Visitor Agreement.
Drew
The maps are OK in urban areas but get inacurate in more rural areas. I looked at all the factory fitted gps systems in BMW, Audi and Mercedes and the Acura was the best. This is research I did 10 months ago.
Not sure where one would put the screen with the McIntosh in there?
-mike
Now I find myself in a Mitsubishi? Mirage. Not impressed (cars a couple of years old and the front bumper paint is already fading). Can't wait to get the VDC back so I can get my 96OB back.
I'll let you know how it goes.
Also whenever the check engine light would come on the VDC OFF light would pop on as well. After a few days the VDC OFF would vanish and then a few more days the check engine would go away as well.
It's not very special since other factory installed navigation systems also have this feature. It is even possible for the aftermarket Alpine systems (Acura's is an Alpine, BTW) to have this capability.
Hope this helps!
Drew
Much thanks,
Colin
Its more of an appearance issue I think (does look nice). Course it might get in the way with a strap on bike rack.
bit
I also debated the rear gate bar. Here's a 1999 post that might help you decide
<< . Some think the gate bar makes your Scooby look like a big barbeque grill. I wanted to get one but as it's my wife's GT, we didn't.
A downside is that someone might use the rear gate bar as a step when loading a roof rack or washing the roof, perhaps bending sheet metal.
..Mike in MD . 00 GT wagon
..Mike
bit - 2001 GT Wagon
Need to get pics in here to show you the bar and hood deflector on my Winestone OB. It compliments Bit's great looking shots of the white GT.
Greg
Did anybody experiment with tires with the LL Bean? Or Do you have to change rims?
Does BFG make any all terrain tires for the LL Bean?
-mike
Benje: luckily, the Outback has the multilink rear suspension, so there is more room for tire than in the older strut models (99 Outback, Forester, Impreza).
So there appears to be room in the rear wheel well. It's the front I'd be concerned with. Turn your tires and see how close they get to the fender wells. You can probably go to a 235/60 or 225/65, but not much more than that.
Also, change all four tires, of course, and remember, your spare will no longer be the same size, so carry a patch kit and an air compressor.
I plus sized my Forester, but had to get wheels with an offset that put the tires further out.
-juice
Jack from Cape Cod
Greg
I would like to find out when SOA will call back from the message I left weeks ago. Has you group forgotten about me? Just so you can find it the case number is 285529, opened in April. Thanks
Keith
If you left a message with SoA weeks ago, someone dropped the ball somewhere along the line -- they don't take that long to respond.
Patti won't be back until Monday (mentioned elsewhere). Call 1-800-SUBARU3 (1-800-782-2783), give the case number, tell the CSR (customer service rep) that SoA didn't return your call, and note the CSR's name in your problem log. I've found that you have to update the case via the 800 number to keep things moving; it's how the SoA customer service process works (not uncommon in large organizations). After speaking to the first CSR, if you're not satisfied, politely explain that and ask for a supervisor.
SoA is open Mo-Th 08:30-17:00 Fr 10:30-17:00 ET (last I checked).
HTH.
..Mike
..Mike
Cheers
Pat in Mtns of NC
I'm sure there is some room, but not much. The rear suspension doesn't have the spring base in the way. Though the wheel wells aren't that big, and keep in mind the Outback already has far bigger tires than the Legacy GT or L.
Call Tire Rack or Discount Tire Direct, and see what sizes they'd be willing to sell you. In my case, I got wheels with a different offset to plus size my Forester's tires.
Remember a couple of things - your spare will no longer match, so carry a patch kit and an air compressor. Also, you'll lose gearing (6.7%) and may find acceleration a bit sluggish. It's already geared 7% taller than the GTs are.
I would guess 225/70s would rub the front wheel well when you turn the wheels and hit a bump. 225/65s would probably fit (no guarantee, just a hunch).
-juice
-mike
Greg
-mike
Ed
On that last one I was a bit shocked to find he had no rubbing.
-juice
...at 6-7pm Pacific/9-10 pm Eastern. Hope to see you there!
http://www.edmunds.com/chat/subaruchat.html
I am interested in getting some heavy duty floor mats, and I am wondering how the Subaru mats have worked for others?
For those who have it...
Does the mat generate static electricity? I remember buying a mat and getting shocked everytime I stepped out of the car.
How durable is the mat? Does it capture fluids well? Does it have provisions to anchor the mat to the floor?
Useless, IMO. Buy aftermarket and then trim to fit with an exacto knife.
-juice
..Mike
..Mike
Jon
Though I haven't seen the Subaru mats in person, I plan on picking up a set of WeatherTech mats shortly after getting a new Bean at the end of the month. I will be able to offer first hand advice on the WeatherTechs made for the Outback then.
The reason I offer them up as a suggestion, I've had a set in my escort since 93' and love them. Had the car in MI at the time and they were large enough and deep enough to take anything I could throw at them. I dropped a full can of pop on the floor on the front driver side and not a drop hit the carpet. I did have to trim the mats for the back seat, but it was a piece of cake and they look and fit great.
Good luck,
Colin from So.Cal.
The front mats fit without trimming; I had to trim the rear mats somewhat with a utility knife, but the fit is almost perfect.
Good luck,
Ed
Greg
Quickly my needs:
1- Driving year-round in adverse conditions in MD, DC, VA, WV, & PA (both rain & snow).
2- Interior room (I am 6'4") and trunk room for salesman's inventory.
3- A vehicle that is reliable to handle 50K a year for 4-5 years. I typically trash my cars after 5 years and/or 300,000 miles.
4- Better mileage than the current brand of SUV's on the market.
5- A safe vehicle (this one I can personally attest to.)
When I re-analyzed these needs I still came up with the VDC AGAIN!!! So I have the identical car a second time around.
What I have noticed after 24,000 miles:
- Premium gas does make a difference in gas mileage and pickup, especially in the mountains.
- The A/T will eventually learn your driving habits, although I do a lot of manual shifting with the A/T anyway. This has worked great for me and gives me amazing acceleration especially when I need to pass on the highway.
- Never had brake squeal, ECM problems, poorly machined wheels, or broken timing chains on either car (knock on wood or is it PLood).
- The VDC works great behind the scenes, especially in the rain. I can't see a need for a cutoff switch because I want it on all the time!
- The seats are great for 500+ mile days. I don't feel beat up after these days either.
- The McIntosh stereo is flat out AWESOMMMME!
The fact that after 20,000 miles I bought another VDC says everything. This car is fun to drive and I wouldn't trade it for anything on the road. Period.
Chuck in Maryland
bit - 2001 GT Wagon
Was the truck going at 50mph on impact or had it slowed down a little bit? Wet road? Did the side airbag deploy? Did it make a difference? On the impact did it engage the B-Pillar? The A Pillar? I've always worried about trucks overiding the side impact beam, I guess that wasn't the case here.
What you went through is my worst vehical nightmare, someone in an SUV runs a light and smashes me in the side. One of the reasons I went for the Outback was because I hoped that the extra ground clearence would give me a better chance in just such a wreck.
Safety is a great salesman.
-juice
Greg
Hah. I would have to pay a pretty high premium for that.
bit
Jon
-mike
We have an initiative at SOA called the Subaru Difference. The focus is on trying to improve dealer relations with retail customers. Al, I'll share your thoughts with the VP responsible for this initiative. Personally, I like it.
The hardest situations for us to get involved with are the retail transactions. However, we do reports on dealers with poor responsiveness to customer's (that covers a gamut of things) and it will impact the dealership.
It seems so simple - treat your customer's right and it's pure good business. I don't know why it is such a struggle with some dealers.
I don't want to add to your agg., so I won't get you directly involved, but I also will not ignore what transpired for you. If you want to go to another dealer, let me know first. I can talk to them and explain what you've been through and try to get you treated with the respect you deserve.
Patti
Patti
I will drop a message here when I am up going for my first service.
All the best,
Gary
Usage would be to tow a small boat and a Sunfish; add one of those bike racks that attach to a tow bar (it is impossible to get a roof rack for my particular bike without swapping out the factory bars, which I have no desire to do).
I am looking for some general guidance. Are there different kinds? How much typically? Is it better to use the dealership?
TIA,
Gary
I have the hitch, and installed it myself. It's not hard if you are handy and have tools. I was around $220 or so for the parts, which includes a harness and instructions. The OE hitch has a custom fit and tucks in nicely under the bumper, plus it attaches with 7 bolts. Here are a series of photos.
I've seen aftermarket hitches from DrawTite and Hidden Hitch, and both were fine. Not quite as neatly tucked in as the OE hitch, and neither used 7 bolts, but they seemed to work for their owners and cost less (under $200), even installed. Given the modest limits of 200 lbs tongue weight and 2000 lbs towing, they should do fine.
I also have the bike rack, the type that slides into the receiver hitch. It holds two bikes, though I've strapped a 3rd bike on once and it was fine. One of the photos in that series shows the rack with 2 bikes on it - they do not touch the vehicle, which is nice. It's SUPER easy to load, far easier than using the roof, plus the roof is free for other gear.
A hitch is quite handy. I've pulled a 5'x8' trailer with 3 yards of wood chips. It saves me about $40 per load vs. having it delivered, and I hauled two loads already. On other trips I picked up all the gear for a sand box, some lumber, and some more mulch.
That plus I've hauled the bikes about a dozen times. The bike rack costs extra, though. My supplier is out of commission right now (financial problems), so I'd try subaruparts.com for prices.
-juice
Now as to GAP insurance. The is insurance that pays the difference between what your auto insurance company will pay when the car is totaled and what you owe the lienholder. It is not just for leases. Obviously with the miles I put on a car, I can't lease. But as soon as I drive a new car off the lot, the value of the car decreases by 20%. This is the difference I want protected by GAP insurance. I have had GAP on my last 4 vehicles. This is the first time I have ever collected on GAP and rest assured I will add it again to all my liens.
I think the vehicle did one hell of of a job protecting my a..! That's just one of the reasons why I bought another one. Again I hope this post proves helpful to someone on the fence concerning the VDC, or provides assurance to other owners.
Chuck in Maryland
