In Australia we refer to people who use their foglights when unnecessary by a special word - "plonker". It carries approximately the same connotation as the English suggestion that the driver wears his shirt tucked into his underpants. Definitely uncool and the sort of behaviour which inspires other road users to cast dreadful hexes upon you, generally of the variety that puts you backwards into a mudbank a mile down the road.
Cheers
Graham
-tom
snow covered ground more detail when driving through a snow storm at night.
If you have fog/aux lighting on, you should switch your fogs off when you are
approaching other cars on the road like you would switch off your high beams.
-mike
Also, anyone have any recommendations for accessories that they've added on to their OB?
thanks,
tom
Ross
Somehow I doubt that the BC Road Traffic Act has since been amended to allow fog lights at other times, although federal (and provincial?) law requires all cars from 1990 model year to have DRLs.
So I only use the fogs if I'm driving in fog or falling snow which happens about twice a year, and even then the so-called fog is pathetic compared with the pea-soupers wot I experienced many times in Britain. On those occasions the only safe mode of transport was walking because your really could only see about 10 feet. Crossing even a two lane road was bloody dangerous. You learn to use your ears. And it's quite frightening to get so totally and completely lost about a mile from the place you grew up and lived in for 23 years, that you just park and wait for a cop car or bus to come along and follow. There would be almost no other traffic under those conditions.
The low position and flat wide beam of a fog light is designed to prevent glareback and as someone pointed out can also be useful on dark, windy, narrow roads to "see round the corner". But of course the headlights stay on too (who's brilliant idea is this?) thus negating most of the benefit of the fog lights. So in my opinion building them into the car is simply a design fad to make the car look "butch" and turning them on is usually a waste of electricity and serves only to annoy others.
I'd guess that within a few years most cars will have the fog lights built right in to the headlight assembly and the macho "front covered in lights" trend will go away.
Nowadays there are so few cops around that I doubt that anyone would get a ticket for using fogs, same as they don't for having the (illegal in BC) blueish accessory driving lights or headlights. Not to mention the van I saw the other day with BRIGHT BLUE brake lights and turn signals at the rear!
Grahampeters: "Plonker" - I love it, it's been a long time since I heard that.
Craig
I installed the Subaru hitch on my '02 OBW as my dealer was willing to match Internet prices. But beware that you get the right one. Seems that the '00-'01 uses a slightly different kit from the '02, and I got to go thru it twice as I was originally given the wrong unit. The Subi kit is well done. It fits snug, has end caps to reduce tube rust, etc.
Some comments:
1) It took me 2-3 hrs as it takes some mental preparation to do the required cutting for the bolt passthru and the exhaust clearance region. The assembly is heavy, and working alone I had trouble with getting the alignment correct when feeding the bolts thru the frame to the welded-in nuts. In fact I did begin to cross-thread one and had to spend some time filing threads to fix the damage. My metric tap & die set didn't go up this far, so I had to do the cleanup with a thread file. Put a bit of light oil on the threads to help get them started more easily.
2) The tush end of the OBW is high, placing the center point of the receiver a good 15" off the ground. This is comparable to some pickups. The tong on the stock draw bar is too short to allow for flipping it over and using it in the 'step down' position, putting the base of the ball at close to 17". If you buy a landscappers type drop-down gate trailer as I did, you will need to buy a Reese 1.25x1.25" class-II bar to lower the ball height. Write back if you need me to find the P/N.
3) As stated, the interface module converts separate turn signals to American style 1157 taillamps found stock on most trailers. It also avoids ckt loading which could affect directional and hazard light flasher performance, as well as the 'bulb out' sensor system that would wonder why there was an extra few amp draw on the line. It is also an excellent safeguard to the car's electrical system as a whole, were you to back the trailer wiring into water on a boat ramp, puddle, etc.
What to do when putting this on a model without the required 10 amp feed? Do regular Legacy models have the rear power outlet? If so, pick up the power there.
Steve
-Frank P.
The OEM attaches to the body in 4 spots. Two are at the existing tow hold-down slots, and the hitch replaces these with two new tongs just slightly below those points. The other two are barrel shaped supports that extend up into holes in the frame rails, allowing a maybe 8" bolt to extend up to a pair of welded nuts on the upper side of the frame. The stock vehicle bumpers have a long underside skirt that covers these, so a 1.5" (?) hole saw must be used to cut thru the plastic to open the access spots. There are markers molded into the plastic for alignment of the pilot bit on the hole saw.
Step two: I like the OEM design because it really hugs the body and is much less visible. It goes 'up' over the exhaust, rather than down below it like the aftermarket. But here again you must cut two (?) squares of underside bumper plastic away to make the required clearance. A good 'snap blade' knife did the trick.
And finally, you have the lighting interface which is made to fit and already has the spare tire well grommet attached.
BTW: I found the drawbar info: Reese P/N 06280 - basically identical to Subaru P/N L1010FS030 but with a longer tab that allows for installation with a 0.75" rise or 1.25" drop.
Steve
I have installed driving lights (distance) on several cars, but put them on a relay to only work with the high beams. I never use them unless I am alone on the road. Why do so many people use them with low beams - insisting on their right to see, while blinding me in the process??
Steve
Patti
-Frank P.
The auxiliary driving lights, or as you called them "butch" lights are of course not illegal. I also agree that people who use them during the day and on clear nights, IMHO, need to get a life.
On the other hand, I would not recommend driving with the blue accessory front or rear lights. I know many tickets are written because the police feel quite possessive about being the only ones who are allowed, under the Motor Vehicle Act, to display blue lights.
Cheers,
Tom
Who wears underware??
Bob
The catch was that we'd save $100, and the price would go up in March, if we bought when paying for the car, instead of thinking about it. We realized that our previous sube OB sport went 120k miles with only routine maintenance. Forget the warranty. These cars go the distance.
Andy
-mike
The more I listened, the more the noise resembled ticking, rather than rattling, and it only happened during acceleration.
Had a good friend who is an engine expert come take a test drive. Also showed him the service bulletin that showed the use of mechanical valve lash adjusters. Verdict: valve lash adjusters noise. The gap was caused by metal contraction in cold weather. No big deal.
Thanks to those who provided their input!
-Frank P.
-Frank P.
rear axle boots
struts
engine seals
lights behind the dash
speakers
all in the post std. warranty period. If the AT tranny goes, you are looking at $3-$4K that alone is worth the $1K price of admission for the Subaru Gold Warranty.
-mike
Of course statistics mean nothing to lots of people. That's why millions buy lottery tickets every day.
-Frank P.
-mike
PS: There is no such thing as self insuring, at least not for me, I'm not going to take the $1000 and save it, it would go for mods!
James
In lines with the earlier statement on verifying that one receives the torx driver for the roof rack when the car is delivered, I am curious as to how many received the valet key. I did not, and am hoping this won't be an issue when I go back to the dealer requesting one. Has anyone had to buy one of these keys? Does anyone ever use these keys?
Colin
-Dave
If my headlights are on, generally my fogs are too... not necessarily to see, but to be seen better.
Cheers!
Paul
Ross
Bob
Steve
I have the Subaru acrylic deflector, and am very happy with it.
Steve
Having said that, I HAVE seen cars that weren't properly cared for that were faded/scratched etc as a result of using a vinyl bra. I like the acrylic deal for the hood because it can stay on all the time, but it leaves the bumper exposed and that's the surface that REALLY feels the brunt of the sanded roads here in the winter.
It's up to you they both have merits and weaknesses.
Brian
mike k
P.S Nascar is back Woo Hoo.
The best argument against a car bra I've seen was an old boss who broke a strap on the LeBra on his 911. He was doing 70 or so when it broke. The bra whipped around, snagged the drivers side mirror and broke it off. It then beat the living heck out of the car with the mirror before he could stop. Definitely an air freshener moment for him. Damage was quite extensive. The humiliation at work was worse.
I like the 3M Chip Guard. Had it on a truck around the wheel wells and after 5 years it was still tight and inconspicuous.
Historical Data: I bought it on my first 3 new cars ('79-'87) and lost money. I skipped it on the next two cars, and had expenses that would have put me ahead by a reasonable margin. Leased the next 3, so no longterm data. Now back to buying, and not sure what to do....
Steve
92 LS wagon - didn't get one, spent over $700 on the stupid pneumatic suspension system the LS had, may have been other things which would have been covered too but I can't think of any other big ticket items. Got rid of it after 6 years and 100K as I had a sense things were going to start happening.
92 L sedan, got an aftermarket warranty , however the oil seals went after that ran out at 75K .also needed two sensors - again out of even the extended warranty, some other stuff I would have loved to have gotten fixed too which I won't however splash out on like an inoperative power mirror on the passenger side
98GT wagon - got the Subaru gold with no deductible at 2/3 "MSRP" for 6 yrs/100K - have had a new radio antenna, front oil seal (they did the timing belt too - "damaged from being covered with oil" - more like they were too embarrased about having to take almost 3 days to do the seals that they charged SOA for the timing belt!!!), replaced HVAC lights (not really supposed to be covered apparently). So far saved almost $700+. I also have an A/C leak which will probably need fixing this season, they suspect a valve behind the dash is the culprit, several hours labor to get to it and a extended warranty covered item. I am going to make money on this warranty!
I also have a warranty on my wifes 00 Venture (which has stunned me by being absolutely faultless for 30K!) and 00 Windstar but then the Ford is a true piece of potential junk - we had a 95 which had the famous transmission and head gasket problems! If Ford hadn't bribed me with $4000 and a better trade than any half intelligent non Ford dealer would give you and 0.9% I wouldn't dream of getting another Windstar (and certainly not one without an extended warranty! -1800 for a rebuilt tranny and 1200 for the head gasket in the 95! plus there was the self ejecting spark plugs!)
Jim J.
-Frank P.
Jim J.
When I got my Subaru one in 98, I did so several months after I purchased the car and so it wasn't rolled into the financing but SOA at that time let you spread the payments by credit card over a year.
I came from a Honda family but my own experience with an Integra and my wifes experiences with a Civic and Accord have not been great, on par or a little worse than the Subarus - things rarely went bad before 60K on the Subarus, my Integra was a piece of junk after 30K, - though my wife claims it was the way I drive! The Civic must have been built on a Canadian holiday
Both makes are far better than the VW Scirocco and Audi Coupe and 4000 we have also had. I will never ever buy a VW/Audi product again.It wasn't just the problems which were many, it was their whole attitude and esp with the 4000 which we bought when we were overseas and brought back to the States. Their claim that US spec models sold to military /diplomatic customers overseas would be treated when back in the US like one sold in the US market was a farce. Yes, they always met their obligations in the end, after about a week or two of my dealer having to make dozens of calls to their HQ with the car sitting there unable to run. This was in the 80s , their product and service may be a lot better now but they lost this customer for good.
If the harness is there (it's there) If not, well...
go slow and good luck
this msg will self distruct...
steve-v
