Krzys
The Bean is a little weaker down low than the XT, but not by much.
You really need a test drive to see for yourself, we all have different opinions. I had an 02 Bean but now have the 05 XT, and appreciate both motors in different ways.
Craig
Alland
Stout and responsive describes the 2.5 turbo. The H4 turbo pretty much bests the H6 in total available power except that it follows the characteristic turbo "push" as Craig describes. Down low, it's producing just a tad less than the H6 but the power climbs very quickly thereafter. Peak torque comes sooner, and stays flatter through the RPM band compared to the H6.
If you absolutely dislike the power delivery of a turbo engine then the H6 is a better choice. However, all else being equal, the H4 turbo produces better acceleration and useable power than the H6.
Ken
I will test drive both, but it seems that it is not enough to really understand how the car will behave. I would prefer the smooth acceleration of LL Bean, but at the same time I hope that acceleration from standstill is good enough for merging on freeway; on surface when I turn right on red; and when I take a left at an intersection. In my current car which is Hyundai Elantra, the acceleration is quite bad. Even when cars are pretty far and I start doing the things mentioned above, it seems that these cars have to slow down in response. Consequently, I have to wait longer for turning right and turning left until oncoming traffic is really far. Hopefully after paying so much for LL Bean, it will not have such a problem.
I have just purchased a used 03 Outabck Sedan and I am wondering is there any way possible to tell what recalls, maintenance, etc was done to a car through the Vin number? I have called our local Subaru dealer and my car is not listed in their database for repairs, only that it was purchased there.
There is a Recall Campaign sticker on the car but the information is unreadable on the sticker.
Thanks much, Susie
The service history will show any recalls and dealer performed maintenence and there should also be an alert for any recalls that are still open.
You can also call 1-800-SUBARU3, give them your VIN and they should be able to tell you the status of each recall and possibly dealer performed maintenance. While you have them on the phone, verify that they have the correct name & address since you bought a previously owned car.
Edit: The only recall on my '03 Outback wagon (manuf. 6/02) is Recall Campaign Number WWK94-A/T Parking Rod Recall.
DaveM
I don't think my.subaru.com will give you previous history, i.e. while the previous owner has it.
Patti once told me even dealers do not have access to that info, it is considered confidential for the owner.
-juice
"Direct from Subaru - the 15208AA031 is no longer available FROM Subaru. We
have to issue the new oil filters in place of this item.
Oil fitler number 15208AA031 supercedes/has been updated from Subaru to oil
filter number SOA5165109
SOA5165109 may not look exactly like the oil filter on your car from the
factory, but SOA5165109 is to take place of the 15208AA031 that you have on
your car."
Is this correct?
Here is the link to cross checking the OEM part number with Purolator part number. Click on the "Vehicle Applications" and then the "interchange guide". Hope this helps.
http://www.pureoil.com/
P.S. I am currently using PL14459 ( Semi-synthetic filtration material) on my 02 LL Bean and you can get it at Pep Boys for about $4.99.
Alland
Any insight would be welcomed
-mike
My 99 GT Sedan has 111k. I had all fluids changed at 99k. While I don't have the grinding, I can feel some drag while backing up and turning.
Also, as long as I'm going to take out the fill plug to check the level at 30k, should I just go ahead and change the rear diff fluid? Both cars see lots of city driving.
Last of all, would changing the front diff fluid at 30K be a good idea, again given that the cars both see lots of city driving?
TIA
Larry
DaveM
Craig
DaveM
-mike
Larry
Thanks in advance.
The 2.5XT "sport" models get a turbo H4 (this is the only turbo in the lineup). Gas mileage is mediocre, but the cars are insanely fast and a lot of fun to drive. This is the hot rod of the bunch (I have one!).
The 3.0R "luxury" models get an H6. This engine is really smooth and quiet, and also very powerful (a bit less hot rod than the turbo, however). Definitely the luxury engine of the bunch. Gas mileage is mediocre on this one as well.
You'll notice the various engine options are paired with the base, sport, and luxury models in the Outback lineup. So, you sort of get the engine based on what type of model (and associated price range) you are interested in.
Good luck! My 05 is my 3rd Outback and I like it a lot.
Craig
The 2.5 today makes the same power as that 2.5 did in 1997, only it now powers an even heavier vehicle. Or, to put it another way, your '93 Camry has 10% more power, 15% more torque, and weighs 500 pounds LESS than this Outback. It's just not that great as the powerplant for a highway-tripper.
DEFINITELY consider the manual transmission very strongly if you are going to go with the base engine. Otherwise, it would be wise to look more at the XT turbo. The H-6 is a very nice engine, but can only be had in trim levels that are absolutely loaded to the gills with luxury equipment, and sell at $30K or more.
If I had my way, Subaru would offer the H-6 with a manual transmission and make it available for base models for $2000 or so extra.
c hunter has a point about the gas mileage, although I wouldn't call the base model's numbers "very good" - I would call them decent for an AWD vehicle. You do have to bear in mind that these cars have AWD which adds weight and consequently reduces fuel economy somewhat.
Boy are these cars nicer on the inside now than when I was looking at them in '97! One thing is odd: I didn't notice it when I was in the car, but the reviews all say Outback does not have a height-adjustable driver's seat. If not, that is kind of a weird omission given they are trying to go upmarket a bit, and the smaller cheaper OBS has it.
Ask yourself how do you really drive daily, and how often you need the extra power?
-juice
Also, the engine smells like it is burning which I'm hoping is just because it only has 500 miles on it.
I'm not sure about the tapping...
-juice
I would get the tapping checked out at the dealer.
Can you tell if it's an engine noise or a driveline noise? Easiest way would be to push the clutch in at 65mph and see if the noise goes away or not. You could also try putting the car in neutral to see if it's a gear noise.
Craig
The only time I have heard "similar" noises when applying throttle in gear at speed was due to people lugging the engine (ie, they would need to downshift). But going 65mph in 5th gear is definitely not lugging the engine!
Craig
I'm as giddy as a school boy. It's days like today that I absolutely love owning a Subaru - it makes me wonder how I ever made it through the winter driving my 2wd '69 chevy.....
-juice
Craig
I'm considering the wagon. I would like to have the power of the turbo once in a while, but most of the time I'm a very conservative driver. I would get the manual transmission, simply because I prefer it.
For those of you who have had Subarus for a while, what is your real world experience with gas mileage?
Bob
Steve
My 04 Forester w/Turbo - 16 around town ( 17 on a really good tankful) and 23-24 on the highway.
My wife and I have exactly the same commute, and when I drive her OBW I get the same mileage she does. She gets the same mileage on my Forester that I do as well.
HTH
Larry
The best tank ever was 23 mpg, the worst ever was 19 mpg when really cold outside. Average is almost always about 21 mpg.
Karl
2000 Outback H4/manual: 22-23mixed/27-28hwy
2002 Outback H6/auto: 21-23mixed/27-29hwy (saw 30 once)
2003 Forester H4/auto: 20-21mixed/26-28hwy
2003 WRX H4-turbo/manual: 20-23mixed
2005 Outback XT H4-turbo/auto: 19-21mixed/23-25hwy
Craig
2003 Outback 2.5 Auto - 22-24 mixed, saw 29 on a 500 mile roadtrip using A/C and cruise, no wife, no kid, no bikes, no luggage
Former 1996 Outback 2.5 Auto - 24-26 mixed. Used Premium.
2000 Legacy L Sedan 2.5L MT 23-31 MPG, average 25 MPG
2003 Legacy SE Wagon 2.5L 4EAT 21-28MPG, average 23 MPG
2005 Legacy 2.5i Sedan 2.5 L MT 26 MPG so far.
The GT with the turbo has a different final drive ratio, so the MPG will not be as good as the 2.5i.
Jim
Seriously, though, I think the Legacy 2.5i Ltd could match or maybe even beat that, and it runs on regular.
The turbo is in an entirely different performance class as far as acceleration, it deserves the extra gas used.
-juice
Consider, though, the Saab 9-5 Aero Wagon - Turbo 2.3 - 250 hp, virtually the same vehicle weight, engine size and output. Rated at 28 MPG, but will consistently deliver 32+ MPG at highway speeds (according to my experience and many others on "another board").
The high axle ratios on the Subaru turbo models kill the mileage.
I drove an wrote a full review in the Test Drive Team thread. Nice car otherwise.
I guess the shorter gearing gives you that kind of performance.
Perhaps Subaru could bridge the gap. The 2.5i is only adequate, and the turbo is so quick it's almost ridiculous. They could have something in between.
I guess the H6 is, but I mean in terms of price also.
-juice
The "newness" never wears off if you have a chance to enjoy the drive. 172,000 miles later with 50% of the year in snow/ice and I enjoy it more now than when it was new because now I know just how far I can push the envelope even on busy highways and still follow the three rules of winter driving:
1. Drive within your ability.
2. Drive within your vehicle's ability.
3. Be courteous and conscientious.
Don't the squealers have a steady noise? I only have about 35K on these pads - replaced them about 18 months ago, so I doubt they are ready for another replacement. At first I figured it was snow/ice build up on the inside of the rim scraping against the brake caliper, but it's as clean as a whistle in there and I don't *notice* any gravel binding it up......
Suggestions?
