Visitor Agreement.
Only the STI has HIDs.
-juice
The car is still running.... that's good news. I also tore into the dash today to figure out what is wrong with my heating system / fan, and isolated the problem with no heat: the temperature selector slide is cable-connected.... with the heat side of the slide pushing the cable and the cold side pulling it. Instead of the cable pushing the flap that controls air access to the heater core, it was just flexing. I gave the flap a good push and it opened right up with a grateful gush of hot air! Thankfully, that's a spot that I can access once the glove box is back in place, so it should be a non-issue from now on. I think I have also isolated the intermittent fan operation to the motor itself. When the motor is not working, if I give the motor housing a thump, it will start up. I'm going to tear it apart and see if I can clean it up / re-lube it, but it might require replacement (gar!).
Still working on the photos..... I'm having an issue accessing the site from a browser, though I can upload files to it just fine!
-Wes-
Enjoy, juice!
-Brian
Great job. Thanks for the photos...like I wrote previously, pretty soon you're so busy working you forget to take pix.
A real accomplishment! Way to go.
Jim
Nice pics, and an awesome job! Thanks for the blow-by-blow.
Enjoy!
Mark
Nice job - great documentation!
Steve
Larry
Bookmarked that, by the way.
-juice
great photos. I saw your comment of the block heater and oil pan heater. Should my cousin get them added to her Subie? She just moved to Alaska about a month ago. She is North of Anchorage a bit but south of Denali...
She got a 2005 Forester just before moving up there. I doubt it has either on it.
--Jay
Where exactly is she? Cantwell? Anything north of Trapper Creek and she probably ought to just get the whole gammet: block, oil pan, transmission, and battery pad heaters. Any extended weather colder than about -30F and she'll be glad she has them. And, if she has not put them on yet this year, get it done right away! Winter is upon us!!!!!!!!!!!! :sick:
Oh, and I did a tire rotation last night..... my rear brake pads need to be replaced ASAP!!!! Will it ever end?! I guess I should not complain, I have put 110K on the car since I bought it and I've never replaced them.... is that about average? When it rains, it pours.... I think I am going to come in a *bit* over my $1500 annual maintenance estimate for this year!
What should it cost?
What is the risk in running around with that problem?
Could it be a DIY job?
Steve
Advantages: 00-04 models do not have the head gasket failure prone DOHC engine
Disadvantages: 00-04 models gained weight over the 95-99 models while the engine output remained the same.
Ken
After '02, the head gasket issue was resolved, so a high mile 02-03 would be a good choice.
-juice
That darn winter struck us the gradual way this year.... with spitting rain turning to snow and back to rain that is expected for at least a week before the temperatures start dropping enough to really provide a freeze up! Oy.... this is just miserable weather. It is not fun to drive in it yet, and it has that "wet cold" about it. Bleah.
I purchased a replacement blower fan yesterday for the car. I told the guy at NAPA, "Dave, I hope I do not see you again this year." I really did mean it sincerely!
The good news is that I went back to NAPA today and they did have the correct one. The only problem was that it cost me $81 MORE than the original $62 unit I had purchased the day before..... and they were IDENTICAL other than the mounting plate! :sick: :sick: I could click on that icon all day....... :P
I stuffed the new fan in there and spliced the wiring up. It works GREAT! Whew.... it's been a while since we've had that much airflow in that car! Now I just have to get those rear brake pads installed before my squealer noise turns to grinding.... :surprise:
Any suggestions would be appreciated!
Dave
I've removed mine, on my Forester. No problems here.
You could always get a skid plate, where's paisan? He makes some.
-juice
Mark
Apparently, though, the skid plate for the 2004 Outback is still being tested. Has anyone you know tried to repair the plastic one? Any idea how much a new plastic one costs? What is the "official" name for the gizmo, anyway?
Dave
I gave up on all the plasic do-dads years ago, but I'm too cheap/lazy to buy a skidplate.
-juice
Mark
The base Outback has the All weather pack, so heated seats, mirrors, wiper de-icer are standard.
It sits a couple of inches higher, and has a long-travel suspension. The seating point is about 5" higher up, I've actually measured.
Some Outbacks are monotone, so that actually does not change. Outbacks have taller profile tires for a little more sidewall, and a softer ride.
There are other details changes, but I think overall the character is different. Outback is a legit alternative to a car-based SUV, while Legacy is just a solid family sedan with AWD.
-juice
I bet you can find aftermarket tires a whole lot cheaper from Tire Rack. $120 tops.
-juice
2) You have to pay to ship them.
3) You have to pay a premium (in my area) to have them installed since I did not buy them from t he local tire guy.
Also, my experience w/H rated tires was that they consistently got max 25K miles. The tire guys said to expect 20K for VRs....this will get expensive...
...anyone with any experience. Why did they make the tires bigger on the 06 anyway!
andrelaplume - Outback also adds standard foglights, rear window spoiler and roof rack. On the other hand, the 2.5i Special Edition Legacy (essentially the base model) includes the beautiful 2-piece panoramic moonroof. Legacy will probably corner a bit better than the Outback (which is certainly not a slouch) and may be a touch faster because of the extra weight of the Outback's additional features and Outback's presumably worse aerodynamics. Outback will definitely be better on that Little League field or on Forest Service-type roads.
They're both great cars... just depends what flavor you want.
Costco mounted my Falkens for $8 per tire ($32 total). The only catch is they do not offer their road hazard warranty unless you buy the tires from them.
The cost to mount is actually the same as if you bought their tire. Exactly.
-juice
Krzys
I don't think the brake rotors got any bigger so it should fit.
-juice
Is it me or does it seem odd the Forester has a rear armrest and the Outback does not?
Hmmm... last time I checked, there was a rear seat armrest in my 2-day old '05 OXT. :P
I cannot believe they would place a fuel filter the tank! What could possibly be the advantage to that?! Maybe they felt it was too dangerous for an end user (owner) to replace the fuel filter. After all, like the Haynes manual so aptly states, "DANGER: Gasoline is Flammable." :surprise: An eye-opener, to be sure!
Those Subaru parts guys..... oy. I was trying to get a set of intake manifold and valve cover gaskets from NAPA. They sold me manifold gaskets but did not have valve cover gaskets. I went to the dealership. They sold me the gaskets in a heartbeat, using a diagrammatic parts database (so it should be pretty near impossible to screw that up) using my car's VIN. The guy takes my money, goes in the back, brings out two sets of gaskets, and I'm on my way. The next day I was back to return the darned things because they were the wrong ones! :mad:
Thanks for taking the time to post your results here after your frustrating experience.
