Visitor Agreement.
My "Sweetpea" (winter-green) wagon will be 3 years old next March. My dealer sent me the "classic" Security advertisement. By March it will be 36 months for 550.00 with a 100.00 deductable. I don't know if I should take it or not. I have 25,000 miles on her now and no problems what-so-ever. should I do it or not?
any help will be appreciated
thanks cassieb
Craig
Now that I've got the alloy's off and cleaned, whats the best way to store them - flat stacked on top of each other? Standing upright just leaning against the wall? I suspect hanging them would be my first choice, but no where to do that.
Any recommendations welcome.
Larry
-mike
Good luck!
--K9Leader
Stock tires? How many miles on them?
Craig
I did, however, find the car to be unstoppable in deep snow -- conditions that would have left any FWD car on the side of the road were not a problem in the Subaru. With a lighter foot on the gas, the back stayed in line around corners and the car would make it through incredible amounts of snow without drama.
Brian
The M+S rating does not mean much. I hear they just take a *look* at the tread to award that. I've owned worn M+S tires that were absolutely lousy in snow, including the Potenzas I used to have on my Miata, it was scary.
There is a new rating that has a snow flake on the side wall, those are truly good tires in snow.
-juice
Also, at tirerack consider yourself lucky to be shopping for an OB - they only have 2 sizes left for the Forester. Sold out quick last year as well
I'm trying the WInterforce series on the OBW and the XT. They're getting some pretty good reviews on tirerack.
Larry
Craig
Regards, Owen (in slippery Calgary)
My '03 OBW w/ rear LSD sure feels more tail happy in the snow than my '96 OBW w/o rear LSD did.
DaveM
-juice
-juice
--K9Leader
One more question from a new Outback owner. We love our '03 Outback but it has one minor irritant that I'd like to correct. The turn signals cancel okay when making a fairly sharp right angle turn (city turn). When making any other turns (lane changes, freeway off ramps etc however, they never cancels. I've experimented with making these turns as sharp as I can but nothing works. Turn signals on other cars I drive usually cancel under these conditions but the Outback never does. I'd like to know if this is normal for this car or if there's something wrong that I can have the dealer fix.
Thanks, Jim
Craig
Try the lane-changing feature of the turn signals - where you just lightly press the lever up or down to activate the signals - without pressing it all the way past the detent [that you would use in a hard turn where you need both hands on the wheel]. Then simply release the lever when you're done changing lanes or exiting - at which point the turn signal stops. It might take a little practice - this feature varies a lot amongst car models. Seems to me the OB is in the middle of the pack - not too hard and not too touchy.
Cheers from Seattle!
Ken M.
J.
If not, your biggest risk is being stranded.
-juice
You may get lucky depending on how many miles you put on it, but you're taking a big chance if it's an interference engine (valves can hit pistons). As Juice says, that could entail a big bucks rebuild.
And even if it doesn't lunch your engine, do you really want to be stuck, possibly with baby #1, in the middle of nowhere, or the busiest intersection in town or in the fast lane on the freeway?
And ask yourself this: What will your wife think of you if this happens to her and it's all because YOU WERE TOO CHEAP! Is it worth that :-)
John
-juice
It is a 5 speed w/ 46k miles, has winter & security packages, speaker upgrade, new tires, and of course all of the standard equiptment. Reportedly, good running condition, the exterior has only a couple small scratches. Based on this, what would a good price here in central Indiana. The seller is a one owner, is anxious and motivated.
Also, is there anything that I should pay close or special attention to?
We bought new a '03 Legacy SE Wagon in June and are tickled pink with it. I saw this car advertised and I am seriously considering it, but I am not as knowledgable about it as my Legacy.
Any and all input would be greatly appreciated.
Thanks, Andy
Things to look for? Check the bottom of the block, at all the gaskets and seals, for oil leaks. If you see any oil stains I'd red flag it, even though it is still under powertrain warranty.
The other thing is the clutch - check for smooth engagement. If it chatters, or shakes, there is a TSB to fix it, but yours that's past the B2B warranty.
The good news is the most common problem with Subies are the wheel bearings, and the Legacy's design is not succeptible to failure, that only affects Foresters before 2003 and Imprezas before 2002.
Happy shopping.
-juice
My 00 OB was recalled for an ECU replacement.
I have an 02 Outback LL Bean now with about 33,000 miles. I absolutely love the car, and plan on keeping it for a long time. It's been trouble-free and is a great vehicle.
Craig
Closest I can come to helping out is my experience with an '86 Dodge Lancer I owned (new). Had a 2.2L OHC 4 cylinder ("non-interference" design as described above). Strangely, neither the owner's manual nor the expanded backyard mechanic's manual called for a timing belt (nylon/plastic) change at all! I even checked this out with a dealer, since I'd had cars needing the change previously. Long and short is it broke around 95K miles (subsequent Chrysler engines - such at the 2.5 L OHC 4 - called for changes at 60K).
As you'd expect - a "free" (auto club) tow to a local San Antonio repair shop, and around $150 to replace the belt. No engine damage - but, man, did that thing crank fast when I tried to restart it right after the belt broke!
Good luck!
Ken in Seattle
[knock on plastic wood - sorry]
Ralph
Clutch judder -is this similar to the initial sign of a clutch starting to slip, a little shake or vibration? The seller is driving an hour to meet me, so it won't be cold; would the clutch judder still be apparent? He said that he has not had any clutch problems; did some or most or nearly all of these '00 clutches have the problem?
What is the B2B warranty; what warranties, if any, would still be in place on a '00 w/46k on it?
What is an ECU replacement?
Thanks again!
I think the basic "B2B" warranty is for 3 years/36,000 miles, though it was less on the 2000 model years if I remember right. Either way, the car would b out of that warranty. What's left are the various other warranties -- I think powertrain goes to 5years/60,000miles, emissions is good to 85,000 miles (?? years) and there's probably also a rust warranty, but I don't know the details of that.
Somewhere along the line, there was a service bulletin on the ECU (engine control unit) for the 2000 models -- basically, they would swap your ECU with a reprogrammed one that had different algorithms, at no cost. No big deal, all it did was improve certain behavior of the engine. Personally, I didn't detect any differnce before/after. You can ask the owner if he had this done, but honestly, I don;t think it's a big deal.
There have been a couple other bulletins, one to get the rear suspension sub-frame re-painted (faulty undercoating on some cars) and the other was for auto-transmission models, so you don't need to worry about that.
Craig
You'll have the remainder of the 5/60 powertrain warranty on that used sample.
-juice
The warranty was 3yr/36K B2B; 5yr/60K Powertrain and Rustproofing.
Good Luck!
Mark
BTW - Kelly Blue Book gives a trade in value of ~$11200
As far as the clutch, it felt okay but not as good as my new '03 Legacy. When depressing the final 25% or so, it felt just a little funny. I did not sense any smell under the hood. The owner claims that there wasn't any problems with the clutch.
Under the hood, there were just a few minor concerns. One of the battery cable connections was heavily corroded and in extremely bad shape. There excessive corrosion around the brace also. There appeared to be some oil residue partially (uneven) around a boot extending to the right front wheel, which had been replaced due to hitting a curb. Other than that, everything looked okay.
There were 3 few minor grocery cart type dings on the exterior. The interior was cherry.
It appears it well maintained fairly well,eg: 30k mile maintenance at 33k; however, neither recall had been performed.
He agreed to pay to have the local Subaru dealer perform an inspection and have the 45k maintenance.
Overall, a pretty nice car, just not as pristine as my new Legacy. But then again, it's half the cost. I need to make the big decision today. It's going to be a tough decision because I will be somewhat over-extending myself before selling my truck if I get it.
Thanks so much for everyone's help!
-Andy
-juice
Funny, the battery hold down was replaced on my OB as well due to heavy corrosion. That was done a while ago, while still under original warranty.
If you go for it, enjoy it!
Mark
Provided the dealer "used car inspection" is acceptable, probably Tuesday or Wednesday, I will become an excited Outback owner next week.
As I mentioned in my previous post, we purchased a new '03 Legacy SE Wagon in June that we have been absolutely thrilled with. I am just as excited to get this '00 Outback now.
I really do appreciate everyone's help. Thank you!
-Andy
One of the Subiphiles will be along soon with the correct answer.
Bob
Jon
Anyway...we are discussing Potenzas and A-2s and he says that I should get a newer model. Gee...mine is only 18 months old...but he is saying that it is the best-time to get a nwer model before mine starts to lose value.
Is is crazy? Should I start looking? HELP and Thanks!
Jon
P.S. I'm running M1 10w30, OEM filter.
