable due to the seat covering the latch for the seat belt. Maybe Volvo has addressed this problem in the 2002 model, but I havent checked.
Yes, go with the turbo. Can't comment on US service but my service in Canada has been very good. Little problems with the car. I doubt resale would be as good as BMW, but you won't get a similarly equipped or size BMW for the money anyway.
While you are at it, take a look at the Saab 9.5 wagon. I have a 2001 9.5 sedan and love this car. Should be able to get a base turbo wagon well equipped for $30k US I would think maybe a bit higher. However, the Saab is a heavy depreciator so lease only I suggest, or look at used ones. The Saab wagon does not have a third seat option like Volvo is this is important.
I can't comment on a 'program' car but would generally stay away from loaners or rentals unless heavily discounted (>20%), especially with turbos as they may have been ridden hard and put away wet
1. I can feel vibrations in the steering wheel and even in the throttle at speeds above 50mph - The dealer has always claimed that my wheels are out of balance and I have had these rebalanced thrice in 36000 miles at $40 a pop. The wheel balancing seems to mitigate the problem somewhat, but not entirely - which leads me to believe that there are other problems. I also find it hard to believe that anyone would design a car that is so sensitive to wheel balance. The dealer could any problems with the suspension. Any thoughts?
2. The wind noise is awful at speeds over 40mph. It seems to be roof related (may the rooof rack). Has anyone had this problem and if so has removing the roof rack solved it?
