-mike
I'm now in B/300, attached to the eData team. After more than 20 years as a programmer I'm finally an engineer (my degree is in EE). Test data is a foundry contract deliverable, just like wafers, and reviewing/straightening out the problems keeps me on my toes. I laughed about you getting an OBW at Hertz recently, but now I know to ask for it on my next trip to Burlington. My dept is primarily BTV based, and I need to go for a visit in the next few weeks.
On the home front... DH and I are planning our move to the Poconos. We'll be building just off I-84 about 10 miles west of Milford in a community called Hemlock Farms. Construction is expected to start in June. The commute will be longer but less curvy than the Taconic. I've done the trip several times already, so I know what I'm getting into.
We're now a 2 Subaru couple, picking up a 2001 Legacy L last December when the Neon bit the dust. Unfortunately we couldn't wait for the new 2005s, but so far Blue has performed well. Both cars will really come in handy as we shift all the stuff over to the new place. The Poconos are also Subaru country!
We're now officially empty-nesters. Our daughter was married last Saturday to a nice young man she met in Athens last summer while backpacking in Europe. He's here in the US on a 90 day fiance visa, so the wedding (really an elopement plus) needed to be performed by early April for him to legally remain here. This weekend will be spent moving them down to Philadelphia. I've been drafted to drive the rental truck, while my daughter follows with SueBee. Pray for nice weather for the move!
Lyn
I replaced the OEM Firestone Wilderness on my '01 Outback Ltd at 45,000 miles with the Turanza LS-H. There was a nice 2-3 inch snow storm in NH last night and got to try them out. They are great! I also drive 120 miles/ day all highway and they are also a lot quieter. The combination of the recommendations from Tirerack.com and Consumer Reports clinched my choice.
Great on the highway! Highly Recommended.
-juice
Note on Hertz - the OB is not a C-class, and will cost you more if you reserve it. The accounting [non-permissible content removed]'s will beat you up big time. But if they are not busy, adding a little begging, nice smile, etc., at the counter will probably secure it at the approved rate.
Did you know that SteveK works in B/330, so there are now 4 of us?
Steve
I plan to get an Oil Change at 9000 mi is there any tips re: other maintainance I should do to maximize the Car
I want to drive it till she won't go no more.
SueBee will pass 43K tomorrow on the trip to Philadelphia. Blue (2001 Legacy L) has just over 36K, so once the weather becomes more Spring-like it'll be time to give her a vacation and let Blue catch up a little.
No, I didn't know about SteveK -- maybe we should have a lunchtime meeting in the B/330 cafeteria...
Lyn
I own an 03 Legacy SE Wagon. This is my first car with a moonroof and last summer, I found I used it very seldom as the air noise with the moonroof open was too annoying.
With summer approaching, I am thinking about using it again and was considering having a moonroof air deflector installed.
I'm curious if others who have these would recommend them. Do they help to cut down on the noise that comes with opening up the moonroof?
Is there any impact on the gas mileage with having one?
Thanks in advance to those who post. David
You did remove the rack crossbars, correct? They make the most noise.
I find that I can get up to about 50 mph on my Outback with the moonroof open (front popped up and back panel opened 2/3) before it gets too noisy.
With a deflector, my wife's Forester gets up to about 65mph before becoming too noisy.
Craig
I have the dual moonroofs on my Outback Ltd so I don't think it would much.
-Brian
As for coverage (with the '00 OEM version), the hood area above the headlights is covered by about 3" or so of deflector. Then as you get toward the middle of the deflector, coverage area increases to about 5" or 6", with a lip at the upper edge.
You might also try posting over in the Subaru Crew threads here as well.
-Brian
-mike
- Cargo bin- I purchased the cargo net (that I have yet to install) and think the bin might be a better solution. I have things sliding around my trunk all the time
- Bike Rack. I found a good deal on one at Allsubaru.com but wondering if I should consider a different brand?
-mike
I have a set of Thule racks for the wagon. I leave the cross bars on most of the time. The ski and bike racks are on/off in 2 minutes. Thule has a set of angle holders with tie downs which are neat. Rob M.
I added the hitch kit for both pulling a light duty trailer and for a bike rack. I am too old for hefting bikes on and off of the roof!! ;-)
Steve
Greg
Any thoughts?
Matt
I have BR 950 tires on my Infiniti G20 (195x60-14), and they seem perfect for that car, which one can fling around quite nicely. Wear is, however, quite noticeable early on. More than the previous Muichelin MXV4 set. That's why they flog that UT tread stuff, I think, in the ads. A little noiser than some options, too.
You didn't say what model year or tire size, so I am assuming that you need the later model 225x60-16 fit? If so, you have limited options, so the 950 series would seem a good choice.
If you have an older model like my 1998 and can use the 205x70-15 fit, think seriously about the Michelin "X" tire at Costco not at TireRack -- although the "Symmetry" may be similar. We have 2 Costco sets on 2 Soobs -- they have been wonderful. Super in the wet, great ride and great mileage -- better than you will get from those 950 "performance all season" shoes.
I thought Subaru made a mistake when they moved models to the 225x60 profile. Typically these are only available as "high performance" tires, raising the cost. I don't know many people who would race or toss an Outback around that much. Good all-seasons should be sufficient.
I have an '02 Bean - so the 225/60-16's are my size.
I agree about the not needing "performance tires" on the Subaru in general, and it would be nice not to be required to use that speed rating - or higher (per CostCo policy).
We just put the Michelin X's on my wife's Civic, and I had to have a little conversation with the service manager to "let" me do this. My argument - a valid one I think - is that you can put an X on a minivan, but not a Honda Civic???? They agreed and put them on for us.
Matt
"Tires will only be installed if the speed rating is the same or higher than the speed rating that the vehicle manufacturer equipped the vehicle with from the factory."
The Civic EX came with H-rated tires, so the S-rated "X" would not be be allowed. My wife never goes over 75, so I am not really concerned with the speed rating. I do believe that the higher speed rated-tires do have better construction and heat resistance that can benefit even "slow" drivers, but I think setting that minimum threshold at more than 50MPH over the max legal speed limit is a bit too much. Especially when other family cars are allowed to use these so-called "unsafe" tires all the time.
"When replacing speed-rated tires, you must use replacement tires with ratings equal to or greater than those of the original equipment tires, if the speed capability of the vehicle is to be maintained."
So...My wife ONLY has a 118 MPH Civic now and no longer a 130 MPH Civic. Hope she doesn't get too mad at me!!! :-)
Has anyone heard of premature failures with the 2.5 2000 Outback engine timing belt or do you think this is just a money maker for the Dealer?
Cheers, Tom
Craig
-Brian
-mike
-Brian
They have not previously looked at the belt, this is just a standard procedure for this dealership which is the only one within a hundred miles. I do realize that what gets done is my decision and not their's. I was just wondering if there was perhaps a problem with this model which would justify the early replacement of the timing belt.
Otherwise, I will not have it done until later in the service schedule.
Thanks, Tom
Anyway anyone have any info on the Patchogue dealer as far as service goes? Also they offer the Gold Plus Added Security Ext. warranty for $1700.00 Is this the usual price? Is it worth it?
BTW I've been a Ford owner for may years. This is my first none Ford car although I've had good luck with the fords and have been reliable (my sister got my '95 and had over 200k on it), I wanted a change and an AWD. So far I love the car.
Joe
I don't have any experience with the Patchogue dealer, but I can certainly recommend Metric Subaru in Huntington, NY.
Oh ya, Congratulations!
-Dave
The decision on the Gold plan is hotly debated on these boards, but personally, I did get one. But don't feel rushed. You can get one from any dealer in the country, via the internet, up to the 3yr/36k point. It is available in various time/mileage units, so first analyze your driving & ownership style. I went 6yr/85k w/$0 deductable for around $700 last year. I would think you should be able to find 7yr/100k/$0 for around $1100-1200, if you are willing to work a bit.
Steve
Congrats on a nice choice!
Mark
Joe
Greg
Larry
But...after seeing my dad's repair bills on a '92 Taurus, no thanks. Prolly coulda bought a new car by now.
-juice
Thanks, Jim
Hope this helps.
Also, a more technical concern is the 2.5 engine. Have they straightened out their engine issues (ie., gaskets and pistons) with the 04's?
There is a $1500 dealer incentive, so they're giving it to you for $400 under invoice. They'll make no profit, but 5k miles means it's basically used.
I'd pay $400 more and buy new, no doubt.
-juice
Craig
