I didn't hit any major hills, nor did I drive long distances with the trailer, though. So YMMV.
-juice
Craig
We had our 2K OB wagon's "back five" windows tinted in the spring of 2000, and have survived [nearly] two Seattle winters without any leaking (and the car lives outside). We're very glad we had the tint job done.
If you plan to keep the car for a few years or longer, I'd recommend the higher quality "metallic" film installed by a well-established shop. It's worth the extra few dollars.
Ken in Seattle
-mike
I've made a mess of the floor. =o)
I'll part with my OB for that GT; and no moon roof.
-Dave
Today I turned on the auto climate control, in the LLB 02, and immediately it said "ac". It is unclear why it did this, since humidity is low and it is cool outside..... It is frustrating to have to turn it off.
http://www.subaru.co.jp/legacy/c/c1/c1_k03.htm
-Brian
I have an 01 Bean. The A/C will turn on automatically when you press the auto button...I think that is how it was designed to operate.
If all you want is the fan...press the fan button once and set the temp you want it to blow at....you can crank up the fan speed by pressing the button consecutively. About 90% of the time I get in the car, crank it up, hit the fan button and off I go. These days I set the temp. just warm enough to cause it to heat on cold mornings. In the afternoon, I hit set the temp to 65 and it just blows fresh air at ambient temp which has been very pleasent here lately.
As for the tint. I have all my windows tinted with fully metallic tint 35%. There is just a slight amount of added privacy, plus much cooler in the sun. No adverse effects to the seal, antenna functions, or defrost lines. BTW I used SolarWorks which is a nationwide chain that uses Lumar film...I chose the film they call the Mellinium film for the windows and Premier film for the moonroofs. If I had to do it again, I'd have tinted the moonroofs with 50% vs the 35 since up there it is virtually see-thru.
You can see pics of my Bean at: www.gatech.edu\oit\oe\design\rob\suby\subaru.htm
-r
-mike
While I haven't noticed a drag on the engine with the H6, it still annoys me to have AC cycling, so I usually put the system in ECON mode or overrride the AC alltogether.
We're lucky Subaru even gives us the option to turn AC off. There are quite a few luxury cars out there that run the AC all the time, without providing an off switch.
Craig
That said, I was happy as a clam with my H4 Outback until I made the mistake of test driving the LL Bean. It pulled me in!
I don't know anything about the Costco program, but you should be able to get a Bean or regular Outback for close to invoice price at most dealerships. I paid $200 over invoice for my bean, with no haggling at all -- just asked the dealer to match another dealer price I saw on the internet.
Craig
I'd glady skip the designer nameplate and the moonroofs for one of these. Thanks for the pic, C_hunter
- Rob
So, bottom line, don't be cheap, life's too short!
If you really hate the logos, you can take them off (someone posted how they did it about a month or two ago).
I guess the next step of evolution would be a manual tranny and a 5-speed auto!
Ken
-mike
The dealer mechanic sent me a copy of a bulletin saying that the noise is normal and will not lead to future problems. The cause of the noise is due to design changes in the engine (shorter piston skirt, etc.) It is true that once the engine heats up, the noise goes away because the piston has expanded somewhat.
How believeable is this bulletin? Any engine noise can't be good.
-mike
I wonder if it's worth the hassle to insist on having it fixed under warranty
-mike
BTW. your Honda has adjustable valve clearance, which has probably been adjusted more than once, thats the reason you do not hear the rattle, subaru has hydraulic lifters hence the rattle until it warms up.
Cheers Pat.
-mike
Also, because the rattling doesn't happen until I began driving it, I highly doubt that it's the hydraulic lifters. When I first start the car, before I drive it, everything sounds fine.
My guess is that the short piston skirt is causing this. When it's cold there isn't enough contact area, that results in knocking the cylinders. As it heats up, the piston expands and noise goes away. I just don't know how serious this is. The Subaru bulletin could be corporate propaganda.
Jon
My '98 OB does that routinely during cold weather and dissipates when the engine warms up.
Now if I could only get a dealer who would be willing to risk their tech to check up on my jackhammer jabbing sound from the engine (piston slap I think) when I hit speeds between 80mph and 96mph (96mph was the fastest I've went).
-Dave
Now I'm a faithful Costco customer and I'm also a shareholder but when buying a new car, price is my primary concern and any affiliation to Costco that I may have quickly is discarded.
Good luck!
--'rocco
Eric
You have a power train warranty for 60,000 miles on this vehicle, if you document your complaint at the beginning and they tell you it is normal then if anything goes wrong at a later date you are covered.
I really do not think it is propaganda, it is not in any companys best interest to ignore a glaring fault in its engines.
Cheers Pat.
Now I myself would settle for a Blitzen wagon, make it in that blue as well.
Cheers Pat.
mike k
Techs at where I service the car knows none of such. In fact, I do have the part# (somewhere) for the oil use at the factory.
-Dave
Is the Beanie worth it? In reality only you can determine that. To my dad, it wasn't. He got the OB Limited H4 and loves it.
I'd probably spring for the H6 for my wife, because it does transform it into a more luxurious cruiser. She loves the wood/leather steering wheel and two-tone leather, plus the other touches that make it feel upscale. You also get 3 years of free service and 7.9" of clearance, more than even the Forester.
-juice
I'll be curious to hear how the engine noise issue turns out. That is the same noise I tried to describe a week or so ago as "gritty".
Eric
If the rattle is related to the timing belt, it could be a simple matter of the belt "slapping" the cover that goes over the belt and pulleys. This would be easily diagnosed with a stethoscope or even just by placing your fingers on the cover and feeling for the slap. I always knew when the timing belt on any Chrysler 2.2/2.5 engine needed to be tightened, because the belt would slap the plastic cover in cold weather. Those were manual tensioners. It could be that the Subaru automatic hydraulic tensioner looses a bit of it's force when it gets cold. This is entirely realistic for a fluid based device like this.
Colin, since you have intimate knowledge of the timing belt and tensioner design, is there anywhere the belt could slap? Also, is there a way to adjust the hydraulic tensioner to give it more oomph when the temps drop?
Craig
I have changed the oil at 1,000 miles on every new car I have owned It may be considered overkill. but for me it is cheap peace of mind.
I like to think I am doing everything I can for a long troublefree life, ( for the car that is).
Cheers Pat. PS. I am doing everything I can also for a long troublefree life for me but is does not seem to be working.
As for the car, yes, prolong its life so you can enjoy it.
My '98 OB had its first oil change at... ~200miles? Well, 3000miles or 3 months and guess which came first? :-D
-Dave
KarenS
Owner's Clubs
Any differences in performance with the 5 speed? They seem to be hard to get a hold of as dealers in the NY area stock 95% auto.
Anyone know about the factory installed security system? Does it go off when a loud truck passes by?
Got quoted $24,900 (+ tax and DMV) for a 02 Limited with security system - fair? Can I do better? (Fleet manager said they have all of their models shipped with it installed - could it be just New York City area?)
My dad paid about $25k for his OB Ltd auto, so that's in the ball park. I don't think there are incentive programs going on right now.
-juice
Brian
But you are right enjoying life is the key, and I do enjoy life, so much in fact, that when my time does come I will be carried away kicking and screaming.
Cheers Pat.
I stopped by there today because I felt the dealer should pay me back for my out of pocket exepense (having to pay an independent tire dealer for what they should have done under warranty). I also wanted them to see the before/after sheet from the alignment machine showing how far the toe was off. The service writer said ' I never told you your car wasn't aligned properly, all I told you was that the tire wear you had was acceptable.' Then he followed that up by saying that I should not come there again for service if I am going to 'slam' them and question their judgement.
Imagine the audacity!
Bottom line is: Time to find a new dealer. I am hoping that the Subaru/Cadillac dealer will be a little more customer service oriented. As for Troncalli Subaru in Alpharetta, GA...They will never see another cent from me.
Sorry, got carried away venting again. I hope nobody else experiences such awful service from their dealer.
-r
Thx - Mike
