Are the racks and boxes sold by Volvo made by Thule?
Is the fit of the Volvo multi-purpose rack same as Thule?
Have you found a significant price difference between getting the equipment from Volvo vs a ski shop? To date I am finding Volvo to have competitive "sale" prices.
Over 26k on our '01 T5, everything is fine, no issues.
Concerning your questions on the Thule Racks and Load bars - most of the roof boxes are made in a single factory (not sure where) and are then branded. I think they are built to specs set out by the branding company. So in effect the Volvo and Thule boxes are made by the same people with a sightly different design.
As far as the load bars are concerned - the Thule set up is a little more versatile. It uses a 415 foot kit and a standard cross bar. I have a 2001 Honda Odyssey and a 2002 V70AWD and the Thule kit works on both. I've had 4 bikes on the roof and a combo of 2 bikes and a roof box and verify the Thule racks are very tough (read: sustained high speeds are not a problem). They also seem to have a tougher attaching design (but you have to buy locks).
As far as ski shops vs the dealers - I think the shops are a little more prepared to deal. You can also buy on-line though the Thule web site. Check out the Packasport boxes though. Having had both a Yakima Space Booster and the Packasport I can say without reservation that the Packasport is way better. Tougher, better looking, more aerodynamic (quieter), better locking mechanism - opens and closes itself with hydraulic struts holds more and attaches more easily. They are about double the cost though.
But I have seen many other people using this weight oil in CA.
Also, what filters do you recommend and where is a good place to order them online?
1. Does anyone notice excessive squeaks and rattles?
2. Any recommendations for a product to protect the plastic molding?
I have a 2001 V70 2.4T with P6000s. The specs have a wide range of tire inflation - 28 - 38 PSI or so - remarkable to me. When I first got the car, I thought the handling was terrible and it seemed to want to float on the road. Then I discovered the tire pressures were set to the low end of the range. Increasing the pressure to 32-34 lbs made a world of difference in the handling. Some might find the ride a bit harsh, for me it's just fine.
Don't leave it up to the dealer, they seem to routinely set it at low pressure for the soft ride.
Higher pressures will lengthen tire life, enhance handling, and are the *only* way to safely carry the full load capacity of the vehicle. Lower pressures give softer ride and softer handling.
And don't forget the Explorer / Firestone fiasco ... there is a real safety issue, check that tire pressure!
Also the Owner's Manual doesn't address break in at all. I have put about 1300km on mine (delivered with 32km). Mostly on the highway at varying speeds and never over 120kmh (ok 140 to pass but only for about 8 seconds-once). At some point I'd like to "open it up" - was thinking I'd wait until 2000km. Does anybody have any insight on break in, what to do and what happens if an engine is not properly broken in? I expect this car to run for a long time so would like to get this right from the start.
In the 2001 T5, the procedure is as follows:
1)Key off
2)Press and hold trip reset button
3)Turn key to position 2 for 10-12 seconds
4)"Service" light will flash
5)Done
Can anyone comment?
Also, any horror stories or praises would be much appreciated.
The title says it all: where do they stick the spare when you get the 3rd seat option on the V70? Depending on where they put it, the drop in cargo area might be too much of a detriment for me to consider it (if, of course, the wife decides that a V70 is what she wants
Greg
Also, while you're there, feel free to say hello in our Volvo Owner's - Meet the Members discussion. Good luck. ;-)
Revka
Hatchbacks & Wagons Boards
i also live in central nj. we're considering buying a '02 V70 2.4. sounds like you got a fair. deal. which dealership did you use? for what its worth, i was a little disappointed by the dashboard. Kind of reminded me of a chevy impala. but then, we test drove it after driving the lexus es 300 (round the same price) and the acura TL (less expensive).
IS THE PURCHASE OF A V70 WAGON ADVISABLE?
We have a a 240 wagon with 180,000 miles; the V70 will be the replacement
ANY ADVICE?
My wife and I live in Oak Park, Illinois and have decided the V70 is the perfect car for our young family. I understand from the discussions here that reliability is a concern, though less of one for new V70's than for the previous generation. Dealer support seems to make all the difference. Does anyone have any information about dealer support and the service departments at Shepherd Volvo in Oak Park and Volvo of Lisle in Lisle, IL? Also, now that we're near the model-year changeover, does anyone have advice about what kind of deal I should be able to cut for a new '02? What prices have people been getting in the area? Thanks for any information you have.
To jmmiller1- Have you checked with Edmunds' New/Used TMV (true market value) Pricing Tools? Also, please note: Edmunds' new vehicle TMV prices do not take into account manufacture-to-consumer incentives or rebates. So you may want to check Edmunds' Incentives & Rebates section to make any necessary adjustments....
For additional feedback, you should try asking your question about dealer service in our Volvo Owner's Club Maintenance & Care discussion. Good luck and please keep us posted on your purchase.
Revka
kirstie_h
Roving Host
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
Yakima Mighty Joe is what we just picked up. It worked well for 3 bikes. No damage. Pretty easy to get set up. Play around with it to get it to sit right. The side straps took a little work to pull correctly. You need to be sure they are not pulling up but as directly from the side. Overall it is very easy to use. There is another rack that is one stage "better". Declined to go up. The Mighty Joe worked fine. Watch your clearance on the bottom after you load the bikes.
Our V70 is only five months old and we went to the dealer. He told us the cause was probably a stone damage and noted that there were a white dot 1 mm in diameter on the crack. He said that the windshields nowadays are not as good as they used to be and that they can crack from a very very small stone. They will not pay for the replacement, instead we will have to use our insurance which will cost us about $400.
I've had some stone damage on my previous cars, and when a stone hits the windshield it makes quite a loud noise. This time we haven't heard anything like that, and if the crack had arose while driving we sure would have noticed since it's right in the drivers view.
Has anyone experienced a similar situation?
When the weather stripping comes off, check to see if the crack starts at one of the screws that holds the windshield in place...If that is the case, fight with the dealer, it was likely installed incorrectly.
I had a similar problem that was the result of a screw being fastened too tightly. The glass cracked and spread like you described.
Good luck
Dan
Wow! Only 0.5 sec. lag ? Wish my VERY hi pressure 850 was that quick ! All turbos must lag. Going from say 15,000 to 80,000rpm just can't be done in an instant.
Only improvement I've found is the larger cat - back exhaust systems such as offered by IPD ( www.ipdusa.com ) Installed one on my 850 and found dramatic improvement. There IS a noticeable hum at about 45 mph and 60 mph compared to stock.
Now ordering 2002 V70 T-5 and will put same system on that.
Senilesurfer
If you have a V70, what has your experience been?
Also, has anyone heard what the differences will be on the 2003's?
Can't think of any new car where 3 people will fit comfortably. Maybe a Crown Vic.
You should plug your zip code into Edmunds' Incentives/Rebates tool to see if they have any incentives listed in your region. For additional feedback, you should also post (copy/paste) your message in our Smart Shopper Rebates and Dealer Incentives discussion. Good luck, and please keep us posted on your purchase. ;-)
Revka
Two things anyone looking for a 3 year or older 70/850 should look for. One is the torque strut motor mount and the other is the rear sway bar. Both were broke on ours and were immediately fixed. I have spoken with several lifetime Volvo owners about his problem and they say it is common.
