Visitor Agreement.
Have fun,
Greg
I seem to remember some discussion a long time ago about which tires are best to replace the Firestones with, but I cannot seem to find that thread.
Thanks in advance.
-andy.
If you put the Protenzas on you can tell everybody you have an '02 model.
Bob
I don't have my owner's manual handy but I remember reading that the circumference of each tire per axle should be checked and there should be no more than "nn" difference between the two.
I don't remember w/o my manual what the value for "nn" is. My guess is if you have 28k miles you would probably need to replace both tires on the same axle.
Vince
That is my $.01 worth....
.....See, I am saving you money already!
BTW tirerack.com has partners state wide that will install tires that are bought from them...you simply buy the tires, have them shipped to one of the partners, coordinate and install date and go have them installed.
Whatever you do, don't drive an a 'cut up' tire.
I will shut up now.
-r
Will drop off? Try HAS dropped off
Broke in keeping it under about 3500 with varying speeds for first 1K.
Tinted windows all around. With so much glass area it really helps keep the car cool. The climate control is as good any car I've owned. At outside temp of 103 we could have froze ice inside
Acceleration is disappointing off the line for 212 HP, but on the road if the revs are kept up it's fair. (Other car is an 01 Acura CL-S which is a rocket next to the Bean).
Gas mileage has varied from 25 on the first tank to high of 27.2 mainly hiway with a/c on. Would expect it to get better.
Seats I find comfortable (6',175) except the pass seat could go back another 2-3 inches.
Fit and finish is excellent, stereo fair
Car has excellent road feel and is solid and quiet at all speeds, except for the one problem I have had. After 1K miles and increasing hiway speeds, I started hearing a slight hum (whine) under light acceleration. Coast and the sound goes away.. touch the gas and it's back. Coming from rear and center of car.
Brought it back in to the shop at Irvine, they first ran the car on the hoist, then road tested it (mechanic only). He eliminated road noise and tire noise and as we were on our way to Mexico, we didn't have time to leave the car at that point. His best guess was a pinion bearing. said to put another 2000 miles on the car and see if it changes. He had not seen that particular situation on the H6.
I have owned 2 other Subs and driven 2 or 3 friends cars. None had this problem. Any one else had a similar situation ?
I have read experiences of people where they have used the OB in up to 18" - 20" of snow. My question is, how much of snow can the L wagon handle (lower height, no rear LSD), and how much of snow can the GT wagon handle (lower height, has rear LSD). The OB is 1" higher in the front, about 2.5" higher in the center, and about 3.5" higher in the rear than the L wagon. We get snowdrifts in the driveway. Also, snow plows dump snow across which is typical. TIA.
Roger
Vince
One more really big difference among the three cars is the effective final drive ratio. The GT and the OB share the same final drive gearing, but the GT has low profile tires; so it feels quicker in acceleration but is turning higher revs than the OB at highway speeds. (I have a GT and I do not find it to feel at all like it is revving too high at highway speeds, but a prospective buyer should note that there is a difference.) The L has a taller final drive ratio and therefore should deliver slightly better gas mileage than either the GT or OB, at the expense of having a bit less oomph off the line. Because its tire diameter is smaller than the OB it might feel very similar in acceleration to that car.
After about a month of ownership out there in The Real World, I don't think any of that last paragraph will make much difference. Go for a model with rear LSD and pick the one that looks the best in your eyes, and welcome to the club!
Cheers,
-wdb
bit
Patti
Patti
Patti
The Outback is a stable handling, safe car; however it has larger diameter tires, and sits a bit higher than, a Legacy L or GT, and so in true emergency situations it may not feel as stable as those cars. However it is still leagues ahead of ANY SUV, and it is by no means a dangerous handling car.
That's my opinion and I'm sticking to it :-) But seriously, what you should really do is go to a dealer and drive the cars. Decide for yourself what handles well and what does not.
Cheers,
-wdb
I think they meant AWD.
Mark
HTH, Theo
Jan - Consumers stated that "handling can get tricky AT IT'S HANDLING LIMITS" which means you really have to push the car to get to that point - something you won't do in snow / ice. Also, look at the year they tested it - 99 when the new OB just came out. The 01 OBs have limited slip rear diffs which I would imagine at least helps this. However, I don't know what they mean by tricky. Anyway, I purchased the OB anyway and love the way it handles. I feel safer in this car than my 92 Camry. It holds the road much better especially in wet weather, handles rough roads easily and when winter comes...... :-))
Greg
Funny, GEICO never asked. AWP not even indicated on my policy ('98 OB Ltd.).
On our Forester, they're wired in with the rear window defroster, which has a timer. So, every 15 minutes or so, you would have to turn it back on. I think on the Legacy/Outback you have a separate switch by the power mirror controls. I don't know if there is a timer on those models.
Bob
Cheers!
Paul
Patti - No previous oil leak but Ross could be right although I would never tell him that! Will let it ride unless I have a similiar problem under dry conditions. Thanks :~})
Tom
Ross
1. wheels have peeling clearcoat and beginnings of corrosion (common to subaru alloy wheels from this vintage)
2. broken power antenna (comon on older cars with this feature)
3. brake shudder on hard stops
4. cracked headlamp and broken fog lamp
5. cd player does not work
I'm not positive on what I will get the car for (I know it will be <$4500).
I like the LSi model because it is fully loaded without having the outback treatment (which is overdone and overpriced in my opinion) and the fact that used outback and GT models are outrageously expensive.
BTW, did this year and trim of legacy have a factory keyless entry system.
"Customer states whinning noise from rear end. Test drove vehicle, heard a slight noise on accelerationaround 70-75 MPH like a pinion bearing noise in rear diff..Unable to pinpoint noise at this time. Need to have customer return for further diagnosis"
Had the car out for a 80 mile drive yesterday and it seems to be getting louder.
Patti...what is your take ? Would hate to have a bearing sieze up while driving. I am almost 400 miles from Irvine, ca. Who do you feel is the better service dealer between Hohl in carson City and Lithia in Reno ? Maybe meet with a Subaru rep as well ??
My Miata's antennae was broken by the gate at my garage, and the estimate to replace it was absolutely ridiculous, something like $350 IIRC. I ended up putting in a $14 rubber antennae from Wal Mart and it works great.
The wheels could be repainted, but it's most likely just cosmetic damage if you don't mind.
The brake shudder and the mileage probably mean the rotors are warped. At that age, you can forget resurfacing them, so it needs an expensive brake job ASAP. I'd guess at the very minimum $300.
A headlamp is probably $150 or more, and double that for the fog lamp. You'll probably need to replace both to pass any safety inspections. Usually, if you have fogs, they must work, so you could just remove those.
Fixing an old head unit probably costs more than replacing the entire thing. You can get head units pretty cheap, even installed.
But that's a pretty long list of damage, and it likely means the car was not well taken care of. I'd pass, personally.
-juice
Anyone out there know how to turn off the annoying tweeting when you lock/unlock the car? Doesn't say in the manual how. If anyone can help, that'd be great. Just email me at NBor101@aol.com.
Nick
-sub
Any advice? Thanks .
Patti
The reason I want to do this is because this way I can simply place jack stands under the either the two front or the two rear jack points. I can either get all four corners or either front/back off the ground and rotate tires, or change the oil, or whatever.
-r
Check out the current issue of Consumer Reports - they tested a bunch of carriers, including soft ones and hard ones (long, wide, and big).
I have a Samsonite soft carrier, and what they wrote about soft carriers in general applies here - it's water resistant but not water proof, and it'll cost you about 1-2mpg. The straps make it a pain to open and close, but it's cheap at just $40 from Samsonite outlets.
My cousin used a Sears X-Cargo on his last trip and it worked well for his '99 Outback. The older ones are kind of ugly though.
r - I have used the rear diffy to jack up the entire rear, and it worked for me. Just be very careful that it doesn't slip. I have the diffy cover and used a peice of wood inbetween to protect it from damage.
I have not jacked up both front wheels, since I use ramps for oil changes.
Tire rotations are front-rear and vice versa, so I have jacked up both tires on each side at the same time. I used a very long piece of 2"x4" lumber along where the recommended jack points are.
I bet you could jack the front up with part of that cross member if you used wood to distribute the load evenly. Just be very, very careful to make sure the wood does not slip.
-juice
HTH, Theo
Yes there is a jack point on the front. It is right in front of where the exhaust system comes together in a "Y". Slide it back there and jack it up. Do use a piece of wood for padding though. Gets rid of slippage and scratches. Go take a look at a Hanes Manual for Subaru. It will point it out if you cant find it.
On the rear it is the rear differential case.
Greg
In any case, I love driving it and am impressed by how much get-up-and-go it has for a non-turbo 4 cylinder (I used to own a Volvo 4 cylinder Turbo that was mighty sluggish at low speeds).
Otto
Selling a WRX for near retail, and servicing cars, brings in profits. Even used cars can be more profitable than new ones.
-juice
...at 6-7pm Pacific/9-10 pm Eastern. Hope to see you there!
http://www.edmunds.com/chat/subaruchat.html
Drew
Is this idea tried and known to work? Thanks,
Roger
