Visitor Agreement.
Good luck with it!
Cheers!
Paul
Maybe a neighborhood animal?
-juice
I learned from long, painful personal experience of many, many, many hours of frustrations that auto alarms can go off at the slightest shock or for no particular reason at all.
When I was in collage my dorm faced the parking lot. Whenever a shuttle bus would go by (every 10 minutes or so) 3-4 car alarms would go off. The bus was over a block away from the furthest of these cars. I also witnessed them going off for no discernable reason whatsoever. Clear day, not a cloud in the sky, nobody in the parking lot, no buses, motorcycles, construction equipment, birds or burglars. Alarm just up and goes off.
Ken
Thanks for the advise.
Robert in Atlanta
Stick with 10w30 oil in summer. If it gets extremely cold where you live, consider a 5w20 in the winter.
You do not have to change oil at a dealer. Just save receipts and keep accurate records of the date and mileage.
Subaru will have a bigger SUW in 2005, that's the closest thing we'll have to a minivan until at least a few years past that. I'm hoping it'll have 3 rows of seats; we'll see.
-juice
No need to go to the dealer for either the filter or the oil change. Of course, you can buy a filter from the dealer (it comes with one of the metal gaskets for the oil drain plug). Or, you can buy a little bag of the gaskets alone (somewhere around $8 for five gaskets) and use an after-market filter (my approach). I use Fram; others here have panned Fram (with no supporting data) and suggested Purolator. I personally think they're all pretty equivalent (no supporting data for that comment, either). Unless you're in a very hot climate (daily highs in the upper 90s or hotter), the recommended 5W30 should be fine. If it's hot, 5W40 or 10W40 would do it. The point is to change the oil regularly (I change oil and filter every 3500-4000 miles), and make certain to check frequently that it's filled to the proper level.
Air Filter observation: Bought a couple of OEM air filters for my 2000 H4 from Subaruparts.com, and darned if they didn't look familiar. Pulled out my spare filter for my '97 Max, and the two could be twins (I'm not certain, but I think the Fram number is CA-4309 - it's the only one for that year Max, in any event). When I come back from my California trip and change the filter in the OB, I'm going to see if that Fram fits as well as I think it will (all three dimensions were essentially identical). If so, I'll switch to Fram (hey, $6 beats $14 any day) when I use up the second filter (I swap 'em every 15K miles). Anyone else noticed/tried this filter in their newer H4? I'll let you know what I discover in a couple of weeks.
Cheers from the PNW!
Ken M.
Thanks in advance.
j
I wanted to post a bit of my buying experience for anyone else who's considering.
The dealer was super sticky on their sticker price (pun not intended) and were trying hard to get me to take one of their few remaining '01s in the lot. I had my heart set on the Blue '02 so I felt it was worth the extra $$.
Bottom line, the Outbacks are gaining major momentum in the marketplace; the dealer knows they don't have to go too far below sticker to make a sale. My trade-in didn't help that much either ('95 Explorer Sport)... seems their tough to move these days, especially with 115K miles.
Anyway, a new chapter begins ... Chapter Subaru.
bit
My 3 Legacys have all run fine on 87 octane. If you want to increase profits at Amoco then use higher octane.
Everything else is also good. Maybe just a few minor problems (squeaky brakes and such) but nothing to worry about. Hey, it's a machine and no machine is perfect. Still say its the best driving car I've ever owned and this makes well over 50.
Sharon: I've been following your posts and I wish you the best of luck. Maybe SOA will come to thier senses but I wouldn't hold my breath. The sad thing is it's such a great car. But who can tolerate what you are going through. Anyway I hope an equitable solution can be reached. Keep us posted.
Guy
Now, here's our next issue. Since it's a Legacy, and not an Outback, it has less ground clearance than we'd like. I suspected this would be a problem with the driveway when we got home, and sure enough, it does a nasty scrape on the black plastic on the bottom of the in the front. The tow hooks scrape, too, but just those and the black plastic part.
What are our options? We own the house, so I suppose we could have the driveway redone . . . Would a 2x4 or ramp of some sort give it enough elevation? Should I be concerned about this in terms of whacking the thing two or four times a day?
I can get my Miata up there without touching, with an approach at about 45 degrees. If a Miata can, any Subie surely can.
Congrats, stinky. Enjoy the new car stench (some Subies really stink until the undercoating burns off) and hang in there because your mileage will only improve with time.
-juice
A few weeks back, I asked for some tire recommenations to replace my Bridgestone Potenza RE92. At current rate of thread wear, I'll need to replace them around 35k. One post mentioned that they should get around 80k. I checked the warrenty for the RE92 and it is for 40k so I wanted to ask what mileage others have got on these tires.
Finally SOA, gave me the following link to find tire replacements www.tirerack.com which is a great site for tire comparisons.
Next Monday will be my first service, but I don't expect much improvement after that.
About your post at July 31, it's interesting that when you pressed harder with the better gas mileage. (not a small different, it's 25% improvement)
Could you mind to tell me more???
Thanks in advance.
When driving to Florida in late April I averaged between 26-27 mpg. The best run was 27.1 on the highway, driving between 70-85 and with the A/C blasting.
I'm sure you'll note increasing mpg with increased miles. Be patient.
Don
-juice
i'm just wondering how the guy at post#2166 having the 25% improvement just by "With a much heavier foot".
Another problem... a 'click' sound coming out from the door when open the driver's window and the same sound happend sometimes when turning right (yes! only turn right!).
Other than that, i'm pretty happy with my Bean.
BTW on the tank before the check I filled up with regular just for curiosity. If there was any difference in performance I couldn't detect it, and absolutely no ping. You might ask "if that is so why didn't you continue using regular?" Guess I just can't bear to not do it by the book.
I will check it a few more times since my curiosity is now piqued.
Guy
Any suggestions welcome!
Thanks in advance.
I think it comes down to what kind of roads your drive on. 95% of the time my GMC was on interstate commuting to work. If your not breaking and turning corners hard, tires just don't wear as fast.
Robert in Atlanta
"Does Zaino Really work?"
It would be like going to a good old Southern Baptist revival and asking "Is Jesus Real?"
I can't think of any other products that have such a zealous cult like following. Not even Subaru.
Patti, I would like to get in touch with the District Manager, (Northern California, Redwood City Subaru), in order to clear up the matter of what went wrong with my clutch, and discuss what happens if the next clutch/pressure plate performs as poorly as this one did right from the start. I don't expect to pay for premature clutch replacements in the future--this should be covered under warranty! And I don't appreciate being blamed for destroying what was obviously faulty to begin with.
Any feedback would be appreciated!
I think the standard adjustment period is one year, so that would fall within even that short period of time.
-juice
Needless to say, with gas around me at nearly $2, I'm glad I didn't pick a less efficient SUV.
-juice
subearu "Subaru Crew - Meet The Members II" Aug 1, 2001 4:43pm
the short: even in 95+ degree temps and 75 degree dew points (read that as really humid), I couldn't get my '00 OB to ping.
-Brian
http://www.properautocare.com/whywaxyourcar.html
I have experience with Meguiars #7 show car glaze, and Meguiar's #26 Hard Yellow and absolutely love them. If done on a regular basis with a machine, the process can be fast if done on a regular basis.
I won't consider Zaino because of a few problems: cost, time involved, and streaking if improperly applied.
Besides part of enjoying the car is that just finished shine. You also learn a lot about your car when it is detailed regularly, and can identify problems quicker.
...at 6-7pm Pacific/9-10 pm Eastern. Hope to see you there!
http://www.edmunds.com/chat/subaruchat.html
Mike
Shelby - sorry to hear about your clutch. Hope things are fixed to your satisfaction. From other folks in here, it appears that Subaru really strives for customer sat. Hope you get the same feeling - let us know what happens.
Greg
I can afford the Outback, but I am struggling with spendind an extra 20K for an All road or 10K for the 4 runner.
Which one is the best buy in the long run?
I drove a Pathfinder a week or so ago because the reviews said it was the most car like ride for an SUV. It's a great ride if you want to haul 5,000 lbs. but I don't. The Outback pulls 2,000 lbs. and handles and rides much better than the Pathfinder. The LE version with leather is trimmed about the same as the llbean. Price on bean was at least $5,000 cheaper. Just my opinion.
Jack - Ohio
Allroad -- have not driven one; audi has a good AWD reputation, complicated suspension would worry me; the the sticker price is ridiculous; the styling (for me) just does not work as well as the conventional wagon. Would go for a Passat 4Motion LONG before I'd ever consider the allroad.
Bean -- we have a VDC; my wife worships it. Comfortable, very drivable on the curvy roads, good room front and back, beautiful leather, wonerful audio. I love looking at allroads, 4Runners, volvo XCs and the like because they show me how smart we were and what a bargain we got with a Subaru.
I'll take a look at the case and see that your issues are addressed. Sorry about the problem.
Patti
Thanks in advance,
tac
Greg
Any way I am happy now! When I called up a local Subi dealer here the rate he quoted was $60 for balancing!! thats a ripoff.
-mike
