Craig
Patti
Cris: I've driven my 5 speed Forester on the sand lots, and it does very well. The key is to keep your momentum and drive smoothly. I didn't exactly go dune-hopping, but if you just want to do a little surf fishing it should be OK. The flounder were biting at the OBX a few months ago! :-)
Steve: the hitch ball height on my OE trailer hitch seemed to mate perfectly with the 5'x8' trailer I borrowed from a friend (Bob, coincidentally). I have a photo here. Maybe the trailers don't have a standard height, and I got lucky?
Allen: hmm, did you check your fuses? Maybe the lights go to high when the low beam fuse it burned out. I'd also check the bulbs.
Annie: the lemon guy was right, there were $750 incentives, though it was regional, so your dealer could have been right, too. I suggest you buy from a place that does have the incentive, obviously. 2002 models have not had any yet, as far as I know.
-juice
-juice
Sorry for the delay - four days without the Internet - refreshing in a way!
The gasket on my replaced windshield looked absolutely normal right from the start. In fact, except for the missing crack (from the old windshield), I wouldn't have been able to tell it had been replaced - and I looked VERY carefully (in view of previous experience with other windshield replacements). The most I've ever encountered is a bit of excess sealant that could be peeled off a few days after installation.
Good luck - and get a good job - you'll be looking at it for a long time (hopefully).
Ken from Seattle
One problem I encountered, which I also remember reading about here on Edmunds many months ago: the first windshield they tried to put in (before I said whoa) had a dark tint band along the top. It was also a Carlex windshield and otherwise identical to the OEM unit. I knew this band would interfere with my line of sight based on my seating position and the layout of the OB. To give you an idea, the tint band actually came down to the rearview mirror mount point, which is way too low for me. The glass shop re-ordered a windshield without the tint band, and everything worked out well. Ended up being a $450 repair.
Paint: while touching up some chips on my bumper, I noticed an egg sized patch on the hood where the paint is beginning to flake off. Not good! I take pretty good care of my OB, washing it regularly and waxing it at least once a year (usually twice). I am assuming this must have been some defect in the paint job that is only now beginning to show. I'm not sure what I should do -- the area is too large for touchup paint, yet too small to justify having the hood repainted (especially since no paint job is as good as a factory job). Anybody know Subaru's policy and/or warranty position on this sort of thing? I have had the car for 1.5 years, and it has 23000 miles. This is way too early for paint problems!
Craig
-Bud
Has anyone noticed the problem with the defrosting system? Our OB equipped with Winter package and the system dindn't perform as expected. We noticed a lot of ice built up at the bottom of the windshield and the wipers were going OVER it.
Also, the inside of the car was fogged up quite a bit even with the heater, defroster were going full blast. I tried to turn on the air conditioning but it didn't seem to help much, if any.
Jude: the symptoms would have me checking belt tension and the belts themselves. Could be the alternator belt is slipping and not charging the battery properly?
At that age, I'd go ahead and change all the belts and hoses anyway. I would also do the timing belt if you are over 50k, just as a preventative measure.
-juice
I brought my 'stubby top' draw bar in to my Suby dealer on Friday to see if there was possibly an updated part that would be reversible. No such luck. The parts guy and another customer both commented on the poor OEM design, and suggested U-haul or the local WalMart (which stocks Reese hitch parts). I ended up with Reese P/N 06280 - basically identical to Subaru P/N L1010FS030 but with a longer tab that allows for installation with a 0.75" rise or 1.25" drop. It is also V-5 spec, but with an overkill Class-2 rating. Installed in the hitch receiver in the drop position the trailer now sits close to level.
Then the real fun began. Picked up the trailer, hooked it up and found that the running lights would not shut off, even with the car lights off and ignition off. Volt meter shows the output from the Subaru interface module (P/N L1010FS020) brown wire is on all the time
Went back to the dealer yesterday morning. He looked it up in the newest book, then began to shake his head. Seems we have a bigger problem.... I had ordered Subaru hitch kit P/N L1010LS100, but that was not what they sold me. They gave me P/N L1010LS000. I balked, but they assured me that there were no changes. Maybe just from another supplier. I even called 800-SUBARU3 and was told it was OK. A few weeks later the story is different. A safety advisory states not to install -000 rev kit on '02 vehicles. No explanations, just remove and replace with -100 rev. Will it fix any of the problems I am having? Who knows....
He tells me to R&R it, I ask him to do it. Hey, I ordered the correct part - they screwed up. He saw my point, and agreed, so the unit is on order, and they will do the labor this time. That at least helped me feel better about the whole fiasco, but I lost the weekend dealing with problems when I needed the trailer to help my parents move furniture. So it goes....
Steve
-mike
Ed
Also, the rear window defroster-heated mirrors are on a timer. You have to reactivate that switch every 15 minutes or so. That may also be true of the front deicer?
Bob
I do recall the hitch recall, or stop order, or something like that. Last year?
-juice
Dervish: Your A/C has a thermal cutoff switch set for about 42' F to protect the compressor from the possibility of liquid freon making it from the expansion valve to the compressor without evaporation. So in snow country, you will not be able to run the A/C for dehumidification.
Craig: If I remember correctly, the base OB has an evenly light tinted windshield. The upper models add the dark tint band for a few inches at the top. Sounds like they ordered the wrong glass.
Steve
Cheers!
Paul
-juice
The button for the windshield de-icers is on the left side of the dash - down by the cruise on/off, the fog lamps, etc. As I recall, it's the closest switch to the steering column in that cluster. The outside mirror defrosters have a switch on the driver's door near the mirror position controls. The defrost mode you want (on the HVAC) is fully right (clockwise) where the symbol shows ONLY the defroster (not the one next to it that shows the defroster and heater). It's this defrost-only position that engages the compressor for more effective dehumidification (and hence better defrosting). Forget the A/C button - and Paul's point about the "recirc" setting is absolutely correct.
I had my 2K O/B down at Mt Bachelor last winter for a ski week, and was very impressed with its defrosting/de-icing capabilities. There are a lot of one-function switches to push (to include the one for the rear window, too), but they all worked well once activated.
Ken in Seattle
Maybe I DID leave the "RECIRC" switch on.
Steve -
"Your A/C has a thermal cutoff switch set for about 42' F to protect the ..." Wow! Are you an engineer?
Ken -
I DO know the functions as well as the locations of those switches. I will try your recommended defrosting mode next time. Well, how about this weekend?
You guys are great!
Cheers!
Patti
Call 800-SUBARU3 to open up a case, they're helpful.
-juice
I apologize for bringing this topic back up, but I've spent a significant amount of time looking through previous posts, on multiple boards, and each time I give up a little bit easier. So, until the search function turns up the posts I am looking for, I have a question that has been asked before.
I'm bringing my 2001 Outback in for an oil change. I asked the dealer what he could do to fix the early morning squeaking when backing out of the garage, and I was not offered the solution presented here. I mentioned that I recalled hearing of a shim kit that Subaru offered under warranty, but the person I was speaking with said he had heard nothing of this, and their fix was tightening 'something'. Is there a memo or any paperwork or part number that Subaru has for this problem/fix? Is there some way that I can steer this guy so that he can tell me if the shim kit is for me or not? Basically, how can he be informed (what should I tell him), if he is not already?
Thanks all...
Colin
Try what the dealer suggests, it can't hurt. If it still squeals, then someone may offer more info by then.
-juice
Mentioned it to the dealer at the first oil change and they did some sort of 'cleaning' to the pads, like removing the glazing from them or something. (knock on wood) haven't had the squeal since then, and it's been over a year now.
I'd try what the dealer suggests, at least they're not giving you the 'can not duplicate problem' answer. If all else fails, you can put a call into the Subaru 800 number.
-Brian
Someone said you could hit the brakes while reversing to do this, too.
-juice
Except for this I love this car. Virtually no complaints worth mentioning.
Guy
Guy: is yours all the time, or only first thing in the AM?
-juice
He had the a.m. back-up squeal from day one and the shim kit fixed it.
John
Eric
BTW: My son (Honda civic owner) is about to buy a Forrester. I attribute this to him being impressed when driving my Outback. I think he would actually rather have the Outback but his wife likes the Forrester. You know how it goes, you do the best you can. I'll keep you all posted on when he makes the leap.
Guy
Patti
Congrats, Eric. Did you choose auto or 5 speed? What color? Also, did you spring for the all weather package?
My dad has a 2001 and has been quite happy with it so far. He had been buying Fords and Toyotas up until this one.
-juice
Steve
Steve
Any help would be greatly appreciated.
-mike
tidester
SUVs
Patty, is it possible for SoA to contact dealerships? My dealership is Concordville Subaru/Nissan in Concordville , PA.
-juice
Juice, I have been looking at the Chilton Manual and think it just may be the belts. Today it was very snowy and roads were rough, poof there was all the lights starting their blinking again so I gave it a little gunning and they went off. A few more bumps and they came back on. Same scenario. Question? Are the belts something we can change or should we have a pro do it? Easy or Difficult?
-juice
Yep, those air bladders are pricey. paisan converted his XT6 to struts as well.
-juice
