However, since I'm buying as "new" and not used I qualify for the special financing rate and incentives. Still, probably can do better if I just tell them I want to buy used and get a used car price.
Would love to hear your opinions, experiences and advice.
I have owned both a 2000 manual 4 cylinder outback and I currently own an automatic 6 cylinder Outback. I haven't done any towing with either cars, so I can't comment on that.
But I can say the H6 is much much quieter than the H4, especially at highway speeds. The H4 runs at around 3500 rpm and the H6 runs at around 2500 rpm at highway speeds. Also the H6 has approx. 40 more horsepower.
All in all, the H6 is much more enjoyable to drive. Especially on long trips.
I'd vote for the H6 with auto tranny. The extra torque and horsepower will be very useful towing in a mountain environment, and most folks seem to have better luck towing with an auto - rather than trying to finesse the clutch with the extra load.
Having said that, I have a 2K H4 with a 5-speed that I've been very pleased with in terms of performance and economy - but I don't tow with the car. But hey, as cheap as gas is in California, why would you care about lower mileage and the requirement (recommendation) for premium fuel in the H6?!
Cheers from Seattle!
Ken M.
But yeah, I'd still pick the H6, it's over-engineered for a job like that.
-juice
So I'd say H4-auto or H6-auto. Personally, I agree that the H6 would be better for all the reasons mentioned above.
Craig
Steve
Mark
Then again, I still have the original clutch at 60k miles.
-juice
The contour may have them in a difficult place to reach and therefor have a longer change interval. My Trooper has 100K plugs but I changed them out at 70K anyway.
-mike
Greg
-juice
Cheers from Seattle...opening day - Go Mariners!
Ken M.
-juice
I actually bought new plugs at 60k miles but never got around to installing them.
Plan to replace the original Champions? with NGK coppers when my '03 OBW hits 30,000 miles.
DaveM
-juice
Yep - OD is outer diameter. I recall that the access sleeve down to the plug was a pretty tight fit for the 5/8" (official size) socket - and that it had an OD of 7/8".
Have fun - run that washer fluid reservoir down near empty if possible.
Ken in Seattle
-mike
Link is on the left.
Can you replicate the problem on demand, every time? If so I'd ask the service writer to take a quick ride with you to demonstrate that there is indeed a problem.
-juice
Every time you encounter a problem, document the problem (feel free to do the sorts of things that bring on the problem), take it to the dealer, get a copy of the work order, and note what (if anything) was done. After doing this three times (typically), you're able to invoke a lemon-law dealer buy-back to replace the [presumably] defective vehicle.
Don't waste any time doing this - there are usually strict time and mileage limits (you'll likely have to "pay" for the miles you put on the car - in the form of a reduced buy-back payment).
Good luck!
Ken in (incredibly warm and sunny) Seattle
I believe it's applicable if the problem adversely affect the driveability, safety, and/or re-sale of the vehicle.
Take Juice's advice.
-Dave
-Brian
-mike
-Brian
-mike
Just curious!
Signed,
...still longing for a 6 speed V6 VDC Wagon...
They also introduced more monotone colors and some with black (unpainted) bumper and side skirts.
DaveM
-mike
Typical last model year changes, i.e. small stuff.
-juice
-mike
Greg
-juice
Bob
DaveM
Model in Canada is called Outback Premium, and has quite a lot of extra goodie for $500 over base.
6-cd in-dash changer, 9 speakers, twin moon roofs, body coloured mirrors and door handles, leather wrapped wheel and shift knob, and 5 spoke wheels, (appear to be the same ones that are on the anniversary edition.
Specs appear to be same as the Limited, but without the leather seats, and available as MT or AT.
So I hope that the "new" H6 provides:
- more low down power, a noticeable butt dyno difference from the revised motor with 250hp/220 ft/lbs, and reduced weight.
- a real ability to feel more involved via the 5 speed clutchless Sportshift, hope this is something useable rather than a neat marketing feature.
- generally hope it's fun to drive.
Why am I even considering an 05 OB H6?
Over MT turbos - much better mpg, long term reliability (?), relaxed lower rpm cruising, long term license preservation...
Over Forester - enhanced safety, towing ability, rear legroom, handling (?), bigger trunk (dog crate + kid stuff + camping stuff), better interior, better paint (I hope), maybe better resale.
Over Legacy - ground clearance and approach/departure angles
JP
Audi offers an automatic "manual" transmission with auto-clutching and gear shifting. It's very intelligent, and can even blip the throttle during upshifts and downshifts. Picture it as a manual transmission that can shift faster and smoother than any human. When you engage the driver controlled shifting mode on that, it does respond like a real manual (except you don't have to worry about the clutch pedal). That is something I could live with!
I will say this about Subaru's current auto transmissions -- you have to get accustomed to their behavior. Driven normally, my Outback H6 is very leisurely and shifts like a turtle. If you get agressive on the throttle from a dead stop (which invokes the transmission's "power mode"), the car is downright snappy off the line, and the shifts are more abrupt. Some cars have a button on the shifter to engage the power mode, but Subaru does it based on throttle action.
Craig
Still, worthwhile, I'd gladly pay the extra $200 or so it costs over a regular automatic.
-juice
So far it has almost 6K track miles on it and no problems at all.
-mike
Had to nip over to Missoula, Montana last week and took the Legacy. It's no longer an unlimited speed limit in MT, but I couldn't resist the urge to see what the '97 Legacy's top speed was with my bike rack up there. Deserted freeway, 4 mile visibility, fresh Michelins, etc. So I floored it for over a mile and got it to an indicated 107. A while later, I was on a downhill with similar conditions and floored it. What's this? The car has a fuel cutoff at 110 MPH! Interesting. It also shut off the cruise control master switch. To be sure, I duplicated the test.
IdahoDoug
-juice
Alland
At any rate, I notice when filling the gas tank (let's say from Empty), that it takes around 30 -45 seconds or so for the gauge to read "Full".
Is that normal? Does something in the tank need adjustment?
Thanks for any info.
Best regards,
Alan
Join the discussions in the Subaru Crew threads and the chat tomorrow night.
-Brian
