Full Sized Vans
Ordered mine Sept. 1 should be here Nov. 1 or so...
But there's a lot of stuff I never heard of.
guitarzan
Community Leader/Vans Conference
- Safety and convenience features (especially dual side doors);
- Maneuverability and ease of parking (especially for my wife who drove a Sable);
- Front wheel drive (for WI snow);
- Fuel efficiency;
- On some like the Pontiac Montana, seating flexibility.
But their negatives are:
- Limited cargo area with four car seats (we are planning on using two, twin-kid strollers);
- Ease of placing child seat in rear (have to hoist over fixed seat);
- Not much room for many more people.
In general, I can expect to outgrow one in a year or so.
So, with the kids some weeks from needing a ride, I am now more seriously considering full size vans. I just saw a GMC Savanna and drooled over the 4' of space behind the third row seating and the ease of access to both rear seat rows from the double doors (on the passenger side only though). I have heard that Dodge RAM vans have dual doors, but haven't seen any yet, and can get an employee deal on Ford company vehicles. We won't be driving this vehicle much over the next year, and I would be happy with a good quality '98 or so that hits the main points I have mentioned.
What would you all recommend ?????
guitarzan
How about it's handling capability in rain and snow?
Thanks in advance.
Michael
Any thoughts on the newer Ford diesel's reliability? Are they still a Navistar? What kind of MPG could I expect in window van (assuming no conversion or camping equipment)?
Thanks in advance for any comments. If you would rather pmail me, use mrnimmo@yahoo.com.
Sorry, NADA has no recent pricing for Regency.
Jerry
are in High School & College and out grew the Lincoln. All there stuff fits under the seats that I can remove in 5 minutes. (The seats are bolted in, in a conversion) It is 15" shorter than the TownCar so my Wife can park it in the same space as a Taurus. All our stuff isn't tied on the roof on vacations. With 95,000 miles on it, all it has had is Oil changes, Tires and a fuel gauge sending unit (under warranty). I will replace it with another one if it ever starts giving me trouble. You my have to order a Ram Wagon at most dealers because conversions have more dealer profit in them. $18000 base van + $3000 dealer pays for the coversion = $27000 window price. My SLT with CD, power seats, 4wheel ABS and more was about $ 22000 on the window. I get about 17mpg at 70mph on flat land.
Guitarzan
Admittedly you have to take your time in the snow but hey it's a small tradoff and they are great to travel in .
After driving my new 2000 Express Pass. Van more over the weekend, it appears that the brakes are OK; just not as hard feeling as my 86 Dodge van that I am used to driving; but, it seem to stop OK.
However, the parking brake does go to the floor and will not hold the vehicle on a hill. I tested it by depressing the parking brake and then dropping it into drive and it began to roll.
I also checked a friends older GMC Savana conversion and her pedal goes to the floor as well.
This must be an inherent fault that GM has never corrected. There are times in life, like parking on a steep hill, when the parking brake is needed to keep from getting "torque lock", is using the park position only.
Has anyone taken it back to the dealer for this and gotten it corrected? What was the problem?
In my owner's manual, it's on page 1-6.
1. lift the carpet flap at the inboard side of the seat base in the rear.
2. locate the red handle on the inboard side of the seat base and rotate it up.
3. once the red handle is rotated up, pull the handle to remove the locking pin.
4. stow the locking pin on the rear of the seat base in the hole that is provided.
5. repeat this procedure for the pin on the other seat base.
6. Pull the seat rearward about 2 inches and then lift the seat from the floor rails.
7. remove the seat from the vehicle.
8. install the trim covers to the floor rails. These were supplied in a cardboard box at delivery.
But before you do this be sure to disconnect the quick release latch plates for the lap shoulder belts on the bench seat to be removed. To do this, press the tip of a key into the release hole of the safety belt buckle while pulling up on the safety belt.
good luck
I started the vehicle, shifted from park into drive, but forgot to release the parking brake. When I pressed the accelerator, I can assure you the parking brake was quite effective. (This happens to everybody once in a while - doesn't it?)
I'll try to perform the hill test... next time I find a hill...
"8. install the trim covers to the floor rails. These were supplied in a cardboard box at delivery."
You mean those cheap plastic POS that don't even fit into the floor rails?
But, really, we LOVE our Savana anyway...
It is possible that the rear brakes are not properly adjusted. However, GM(and most other)brakes can be adjusted by backing the vehicle up and repeatedly pumping the brakes. This will allow the adjuster on the drum brakes to take up the slack. An emergency brake going to the floor with little effort is a sure sign of rear brakes being out of adjustment or badly worn.
If you are seeing this problem on a new vehicle, I would definitly take it to the dealer for a check out. I may be nothing more than an improper initial adjustment.
Jim
We have a '99 Savana and are very happy at almost 14K miles so far.
Jim
Thanks for taking the time to respond.
ALso, are people having good luck with the transmission and engine as far as reliability?
body style on the current Econolines.
So, if history means anything, we can probably expect the current designs to be around for quite a while.
While performing routine fluid change on the rear locking differential, this clip just fell off. Good thing the tire was off! Otherwise the tire would be stuck in the up position!
I reshaped the clip so that once snapped into position, it wouldn't unsnap again. An easy preventative measure would be to wrap the pin and clip with durable electrical tape.
Take it back to the dealer!
Paul
Guitarzan
I have it list at 5300 and received some calls but as soon as you tell them the miles its "bye".
Confused...any help??
Your object is to get as much as possible for it. Why not reduce it $500, and put the mileage in the ad, and see what happens?
Guitarzan
If the Kelley thing takes mileage into account, I'd try getting some other estimates, like Edmunds' guide, and checking the ads on a site like Excite. Do a search. You'll find em.
But of course the main thing is if nobody's buying, you gotta drop the price.
Comparing tradein and retail values between KBB and Edmund's on the cargo van it appears that the two are close on tradein,about 2700. but widely apart on the retail. KBB is about 5300-5400 on your '89 and Edmunds is about 3700. on a '90.
NADA shows Starcraft value at 1300. tradein and 1600. retail. The 5300. asking is probably upper end of scale.
I agree with Guitarzan, show mileage in your ads. Maybe a price drop to 4995. or best offer will stir more interest too.
Jerry
